各位,按照 Tina Linux 存储介质切换
将R328从原来的spinand介质切换到spinor介质,目前可以正常烧录,但是启动的时候,会报以下错误log
[19]HELLO! BOOT0 is starting Jul 26 2019 19:41:59!
[24]BOOT0 commit : 6afae37e646720d2316ea41910732c588f35f6e0-dirty
[61]set pll start
[64]set pll end
[65]board init ok
[67]the chip id is 0x3
[69]the chip id is 0x3
[71]the chip id is 0x3
[73]the chip id is 0x3
[76]the chip id is 0x3
[78]chip id check OK
[80]DRAM BOOT DRIVE INFO: V0.18
[83]DRAM CLK = 792 MHz
[85]DRAM Type = 3 (2:DDR2,3:DDR3)
[88]DRAMC ZQ value: 0x3bfb
[91]DRAM ODT off.
[93]DRAM SIZE =128 M
[100]DRAM simple test OK.
[102]dram size =128
[105]spinor id is: c8 40 18, read cmd: 3b
[110]Succeed in reading toc file head.
[113]The size of toc is 88000.
[256]Entry_name = u-boot
[260]Entry_name = optee
[264]Entry_name = dtb
[267]Jump to secend Boot.
U-Boot 2018.05-g6dea684-dirty (Nov 13 2023 - 16:48:28 +0800) Allwinner Technology
[00.294]CPU: Allwinner Family
[00.297]Model: sun8iw18
[00.299]DRAM: 128 MiB
[00.302]Relocation Offset is: 04f7d000
[00.313]secure enable bit: 0
[00.315]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=396Mhz
[00.322]gic: sec monitor mode
[00.324]flash init start
[00.327]workmode = 0,storage type = 3
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
[00.339]sunxi flash init ok
[00.342]Loading Environment from SUNXI_FLASH... env and backup env all check CRC fail
Now set env to default
Saving Environment to SUNXI_FLASH... Writing to env...
CACHE: Misaligned operation at range [46aca648, 46aca748]
CACHE: Misaligned operation at range [46aca748, 46aca848]
CACHE: Misaligned operation at range [46aca848, 46aca948]
CACHE: Misaligned operation at range [46aca948, 46acaa48]
CACHE: Misaligned operation at range [46acaa48, 46acab48]
CACHE: Misaligned operation at range [46acab48, 46acac48]
CACHE: Misaligned operation at range [46acac48, 46acad48]
CACHE: Misaligned operation at range [46acad48, 46acae48]
CACHE: Misaligned operation at range [46acae48, 46acaf48]
CACHE: Misaligned operation at range [46acaf48, 46acb048]
CACHE: Misaligned operation at range [46acb048, 46acb148]
CACHE: Misaligned operation at range [46acb148, 46acb248]
CACHE: Misaligned operation at range [46acb248, 46acb348]
CACHE: Misaligned operation at range [46acb348, 46acb448]
CACHE: Misaligned operation at range [46acb448, 46acb548]
CACHE: Misaligned operation at range [46acb548, 46acb648]
CACHE: Misaligned operation at range [46acb648, 46acb748]
CACHE: Misaligned operation at range [46acb748, 46acb848]
CACHE: Misaligned operation at range [46acb848, 46acb948]
CACHE: Misaligned operation at range [46acb948, 46acba48]
CACHE: Misaligned operation at range [46acba48, 46acbb48]
CACHE: Misaligned operation at range [46acbb48, 46acbc48]
CACHE: Misaligned operation at range [46acbc48, 46acbd48]
CACHE: Misaligned operation at range [46acbd48, 46acbe48]
CACHE: Misaligned operation at range [46acbe48, 46acbf48]
CACHE: Misaligned operation at range [46acbf48, 46acc048]
CACHE: Misaligned operation at range [46acc048, 46acc148]
CACHE: Misaligned operation at range [46acc148, 46acc248]
CACHE: Misaligned operation at range [46acc248, 46acc348]
CACHE: Misaligned operation at range [46acc348, 46acc448]
CACHE: Misaligned operation at range [46acc448, 46acc548]
CACHE: Misaligned operation at range [46acc548, 46acc648]
CACHE: Misaligned operation at range [46acc648, 46acc748]
CACHE: Misaligned operation at range [46acc748, 46acc848]
CACHE: Misaligned operation at range [46acc848, 46acc948]
CACHE: Misaligned operation at range [46acc948, 46acca48]
CACHE: Misaligned operation at range [46acca48, 46accb48]
CACHE: Misaligned operation at range [46accb48, 46accc48]
CACHE: Misaligned operation at range [46accc48, 46accd48]
CACHE: Misaligned operation at range [46accd48, 46acce48]
CACHE: Misaligned operation at range [46acce48, 46accf48]
CACHE: Misaligned operation at range [46accf48, 46acd048]
CACHE: Misaligned operation at range [46acd048, 46acd148]
CACHE: Misaligned operation at range [46acd148, 46acd248]
CACHE: Misaligned operation at range [46acd248, 46acd348]
CACHE: Misaligned operation at range [46acd348, 46acd448]
CACHE: Misaligned operation at range [46acd448, 46acd548]
CACHE: Misaligned operation at range [46acd548, 46acd648]
CACHE: Misaligned operation at range [46acd648, 46acd748]
CACHE: Misaligned operation at range [46acd748, 46acd848]
CACHE: Misaligned operation at range [46acd848, 46acd948]
CACHE: Misaligned operation at range [46acd948, 46acda48]
CACHE: Misaligned operation at range [46acda48, 46acdb48]
CACHE: Misaligned operation at range [46acdb48, 46acdc48]
CACHE: Misaligned operation at range [46acdc48, 46acdd48]
CACHE: Misaligned operation at range [46acdd48, 46acde48]
CACHE: Misaligned operation at range [46acde48, 46acdf48]
CACHE: Misaligned operation at range [46acdf48, 46ace048]
CACHE: Misaligned operation at range [46ace048, 46ace148]
CACHE: Misaligned operation at range [46ace148, 46ace248]
CACHE: Misaligned operation at range [46ace248, 46ace348]
CACHE: Misaligned operation at range [46ace348, 46ace448]
CACHE: Misaligned operation at range [46ace448, 46ace548]
CACHE: Misaligned operation at range [46ace548, 46ace648]
CACHE: Misaligned operation at range [46ace648, 46ace748]
CACHE: Misaligned operation at range [46ace748, 46ace848]
CACHE: Misaligned operation at range [46ace848, 46ace948]
CACHE: Misaligned operation at range [46ace948, 46acea48]
CACHE: Misaligned operation at range [46acea48, 46aceb48]
CACHE: Misaligned operation at range [46aceb48, 46acec48]
CACHE: Misaligned operation at range [46acec48, 46aced48]
CACHE: Misaligned operation at range [46aced48, 46acee48]
CACHE: Misaligned operation at range [46acee48, 46acef48]
CACHE: Misaligned operation at range [46acef48, 46acf048]
CACHE: Misaligned operation at range [46acf048, 46acf148]
CACHE: Misaligned operation at range [46acf148, 46acf248]
CACHE: Misaligned operation at range [46acf248, 46acf348]
CACHE: Misaligned operation at range [46acf348, 46acf448]
CACHE: Misaligned operation at range [46acf448, 46acf548]
CACHE: Misaligned operation at range [46acf548, 46acf648]
CACHE: Misaligned operation at range [46acf648, 46acf748]
CACHE: Misaligned operation at range [46acf748, 46acf848]
CACHE: Misaligned operation at range [46acf848, 46acf948]
CACHE: Misaligned operation at range [46acf948, 46acfa48]
CACHE: Misaligned operation at range [46acfa48, 46acfb48]
CACHE: Misaligned operation at range [46acfb48, 46acfc48]
CACHE: Misaligned operation at range [46acfc48, 46acfd48]
CACHE: Misaligned operation at range [46acfd48, 46acfe48]
CACHE: Misaligned operation at range [46acfe48, 46acff48]
CACHE: Misaligned operation at range [46acff48, 46ad0048]
CACHE: Misaligned operation at range [46ad0048, 46ad0148]
CACHE: Misaligned operation at range [46ad0148, 46ad0248]
CACHE: Misaligned operation at range [46ad0248, 46ad0348]
CACHE: Misaligned operation at range [46ad0348, 46ad0448]
CACHE: Misaligned operation at range [46ad0448, 46ad0548]
CACHE: Misaligned operation at range [46ad0548, 46ad0648]
CACHE: Misaligned operation at range [46ad0648, 46ad0748]
CACHE: Misaligned operation at range [46ad0748, 46ad0848]
CACHE: Misaligned operation at range [46ad0848, 46ad0948]
CACHE: Misaligned operation at range [46ad0948, 46ad0a48]
CACHE: Misaligned operation at range [46ad0a48, 46ad0b48]
CACHE: Misaligned operation at range [46ad0b48, 46ad0c48]
CACHE: Misaligned operation at range [46ad0c48, 46ad0d48]
CACHE: Misaligned operation at range [46ad0d48, 46ad0e48]
CACHE: Misaligned operation at range [46ad0e48, 46ad0f48]
CACHE: Misaligned operation at range [46ad0f48, 46ad1048]
CACHE: Misaligned operation at range [46ad1048, 46ad1148]
