U-Boot SPL 2022.10 (Jul 02 2023 - 12:23:22 +0800)
sunxi_ram_probe: dram-controller@3102000: probing
DRAM only have internal ZQ!!
ddr_efuse_type: 0x0
[AUTO DEBUG] single rank and full DQ!
ddr_efuse_type: 0x0
[AUTO DEBUG] rank 0 row = 15
[AUTO DEBUG] rank 0 bank = 8
[AUTO DEBUG] rank 0 page size = 2 KB
DRAM BOOT DRIVE INFO: V0.24
DRAM CLK = 792 MHz
DRAM Type = 3 (2:DDR2,3:DDR3)
DRAMC ZQ value: 0x7b7bfb
DRAM ODT value: 0x42.
ddr_efuse_type: 0x0
DRAM SIZE =512 M
DRAM simple test OK.
mxstatus=0xc0408000 mhcr=0x00000109 mcor=0x00000003 mhint=0x00004000
Trying to boot from MMC1
PLL reg = 0xf8216300, freq = 1200000000
SPL size = 81920, sector = 400
sunxi_ram_get_info: dram-controller@3102000: getting info
OpenSBI v1.2
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
| | | |_ __ ___ _ __ | (___ | |_) || |
| | | | '_ \ / _ \ '_ \ \___ \| _ < | |
| |__| | |_) | __/ | | |____) | |_) || |_
\____/| .__/ \___|_| |_|_____/|____/_____|
|_|
Platform Name : Allwinner D1 Nezha
Platform Features : medeleg
Platform HART Count : 1
Platform IPI Device : ---
Platform Timer Device : --- @ 0Hz
Platform Console Device : uart8250
Platform HSM Device : sun20i-d1-ppu
Platform PMU Device :
Platform Reboot Device : sunxi-wdt-reset
Platform Shutdown Device : ---
Firmware Base : 0x40000000
Firmware Size : 228 KB
Firmware RW Offset : 0x20000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 0
Domain0 HARTs : 0*
Domain0 Region00 : 0x0000000040000000-0x000000004001ffff M: (R,X) S/U: ()
Domain0 Region01 : 0x0000000040020000-0x000000004003ffff M: (R,W) S/U: ()
Domain0 Region02 : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X)
Domain0 Next Address : 0x0000000046000000
Domain0 Next Arg1 : 0x000000004608b808
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 0
Boot HART Domain : root
Boot HART Priv Version : v1.11
Boot HART Base ISA : rv64imafdcvx
Boot HART ISA Extensions : time
Boot HART PMP Count : 8
Boot HART PMP Granularity : 2048
Boot HART PMP Address Bits: 38
Boot HART MHPM Count : 29
Boot HART MIDELEG : 0x0000000000020222
Boot HART MEDELEG : 0x000000000000b109
sunxi_set_gate: (CLK#24) unhandled
U-Boot 2022.10 (Jul 02 2023 - 12:23:22 +0800) Allwinner Technology
DRAM: 512 MiB
Core: 54 devices, 20 uclasses, devicetree: separate
WDT: Started watchdog@6011000 with servicing every 1000ms (16s timeout)
MMC: mmc@4020000: 0, mmc@4021000: 1
Loading Environment from FAT... PLL reg = 0xf8216300, freq = 1200000000
Unable to use mmc 0:1...
