楼主 #1 2018-04-22 15:04:46
已发帖子: 9,397
ubuntu 搭建 apache php mysql 运行环境,并在服务器恢复网站数据.
ubuntu14.04 :
sudo apt-get install -y apache2
sudo apt-get install -y php5
sudo apt-get install -y mysql-server
sudo apt-get install -y php5-mysql
ubuntu16.04 :
sudo apt-get install -y php libapache2-mod-php
sudo apt-get install -y php-mysql
sudo a2enmod php7.0
sudo service apache2 restart
sudo service mysql restart
接着安装网页版mysql管理程序:
cd /var/www/html
wget https://files.phpmyadmin.net/phpMyAdmin/4.8.0.1/phpMyAdmin-4.8.0.1-all-languages.tar.gz
tar xvf phpMyAdmin-4.8.0.1-all-languages.tar.gz
mv phpMyAdmin-4.8.0.1-all-languages pma
楼主 #2 2018-04-22 18:20:00
已发帖子: 9,397
Re: ubuntu 搭建 apache php mysql 运行环境,并在服务器恢复网站数据.
安装完
之后,出现这个错误:
This PHP environment doesn't have MySQL support built in. MySQL support is required if you want to use a MySQL database to run this forum. Consult the PHP documentation for further assistance.
解决方案:
楼主 #3 2018-04-22 19:23:25
已发帖子: 9,397
接着安装网页版mysql管理程序:
cd /var/www/html
然后在浏览器输入 http://localhost/pma/
可以看到界面了:
登录:
登录进去:
新建数据库:
楼主 #4 2018-04-22 20:10:57
已发帖子: 9,397
备份数据库 命令行输入:
mysqldump -u root -p bb > _bb20180422.txt
恢复数据库 命令行输入:
mysql -u root -p bb5 < _bb20180422.txt
楼主 #5 2018-04-22 20:21:28
已发帖子: 9,397
到此位置,我们把服务器的数据恢复到本地了。
楼主 #6 2018-04-22 20:35:28
已发帖子: 9,397
使能ssl与rewrite模块:
sudo a2enmod rewrite
sudo a2enmod ssl
修改 /etc/apache2/sites-available/000-default.conf
VirtualHost 节点添加:
Options +FollowSymLinks
RewriteEngine On
#RewriteRule /phpinfo.html /phpinfo.php
#RewriteRule /6a.tar.gz    /6a.mp4
#RewriteRule /q_23.html /index.php?q-23.html
#RewriteRule /q/(\d+)\.html /index.php?q-$1.html
#RewriteRule /a/(\d+)\.html /index.php?article-$1.html
RewriteRule ^/t_(\d+)\.html /viewtopic.php?id=$1
#RewriteRule ^/p_(\d+)\.html /viewtopic.php?pid=$1
RewriteRule ^/f_(\d+)\.html /viewforum.php?id=$1
RewriteRule ^/index.php     /viewall.php?id=4
RewriteRule ^/f_(\d+)_(\d+)\.html /viewforum.php?id=$1&p=$2
RewriteRule ^/index.html /viewall.php?id=4
RewriteRule ^/index_4.html /viewall.php?id=4
RewriteRule ^/index_4_(\d+)\.html /viewall.php?id=4&p=$1
搞定重写URL
#7 2018-04-23 20:31:04
kgp0213
已发帖子: 149
厉害了,我的晕哥~~
#8 2018-04-23 20:35:31
kgp0213
已发帖子: 149
建站高手~
#9 2018-04-24 11:52:37
全栈!
#10 2018-04-25 14:38:18
xinxiaoci
已发帖子: 71
晕哥,你别学了,跟不上
#11 2018-12-27 22:33:27
全栈啊,认真跟帖学习!
#12 2019-10-28 10:25:20
我思故我在
已发帖子: 244
全栈啊,认真跟帖学习!
#13 2019-10-28 10:35:43
已发帖子: 852
晕哥在哪里买的主机,性价比怎么样
楼主 #14 2019-10-28 10:47:32
已发帖子: 9,397
搬瓦工的,带宽比阿里云/腾讯云的乞丐版好很多,共享1Gbps, 国内访问根据地域和上午下午有差异。
但是不能备案,这样就没办法国内社交软件登录了。
#15 2019-10-28 11:06:39
已发帖子: 852
可以支付宝支付吗?还是需要visa卡支付
楼主 #16 2019-10-28 11:09:14
已发帖子: 9,397
可以支付宝,paypal 付款
#17 2020-03-03 16:04:26
光头程序员
备份数据库 命令行输入:
恢复数据库 命令行输入:
补充一下,这里sql脚本创建数据库:
create database bb default character set utf8mb4 collate utf8mb4_general_ci;
sql脚本删除数据库:
drop databse bb