CACHE: Misaligned operation at range [46ad1148, 46ad1248]
CACHE: Misaligned operation at range [46ad1248, 46ad1348]
CACHE: Misaligned operation at range [46ad1348, 46ad1448]
CACHE: Misaligned operation at range [46ad1448, 46ad1548]
CACHE: Misaligned operation at range [46ad1548, 46ad1648]
CACHE: Misaligned operation at range [46ad1648, 46ad1748]
CACHE: Misaligned operation at range [46ad1748, 46ad1848]
CACHE: Misaligned operation at range [46ad1848, 46ad1948]
CACHE: Misaligned operation at range [46ad1948, 46ad1a48]
CACHE: Misaligned operation at range [46ad1a48, 46ad1b48]
CACHE: Misaligned operation at range [46ad1b48, 46ad1c48]
CACHE: Misaligned operation at range [46ad1c48, 46ad1d48]
CACHE: Misaligned operation at range [46ad1d48, 46ad1e48]
CACHE: Misaligned operation at range [46ad1e48, 46ad1f48]
CACHE: Misaligned operation at range [46ad1f48, 46ad2048]
CACHE: Misaligned operation at range [46ad2048, 46ad2148]
CACHE: Misaligned operation at range [46ad2148, 46ad2248]
CACHE: Misaligned operation at range [46ad2248, 46ad2348]
CACHE: Misaligned operation at range [46ad2348, 46ad2448]
CACHE: Misaligned operation at range [46ad2448, 46ad2548]
CACHE: Misaligned operation at range [46ad2548, 46ad2648]
CACHE: Misaligned operation at range [46ad2648, 46ad2748]
CACHE: Misaligned operation at range [46ad2748, 46ad2848]
CACHE: Misaligned operation at range [46ad2848, 46ad2948]
CACHE: Misaligned operation at range [46ad2948, 46ad2a48]
CACHE: Misaligned operation at range [46ad2a48, 46ad2b48]
CACHE: Misaligned operation at range [46ad2b48, 46ad2c48]
CACHE: Misaligned operation at range [46ad2c48, 46ad2d48]
CACHE: Misaligned operation at range [46ad2d48, 46ad2e48]
CACHE: Misaligned operation at range [46ad2e48, 46ad2f48]
CACHE: Misaligned operation at range [46ad2f48, 46ad3048]
CACHE: Misaligned operation at range [46ad3048, 46ad3148]
CACHE: Misaligned operation at range [46ad3148, 46ad3248]
CACHE: Misaligned operation at range [46ad3248, 46ad3348]
CACHE: Misaligned operation at range [46ad3348, 46ad3448]
CACHE: Misaligned operation at range [46ad3448, 46ad3548]
CACHE: Misaligned operation at range [46ad3548, 46ad3648]
CACHE: Misaligned operation at range [46ad3648, 46ad3748]
CACHE: Misaligned operation at range [46ad3748, 46ad3848]
CACHE: Misaligned operation at range [46ad3848, 46ad3948]
CACHE: Misaligned operation at range [46ad3948, 46ad3a48]
CACHE: Misaligned operation at range [46ad3a48, 46ad3b48]
CACHE: Misaligned operation at range [46ad3b48, 46ad3c48]
CACHE: Misaligned operation at range [46ad3c48, 46ad3d48]
CACHE: Misaligned operation at range [46ad3d48, 46ad3e48]
CACHE: Misaligned operation at range [46ad3e48, 46ad3f48]
CACHE: Misaligned operation at range [46ad3f48, 46ad4048]
CACHE: Misaligned operation at range [46ad4048, 46ad4148]
CACHE: Misaligned operation at range [46ad4148, 46ad4248]
CACHE: Misaligned operation at range [46ad4248, 46ad4348]
CACHE: Misaligned operation at range [46ad4348, 46ad4448]
CACHE: Misaligned operation at range [46ad4448, 46ad4548]
CACHE: Misaligned operation at range [46ad4548, 46ad4648]
CACHE: Misaligned operation at range [46ad4648, 46ad4748]
CACHE: Misaligned operation at range [46ad4748, 46ad4848]
CACHE: Misaligned operation at range [46ad4848, 46ad4948]
CACHE: Misaligned operation at range [46ad4948, 46ad4a48]
CACHE: Misaligned operation at range [46ad4a48, 46ad4b48]
CACHE: Misaligned operation at range [46ad4b48, 46ad4c48]
CACHE: Misaligned operation at range [46ad4c48, 46ad4d48]
CACHE: Misaligned operation at range [46ad4d48, 46ad4e48]
CACHE: Misaligned operation at range [46ad4e48, 46ad4f48]
CACHE: Misaligned operation at range [46ad4f48, 46ad5048]
CACHE: Misaligned operation at range [46ad5048, 46ad5148]
CACHE: Misaligned operation at range [46ad5148, 46ad5248]
CACHE: Misaligned operation at range [46ad5248, 46ad5348]
CACHE: Misaligned operation at range [46ad5348, 46ad5448]
CACHE: Misaligned operation at range [46ad5448, 46ad5548]
CACHE: Misaligned operation at range [46ad5548, 46ad5648]
CACHE: Misaligned operation at range [46ad5648, 46ad5748]
CACHE: Misaligned operation at range [46ad5748, 46ad5848]
CACHE: Misaligned operation at range [46ad5848, 46ad5948]
CACHE: Misaligned operation at range [46ad5948, 46ad5a48]
CACHE: Misaligned operation at range [46ad5a48, 46ad5b48]
CACHE: Misaligned operation at range [46ad5b48, 46ad5c48]
CACHE: Misaligned operation at range [46ad5c48, 46ad5d48]
CACHE: Misaligned operation at range [46ad5d48, 46ad5e48]
CACHE: Misaligned operation at range [46ad5e48, 46ad5f48]
CACHE: Misaligned operation at range [46ad5f48, 46ad6048]
CACHE: Misaligned operation at range [46ad6048, 46ad6148]
CACHE: Misaligned operation at range [46ad6148, 46ad6248]
CACHE: Misaligned operation at range [46ad6248, 46ad6348]
CACHE: Misaligned operation at range [46ad6348, 46ad6448]
CACHE: Misaligned operation at range [46ad6448, 46ad6548]
CACHE: Misaligned operation at range [46ad6548, 46ad6648]
CACHE: Misaligned operation at range [46ad6648, 46ad6748]
CACHE: Misaligned operation at range [46ad6748, 46ad6848]
CACHE: Misaligned operation at range [46ad6848, 46ad6948]
CACHE: Misaligned operation at range [46ad6948, 46ad6a48]
CACHE: Misaligned operation at range [46ad6a48, 46ad6b48]
CACHE: Misaligned operation at range [46ad6b48, 46ad6c48]
CACHE: Misaligned operation at range [46ad6c48, 46ad6d48]
CACHE: Misaligned operation at range [46ad6d48, 46ad6e48]
CACHE: Misaligned operation at range [46ad6e48, 46ad6f48]
CACHE: Misaligned operation at range [46ad6f48, 46ad7048]
CACHE: Misaligned operation at range [46ad7048, 46ad7148]
CACHE: Misaligned operation at range [46ad7148, 46ad7248]
CACHE: Misaligned operation at range [46ad7248, 46ad7348]
CACHE: Misaligned operation at range [46ad7348, 46ad7448]
CACHE: Misaligned operation at range [46ad7448, 46ad7548]
CACHE: Misaligned operation at range [46ad7548, 46ad7648]
CACHE: Misaligned operation at range [46ad7648, 46ad7748]
CACHE: Misaligned operation at range [46ad7748, 46ad7848]
CACHE: Misaligned operation at range [46ad7848, 46ad7948]
CACHE: Misaligned operation at range [46ad7948, 46ad7a48]
CACHE: Misaligned operation at range [46ad7a48, 46ad7b48]
CACHE: Misaligned operation at range [46ad7b48, 46ad7c48]
CACHE: Misaligned operation at range [46ad7c48, 46ad7d48]
CACHE: Misaligned operation at range [46ad7d48, 46ad7e48]
CACHE: Misaligned operation at range [46ad7e48, 46ad7f48]
CACHE: Misaligned operation at range [46ad7f48, 46ad8048]
CACHE: Misaligned operation at range [46ad8048, 46ad8148]
CACHE: Misaligned operation at range [46ad8148, 46ad8248]
CACHE: Misaligned operation at range [46ad8248, 46ad8348]
CACHE: Misaligned operation at range [46ad8348, 46ad8448]
CACHE: Misaligned operation at range [46ad8448, 46ad8548]
CACHE: Misaligned operation at range [46ad8548, 46ad8648]
CACHE: Misaligned operation at range [46ad8648, 46ad8748]
CACHE: Misaligned operation at range [46ad8748, 46ad8848]
CACHE: Misaligned operation at range [46ad8848, 46ad8948]
CACHE: Misaligned operation at range [46ad8948, 46ad8a48]
CACHE: Misaligned operation at range [46ad8a48, 46ad8b48]
CACHE: Misaligned operation at range [46ad8b48, 46ad8c48]
CACHE: Misaligned operation at range [46ad8c48, 46ad8d48]
CACHE: Misaligned operation at range [46ad8d48, 46ad8e48]
CACHE: Misaligned operation at range [46ad8e48, 46ad8f48]
CACHE: Misaligned operation at range [46ad8f48, 46ad9048]
CACHE: Misaligned operation at range [46ad9048, 46ad9148]
CACHE: Misaligned operation at range [46ad9148, 46ad9248]
CACHE: Misaligned operation at range [46ad9248, 46ad9348]
CACHE: Misaligned operation at range [46ad9348, 46ad9448]