In: serial@2500000
Out: serial@2500000
Err: serial@2500000
Net:
Warning: ethernet@4500000 (eth0) using random MAC address - 12:61:84:78:2a:01
eth0: ethernet@4500000
Bus usb@4101000: USB EHCI 1.00
Bus usb@4101400: USB OHCI 1.0
Bus usb@4200000: USB EHCI 1.00
Bus usb@4200400: USB OHCI 1.0
scanning bus usb@4101000 for devices... 1 USB Device(s) found
scanning bus usb@4101400 for devices... 1 USB Device(s) found
scanning bus usb@4200000 for devices... 1 USB Device(s) found
scanning bus usb@4200400 for devices... 1 USB Device(s) found
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
624 bytes read in 1 ms (609.4 KiB/s)
Loading kernel from mmc 0:1 to address 0x42000000
10185576 bytes read in 1687 ms (5.8 MiB/s)
Loading dtb from mmc 0:1 to address 0x40100000
17924 bytes read in 4 ms (4.3 MiB/s)
Booting kernel with bootargs as earlycon=sbi console=ttyS0,115200n8 root=/dev/mmcblk0p2; and fdtcontroladdr is 5fd3dda0
Uncompressing Kernel Image
Moving Image from 0x42000000 to 0x40200000, end=41a1c000
Booting using the fdt blob at 0x5fd3dda0
Working FDT set to 5fd3dda0
Loading Device Tree to 0000000042df1000, end 0000000042dff017 ... OK
Working FDT set to 42df1000
[ 0.000000] Linux version 6.5.0 (quentin@quentin) (riscv64-linux-gnu-gcc (Ubuntu 12.2.0-14ubuntu2) 12.2.0, GNU ld (GNU Binutils for Ubuntu) 2.40) #1 PREEMPT Sat Sep 2 09:10:29 HKT 2023
[ 0.000000] Machine model: Allwinner D1 Nezha
[ 0.000000] SBI specification v1.0 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10002
[ 0.000000] SBI TIME extension detected
[ 0.000000] SBI IPI extension detected
[ 0.000000] SBI RFENCE extension detected
[ 0.000000] SBI SRST extension detected
[ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '')
[ 0.000000] printk: bootconsole [sbi0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: 0x0000000040000000..0x000000004001ffff (128 KiB) map non-reusable mmode_resv0@40000000
[ 0.000000] OF: reserved mem: 0x0000000040020000..0x000000004003ffff (128 KiB) map non-reusable mmode_resv1@40020000
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] riscv: base ISA extensions acdfim
[ 0.000000] riscv: ELF capabilities acdfim
[ 0.000000] Kernel command line: earlycon=sbi console=ttyS0,115200n8 root=/dev/mmcblk0p2
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 488216K/524288K available (7403K kernel code, 5776K rwdata, 8192K rodata, 2194K init, 329K bss, 36072K reserved, 0K cma-reserved)
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] riscv-intc: 64 local interrupts mapped
[ 0.000000] plic: interrupt-controller@10000000: mapped 176 interrupts with 1 handlers for 2 contexts.
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000001] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008576] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.018628] Console: colour dummy device 80x25
[ 0.023155] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.033419] pid_max: default: 32768 minimum: 301
[ 0.038433] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.045754] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.057922] RCU Tasks: Setting shift to 0 and lim to 1 rcu_task_cb_adjust=1.
[ 0.065235] riscv: ELF compat mode unsupported
[ 0.065319] ASID allocator using 16 bits (65536 entries)
[ 0.075439] rcu: Hierarchical SRCU implementation.
[ 0.080245] rcu: Max phase no-delay instances is 1000.
[ 0.085898] EFI services will not be available.
