楼主 # 2024-02-09 20:28:31
hech
求助,全志h3,内核6.74无法驱动fbtft st7789 134x240lcd
板子是 quark-n 稚辉君开发
原本内核4.14 lcd可以正常使用
重新移植uboot和内核
内核版本6.7.4
结果
内核加载了,但是没有显示,跪求大佬帮忙
jt
设备树
&spi0 {
	/* needed to avoid dtc warning */
	#address-cells = <1>;
	#size-cells = <0>;
	mode = <3>;
	pinctrl-names = "default";
	pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
	cs-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>, <&pio 0 6 GPIO_ACTIVE_HIGH>; /*SPI-CS:PC3 and PA6*/
	pitft: pitft@0{
		compatible = "sitronix,st7789v";
		reg = <0>;
		rotate = <0>;
		fps = <33>;
		buswidth = <8>;
		dc-gpios = <&pio 0 11 GPIO_ACTIVE_HIGH>;	 /* PA11 */
		reset-gpios = <&pio 0 12 GPIO_ACTIVE_HIGH>; /* PA12 */
		// led-gpios = <&pio 0 0 GPIO_ACTIVE_LOW>;	 /* PA0 */
		debug = <0x7>;
		init = <0x2000032
				0x1000011
				0x2000012
				0x1000011
				0x100003a 0x05
				0x10000c5 0x1a
				0x1000036 0x70
				0x10000b2 0x05 0x05 0x00 0x33 0x33
				0x10000b7 0x35
				0x10000bb 0x3f
				0x10000c0 0x2c
				0x10000c2 0xc1
				0x10000c3 0x0f
				0x10000c4 0x20
				0x10000c6 0x11
				0x10000d0 0xa4 0xa1
				0x10000e8 0x03
				0x10000e9 0x09 0x09 0x08
				0x10000e0 0xd0 0x05 0x09 0x09 0x08 0x14 0x28 0x33 0x3f 0x07 0x13 0x14 0x28 0x30
				0x10000e1 0xd0 0x05 0x08 0x09 0x08 0x03 0x24 0x32 0x32 0x3b 0x14 0x13 0x28 0x2f
				0x1000021
				0x1000011
				0x2000078
				0x1000029
				0x20000c8>;
驱动文件
drivers/staging/fbtft/fb_st7789v.c
// SPDX-License-Identifier: GPL-2.0+
 * FB driver for the ST7789V LCD Controller
 * Copyright (C) 2015 Dennis Menschel
#include <linux/bitops.h>
#include <linux/delay.h>
#include <linux/gpio/consumer.h>
#include <linux/init.h>
#include <linux/kernel.h>
#include <linux/interrupt.h>
#include <linux/completion.h>
#include <linux/module.h>
#include <video/mipi_display.h>
#include "fbtft.h"
#define DRVNAME "fb_st7789v"
#define DEFAULT_GAMMA \
	"70 2C 2E 15 10 09 48 33 53 0B 19 18 20 25\n" \
	"70 2C 2E 15 10 09 48 33 53 0B 19 18 20 25"
#define HSD20_IPS_GAMMA \
	"D0 05 0A 09 08 05 2E 44 45 0F 17 16 2B 33\n" \
	"D0 05 0A 09 08 05 2E 43 45 0F 16 16 2B 33"
#define HSD20_IPS 1
 * enum st7789v_command - ST7789V display controller commands
 * @PORCTRL: porch setting
 * @GCTRL: gate control
 * @VCOMS: VCOM setting
 * @VDVVRHEN: VDV and VRH command enable
 * @VRHS: VRH set
 * @VDVS: VDV set
 * @VCMOFSET: VCOM offset set
 * @PWCTRL1: power control 1
 * @PVGAMCTRL: positive voltage gamma control
 * @NVGAMCTRL: negative voltage gamma control
 * The command names are the same as those found in the datasheet to ease
 * looking up their semantics and usage.