CACHE: Misaligned operation at range [46ad9448, 46ad9548]
CACHE: Misaligned operation at range [46ad9548, 46ad9648]
CACHE: Misaligned operation at range [46ad9648, 46ad9748]
CACHE: Misaligned operation at range [46ad9748, 46ad9848]
CACHE: Misaligned operation at range [46ad9848, 46ad9948]
CACHE: Misaligned operation at range [46ad9948, 46ad9a48]
CACHE: Misaligned operation at range [46ad9a48, 46ad9b48]
CACHE: Misaligned operation at range [46ad9b48, 46ad9c48]
CACHE: Misaligned operation at range [46ad9c48, 46ad9d48]
CACHE: Misaligned operation at range [46ad9d48, 46ad9e48]
CACHE: Misaligned operation at range [46ad9e48, 46ad9f48]
CACHE: Misaligned operation at range [46ad9f48, 46ada048]
CACHE: Misaligned operation at range [46ada048, 46ada148]
CACHE: Misaligned operation at range [46ada148, 46ada248]
CACHE: Misaligned operation at range [46ada248, 46ada348]
CACHE: Misaligned operation at range [46ada348, 46ada448]
CACHE: Misaligned operation at range [46ada448, 46ada548]
CACHE: Misaligned operation at range [46ada548, 46ada648]
CACHE: Misaligned operation at range [46ada648, 46ada748]
CACHE: Misaligned operation at range [46ada748, 46ada848]
CACHE: Misaligned operation at range [46ada848, 46ada948]
CACHE: Misaligned operation at range [46ada948, 46adaa48]
CACHE: Misaligned operation at range [46adaa48, 46adab48]
CACHE: Misaligned operation at range [46adab48, 46adac48]
CACHE: Misaligned operation at range [46adac48, 46adad48]
CACHE: Misaligned operation at range [46adad48, 46adae48]
CACHE: Misaligned operation at range [46adae48, 46adaf48]
CACHE: Misaligned operation at range [46adaf48, 46adb048]
CACHE: Misaligned operation at range [46adb048, 46adb148]
CACHE: Misaligned operation at range [46adb148, 46adb248]
CACHE: Misaligned operation at range [46adb248, 46adb348]
CACHE: Misaligned operation at range [46adb348, 46adb448]
CACHE: Misaligned operation at range [46adb448, 46adb548]
CACHE: Misaligned operation at range [46adb548, 46adb648]
CACHE: Misaligned operation at range [46adb648, 46adb748]
CACHE: Misaligned operation at range [46adb748, 46adb848]
CACHE: Misaligned operation at range [46adb848, 46adb948]
CACHE: Misaligned operation at range [46adb948, 46adba48]
CACHE: Misaligned operation at range [46adba48, 46adbb48]
CACHE: Misaligned operation at range [46adbb48, 46adbc48]
CACHE: Misaligned operation at range [46adbc48, 46adbd48]
CACHE: Misaligned operation at range [46adbd48, 46adbe48]
CACHE: Misaligned operation at range [46adbe48, 46adbf48]
CACHE: Misaligned operation at range [46adbf48, 46adc048]
CACHE: Misaligned operation at range [46adc048, 46adc148]
CACHE: Misaligned operation at range [46adc148, 46adc248]
CACHE: Misaligned operation at range [46adc248, 46adc348]
CACHE: Misaligned operation at range [46adc348, 46adc448]
CACHE: Misaligned operation at range [46adc448, 46adc548]
CACHE: Misaligned operation at range [46adc548, 46adc648]
CACHE: Misaligned operation at range [46adc648, 46adc748]
CACHE: Misaligned operation at range [46adc748, 46adc848]
CACHE: Misaligned operation at range [46adc848, 46adc948]
CACHE: Misaligned operation at range [46adc948, 46adca48]
CACHE: Misaligned operation at range [46adca48, 46adcb48]
CACHE: Misaligned operation at range [46adcb48, 46adcc48]
CACHE: Misaligned operation at range [46adcc48, 46adcd48]
CACHE: Misaligned operation at range [46adcd48, 46adce48]
CACHE: Misaligned operation at range [46adce48, 46adcf48]
CACHE: Misaligned operation at range [46adcf48, 46add048]
CACHE: Misaligned operation at range [46add048, 46add148]
CACHE: Misaligned operation at range [46add148, 46add248]
CACHE: Misaligned operation at range [46add248, 46add348]
CACHE: Misaligned operation at range [46add348, 46add448]
CACHE: Misaligned operation at range [46add448, 46add548]
CACHE: Misaligned operation at range [46add548, 46add648]
CACHE: Misaligned operation at range [46add648, 46add748]
CACHE: Misaligned operation at range [46add748, 46add848]
CACHE: Misaligned operation at range [46add848, 46add948]
CACHE: Misaligned operation at range [46add948, 46adda48]
CACHE: Misaligned operation at range [46adda48, 46addb48]
CACHE: Misaligned operation at range [46addb48, 46addc48]
CACHE: Misaligned operation at range [46addc48, 46addd48]
CACHE: Misaligned operation at range [46addd48, 46adde48]
CACHE: Misaligned operation at range [46adde48, 46addf48]
CACHE: Misaligned operation at range [46addf48, 46ade048]
CACHE: Misaligned operation at range [46ade048, 46ade148]
CACHE: Misaligned operation at range [46ade148, 46ade248]
CACHE: Misaligned operation at range [46ade248, 46ade348]
CACHE: Misaligned operation at range [46ade348, 46ade448]
CACHE: Misaligned operation at range [46ade448, 46ade548]
CACHE: Misaligned operation at range [46ade548, 46ade648]
CACHE: Misaligned operation at range [46ade648, 46ade748]
CACHE: Misaligned operation at range [46ade748, 46ade848]
CACHE: Misaligned operation at range [46ade848, 46ade948]
CACHE: Misaligned operation at range [46ade948, 46adea48]
CACHE: Misaligned operation at range [46adea48, 46adeb48]
CACHE: Misaligned operation at range [46adeb48, 46adec48]
CACHE: Misaligned operation at range [46adec48, 46aded48]
CACHE: Misaligned operation at range [46aded48, 46adee48]
CACHE: Misaligned operation at range [46adee48, 46adef48]
CACHE: Misaligned operation at range [46adef48, 46adf048]
CACHE: Misaligned operation at range [46adf048, 46adf148]
CACHE: Misaligned operation at range [46adf148, 46adf248]
CACHE: Misaligned operation at range [46adf248, 46adf348]
CACHE: Misaligned operation at range [46adf348, 46adf448]
CACHE: Misaligned operation at range [46adf448, 46adf548]
CACHE: Misaligned operation at range [46adf548, 46adf648]
CACHE: Misaligned operation at range [46adf648, 46adf748]
CACHE: Misaligned operation at range [46adf748, 46adf848]
CACHE: Misaligned operation at range [46adf848, 46adf948]
CACHE: Misaligned operation at range [46adf948, 46adfa48]
CACHE: Misaligned operation at range [46adfa48, 46adfb48]
CACHE: Misaligned operation at range [46adfb48, 46adfc48]
CACHE: Misaligned operation at range [46adfc48, 46adfd48]
CACHE: Misaligned operation at range [46adfd48, 46adfe48]
CACHE: Misaligned operation at range [46adfe48, 46adff48]
CACHE: Misaligned operation at range [46adff48, 46ae0048]
CACHE: Misaligned operation at range [46ae0048, 46ae0148]
CACHE: Misaligned operation at range [46ae0148, 46ae0248]
CACHE: Misaligned operation at range [46ae0248, 46ae0348]
CACHE: Misaligned operation at range [46ae0348, 46ae0448]
CACHE: Misaligned operation at range [46ae0448, 46ae0548]
CACHE: Misaligned operation at range [46ae0548, 46ae0648]
CACHE: Misaligned operation at range [46ae0648, 46ae0748]
CACHE: Misaligned operation at range [46ae0748, 46ae0848]
CACHE: Misaligned operation at range [46ae0848, 46ae0948]
CACHE: Misaligned operation at range [46ae0948, 46ae0a48]
CACHE: Misaligned operation at range [46ae0a48, 46ae0b48]
CACHE: Misaligned operation at range [46ae0b48, 46ae0c48]
CACHE: Misaligned operation at range [46ae0c48, 46ae0d48]
CACHE: Misaligned operation at range [46ae0d48, 46ae0e48]
CACHE: Misaligned operation at range [46ae0e48, 46ae0f48]
CACHE: Misaligned operation at range [46ae0f48, 46ae1048]
CACHE: Misaligned operation at range [46ae1048, 46ae1148]
CACHE: Misaligned operation at range [46ae1148, 46ae1248]
CACHE: Misaligned operation at range [46ae1248, 46ae1348]
CACHE: Misaligned operation at range [46ae1348, 46ae1448]
CACHE: Misaligned operation at range [46ae1448, 46ae1548]
CACHE: Misaligned operation at range [46ae1548, 46ae1648]
CACHE: Misaligned operation at range [46ae1648, 46ae1748]
CACHE: Misaligned operation at range [46ae1748, 46ae1848]