[ 0.091324] devtmpfs: initialized
[ 0.114834] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.124630] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.131532] pinctrl core: initialized pinctrl subsystem
[ 0.140162] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.147384] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.154544] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.162562] audit: initializing netlink subsys (disabled)
[ 0.169505] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.169533] thermal_sys: Registered thermal governor 'step_wise'
[ 0.175542] audit: type=2000 audit(0.112:1): state=initialized audit_enabled=0 res=1
[ 0.189371] thermal_sys: Registered thermal governor 'user_space'
[ 0.189519] cpuidle: using governor menu
[ 0.210491] platform soc: Fixed dependency cycle(s) with /soc/interrupt-controller@10000000
[ 0.221085] platform 2001000.clock-controller: Fixed dependency cycle(s) with /soc/rtc@7090000
[ 0.232478] platform 2030000.audio-codec: Fixed dependency cycle(s) with /soc/audio-codec@2030000/regulators@2030348/hpldo
[ 0.243540] platform 2030000.audio-codec: Fixed dependency cycle(s) with /soc/audio-codec@2030000/regulators@2030348/aldo
[ 0.271415] platform 5460000.tcon-top: Fixed dependency cycle(s) with /soc/mixer@5200000/ports/port@1/endpoint
[ 0.281477] platform 5460000.tcon-top: Fixed dependency cycle(s) with /soc/mixer@5100000/ports/port@1/endpoint
[ 0.292217] platform 5461000.lcd-controller: Fixed dependency cycle(s) with /soc/tcon-top@5460000/ports/port@3/endpoint@0
[ 0.303258] platform 5461000.lcd-controller: Fixed dependency cycle(s) with /soc/tcon-top@5460000/ports/port@1/endpoint@0
[ 0.315200] platform 5470000.lcd-controller: Fixed dependency cycle(s) with /soc/tcon-top@5460000/ports/port@4/endpoint
[ 0.326120] platform 5470000.lcd-controller: Fixed dependency cycle(s) with /soc/tcon-top@5460000/ports/port@3/endpoint@2
[ 0.337182] platform 5470000.lcd-controller: Fixed dependency cycle(s) with /soc/tcon-top@5460000/ports/port@1/endpoint@2
[ 0.348237] platform 5470000.lcd-controller: Fixed dependency cycle(s) with /soc/tcon-top@5460000
[ 0.358154] platform 5500000.hdmi: Fixed dependency cycle(s) with /soc/tcon-top@5460000/ports/port@5/endpoint
[ 0.370188] platform 7010000.clock-controller: Fixed dependency cycle(s) with /soc/rtc@7090000
[ 0.383620] platform connector: Fixed dependency cycle(s) with /soc/hdmi@5500000/ports/port@1/endpoint
[ 0.411910] iommu: Default domain type: Translated
[ 0.418643] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.434550] SCSI subsystem initialized
[ 0.442286] usbcore: registered new interface driver usbfs
[ 0.453841] usbcore: registered new interface driver hub
[ 0.465828] usbcore: registered new device driver usb
[ 0.478313] mc: Linux media interface: v0.10
[ 0.482706] videodev: Linux video capture interface: v2.00
[ 0.498067] Advanced Linux Sound Architecture Driver Initialized.
[ 0.518051] clocksource: Switched to clocksource riscv_clocksource
[ 0.575970] NET: Registered PF_INET protocol family
[ 0.586660] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.610769] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.630125] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.646135] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.658219] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.674422] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.686261] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.702138] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.714457] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.730733] RPC: Registered named UNIX socket transport module.
[ 0.742082] RPC: Registered udp transport module.
[ 0.750091] RPC: Registered tcp transport module.
[ 0.758138] RPC: Registered tcp-with-tls transport module.