 * Note that the ST7789V display controller offers quite a few more commands
 * which have been omitted from this list as they are not used at the moment.
 * Furthermore, commands that are compliant with the MIPI DCS have been left
 * out as well to avoid duplicate entries.
enum st7789v_command {
	PORCTRL = 0xB2,
	GCTRL = 0xB7,
	VCOMS = 0xBB,
	VDVVRHEN = 0xC2,
	VRHS = 0xC3,
	VDVS = 0xC4,
	VCMOFSET = 0xC5,
	PWCTRL1 = 0xD0,
	PVGAMCTRL = 0xE0,
	NVGAMCTRL = 0xE1,
#define MADCTL_BGR BIT(3) /* bitmask for RGB/BGR order */
#define MADCTL_MV BIT(5) /* bitmask for page/column order */
#define MADCTL_MX BIT(6) /* bitmask for column address order */
#define MADCTL_MY BIT(7) /* bitmask for page address order */
/* 60Hz for 16.6ms, configured as 2*16.6ms */
#define PANEL_TE_TIMEOUT_MS  33
static struct completion panel_te; /* completion for panel TE line */
static int irq_te; /* Linux IRQ for LCD TE line */
static irqreturn_t panel_te_handler(int irq, void *data)
	complete(&panel_te);
	return IRQ_HANDLED;
 * init_tearing_effect_line() - init tearing effect line.
 * @par: FBTFT parameter object.
 * Return: 0 on success, or a negative error code otherwise.
static int init_tearing_effect_line(struct fbtft_par *par)
	struct device *dev = par->info->device;
	struct gpio_desc *te;
	int rc, irq;
	te = gpiod_get_optional(dev, "te", GPIOD_IN);
	if (IS_ERR(te))
		return dev_err_probe(dev, PTR_ERR(te), "Failed to request te GPIO\n");
	/* if te is NULL, indicating no configuration, directly return success */
	if (!te) {
		irq_te = 0;
	irq = gpiod_to_irq(te);
	/* GPIO is locked as an IRQ, we may drop the reference */
	gpiod_put(te);
	if (irq < 0)
		return irq;
	irq_te = irq;
	init_completion(&panel_te);
	/* The effective state is high and lasts no more than 1000 microseconds */
	rc = devm_request_irq(dev, irq_te, panel_te_handler,
			      IRQF_TRIGGER_RISING, "TE_GPIO", par);
	if (rc)
		return dev_err_probe(dev, rc, "TE IRQ request failed.\n");
	disable_irq_nosync(irq_te);
 * init_display() - initialize the display controller
 * Most of the commands in this init function set their parameters to the
 * same default values which are already in place after the display has been
 * powered up. (The main exception to this rule is the pixel format which
 * would default to 18 instead of 16 bit per pixel.)
 * Nonetheless, this sequence can be used as a template for concrete
 * displays which usually need some adjustments.
 * Return: 0 on success, < 0 if error occurred.
static int init_display(struct fbtft_par *par)
	int rc;
	par->fbtftops.reset(par);
	rc = init_tearing_effect_line(par);
	if (rc)
		return rc;
	write_reg(par,0x3A,0x05);
	write_reg(par,0xB2,0x0C,0x0C,0x00,0x33);
	write_reg(par,0xB7,0x35);
	write_reg(par,0xBB,0x19);
	write_reg(par,0xC0,0x2C);
	write_reg(par,0xC2,0x01);
	write_reg(par,0xC3,0x12);
	write_reg(par,0xC4,0x20);
	write_reg(par,0xC6,0x0F);
	write_reg(par,0xD0,0xA4,0xA1);
	write_reg(par,0xE0,0xD0,0x04,0x0D,0x11,0x13,0x2B,0x3F,0x54,0x4C,0x18,0x0D,0x0B,0x1F,0x23);
	write_reg(par,0xE1,0xD0,0x04,0x0C,0x11,0x13,0x2C,0x3F,0x44,0x51,0x2F,0x1F,0x1F,0x20,0x23);
	write_reg(par,0x21);
	write_reg(par,0x11);
	write_reg(par,0x29);
	printk("-------------lcd-info-------------");
 * write_vmem() - write data to display.