CACHE: Misaligned operation at range [46ae1848, 46ae1948]
CACHE: Misaligned operation at range [46ae1948, 46ae1a48]
CACHE: Misaligned operation at range [46ae1a48, 46ae1b48]
CACHE: Misaligned operation at range [46ae1b48, 46ae1c48]
CACHE: Misaligned operation at range [46ae1c48, 46ae1d48]
CACHE: Misaligned operation at range [46ae1d48, 46ae1e48]
CACHE: Misaligned operation at range [46ae1e48, 46ae1f48]
CACHE: Misaligned operation at range [46ae1f48, 46ae2048]
CACHE: Misaligned operation at range [46ae2048, 46ae2148]
CACHE: Misaligned operation at range [46ae2148, 46ae2248]
CACHE: Misaligned operation at range [46ae2248, 46ae2348]
CACHE: Misaligned operation at range [46ae2348, 46ae2448]
CACHE: Misaligned operation at range [46ae2448, 46ae2548]
CACHE: Misaligned operation at range [46ae2548, 46ae2648]
CACHE: Misaligned operation at range [46ae2648, 46ae2748]
CACHE: Misaligned operation at range [46ae2748, 46ae2848]
CACHE: Misaligned operation at range [46ae2848, 46ae2948]
CACHE: Misaligned operation at range [46ae2948, 46ae2a48]
CACHE: Misaligned operation at range [46ae2a48, 46ae2b48]
CACHE: Misaligned operation at range [46ae2b48, 46ae2c48]
CACHE: Misaligned operation at range [46ae2c48, 46ae2d48]
CACHE: Misaligned operation at range [46ae2d48, 46ae2e48]
CACHE: Misaligned operation at range [46ae2e48, 46ae2f48]
CACHE: Misaligned operation at range [46ae2f48, 46ae3048]
CACHE: Misaligned operation at range [46ae3048, 46ae3148]
CACHE: Misaligned operation at range [46ae3148, 46ae3248]
CACHE: Misaligned operation at range [46ae3248, 46ae3348]
CACHE: Misaligned operation at range [46ae3348, 46ae3448]
CACHE: Misaligned operation at range [46ae3448, 46ae3548]
CACHE: Misaligned operation at range [46ae3548, 46ae3648]
CACHE: Misaligned operation at range [46ae3648, 46ae3748]
CACHE: Misaligned operation at range [46ae3748, 46ae3848]
CACHE: Misaligned operation at range [46ae3848, 46ae3948]
CACHE: Misaligned operation at range [46ae3948, 46ae3a48]
CACHE: Misaligned operation at range [46ae3a48, 46ae3b48]
CACHE: Misaligned operation at range [46ae3b48, 46ae3c48]
CACHE: Misaligned operation at range [46ae3c48, 46ae3d48]
CACHE: Misaligned operation at range [46ae3d48, 46ae3e48]
CACHE: Misaligned operation at range [46ae3e48, 46ae3f48]
CACHE: Misaligned operation at range [46ae3f48, 46ae4048]
CACHE: Misaligned operation at range [46ae4048, 46ae4148]
CACHE: Misaligned operation at range [46ae4148, 46ae4248]
CACHE: Misaligned operation at range [46ae4248, 46ae4348]
CACHE: Misaligned operation at range [46ae4348, 46ae4448]
CACHE: Misaligned operation at range [46ae4448, 46ae4548]
CACHE: Misaligned operation at range [46ae4548, 46ae4648]
CACHE: Misaligned operation at range [46ae4648, 46ae4748]
CACHE: Misaligned operation at range [46ae4748, 46ae4848]
CACHE: Misaligned operation at range [46ae4848, 46ae4948]
CACHE: Misaligned operation at range [46ae4948, 46ae4a48]
CACHE: Misaligned operation at range [46ae4a48, 46ae4b48]
CACHE: Misaligned operation at range [46ae4b48, 46ae4c48]
CACHE: Misaligned operation at range [46ae4c48, 46ae4d48]
CACHE: Misaligned operation at range [46ae4d48, 46ae4e48]
CACHE: Misaligned operation at range [46ae4e48, 46ae4f48]
CACHE: Misaligned operation at range [46ae4f48, 46ae5048]
CACHE: Misaligned operation at range [46ae5048, 46ae5148]
CACHE: Misaligned operation at range [46ae5148, 46ae5248]
CACHE: Misaligned operation at range [46ae5248, 46ae5348]
CACHE: Misaligned operation at range [46ae5348, 46ae5448]
CACHE: Misaligned operation at range [46ae5448, 46ae5548]
CACHE: Misaligned operation at range [46ae5548, 46ae5648]
CACHE: Misaligned operation at range [46ae5648, 46ae5748]
CACHE: Misaligned operation at range [46ae5748, 46ae5848]
CACHE: Misaligned operation at range [46ae5848, 46ae5948]
CACHE: Misaligned operation at range [46ae5948, 46ae5a48]
CACHE: Misaligned operation at range [46ae5a48, 46ae5b48]
CACHE: Misaligned operation at range [46ae5b48, 46ae5c48]
CACHE: Misaligned operation at range [46ae5c48, 46ae5d48]
CACHE: Misaligned operation at range [46ae5d48, 46ae5e48]
CACHE: Misaligned operation at range [46ae5e48, 46ae5f48]
CACHE: Misaligned operation at range [46ae5f48, 46ae6048]
CACHE: Misaligned operation at range [46ae6048, 46ae6148]
CACHE: Misaligned operation at range [46ae6148, 46ae6248]
CACHE: Misaligned operation at range [46ae6248, 46ae6348]
CACHE: Misaligned operation at range [46ae6348, 46ae6448]
CACHE: Misaligned operation at range [46ae6448, 46ae6548]
CACHE: Misaligned operation at range [46ae6548, 46ae6648]
CACHE: Misaligned operation at range [46ae6648, 46ae6748]
CACHE: Misaligned operation at range [46ae6748, 46ae6848]
CACHE: Misaligned operation at range [46ae6848, 46ae6948]
CACHE: Misaligned operation at range [46ae6948, 46ae6a48]
CACHE: Misaligned operation at range [46ae6a48, 46ae6b48]
CACHE: Misaligned operation at range [46ae6b48, 46ae6c48]
CACHE: Misaligned operation at range [46ae6c48, 46ae6d48]
CACHE: Misaligned operation at range [46ae6d48, 46ae6e48]
CACHE: Misaligned operation at range [46ae6e48, 46ae6f48]
CACHE: Misaligned operation at range [46ae6f48, 46ae7048]
CACHE: Misaligned operation at range [46ae7048, 46ae7148]
CACHE: Misaligned operation at range [46ae7148, 46ae7248]
CACHE: Misaligned operation at range [46ae7248, 46ae7348]
CACHE: Misaligned operation at range [46ae7348, 46ae7448]
CACHE: Misaligned operation at range [46ae7448, 46ae7548]
CACHE: Misaligned operation at range [46ae7548, 46ae7648]
CACHE: Misaligned operation at range [46ae7648, 46ae7748]
CACHE: Misaligned operation at range [46ae7748, 46ae7848]
CACHE: Misaligned operation at range [46ae7848, 46ae7948]
CACHE: Misaligned operation at range [46ae7948, 46ae7a48]
CACHE: Misaligned operation at range [46ae7a48, 46ae7b48]
CACHE: Misaligned operation at range [46ae7b48, 46ae7c48]
CACHE: Misaligned operation at range [46ae7c48, 46ae7d48]
CACHE: Misaligned operation at range [46ae7d48, 46ae7e48]
CACHE: Misaligned operation at range [46ae7e48, 46ae7f48]
CACHE: Misaligned operation at range [46ae7f48, 46ae8048]
CACHE: Misaligned operation at range [46ae8048, 46ae8148]
CACHE: Misaligned operation at range [46ae8148, 46ae8248]
CACHE: Misaligned operation at range [46ae8248, 46ae8348]
CACHE: Misaligned operation at range [46ae8348, 46ae8448]
CACHE: Misaligned operation at range [46ae8448, 46ae8548]
CACHE: Misaligned operation at range [46ae8548, 46ae8648]
CACHE: Misaligned operation at range [46ae8648, 46ae8748]
CACHE: Misaligned operation at range [46ae8748, 46ae8848]
CACHE: Misaligned operation at range [46ae8848, 46ae8948]
CACHE: Misaligned operation at range [46ae8948, 46ae8a48]
CACHE: Misaligned operation at range [46ae8a48, 46ae8b48]
CACHE: Misaligned operation at range [46ae8b48, 46ae8c48]
CACHE: Misaligned operation at range [46ae8c48, 46ae8d48]
CACHE: Misaligned operation at range [46ae8d48, 46ae8e48]
CACHE: Misaligned operation at range [46ae8e48, 46ae8f48]
CACHE: Misaligned operation at range [46ae8f48, 46ae9048]
CACHE: Misaligned operation at range [46ae9048, 46ae9148]
CACHE: Misaligned operation at range [46ae9148, 46ae9248]
CACHE: Misaligned operation at range [46ae9248, 46ae9348]
CACHE: Misaligned operation at range [46ae9348, 46ae9448]
CACHE: Misaligned operation at range [46ae9448, 46ae9548]
CACHE: Misaligned operation at range [46ae9548, 46ae9648]
CACHE: Misaligned operation at range [46ae9648, 46ae9748]
CACHE: Misaligned operation at range [46ae9748, 46ae9848]
CACHE: Misaligned operation at range [46ae9848, 46ae9948]
CACHE: Misaligned operation at range [46ae9948, 46ae9a48]
CACHE: Misaligned operation at range [46ae9a48, 46ae9b48]
