楼主 # 2023-08-30 10:30:40
jkl
已发帖子: 271
100s tina nor启动,怎么新增支持一个32M的norflash?
目前16M的配置没有问题,就在ids表格中新增芯片配置就可以了,但是32M的不行,会出现不识别,请问下,有人刚才支持过32M norflash吗?有弄过的帮忙指点一下,非常感谢!!!
sunxi dma exit
[0]HELLO! BOOT0 is starting!
[2]boot0 commit : f847d4e4b27dd960a09d765e9ffc91791bab2ced
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.65 (jkangli@server-211) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #841 Wed Aug 30 02:10:22 UTC 2023
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] Machine: Allwinner A1X (Device Tree), model: sun3iw1p1
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: CMA: reserved 8 MiB at 81800000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 8192
[ 0.000000] free_area_init_node: node 0, pgdat c05528ec, node_mem_map c057f000
[ 0.000000] Normal zone: 64 pages used for memmap
[ 0.000000] Normal zone: 8192 pages, LIFO batch:0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: enforcing=1 earlyprintk=sunxi-uart,0x01c25400 initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mtdblock4 init=/pseudo_init rdinit=/rdinit partitions=boot@mtdblock1:bootlogo@mtdblock2:env@mtdblock3:rootfs@mtdblock4:rootfs_data@mtdblock5:misc@mtdblock6:private@mtdblock7:UDISK@mtdblock8 cma=8M fb_base=0x81e00000 androidboot.serialno=<NULL> boot_type=3
[ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[ 0.000000] Memory: 32MB = 32MB total
[ 0.000000] Memory: 18480k/18480k available, 14288k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc2800000 - 0xff000000 ( 968 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0444e4c (4340 kB)
[ 0.000000] .init : 0xc0445000 - 0xc0463e18 ( 124 kB)
[ 0.000000] .data : 0xc0464000 - 0xc0553208 ( 957 kB)
[ 0.000000] .bss : 0xc0553208 - 0xc057e5c0 ( 173 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] of_sunxi_clocks_init : sunxi_clk_base[0xf1c20000]
[ 0.000000] pll_cpu-set_default_rate=552000000 success!
[ 0.000000] pll_video-set_default_rate=297000000 success!
[ 0.000000] pll_ddr-set_default_rate=312000000 success!
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000365] Calibrating delay loop... 275.25 BogoMIPS (lpj=1376256)
[ 0.085341] pid_max: default: 32768 minimum: 301
[ 0.090439] Mount-cache hash table entries: 512
[ 0.096364] CPU: Testing write buffer coherency: ok
[ 0.102053] Setting up static identity map for 0xc0347338 - 0xc0347390
[ 0.111878] devtmpfs: initialized
[ 0.117263] pinctrl core: initialized pinctrl subsystem
[ 0.124772] NET: Registered protocol family 16
[ 0.132517] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.144916] sun3iw1p1-pinctrl pio: initialized sunXi PIO driver
[ 0.167432] bio: create slab <bio-0> at 0
[ 0.172781] pwm module init!
[ 0.177485] SCSI subsystem initialized
[ 0.181603] usbcore: registered new interface driver usbfs
[ 0.187383] usbcore: registered new interface driver hub
[ 0.193160] usbcore: registered new device driver usb
[ 0.201247] Advanced Linux Sound Architecture Driver Initialized.
[ 0.209122] cfg80211: Calling CRDA to update world regulatory domain
[ 0.216469] Switching to clocksource sun3i high-res couter
[ 0.224858] get det_vbus is fail, 84
[ 0.228535] of_get_named_gpio_flags: can't parse gpios property
[ 0.236141] NET: Registered protocol family 2
[ 0.242745] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.249727] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.256266] TCP: Hash tables configured (established 512 bind 512)
[ 0.262703] TCP: reno registered
[ 0.266041] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.271971] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.278997] NET: Registered protocol family 1
[ 0.296922] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.303535] jffs2: version 2.2. (NAND) (SUMMARY) ? 2001-2006 Red Hat, Inc.