 * @offset: offset from screen_buffer.
 * @len: the length of data to be writte.
static int write_vmem(struct fbtft_par *par, size_t offset, size_t len)
	int ret;
	if (irq_te) {
		enable_irq(irq_te);
		reinit_completion(&panel_te);
		ret = wait_for_completion_timeout(&panel_te,
						  msecs_to_jiffies(PANEL_TE_TIMEOUT_MS));
		if (ret == 0)
			dev_err(dev, "wait panel TE timeout\n");
		disable_irq(irq_te);
	switch (par->pdata->display.buswidth) {
	case 8:
		ret = fbtft_write_vmem16_bus8(par, offset, len);
		break;
	case 9:
		ret = fbtft_write_vmem16_bus9(par, offset, len);
		break;
	case 16:
		ret = fbtft_write_vmem16_bus16(par, offset, len);
		break;
	default:
		dev_err(dev, "Unsupported buswidth %d\n",
			par->pdata->display.buswidth);
		ret = 0;
		break;
	return ret;
 * set_var() - apply LCD properties like rotation and BGR mode
static int set_var(struct fbtft_par *par)
	u8 madctl_par = 0;
	if (par->bgr)
		madctl_par |= MADCTL_BGR;
	switch (par->info->var.rotate) {
	case 0:
		break;
	case 90:
		madctl_par |= (MADCTL_MV | MADCTL_MY);
		break;
	case 180:
		madctl_par |= (MADCTL_MX | MADCTL_MY);
		break;
	case 270:
		madctl_par |= (MADCTL_MV | MADCTL_MX);
		break;
	default:
		return -EINVAL;
	write_reg(par, MIPI_DCS_SET_ADDRESS_MODE, madctl_par);
 * set_gamma() - set gamma curves
 * @curves: gamma curves
 * Before the gamma curves are applied, they are preprocessed with a bitmask
 * to ensure syntactically correct input for the display controller.
 * This implies that the curves input parameter might be changed by this
 * function and that illegal gamma values are auto-corrected and not
 * reported as errors.
static int set_gamma(struct fbtft_par *par, u32 *curves)
	int i;
	int j;
	int c; /* curve index offset */
	 * Bitmasks for gamma curve command parameters.
	 * The masks are the same for both positive and negative voltage
	 * gamma curves.
	static const u8 gamma_par_mask[] = {
		0xFF, /* V63[3:0], V0[3:0]*/
		0x3F, /* V1[5:0] */
		0x3F, /* V2[5:0] */
		0x1F, /* V4[4:0] */
		0x1F, /* V6[4:0] */
		0x3F, /* J0[1:0], V13[3:0] */
		0x7F, /* V20[6:0] */
		0x77, /* V36[2:0], V27[2:0] */
		0x7F, /* V43[6:0] */
		0x3F, /* J1[1:0], V50[3:0] */
		0x1F, /* V57[4:0] */
		0x1F, /* V59[4:0] */
		0x3F, /* V61[5:0] */
		0x3F, /* V62[5:0] */
	for (i = 0; i < par->gamma.num_curves; i++) {
		c = i * par->gamma.num_values;
		for (j = 0; j < par->gamma.num_values; j++)
			curves[c + j] &= gamma_par_mask[j];
		write_reg(par, PVGAMCTRL + i,
			  curves[c + 0],  curves[c + 1],  curves[c + 2],
			  curves[c + 3],  curves[c + 4],  curves[c + 5],
			  curves[c + 6],  curves[c + 7],  curves[c + 8],
			  curves[c + 9],  curves[c + 10], curves[c + 11],
			  curves[c + 12], curves[c + 13]);
 * blank() - blank the display
 * @on: whether to enable or disable blanking the display
static int blank(struct fbtft_par *par, bool on)
	if (on)