CACHE: Misaligned operation at range [46ae9b48, 46ae9c48]
CACHE: Misaligned operation at range [46ae9c48, 46ae9d48]
CACHE: Misaligned operation at range [46ae9d48, 46ae9e48]
CACHE: Misaligned operation at range [46ae9e48, 46ae9f48]
CACHE: Misaligned operation at range [46ae9f48, 46aea048]
CACHE: Misaligned operation at range [46aea048, 46aea148]
CACHE: Misaligned operation at range [46aea148, 46aea248]
CACHE: Misaligned operation at range [46aea248, 46aea348]
CACHE: Misaligned operation at range [46aea348, 46aea448]
CACHE: Misaligned operation at range [46aea448, 46aea548]
CACHE: Misaligned operation at range [46aea548, 46aea648]
CACHE: Misaligned operation at range [46aea648, 46aea748]
CACHE: Misaligned operation at range [46aea748, 46aea848]
CACHE: Misaligned operation at range [46aea848, 46aea948]
CACHE: Misaligned operation at range [46aea948, 46aeaa48]
CACHE: Misaligned operation at range [46aeaa48, 46aeab48]
CACHE: Misaligned operation at range [46aeab48, 46aeac48]
CACHE: Misaligned operation at range [46aeac48, 46aead48]
CACHE: Misaligned operation at range [46aead48, 46aeae48]
CACHE: Misaligned operation at range [46aeae48, 46aeaf48]
CACHE: Misaligned operation at range [46aeaf48, 46aeb048]
CACHE: Misaligned operation at range [46aeb048, 46aeb148]
CACHE: Misaligned operation at range [46aeb148, 46aeb248]
CACHE: Misaligned operation at range [46aeb248, 46aeb348]
CACHE: Misaligned operation at range [46aeb348, 46aeb448]
CACHE: Misaligned operation at range [46aeb448, 46aeb548]
CACHE: Misaligned operation at range [46aeb548, 46aeb648]
CACHE: Misaligned operation at range [46aeb648, 46aeb748]
CACHE: Misaligned operation at range [46aeb748, 46aeb848]
CACHE: Misaligned operation at range [46aeb848, 46aeb948]
CACHE: Misaligned operation at range [46aeb948, 46aeba48]
CACHE: Misaligned operation at range [46aeba48, 46aebb48]
CACHE: Misaligned operation at range [46aebb48, 46aebc48]
CACHE: Misaligned operation at range [46aebc48, 46aebd48]
CACHE: Misaligned operation at range [46aebd48, 46aebe48]
CACHE: Misaligned operation at range [46aebe48, 46aebf48]
CACHE: Misaligned operation at range [46aebf48, 46aec048]
CACHE: Misaligned operation at range [46aec048, 46aec148]
CACHE: Misaligned operation at range [46aec148, 46aec248]
CACHE: Misaligned operation at range [46aec248, 46aec348]
CACHE: Misaligned operation at range [46aec348, 46aec448]
CACHE: Misaligned operation at range [46aec448, 46aec548]
CACHE: Misaligned operation at range [46aec548, 46aec648]
CACHE: Misaligned operation at range [46aec648, 46aec748]
CACHE: Misaligned operation at range [46aec748, 46aec848]
CACHE: Misaligned operation at range [46aec848, 46aec948]
CACHE: Misaligned operation at range [46aec948, 46aeca48]
CACHE: Misaligned operation at range [46aeca48, 46aecb48]
CACHE: Misaligned operation at range [46aecb48, 46aecc48]
CACHE: Misaligned operation at range [46aecc48, 46aecd48]
CACHE: Misaligned operation at range [46aecd48, 46aece48]
CACHE: Misaligned operation at range [46aece48, 46aecf48]
CACHE: Misaligned operation at range [46aecf48, 46aed048]
CACHE: Misaligned operation at range [46aed048, 46aed148]
CACHE: Misaligned operation at range [46aed148, 46aed248]
CACHE: Misaligned operation at range [46aed248, 46aed348]
CACHE: Misaligned operation at range [46aed348, 46aed448]
CACHE: Misaligned operation at range [46aed448, 46aed548]
CACHE: Misaligned operation at range [46aed548, 46aed648]
CACHE: Misaligned operation at range [46aed648, 46aed748]
CACHE: Misaligned operation at range [46aed748, 46aed848]
CACHE: Misaligned operation at range [46aed848, 46aed948]
CACHE: Misaligned operation at range [46aed948, 46aeda48]
CACHE: Misaligned operation at range [46aeda48, 46aedb48]
CACHE: Misaligned operation at range [46aedb48, 46aedc48]
CACHE: Misaligned operation at range [46aedc48, 46aedd48]
CACHE: Misaligned operation at range [46aedd48, 46aede48]
CACHE: Misaligned operation at range [46aede48, 46aedf48]
CACHE: Misaligned operation at range [46aedf48, 46aee048]
CACHE: Misaligned operation at range [46aee048, 46aee148]
CACHE: Misaligned operation at range [46aee148, 46aee248]
CACHE: Misaligned operation at range [46aee248, 46aee348]
CACHE: Misaligned operation at range [46aee348, 46aee448]
CACHE: Misaligned operation at range [46aee448, 46aee548]
CACHE: Misaligned operation at range [46aee548, 46aee648]
CACHE: Misaligned operation at range [46aee648, 46aee748]
CACHE: Misaligned operation at range [46aee748, 46aee848]
CACHE: Misaligned operation at range [46aee848, 46aee948]
CACHE: Misaligned operation at range [46aee948, 46aeea48]
CACHE: Misaligned operation at range [46aeea48, 46aeeb48]
CACHE: Misaligned operation at range [46aeeb48, 46aeec48]
CACHE: Misaligned operation at range [46aeec48, 46aeed48]
CACHE: Misaligned operation at range [46aeed48, 46aeee48]
CACHE: Misaligned operation at range [46aeee48, 46aeef48]
CACHE: Misaligned operation at range [46aeef48, 46aef048]
CACHE: Misaligned operation at range [46aef048, 46aef148]
CACHE: Misaligned operation at range [46aef148, 46aef248]
CACHE: Misaligned operation at range [46aef248, 46aef348]
CACHE: Misaligned operation at range [46aef348, 46aef448]
CACHE: Misaligned operation at range [46aef448, 46aef548]
CACHE: Misaligned operation at range [46aef548, 46aef648]
CACHE: Misaligned operation at range [46aef648, 46aef748]
CACHE: Misaligned operation at range [46aef748, 46aef848]
CACHE: Misaligned operation at range [46aef848, 46aef948]
CACHE: Misaligned operation at range [46aef948, 46aefa48]
CACHE: Misaligned operation at range [46aefa48, 46aefb48]
CACHE: Misaligned operation at range [46aefb48, 46aefc48]
CACHE: Misaligned operation at range [46aefc48, 46aefd48]
CACHE: Misaligned operation at range [46aefd48, 46aefe48]
CACHE: Misaligned operation at range [46aefe48, 46aeff48]
CACHE: Misaligned operation at range [46aeff48, 46af0048]
CACHE: Misaligned operation at range [46af0048, 46af0148]
CACHE: Misaligned operation at range [46af0148, 46af0248]
CACHE: Misaligned operation at range [46af0248, 46af0348]
CACHE: Misaligned operation at range [46af0348, 46af0448]
CACHE: Misaligned operation at range [46af0448, 46af0548]
CACHE: Misaligned operation at range [46af0548, 46af0648]
CACHE: Misaligned operation at range [46af0648, 46af0748]
CACHE: Misaligned operation at range [46af0748, 46af0848]
CACHE: Misaligned operation at range [46af0848, 46af0948]
CACHE: Misaligned operation at range [46af0948, 46af0a48]
CACHE: Misaligned operation at range [46af0a48, 46af0b48]
CACHE: Misaligned operation at range [46af0b48, 46af0c48]
CACHE: Misaligned operation at range [46af0c48, 46af0d48]
CACHE: Misaligned operation at range [46af0d48, 46af0e48]
CACHE: Misaligned operation at range [46af0e48, 46af0f48]
CACHE: Misaligned operation at range [46af0f48, 46af1048]
CACHE: Misaligned operation at range [46af1048, 46af1148]
CACHE: Misaligned operation at range [46af1148, 46af1248]
CACHE: Misaligned operation at range [46af1248, 46af1348]
CACHE: Misaligned operation at range [46af1348, 46af1448]
CACHE: Misaligned operation at range [46af1448, 46af1548]
CACHE: Misaligned operation at range [46af1548, 46af1648]
CACHE: Misaligned operation at range [46af1648, 46af1748]
CACHE: Misaligned operation at range [46af1748, 46af1848]
CACHE: Misaligned operation at range [46af1848, 46af1948]
CACHE: Misaligned operation at range [46af1948, 46af1a48]
CACHE: Misaligned operation at range [46af1a48, 46af1b48]
CACHE: Misaligned operation at range [46af1b48, 46af1c48]
CACHE: Misaligned operation at range [46af1c48, 46af1d48]
CACHE: Misaligned operation at range [46af1d48, 46af1e48]
CACHE: Misaligned operation at range [46af1e48, 46af1f48]
