楼主 # 2023-11-11 05:10:06
alizx
V3S USB Camera
I started using V3S with implement USB camera on it.
I used Yokto to make the linux image and I added usb video class and ffmpeg to it.
after some weeks at last I get the video.
Because I wanted to have a smooth video I could not get better resoloution of 320x240 from camera. on higher qualities, I has delay in video.
video (LCD Resoloution: 480x272 - but input resoloution from camera is 320x240)
https://whycan.com/files/members/11174/VID_20230118_194215.mp4
after that, I designed a PCB for it and I used 54 pin FPC connector for 3.5 inch LCD.
But after assemble the hardware, the colors on picture was not correct. It is like a burned picture!
I'm sure that my board has not problem (because I made a 54-to-40 pin converter and I still have a good output on 4.3inch LCD!)
3.5inch output
Designed Board
I'm still working on it. but I could not get the problem!
#1 2023-11-11 23:25:07
已发帖子: 3,394
Re: V3S USB Camera
@alizx
这种情况,看起来可能 R/G/B 上面有一两根线断路或者短路了。
楼主 #2 2023-11-12 16:26:10
alizx
Re: V3S USB Camera
@alizx
Thanks for your reply.
I check the hardware. there is no issue there. in addition, I tested 4.3 inch LCD (I designed a simple 54-to-40 pin converter) and there was no issue!
#3 2023-11-12 16:32:49
已发帖子: 3,394
Re: V3S USB Camera
alizx 说:
@alizx
① 抓一张图片到电脑里面,用电脑看图软件显示,看是否正常
② 发一张图片到V3s,看V3s显示是否正常
楼主 #4 2023-11-27 19:24:28
alizx
Re: V3S USB Camera
@哇酷小二
a) I get a snapshot with v3s from usb camera and I checked it on my pc. it's ok
b) I show an image on this LCD but it is not ok. it's like output of usb cam.