		write_reg(par, MIPI_DCS_SET_DISPLAY_OFF);
		write_reg(par, MIPI_DCS_SET_DISPLAY_ON);
static struct fbtft_display display = {
	.regwidth = 8,
	.width = 240,
	.height = 135,
	.gamma_num = 2,
	.gamma_len = 14,
	.gamma = HSD20_IPS_GAMMA,
	.fbtftops = {
		.init_display = init_display,
		.write_vmem = write_vmem,
		.set_var = set_var,
		.set_gamma = set_gamma,
		.blank = blank,
FBTFT_REGISTER_DRIVER(DRVNAME, "sitronix,st7789v", &display);
MODULE_ALIAS("spi:" DRVNAME);
MODULE_ALIAS("platform:" DRVNAME);
MODULE_ALIAS("spi:st7789v");
MODULE_ALIAS("platform:st7789v");
MODULE_DESCRIPTION("FB driver for the ST7789V LCD Controller");
MODULE_AUTHOR("Dennis Menschel");
MODULE_LICENSE("GPL");
drivers/staging/fbtft/fbtft-core.c
 * Copyright (C) 2013 Noralf Tronnes
 * This driver is inspired by:
 *   st7735fb.c, Copyright (C) 2011, Matt Porter
 *   broadsheetfb.c, Copyright (C) 2008, Jaya Kumar
#include <linux/errno.h>
#include <linux/string.h>
#include <linux/mm.h>
#include <linux/vmalloc.h>
#include <linux/slab.h>
#include <linux/fb.h>
#include <linux/spi/spi.h>
#include <linux/uaccess.h>
#include <linux/backlight.h>
#include <linux/platform_device.h>
#include <linux/property.h>
#include <linux/spinlock.h>
#include "fbtft.h"
#include "internal.h"
static unsigned long debug;
module_param(debug, ulong, 0000);
MODULE_PARM_DESC(debug, "override device debug level");
int fbtft_write_buf_dc(struct fbtft_par *par, void *buf, size_t len, int dc)
	int ret;
	gpiod_set_value(par->gpio.dc, dc);
	ret = par->fbtftops.write(par, buf, len);
	if (ret < 0)
		dev_err(par->info->device,
			"write() failed and returned %d\n", ret);
	return ret;
EXPORT_SYMBOL(fbtft_write_buf_dc);
void fbtft_dbg_hex(const struct device *dev, int groupsize,
		   const void *buf, size_t len, const char *fmt, ...)
	va_list args;
	static char textbuf[512];
	char *text = textbuf;
	size_t text_len;
	va_start(args, fmt);
	text_len = vscnprintf(text, sizeof(textbuf), fmt, args);
	va_end(args);
	hex_dump_to_buffer(buf, len, 32, groupsize, text + text_len,
			   512 - text_len, false);
	if (len > 32)
		dev_info(dev, "%s ...\n", text);
		dev_info(dev, "%s\n", text);
EXPORT_SYMBOL(fbtft_dbg_hex);
static int fbtft_request_one_gpio(struct fbtft_par *par,
				  const char *name, int index,
				  struct gpio_desc **gpiop)
	*gpiop = devm_gpiod_get_index_optional(dev, name, index,
					       GPIOD_OUT_LOW);
	if (IS_ERR(*gpiop))
		return dev_err_probe(dev, PTR_ERR(*gpiop), "Failed to request %s GPIO\n", name);
	fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' GPIO\n",
		      __func__, name);
static int fbtft_request_gpios(struct fbtft_par *par)
	int i;
	int ret;
	ret = fbtft_request_one_gpio(par, "reset", 0, &par->gpio.reset);
	if (ret)
		return ret;
	ret = fbtft_request_one_gpio(par, "dc", 0, &par->gpio.dc);
	if (ret)
		return ret;
	ret = fbtft_request_one_gpio(par, "rd", 0, &par->gpio.rd);