CACHE: Misaligned operation at range [46af1f48, 46af2048]
CACHE: Misaligned operation at range [46af2048, 46af2148]
CACHE: Misaligned operation at range [46af2148, 46af2248]
CACHE: Misaligned operation at range [46af2248, 46af2348]
CACHE: Misaligned operation at range [46af2348, 46af2448]
CACHE: Misaligned operation at range [46af2448, 46af2548]
CACHE: Misaligned operation at range [46af2548, 46af2648]
CACHE: Misaligned operation at range [46af2648, 46af2748]
CACHE: Misaligned operation at range [46af2748, 46af2848]
CACHE: Misaligned operation at range [46af2848, 46af2948]
CACHE: Misaligned operation at range [46af2948, 46af2a48]
CACHE: Misaligned operation at range [46af2a48, 46af2b48]
CACHE: Misaligned operation at range [46af2b48, 46af2c48]
CACHE: Misaligned operation at range [46af2c48, 46af2d48]
CACHE: Misaligned operation at range [46af2d48, 46af2e48]
CACHE: Misaligned operation at range [46af2e48, 46af2f48]
CACHE: Misaligned operation at range [46af2f48, 46af3048]
CACHE: Misaligned operation at range [46af3048, 46af3148]
CACHE: Misaligned operation at range [46af3148, 46af3248]
CACHE: Misaligned operation at range [46af3248, 46af3348]
CACHE: Misaligned operation at range [46af3348, 46af3448]
CACHE: Misaligned operation at range [46af3448, 46af3548]
CACHE: Misaligned operation at range [46af3548, 46af3648]
CACHE: Misaligned operation at range [46af3648, 46af3748]
CACHE: Misaligned operation at range [46af3748, 46af3848]
CACHE: Misaligned operation at range [46af3848, 46af3948]
CACHE: Misaligned operation at range [46af3948, 46af3a48]
CACHE: Misaligned operation at range [46af3a48, 46af3b48]
CACHE: Misaligned operation at range [46af3b48, 46af3c48]
CACHE: Misaligned operation at range [46af3c48, 46af3d48]
CACHE: Misaligned operation at range [46af3d48, 46af3e48]
CACHE: Misaligned operation at range [46af3e48, 46af3f48]
CACHE: Misaligned operation at range [46af3f48, 46af4048]
CACHE: Misaligned operation at range [46af4048, 46af4148]
CACHE: Misaligned operation at range [46af4148, 46af4248]
CACHE: Misaligned operation at range [46af4248, 46af4348]
CACHE: Misaligned operation at range [46af4348, 46af4448]
CACHE: Misaligned operation at range [46af4448, 46af4548]
CACHE: Misaligned operation at range [46af4548, 46af4648]
CACHE: Misaligned operation at range [46af4648, 46af4748]
CACHE: Misaligned operation at range [46af4748, 46af4848]
CACHE: Misaligned operation at range [46af4848, 46af4948]
CACHE: Misaligned operation at range [46af4948, 46af4a48]
CACHE: Misaligned operation at range [46af4a48, 46af4b48]
CACHE: Misaligned operation at range [46af4b48, 46af4c48]
CACHE: Misaligned operation at range [46af4c48, 46af4d48]
CACHE: Misaligned operation at range [46af4d48, 46af4e48]
CACHE: Misaligned operation at range [46af4e48, 46af4f48]
CACHE: Misaligned operation at range [46af4f48, 46af5048]
CACHE: Misaligned operation at range [46af5048, 46af5148]
CACHE: Misaligned operation at range [46af5148, 46af5248]
CACHE: Misaligned operation at range [46af5248, 46af5348]
CACHE: Misaligned operation at range [46af5348, 46af5448]
CACHE: Misaligned operation at range [46af5448, 46af5548]
CACHE: Misaligned operation at range [46af5548, 46af5648]
CACHE: Misaligned operation at range [46af5648, 46af5748]
CACHE: Misaligned operation at range [46af5748, 46af5848]
CACHE: Misaligned operation at range [46af5848, 46af5948]
CACHE: Misaligned operation at range [46af5948, 46af5a48]
CACHE: Misaligned operation at range [46af5a48, 46af5b48]
CACHE: Misaligned operation at range [46af5b48, 46af5c48]
CACHE: Misaligned operation at range [46af5c48, 46af5d48]
CACHE: Misaligned operation at range [46af5d48, 46af5e48]
CACHE: Misaligned operation at range [46af5e48, 46af5f48]
CACHE: Misaligned operation at range [46af5f48, 46af6048]
CACHE: Misaligned operation at range [46af6048, 46af6148]
CACHE: Misaligned operation at range [46af6148, 46af6248]
CACHE: Misaligned operation at range [46af6248, 46af6348]
CACHE: Misaligned operation at range [46af6348, 46af6448]
CACHE: Misaligned operation at range [46af6448, 46af6548]
CACHE: Misaligned operation at range [46af6548, 46af6648]
CACHE: Misaligned operation at range [46af6648, 46af6748]
CACHE: Misaligned operation at range [46af6748, 46af6848]
CACHE: Misaligned operation at range [46af6848, 46af6948]
CACHE: Misaligned operation at range [46af6948, 46af6a48]
CACHE: Misaligned operation at range [46af6a48, 46af6b48]
CACHE: Misaligned operation at range [46af6b48, 46af6c48]
CACHE: Misaligned operation at range [46af6c48, 46af6d48]
CACHE: Misaligned operation at range [46af6d48, 46af6e48]
CACHE: Misaligned operation at range [46af6e48, 46af6f48]
CACHE: Misaligned operation at range [46af6f48, 46af7048]
CACHE: Misaligned operation at range [46af7048, 46af7148]
CACHE: Misaligned operation at range [46af7148, 46af7248]
CACHE: Misaligned operation at range [46af7248, 46af7348]
CACHE: Misaligned operation at range [46af7348, 46af7448]
CACHE: Misaligned operation at range [46af7448, 46af7548]
CACHE: Misaligned operation at range [46af7548, 46af7648]
CACHE: Misaligned operation at range [46af7648, 46af7748]
CACHE: Misaligned operation at range [46af7748, 46af7848]
CACHE: Misaligned operation at range [46af7848, 46af7948]
CACHE: Misaligned operation at range [46af7948, 46af7a48]
CACHE: Misaligned operation at range [46af7a48, 46af7b48]
CACHE: Misaligned operation at range [46af7b48, 46af7c48]
CACHE: Misaligned operation at range [46af7c48, 46af7d48]
CACHE: Misaligned operation at range [46af7d48, 46af7e48]
CACHE: Misaligned operation at range [46af7e48, 46af7f48]
CACHE: Misaligned operation at range [46af7f48, 46af8048]
CACHE: Misaligned operation at range [46af8048, 46af8148]
CACHE: Misaligned operation at range [46af8148, 46af8248]
CACHE: Misaligned operation at range [46af8248, 46af8348]
CACHE: Misaligned operation at range [46af8348, 46af8448]
CACHE: Misaligned operation at range [46af8448, 46af8548]
CACHE: Misaligned operation at range [46af8548, 46af8648]
CACHE: Misaligned operation at range [46af8648, 46af8748]
CACHE: Misaligned operation at range [46af8748, 46af8848]
CACHE: Misaligned operation at range [46af8848, 46af8948]
CACHE: Misaligned operation at range [46af8948, 46af8a48]
CACHE: Misaligned operation at range [46af8a48, 46af8b48]
CACHE: Misaligned operation at range [46af8b48, 46af8c48]
CACHE: Misaligned operation at range [46af8c48, 46af8d48]
CACHE: Misaligned operation at range [46af8d48, 46af8e48]
CACHE: Misaligned operation at range [46af8e48, 46af8f48]
CACHE: Misaligned operation at range [46af8f48, 46af9048]
CACHE: Misaligned operation at range [46af9048, 46af9148]
CACHE: Misaligned operation at range [46af9148, 46af9248]
CACHE: Misaligned operation at range [46af9248, 46af9348]
CACHE: Misaligned operation at range [46af9348, 46af9448]
CACHE: Misaligned operation at range [46af9448, 46af9548]
CACHE: Misaligned operation at range [46af9548, 46af9648]
CACHE: Misaligned operation at range [46af9648, 46af9748]
CACHE: Misaligned operation at range [46af9748, 46af9848]
CACHE: Misaligned operation at range [46af9848, 46af9948]
CACHE: Misaligned operation at range [46af9948, 46af9a48]
CACHE: Misaligned operation at range [46af9a48, 46af9b48]
CACHE: Misaligned operation at range [46af9b48, 46af9c48]
CACHE: Misaligned operation at range [46af9c48, 46af9d48]
CACHE: Misaligned operation at range [46af9d48, 46af9e48]
CACHE: Misaligned operation at range [46af9e48, 46af9f48]
CACHE: Misaligned operation at range [46af9f48, 46afa048]
CACHE: Misaligned operation at range [46afa048, 46afa148]
CACHE: Misaligned operation at range [46afa148, 46afa248]