[ 0.770081] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.783700] Initialise system trusted keyrings
[ 0.798205] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.812817] SGI XFS with ACLs, security attributes, no debug enabled
[ 0.831108] NET: Registered PF_ALG protocol family
[ 0.842126] Key type asymmetric registered
[ 0.846220] Asymmetric key parser 'x509' registered
[ 0.858251] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.874164] io scheduler bfq registered
[ 0.973668] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.034837] zram: Added device: zram0
[ 1.058776] usbcore: registered new interface driver uas
[ 1.070229] usbcore: registered new interface driver usb-storage
[ 1.082387] usbcore: registered new interface driver ch341
[ 1.094190] usbserial: USB Serial support registered for ch341-uart
[ 1.107290] UDC core: g_ether: couldn't find an available UDC
[ 1.126858] sun6i-rtc 7090000.rtc: registered as rtc0
[ 1.138210] sun6i-rtc 7090000.rtc: setting system clock to 1970-01-02T00:01:02 UTC (86462)
[ 1.154457] sun6i-rtc 7090000.rtc: RTC enabled
[ 1.166377] i2c_dev: i2c /dev entries driver
[ 1.182670] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.195435] cpuidle-riscv-sbi: idle driver registered for all CPUs
[ 1.212485] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.226504] usbcore: registered new interface driver usbhid
[ 1.238088] usbhid: USB HID core driver
[ 1.255152] usbcore: registered new interface driver snd-usb-audio
[ 1.279058] NET: Registered PF_INET6 protocol family
[ 1.298988] Segment Routing with IPv6
[ 1.302904] In-situ OAM (IOAM) with IPv6
[ 1.310348] NET: Registered PF_PACKET protocol family
[ 1.381085] registered taskstats version 1
[ 1.390126] Loading compiled-in X.509 certificates
[ 1.535119] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.604470] sun20i-d1-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 1.631902] printk: console [ttyS0] disabled
[ 1.682095] 2500000.serial: ttyS0 at MMIO 0x2500000 (irq = 204, base_baud = 1500000) is a 16550A
[ 1.698179] printk: console [ttyS0] enabled
[ 1.718078] printk: bootconsole [sbi0] disabled
[ 1.786088] 2500400.serial: ttyS1 at MMIO 0x2500400 (irq = 205, base_baud = 1500000) is a 16550A
[ 1.820252] dwmac-sun8i 4500000.ethernet: IRQ eth_wake_irq not found
[ 1.838108] dwmac-sun8i 4500000.ethernet: IRQ eth_lpi not found
[ 1.850823] dwmac-sun8i 4500000.ethernet: PTP uses main clock
[ 1.862143] dwmac-sun8i 4500000.ethernet: Current syscon value is not the default 50006 (expect 0)
[ 1.882531] dwmac-sun8i 4500000.ethernet: No HW DMA feature register supported
[ 1.894102] dwmac-sun8i 4500000.ethernet: RX Checksum Offload Engine supported
[ 1.910091] dwmac-sun8i 4500000.ethernet: COE Type 2
[ 1.922096] dwmac-sun8i 4500000.ethernet: TX Checksum insertion supported
[ 1.934102] dwmac-sun8i 4500000.ethernet: Normal descriptors
[ 1.946130] dwmac-sun8i 4500000.ethernet: Chain mode enabled
[ 2.002475] sunxi-mmc 4020000.mmc: Got CD GPIO
[ 2.034164] sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 2.043712] phy phy-4100400.phy.1: Changing dr_mode to 1
[ 2.052335] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 2.064220] ehci-platform 4200000.usb: EHCI Host Controller
[ 2.075841] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
[ 2.086671] ohci-platform 4200400.usb: Generic Platform OHCI controller
[ 2.093805] phy phy-4100400.phy.1: External vbus detected, not enabling our own vbus
[ 2.105126] ehci-platform 4200000.usb: new USB bus registered, assigned bus number 1
[ 2.113003] mmc1: Failed to initialize a non-removable card
[ 2.117685] ohci-platform 4200400.usb: new USB bus registered, assigned bus number 2
[ 2.134138] ohci-platform 4101400.usb: Generic Platform OHCI controller
[ 2.140943] ehci-platform 4101000.usb: EHCI Host Controller
