楼主 # 2024-07-24 15:40:30
gaoda
已发帖子: 44
【求助】STM32H750外置下载算法
请问有哪位大佬有H750XB基于openocd的w25q256下载算法?我现在用clion+openocd环境,下载算法怎么写都报错,用反客群友的w25q64模板修改,总是出错
#1 2024-07-24 22:50:59
flex-A
已发帖子: 51
Re: 【求助】STM32H750外置下载算法
楼主 #2 2024-07-25 08:53:45
gaoda
已发帖子: 44
我的是w25q256的flash,模板用64改,也不行
#3 2024-07-26 11:24:56
leifeng
比较一下w25q64和w25q256的区别
#4 2024-07-27 21:37:48
表慌张
自己改改
source [find interface/stlink.cfg]
set CHIPNAME stm32h750vbt6
# enable stmqspi
if {![info exists QUADSPI]} {
    set QUADSPI 1
source [find target/stm32h7x.cfg]
# QUADSPI initialization
proc qspi_init {  } {
    global a
    mmw 0x580244E0 0x000007FF 0             ;# RCC_AHB4ENR |= GPIOAEN-GPIOKEN (enable clocks)
    mmw 0x580244D4 0x00004000 0             ;# RCC_AHB3ENR |= QSPIEN (enable clock)
    sleep 1                                 ;# Wait for clock startup
    # PB06:AF10:H, PB02:AF09:H, PD13:AF09:H, PD12:AF09:H, PD11:AF09:H, PE02:AF09:H
    # Port B: PB06:AF10:H, PB02:AF09:H
    mmw 0x58020400 0x00002020 0x00001010    ;# MODER
    mmw 0x58020408 0x00002020 0x00001010    ;# OSPEEDR
    mmw 0x5802040C 0x00000000 0x00003030    ;# PUPDR
    mmw 0x58020420 0x0A000900 0x05000600    ;# AFRL
    # Port D: PD13:AF09:H, PD12:AF09:H, PD11:AF09:H
    mmw 0x58020C00 0x0A800000 0x05400000    ;# MODER
    mmw 0x58020C08 0x0A800000 0x05400000    ;# OSPEEDR
    mmw 0x58020C0C 0x00000000 0x0FC00000    ;# PUPDR
    mmw 0x58020C24 0x00999000 0x00666000    ;# AFRH
    # Port E: PE02:AF09:H
    mmw 0x58021000 0x00000020 0x00000010    ;# MODER
    mmw 0x58021008 0x00000020 0x00000010    ;# OSPEEDR
    mmw 0x5802100C 0x00000000 0x00000030    ;# PUPDR
    mmw 0x58021020 0x00000900 0x00000600    ;# AFRL
    # correct FSIZE is 0x16, however, this causes trouble when
    # reading the last bytes at end of bank in *memory mapped* mode
    # for single flash mode w25q64jv
                                            ;# 010101010000000000000 0 011000
    mww 0x52005000 0x05500018               ;# QUADSPI_CR: PRESCALER=5, APMS=1, FTHRES=1, FSEL=0, DFM=0, SSHIFT=1, TCEN=1
    mww 0x52005004 0x00160500               ;# QUADSPI_DCR: FSIZE=0x16, CSHT=0x05, CKMODE=0
                                            ;# FSIZE flash的大小。
    mww 0x52005030 0x00001000               ;# QUADSPI_LPTR: deactivate CS after 4096 clocks when FIFO is full
                                            ;# 11010000000000 10 010100000011
    mww 0x52005014 0x0D002503               ;# QUADSPI_CCR: FMODE=0x3, DMODE=0x1, DCYC=0x0, ADSIZE=0x2, ADMODE=0x1, IMODE=0x1
    mmw 0x52005000 0x00000001 0             ;# QUADSPI_CR: EN=1
    # Exit QPI mode
    #mmw 0x52005000 0x00000002 0            ;# QUADSPI_CR: ABORT=1
    #mww 0x52005014 0x000003F5              ;# QUADSPI_CCR: FMODE=0x0, DMODE=0x0, DCYC=0x0, ADSIZE=0x0, ADMODE=0x0, IMODE=0x3, INSTR=Exit QPI
    sleep 1
    # reset flash
    mww 0x52005014 0x00000166               ;# QUADSPI_CCR: FMODE=0x0, DMODE=0x0, DCYC=0x0, ADSIZE=0x0, ADMODE=0x0, IMODE=0x1, INSTR=0x66
    mww 0x52005014 0x00000199               ;# QUADSPI_CCR: FMODE=0x0, DMODE=0x0, DCYC=0x0, ADSIZE=0x0, ADMODE=0x0, IMODE=0x1, INSTR=0x99
    # memory-mapped read mode with 3-byte addresses
                                            ;# 11 11 0 00100 00 11 10 11 01 11101011