CACHE: Misaligned operation at range [46afa248, 46afa348]
CACHE: Misaligned operation at range [46afa348, 46afa448]
CACHE: Misaligned operation at range [46afa448, 46afa548]
CACHE: Misaligned operation at range [46afa548, 46afa648]
CACHE: Misaligned operation at range [46afa648, 46afa748]
CACHE: Misaligned operation at range [46afa748, 46afa848]
CACHE: Misaligned operation at range [46afa848, 46afa948]
CACHE: Misaligned operation at range [46afa948, 46afaa48]
CACHE: Misaligned operation at range [46afaa48, 46afab48]
CACHE: Misaligned operation at range [46afab48, 46afac48]
CACHE: Misaligned operation at range [46afac48, 46afad48]
CACHE: Misaligned operation at range [46afad48, 46afae48]
CACHE: Misaligned operation at range [46afae48, 46afaf48]
CACHE: Misaligned operation at range [46afaf48, 46afb048]
CACHE: Misaligned operation at range [46afb048, 46afb148]
CACHE: Misaligned operation at range [46afb148, 46afb248]
CACHE: Misaligned operation at range [46afb248, 46afb348]
CACHE: Misaligned operation at range [46afb348, 46afb448]
CACHE: Misaligned operation at range [46afb448, 46afb548]
CACHE: Misaligned operation at range [46afb548, 46afb648]
CACHE: Misaligned operation at range [46afb648, 46afb748]
CACHE: Misaligned operation at range [46afb748, 46afb848]
CACHE: Misaligned operation at range [46afb848, 46afb948]
CACHE: Misaligned operation at range [46afb948, 46afba48]
CACHE: Misaligned operation at range [46afba48, 46afbb48]
CACHE: Misaligned operation at range [46afbb48, 46afbc48]
CACHE: Misaligned operation at range [46afbc48, 46afbd48]
CACHE: Misaligned operation at range [46afbd48, 46afbe48]
CACHE: Misaligned operation at range [46afbe48, 46afbf48]
CACHE: Misaligned operation at range [46afbf48, 46afc048]
CACHE: Misaligned operation at range [46afc048, 46afc148]
CACHE: Misaligned operation at range [46afc148, 46afc248]
CACHE: Misaligned operation at range [46afc248, 46afc348]
CACHE: Misaligned operation at range [46afc348, 46afc448]
CACHE: Misaligned operation at range [46afc448, 46afc548]
CACHE: Misaligned operation at range [46afc548, 46afc648]
CACHE: Misaligned operation at range [46afc648, 46afc748]
CACHE: Misaligned operation at range [46afc748, 46afc848]
CACHE: Misaligned operation at range [46afc848, 46afc948]
CACHE: Misaligned operation at range [46afc948, 46afca48]
CACHE: Misaligned operation at range [46afca48, 46afcb48]
CACHE: Misaligned operation at range [46afcb48, 46afcc48]
CACHE: Misaligned operation at range [46afcc48, 46afcd48]
CACHE: Misaligned operation at range [46afcd48, 46afce48]
CACHE: Misaligned operation at range [46afce48, 46afcf48]
CACHE: Misaligned operation at range [46afcf48, 46afd048]
CACHE: Misaligned operation at range [46afd048, 46afd148]
CACHE: Misaligned operation at range [46afd148, 46afd248]
CACHE: Misaligned operation at range [46afd248, 46afd348]
CACHE: Misaligned operation at range [46afd348, 46afd448]
CACHE: Misaligned operation at range [46afd448, 46afd548]
CACHE: Misaligned operation at range [46afd548, 46afd648]
CACHE: Misaligned operation at range [46afd648, 46afd748]
CACHE: Misaligned operation at range [46afd748, 46afd848]
CACHE: Misaligned operation at range [46afd848, 46afd948]
CACHE: Misaligned operation at range [46afd948, 46afda48]
CACHE: Misaligned operation at range [46afda48, 46afdb48]
CACHE: Misaligned operation at range [46afdb48, 46afdc48]
CACHE: Misaligned operation at range [46afdc48, 46afdd48]
CACHE: Misaligned operation at range [46afdd48, 46afde48]
CACHE: Misaligned operation at range [46afde48, 46afdf48]
CACHE: Misaligned operation at range [46afdf48, 46afe048]
CACHE: Misaligned operation at range [46afe048, 46afe148]
CACHE: Misaligned operation at range [46afe148, 46afe248]
CACHE: Misaligned operation at range [46afe248, 46afe348]
CACHE: Misaligned operation at range [46afe348, 46afe448]
CACHE: Misaligned operation at range [46afe448, 46afe548]
CACHE: Misaligned operation at range [46afe548, 46afe648]
CACHE: Misaligned operation at range [46afe648, 46afe748]
CACHE: Misaligned operation at range [46afe748, 46afe848]
CACHE: Misaligned operation at range [46afe848, 46afe948]
CACHE: Misaligned operation at range [46afe948, 46afea48]
CACHE: Misaligned operation at range [46afea48, 46afeb48]
CACHE: Misaligned operation at range [46afeb48, 46afec48]
CACHE: Misaligned operation at range [46afec48, 46afed48]
CACHE: Misaligned operation at range [46afed48, 46afee48]
CACHE: Misaligned operation at range [46afee48, 46afef48]
CACHE: Misaligned operation at range [46afef48, 46aff048]
CACHE: Misaligned operation at range [46aff048, 46aff148]
CACHE: Misaligned operation at range [46aff148, 46aff248]
CACHE: Misaligned operation at range [46aff248, 46aff348]
CACHE: Misaligned operation at range [46aff348, 46aff448]
CACHE: Misaligned operation at range [46aff448, 46aff548]
CACHE: Misaligned operation at range [46aff548, 46aff648]
CACHE: Misaligned operation at range [46aff648, 46aff748]
CACHE: Misaligned operation at range [46aff748, 46aff848]
CACHE: Misaligned operation at range [46aff848, 46aff948]
CACHE: Misaligned operation at range [46aff948, 46affa48]
CACHE: Misaligned operation at range [46affa48, 46affb48]
CACHE: Misaligned operation at range [46affb48, 46affc48]
CACHE: Misaligned operation at range [46affc48, 46affd48]
CACHE: Misaligned operation at range [46affd48, 46affe48]
CACHE: Misaligned operation at range [46affe48, 46afff48]
CACHE: Misaligned operation at range [46afff48, 46b00048]
CACHE: Misaligned operation at range [46b00048, 46b00148]
CACHE: Misaligned operation at range [46b00148, 46b00248]
CACHE: Misaligned operation at range [46b00248, 46b00348]
CACHE: Misaligned operation at range [46b00348, 46b00448]
CACHE: Misaligned operation at range [46b00448, 46b00548]
CACHE: Misaligned operation at range [46b00548, 46b00648]
CACHE: Misaligned operation at range [46b00648, 46b00748]
CACHE: Misaligned operation at range [46b00748, 46b00848]
CACHE: Misaligned operation at range [46b00848, 46b00948]
CACHE: Misaligned operation at range [46b00948, 46b00a48]
CACHE: Misaligned operation at range [46b00a48, 46b00b48]
CACHE: Misaligned operation at range [46b00b48, 46b00c48]
CACHE: Misaligned operation at range [46b00c48, 46b00d48]
CACHE: Misaligned operation at range [46b00d48, 46b00e48]
CACHE: Misaligned operation at range [46b00e48, 46b00f48]
CACHE: Misaligned operation at range [46b00f48, 46b01048]
CACHE: Misaligned operation at range [46b01048, 46b01148]
CACHE: Misaligned operation at range [46b01148, 46b01248]
CACHE: Misaligned operation at range [46b01248, 46b01348]
CACHE: Misaligned operation at range [46b01348, 46b01448]
CACHE: Misaligned operation at range [46b01448, 46b01548]
CACHE: Misaligned operation at range [46b01548, 46b01648]
CACHE: Misaligned operation at range [46b01648, 46b01748]
CACHE: Misaligned operation at range [46b01748, 46b01848]
CACHE: Misaligned operation at range [46b01848, 46b01948]
CACHE: Misaligned operation at range [46b01948, 46b01a48]
CACHE: Misaligned operation at range [46b01a48, 46b01b48]
CACHE: Misaligned operation at range [46b01b48, 46b01c48]
CACHE: Misaligned operation at range [46b01c48, 46b01d48]
CACHE: Misaligned operation at range [46b01d48, 46b01e48]
CACHE: Misaligned operation at range [46b01e48, 46b01f48]
CACHE: Misaligned operation at range [46b01f48, 46b02048]
CACHE: Misaligned operation at range [46b02048, 46b02148]
CACHE: Misaligned operation at range [46b02148, 46b02248]
CACHE: Misaligned operation at range [46b02248, 46b02348]
CACHE: Misaligned operation at range [46b02348, 46b02448]
CACHE: Misaligned operation at range [46b02448, 46b02548]
CACHE: Misaligned operation at range [46b02548, 46b02648]