[ 2.147029] ehci-platform 4200000.usb: irq 213, io mem 0x04200000
[ 2.156703] ohci-platform 4101400.usb: new USB bus registered, assigned bus number 3
[ 2.166180] ehci-platform 4101000.usb: new USB bus registered, assigned bus number 4
[ 2.181808] ohci-platform 4101400.usb: irq 214, io mem 0x04101400
[ 2.188328] mmc0: new high speed SDHC card at address 5048
[ 2.194131] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
[ 2.200489] ohci-platform 4200400.usb: irq 215, io mem 0x04200400
[ 2.210506] ehci-platform 4101000.usb: irq 212, io mem 0x04101000
[ 2.217846] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
[ 2.231077] mmcblk0: mmc0:5048 SD32G 28.9 GiB
[ 2.242990] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.250427] ehci-platform 4101000.usb: USB 2.0 started, EHCI 1.00
[ 2.262419] mmcblk0: p1 p2 p3
[ 2.271726] usb usb1: Product: EHCI Host Controller
[ 2.282145] usb usb1: Manufacturer: Linux 6.5.0 ehci_hcd
[ 2.302092] usb usb1: SerialNumber: 4200000.usb
[ 2.311758] hub 1-0:1.0: USB hub found
[ 2.322197] hub 1-0:1.0: 1 port detected
[ 2.331568] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
[ 2.346110] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.362110] usb usb4: Product: EHCI Host Controller
[ 2.374107] usb usb4: Manufacturer: Linux 6.5.0 ehci_hcd
[ 2.386107] usb usb4: SerialNumber: 4101000.usb
[ 2.394858] hub 4-0:1.0: USB hub found
[ 2.402189] hub 4-0:1.0: 1 port detected
[ 2.411515] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.05
[ 2.426111] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.442111] usb usb2: Product: Generic Platform OHCI controller
[ 2.454102] usb usb2: Manufacturer: Linux 6.5.0 ohci_hcd
[ 2.466111] usb usb2: SerialNumber: 4200400.usb
[ 2.475635] hub 2-0:1.0: USB hub found
[ 2.486200] hub 2-0:1.0: 1 port detected
[ 2.495559] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.05
[ 2.510113] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.526140] usb usb3: Product: Generic Platform OHCI controller
[ 2.538123] usb usb3: Manufacturer: Linux 6.5.0 ohci_hcd
[ 2.550123] usb usb3: SerialNumber: 4101400.usb
[ 2.562862] hub 3-0:1.0: USB hub found
[ 2.570211] hub 3-0:1.0: 1 port detected
[ 3.162979] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 3.168879] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 5
[ 3.177124] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
[ 3.185480] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.192795] usb usb5: Product: MUSB HDRC host driver
[ 3.197827] usb usb5: Manufacturer: Linux 6.5.0 musb-hcd
[ 3.203191] usb usb5: SerialNumber: musb-hdrc.2.auto
[ 3.209768] hub 5-0:1.0: USB hub found
[ 3.213733] hub 5-0:1.0: 1 port detected
[ 3.233029] g_ether gadget.0: HOST MAC 06:ca:a8:38:55:e2
[ 3.238710] g_ether gadget.0: MAC de:26:25:d2:de:44
[ 3.243763] g_ether gadget.0: Ethernet Gadget, version: Memorial Day 2008
[ 3.250681] g_ether gadget.0: g_ether ready
[ 3.261913] clk: Disabling unused clocks
[ 3.266474] ALSA device list:
[ 3.269482] No soundcards found.
[ 3.765445] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 3.782302] EXT4-fs (mmcblk0p2): mounted filesystem 477fee25-4782-4db7-9935-f688c70d8bb9 ro with ordered data mode. Quota mode: disabled.
[ 3.794826] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.803993] devtmpfs: mounted
[ 3.809765] Freeing unused kernel image (initmem) memory: 2192K
[ 3.815834] Run /sbin/init as init process
mount: according to /proc/mounts, proc is already mounted on /proc
mount: mounting devpts on /dev/pts failed: No such file or directory
mount: mounting tmpfs on /var/volatile failed: No such file or directory
---------Starting mdev--------------
/etc/init.d/rcS: line 16: can't create /proc/sys/kernel/hotplug: nonexistent directory
Processing /etc/profile...
Welcome to Linux
最近编辑记录 quentin (2023-09-02 09:26:47)