[ 0.311532] msgmni has been set to 52
[ 0.318581] io scheduler noop registered
[ 0.322801] io scheduler cfq registered (default)
[ 0.328219] [pm]aw_pm_init!
[ 0.331461] [pm]valid
[ 0.333926] [pm]valid
[ 0.336848] [DISP]disp_module_init
[ 0.341998] of_get_named_gpio_flags: can't parse gpios property
[ 0.348790] of_get_named_gpio_flags: can't parse gpios property
[ 0.355226] of_get_named_gpio_flags: can't parse gpios property
[ 0.361588] of_get_named_gpio_flags exited with status 130
[ 0.367600] of_get_named_gpio_flags exited with status 96
[ 0.373524] of_get_named_gpio_flags exited with status 108
[ 0.379449] of_get_named_gpio_flags exited with status 131
[ 0.385439] of_get_named_gpio_flags: can't parse gpios property
[ 0.391768] of_get_named_gpio_flags: can't parse gpios property
[ 0.398177] of_get_named_gpio_flags: can't parse gpios property
[ 0.462171] pll_freq=297000000HZ, lcd_dclk_freq=14000000HZ, clk_div=21
[ 0.469527] num_screens=1
[ 0.472333] screen_id=0
[ 0.474865] para->mclk[MOD_CLK_LCD1CH0]=0xc0c0c340
[ 0.479724] para->mclk[MOD_CLK_LCD1CH1]=0xc0c0c440
[ 0.484630] disp tv init
[ 0.487251] tcon_clk=0xc0c0c340, tcon_clk_parent=0x0
[ 0.492328] tcon_clk=0xc0c0c340, tcon_clk_parent=0xc0c04400
[ 0.497971] tve_clk=0xc0c0c440, tve_clk_parent=0xc0c04400
[ 0.503469] disp al tv init
[ 0.509223] fetch script datadisp.screen2_output_type fail
[ 0.515231] fetch script datadisp.screen2_output_mode fail
[ 0.523623] fetch script datadisp.fb2_format fail
[ 0.528726] fetch script datadisp.fb2_scaler_mode_enable fail
[ 0.534941] fetch script datadisp.fb2_width fail
[ 0.539957] fetch script datadisp.fb2_height fail
[ 0.551704] [DISP] Fb_map_kernel_logo,line:561: this is not a bmp picture
[ 0.560521] [DISP]disp_module_init finish
[ 0.578967] uart0: ttyS0 at MMIO 0x1c25000 (irq = 104) is a SUNXI
[ 0.586396] uart1: ttyS1 at MMIO 0x1c25400 (irq = 105) is a SUNXI
[ 0.592720] sw_console_setup()1324 - console setup baud 115200 parity n bits 8, flow n
[ 0.600729] console [ttyS1] enabled, bootconsole disabled
[ 0.613516] uart2: ttyS2 at MMIO 0x1c25800 (irq = 106) is a SUNXI
[ 0.625126] spi spi0: master is unqueued, this is deprecated
[ 0.632830] m25p80 spi0.0: found py25q256hb, expected m25p64
[ 0.639254] m25p80 spi0.0: py25q256hb (32768 Kbytes) - fast mode
[ 0.649886] sunxi_mbr->PartCount = 216375170
[ 0.654724] sunxipart: failed to parse sunxi_mbr)!