CACHE: Misaligned operation at range [46b02648, 46b02748]
CACHE: Misaligned operation at range [46b02748, 46b02848]
CACHE: Misaligned operation at range [46b02848, 46b02948]
CACHE: Misaligned operation at range [46b02948, 46b02a48]
CACHE: Misaligned operation at range [46b02a48, 46b02b48]
CACHE: Misaligned operation at range [46b02b48, 46b02c48]
CACHE: Misaligned operation at range [46b02c48, 46b02d48]
CACHE: Misaligned operation at range [46b02d48, 46b02e48]
CACHE: Misaligned operation at range [46b02e48, 46b02f48]
CACHE: Misaligned operation at range [46b02f48, 46b03048]
CACHE: Misaligned operation at range [46b03048, 46b03148]
CACHE: Misaligned operation at range [46b03148, 46b03248]
CACHE: Misaligned operation at range [46b03248, 46b03348]
CACHE: Misaligned operation at range [46b03348, 46b03448]
CACHE: Misaligned operation at range [46b03448, 46b03548]
CACHE: Misaligned operation at range [46b03548, 46b03648]
CACHE: Misaligned operation at range [46b03648, 46b03748]
CACHE: Misaligned operation at range [46b03748, 46b03848]
CACHE: Misaligned operation at range [46b03848, 46b03948]
CACHE: Misaligned operation at range [46b03948, 46b03a48]
CACHE: Misaligned operation at range [46b03a48, 46b03b48]
CACHE: Misaligned operation at range [46b03b48, 46b03c48]
CACHE: Misaligned operation at range [46b03c48, 46b03d48]
CACHE: Misaligned operation at range [46b03d48, 46b03e48]
CACHE: Misaligned operation at range [46b03e48, 46b03f48]
CACHE: Misaligned operation at range [46b03f48, 46b04048]
CACHE: Misaligned operation at range [46b04048, 46b04148]
CACHE: Misaligned operation at range [46b04148, 46b04248]
CACHE: Misaligned operation at range [46b04248, 46b04348]
CACHE: Misaligned operation at range [46b04348, 46b04448]
CACHE: Misaligned operation at range [46b04448, 46b04548]
CACHE: Misaligned operation at range [46b04548, 46b04648]
CACHE: Misaligned operation at range [46b04648, 46b04748]
CACHE: Misaligned operation at range [46b04748, 46b04848]
CACHE: Misaligned operation at range [46b04848, 46b04948]
CACHE: Misaligned operation at range [46b04948, 46b04a48]
CACHE: Misaligned operation at range [46b04a48, 46b04b48]
CACHE: Misaligned operation at range [46b04b48, 46b04c48]
CACHE: Misaligned operation at range [46b04c48, 46b04d48]
CACHE: Misaligned operation at range [46b04d48, 46b04e48]
CACHE: Misaligned operation at range [46b04e48, 46b04f48]
CACHE: Misaligned operation at range [46b04f48, 46b05048]
CACHE: Misaligned operation at range [46b05048, 46b05148]
CACHE: Misaligned operation at range [46b05148, 46b05248]
CACHE: Misaligned operation at range [46b05248, 46b05348]
CACHE: Misaligned operation at range [46b05348, 46b05448]
CACHE: Misaligned operation at range [46b05448, 46b05548]
CACHE: Misaligned operation at range [46b05548, 46b05648]
CACHE: Misaligned operation at range [46b05648, 46b05748]
CACHE: Misaligned operation at range [46b05748, 46b05848]
CACHE: Misaligned operation at range [46b05848, 46b05948]
CACHE: Misaligned operation at range [46b05948, 46b05a48]
CACHE: Misaligned operation at range [46b05a48, 46b05b48]
CACHE: Misaligned operation at range [46b05b48, 46b05c48]
CACHE: Misaligned operation at range [46b05c48, 46b05d48]
CACHE: Misaligned operation at range [46b05d48, 46b05e48]
CACHE: Misaligned operation at range [46b05e48, 46b05f48]
CACHE: Misaligned operation at range [46b05f48, 46b06048]
CACHE: Misaligned operation at range [46b06048, 46b06148]
CACHE: Misaligned operation at range [46b06148, 46b06248]
CACHE: Misaligned operation at range [46b06248, 46b06348]
CACHE: Misaligned operation at range [46b06348, 46b06448]
CACHE: Misaligned operation at range [46b06448, 46b06548]
CACHE: Misaligned operation at range [46b06548, 46b06648]
CACHE: Misaligned operation at range [46b06648, 46b06748]
CACHE: Misaligned operation at range [46b06748, 46b06848]
CACHE: Misaligned operation at range [46b06848, 46b06948]
CACHE: Misaligned operation at range [46b06948, 46b06a48]
CACHE: Misaligned operation at range [46b06a48, 46b06b48]
CACHE: Misaligned operation at range [46b06b48, 46b06c48]
CACHE: Misaligned operation at range [46b06c48, 46b06d48]
CACHE: Misaligned operation at range [46b06d48, 46b06e48]
CACHE: Misaligned operation at range [46b06e48, 46b06f48]
CACHE: Misaligned operation at range [46b06f48, 46b07048]
CACHE: Misaligned operation at range [46b07048, 46b07148]
CACHE: Misaligned operation at range [46b07148, 46b07248]
CACHE: Misaligned operation at range [46b07248, 46b07348]
CACHE: Misaligned operation at range [46b07348, 46b07448]
CACHE: Misaligned operation at range [46b07448, 46b07548]
CACHE: Misaligned operation at range [46b07548, 46b07648]
CACHE: Misaligned operation at range [46b07648, 46b07748]
CACHE: Misaligned operation at range [46b07748, 46b07848]
CACHE: Misaligned operation at range [46b07848, 46b07948]
CACHE: Misaligned operation at range [46b07948, 46b07a48]
CACHE: Misaligned operation at range [46b07a48, 46b07b48]
CACHE: Misaligned operation at range [46b07b48, 46b07c48]
CACHE: Misaligned operation at range [46b07c48, 46b07d48]
CACHE: Misaligned operation at range [46b07d48, 46b07e48]
CACHE: Misaligned operation at range [46b07e48, 46b07f48]
CACHE: Misaligned operation at range [46b07f48, 46b08048]
CACHE: Misaligned operation at range [46b08048, 46b08148]
CACHE: Misaligned operation at range [46b08148, 46b08248]
CACHE: Misaligned operation at range [46b08248, 46b08348]
CACHE: Misaligned operation at range [46b08348, 46b08448]
CACHE: Misaligned operation at range [46b08448, 46b08548]
CACHE: Misaligned operation at range [46b08548, 46b08648]
CACHE: Misaligned operation at range [46b08648, 46b08748]
CACHE: Misaligned operation at range [46b08748, 46b08848]
CACHE: Misaligned operation at range [46b08848, 46b08948]
CACHE: Misaligned operation at range [46b08948, 46b08a48]
CACHE: Misaligned operation at range [46b08a48, 46b08b48]
CACHE: Misaligned operation at range [46b08b48, 46b08c48]
CACHE: Misaligned operation at range [46b08c48, 46b08d48]
CACHE: Misaligned operation at range [46b08d48, 46b08e48]
CACHE: Misaligned operation at range [46b08e48, 46b08f48]
CACHE: Misaligned operation at range [46b08f48, 46b09048]
CACHE: Misaligned operation at range [46b09048, 46b09148]
CACHE: Misaligned operation at range [46b09148, 46b09248]
CACHE: Misaligned operation at range [46b09248, 46b09348]
CACHE: Misaligned operation at range [46b09348, 46b09448]
CACHE: Misaligned operation at range [46b09448, 46b09548]
CACHE: Misaligned operation at range [46b09548, 46b09648]
CACHE: Misaligned operation at range [46b09648, 46b09748]
CACHE: Misaligned operation at range [46b09748, 46b09848]
CACHE: Misaligned operation at range [46b09848, 46b09948]
CACHE: Misaligned operation at range [46b09948, 46b09a48]
CACHE: Misaligned operation at range [46b09a48, 46b09b48]
CACHE: Misaligned operation at range [46b09b48, 46b09c48]
CACHE: Misaligned operation at range [46b09c48, 46b09d48]
CACHE: Misaligned operation at range [46b09d48, 46b09e48]
CACHE: Misaligned operation at range [46b09e48, 46b09f48]
CACHE: Misaligned operation at range [46b09f48, 46b0a048]
CACHE: Misaligned operation at range [46b0a048, 46b0a148]
CACHE: Misaligned operation at range [46b0a148, 46b0a248]
CACHE: Misaligned operation at range [46b0a248, 46b0a348]
CACHE: Misaligned operation at range [46b0a348, 46b0a448]
CACHE: Misaligned operation at range [46b0a448, 46b0a548]
CACHE: Misaligned operation at range [46b0a548, 46b0a648]
OK
OK
[08.020]update dts
[08.023]update part info
[08.025]update bootcmd
wlan_hostwake port(5) interrupt clock set to 24Mhz
## Error: "distro_bootcmd" not defined
=>请问这个是有什么可能原因呢?目前为Tina3.5.1 SDK