    mww 0x52005014 0x0F10EDEB               ;# QUADSPI_CCR: FMODE=0x3, DMODE=0x3, DCYC=0x4, ADSIZE=0x2, ADMODE=0x3, IMODE=0x1, INSTR=READ
    ;mww 0x52005014 0x0D002503
$_CHIPNAME.cpu0 configure -event reset-init {
    global QUADSPI
    mmw 0x52002000 0x00000004 0x0000000B    ;# FLASH_ACR: 4 WS for 192 MHZ HCLK
    mmw 0x58024400 0x00000001 0x00000018    ;# RCC_CR: HSIDIV=1, HSI on
    mmw 0x58024410 0x10000000 0xEE000007    ;# RCC_CFGR: MCO2=system, MCO2PRE=8, HSI as system clock
    mww 0x58024418 0x00000040               ;# RCC_D1CFGR: D1CPRE=1, D1PPRE=2, HPRE=1
    mww 0x5802441C 0x00000440               ;# RCC_D2CFGR: D2PPRE2=2, D2PPRE1=2
    mww 0x58024420 0x00000040               ;# RCC_D3CFGR: D3PPRE=2
    mww 0x58024428 0x00000040               ;# RCC_PPLCKSELR: DIVM3=0, DIVM2=0, DIVM1=4, PLLSRC=HSI
    mmw 0x5802442C 0x0001000C 0x00000002    ;# RCC_PLLCFGR: PLL1RGE=8MHz to 16MHz, PLL1VCOSEL=wide
    mww 0x58024430 0x01070217               ;# RCC_PLL1DIVR: 192 MHz: DIVR1=2, DIVQ=8, DIVP1=2, DIVN1=24
    mmw 0x58024400 0x01000000 0             ;# RCC_CR: PLL1ON=1
    sleep 1
    mmw 0x58024410 0x00000003 0             ;# RCC_CFGR: PLL1 as system clock
    sleep 1
    adapter speed 4000
    if { $QUADSPI } {
        qspi_init
楼主 #5 2024-07-27 21:49:47
gaoda
已发帖子: 44
试了w25q64,修改了引脚,烧录一次成功后,后面就烧录不了了,用测试qspi程序能读写flash,就是烧录不了,不知道为什么。下面是openocd的烧录信息:
Info : The selected transport took over low-level target control. The results mi
ght differ compared to plain JTAG/SWD
Info : clock speed 1800 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : STLINK V2J43S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.214708
Info : [stm32h750xbh6.cpu0] Cortex-M7 r1p1 processor detected
Info : [stm32h750xbh6.cpu0] target has 8 breakpoints, 4 watchpoints
Info : gdb port disabled
[stm32h750xbh6.cpu0] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x080015d4 msp: 0x24080000
Info : Unable to match requested speed 24000 kHz, using 4000 kHz
Programming Started
Info : Device: STM32H74x/75x
Info : flash size probed value 128k
Info : STM32H7 flash has a single bank
Info : Bank (0) size is 128 kb, base address is 0x08000000
Info : No id from flash1
Info : No id - set flash parameters manually
Error: Bank is invalid
embedded:startup.tcl:1467: Error: Programming Failed
in procedure 'program'
in procedure 'program_error' called at file "embedded:startup.tcl", line 1532
at file "embedded:startup.tcl", line 1467
楼主 #6 2024-07-27 22:14:42
gaoda
已发帖子: 44
@表慌张
现在我用的w25q64,使用您这个.cfg,我改成我板子的引脚,也报错,qspi flash可以确定是没有硬件问题的
libusb1 09e75e98b4d9ea7909e8837b7a3f00dda4589dc3
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override u
se 'transport select <transport>'.
Info : Target voltage: 3.211024
Info : [stm32h750vbt6.cpu0] Cortex-M7 r1p1 processor detected
Info : [stm32h750vbt6.cpu0] target has 8 breakpoints, 4 watchpoints
[stm32h750vbt6.cpu0] halted due to debug-request, current mode: Thread
Programming Started
#7 2024-07-28 17:05:52
表慌张
要对照你的程序改cfg里的时钟,qspi等相关的配置
#8 2024-08-01 17:12:35
bigniudiy
第一次成功,后面不成功,我好像在哪看到过,说是flash的烧写寄存器值被修改了,被改成不能烧录了,需要重新把寄存器的值重置后,才可以
楼主 #9 2024-08-01 17:43:24
gaoda
已发帖子: 44
是哪个寄存器?
#10 2024-08-01 21:05:47
刘德权
gaoda wrote:
是哪个寄存器?
有可能是状态寄存器里的QE位被使能了,就是第一次烧录之后,那个下载算法,顺手把QE位使能了,而且是掉电不丢失的那个位。导致下一次上电,flash默认就是按照QSPI模式工作。但是下载算法本身可能还是遵循SPI模式在下载。
楼主 #11 2024-08-04 08:02:42
gaoda
已发帖子: 44
不知道这是什么原因
