楼主 # 2023-12-27 18:19:23
leo_d1s
D1s xr829 Wi-Fi问题求助
各位大佬谁用过Melis上面那个Wi-Fi啊,
我编译成功了Wi-Fi驱动,还有应用
但是在测试的过程直接报错了
扫网直接崩溃了
msh />wifi -s
[sysinfo] mac addr source: 2
[sysinfo] random mac addr
[sysinfo] set default value
[wifi_event_init,93]:wlan init, register network observer
[wifi_event_init,102]:wifi init success!!
[wifi_on,841]:starting Station mode.
[net DBG] net_switch_mode(), mode 3 --> 0
[net DBG] net_open(), mode 0
[wlan D] wlan_attach()
[ERR:1535]xradio_load_mac_addr, 1535, '/data/xr_wifi.conf' doesn't exist, just create it!
[ERR:1483]xradio_save_mac_addr, 1483, open '/data/xr_wifi.conf' fail!
[xr_taskqueue_start_thread , 131]+-+0x40807fe0 :umac,8192
card id is 1
SD:mmc_card_create card:0x413bf518 id:1
host debug mask 18[ERR] SDC:name ???,port 7,port_num 0,mul_sel 2, pull 1, drv_level 1
[ERR] SDC:name ???,port 7,port_num 1,mul_sel 2, pull 1, drv_level 1
[ERR] SDC:name ???,port 7,port_num 2,mul_sel 2, pull 1, drv_level 1
[ERR] SDC:name ???,port 7,port_num 3,mul_sel 2, pull 1, drv_level 1
[ERR] SDC:name ???,port 7,port_num 4,mul_sel 2, pull 1, drv_level 1
[ERR] SDC:name ???,port 7,port_num 5,mul_sel 2, pull 1, drv_level 1
HAL_GetHFClock,53 Warning Use fix value 24000000
[ERR] SDC:__mci_irq_handler,903 raw_int:100 err!
[ERR] SDC:SDC err, cmd 52, RTO
[ERR] SDC:sdc 688 abnormal status: RespErr
[ERR] SDC:SDC err, cmd 8, RTO
SD:sd1.0 or mmc
SD: Try sdio
[ERR] SDC:SDC err, cmd 5, RTO
EXC_LOAD_PAGE_FAULT