[ 0.660096] m25p80: probe of spi0.0 failed with error -22
[ 0.666435] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.674239] usbcore: registered new interface driver usb-storage
[ 0.681905] /soc/usbc0@0: could not find phandle
[ 0.687160] of_get_named_gpio_flags: can't parse gpios property
[ 0.693783] get regulator_io is no nocare
[ 0.698373] sunxi_hcd_host0 1c13000.otghci0-controller: sunxi_hcd host driver
[ 0.706387] sunxi_hcd_host0 1c13000.otghci0-controller: new USB bus registered, assigned bus number 1
[ 0.718125] hub 1-0:1.0: USB hub found
[ 0.722497] hub 1-0:1.0: 1 port detected
[ 0.727333] wrn: hcd is not enable, need not stop hcd
[ 0.757185] rtc-pcf85063 2-0051: rtc core: registered pcf85063 as rtc0
[ 0.766572] i2c /dev entries driver
[ 0.771024] IR NEC protocol handler initialized
[ 0.776542] pdev->dev.of_node name :cir
[ 0.781133] Registered IR keymap rc-nec-terratec-cinergy-xs
[ 0.788207] input: sunxi_ir_recv as /devices/soc/1c22c00.cir/rc/rc0/input0
[ 0.796474] rc0: sunxi_ir_recv as /devices/soc/1c22c00.cir/rc/rc0
[ 0.808373] ipip: IPv4 over IPv4 tunneling driver
[ 0.814893] gre: GRE over IPv4 demultiplexor driver
[ 0.820324] ip_gre: GRE over IPv4 tunneling driver
[ 0.828196] TCP: cubic registered
[ 0.831892] Initializing XFRM netlink socket
[ 0.836792] NET: Registered protocol family 17
[ 0.841839] NET: Registered protocol family 15
[ 0.847293] VFP support v0.3: not present
[ 0.853071] [LCD]lcd_module_init
[ 0.860349] enhance_en=1
[ 0.863342] matrixresult:(0x0, 0x3c4, 0x0, 0x0)
[ 0.868421] ERROR,DE_BE_Layer_Set_Screen_Win:174 w,h=[0,0]
[ 0.874611] ERROR,DE_BE_Layer_Set_Screen_Win:174 w,h=[0,0]
[ 0.880713] ERROR,DE_BE_Layer_Set_Screen_Win:174 w,h=[0,0]
[ 0.886929] pll_freq=297000000HZ, lcd_dclk_freq=14000000HZ, clk_div=21
[ 0.894254] clk_div=21
[ 0.897103] [drivers/video/sunxi/disp/lcd/panels/st7796p_320x480.c][LCD_power_on]299
[ 1.122138] [LCD]open, step 0 finish
[ 1.162147] [drivers/video/sunxi/disp/lcd/panels/st7796p_320x480.c][LCD_panel_init]361
[ 1.171022] [drivers/video/sunxi/disp/lcd/panels/st7796p_320x480.c][lcd_init_data]103
[ 1.542664] [LCD]open, step 1 finish
[ 1.602147] [LCD]open, step 2 finish
[ 1.712569] [LCD]open, step 3 finish
[ 1.722206] [LCD]lcd_module_init finish
[ 1.727000] usb_serial_number:20080411
[ 1.731752] file system registered
[ 1.738365] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.746136] android_usb gadget: Number of LUNs=3
[ 1.751311] lun0: LUN: removable file: (no medium)
[ 1.756781] lun1: LUN: removable file: (no medium)
[ 1.762235] lun2: LUN: removable file: (no medium)
[ 1.768559] android_usb gadget: android_usb ready
[ 1.775488] rtc-pcf85063 2-0051: setting system clock to 2000-01-01 18:18:27 UTC (946750707)
[ 1.785178] ALSA device list:
[ 1.788486] No soundcards found.
[ 1.793260] VFS: Cannot open root device "mtdblock4" or unknown-block(0,0): error -6
[ 1.801918] Please append a correct "root=" boot option; here are the available partitions:
[ 1.811289] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
#1 2023-08-30 18:00:15
gaocangjian
已发帖子: 32
Re: 100s tina nor启动,怎么新增支持一个32M的norflash?
在 sys_config.fex 中有个存储介质那 选norflash,然后,写一个字段
[norflash]
size = 32
再去有个 分区配置的文件 也是 fex类型的,也就是你每次pack时,系统用到的那个文件。看看有没有什么好改的。
我记不住那个单词。
最近编辑记录 gaocangjian (2023-08-30 18:00:49)
楼主 #2 2023-08-31 11:56:26
jkl
已发帖子: 271
感谢,问题已经解决了,需要使用4字节的地址模式,打开这个就行了