	if (ret)
		return ret;
	ret = fbtft_request_one_gpio(par, "wr", 0, &par->gpio.wr);
	if (ret)
		return ret;
	ret = fbtft_request_one_gpio(par, "cs", 0, &par->gpio.cs);
	if (ret)
		return ret;
	ret = fbtft_request_one_gpio(par, "latch", 0, &par->gpio.latch);
	if (ret)
		return ret;
	for (i = 0; i < 16; i++) {
		ret = fbtft_request_one_gpio(par, "db", i,
					     &par->gpio.db[i]);
		if (ret)
			return ret;
		ret = fbtft_request_one_gpio(par, "led", i,
					     &par->gpio.led[i]);
		if (ret)
			return ret;
		ret = fbtft_request_one_gpio(par, "aux", i,
					     &par->gpio.aux[i]);
		if (ret)
			return ret;
static int fbtft_backlight_update_status(struct backlight_device *bd)
	struct fbtft_par *par = bl_get_data(bd);
	bool polarity = par->polarity;
	fbtft_par_dbg(DEBUG_BACKLIGHT, par,
		      "%s: polarity=%d, power=%d, fb_blank=%d\n",
		      __func__, polarity, bd->props.power, bd->props.fb_blank);
	if (!backlight_is_blank(bd))
		gpiod_set_value(par->gpio.led[0], polarity);
		gpiod_set_value(par->gpio.led[0], !polarity);
static int fbtft_backlight_get_brightness(struct backlight_device *bd)
	return bd->props.brightness;
void fbtft_unregister_backlight(struct fbtft_par *par)
	if (par->info->bl_dev) {
		par->info->bl_dev->props.power = FB_BLANK_POWERDOWN;
		backlight_update_status(par->info->bl_dev);
		backlight_device_unregister(par->info->bl_dev);
		par->info->bl_dev = NULL;
EXPORT_SYMBOL(fbtft_unregister_backlight);
static const struct backlight_ops fbtft_bl_ops = {
	.get_brightness	= fbtft_backlight_get_brightness,
	.update_status	= fbtft_backlight_update_status,
void fbtft_register_backlight(struct fbtft_par *par)
	struct backlight_device *bd;
	struct backlight_properties bl_props = { 0, };
	if (!par->gpio.led[0]) {
			      "%s(): led pin not set, exiting.\n", __func__);
		return;
	bl_props.type = BACKLIGHT_RAW;
	/* Assume backlight is off, get polarity from current state of pin */
	bl_props.power = FB_BLANK_POWERDOWN;
	if (!gpiod_get_value(par->gpio.led[0]))
		par->polarity = true;
	bd = backlight_device_register(dev_driver_string(par->info->device),
				       par->info->device, par,
				       &fbtft_bl_ops, &bl_props);
	if (IS_ERR(bd)) {
			"cannot register backlight device (%ld)\n",
			PTR_ERR(bd));
		return;
	par->info->bl_dev = bd;
	if (!par->fbtftops.unregister_backlight)
		par->fbtftops.unregister_backlight = fbtft_unregister_backlight;
EXPORT_SYMBOL(fbtft_register_backlight);
static void fbtft_set_addr_win(struct fbtft_par *par, int xs, int ys, int xe,
			       int ye)
	write_reg(par, MIPI_DCS_SET_COLUMN_ADDRESS,
		  (xs >> 8) & 0xFF, xs & 0xFF, (xe >> 8) & 0xFF, xe & 0xFF);
	write_reg(par, MIPI_DCS_SET_PAGE_ADDRESS,
		  (ys >> 8) & 0xFF, ys & 0xFF, (ye >> 8) & 0xFF, ye & 0xFF);
	write_reg(par, MIPI_DCS_WRITE_MEMORY_START);
static void fbtft_reset(struct fbtft_par *par)
	if (!par->gpio.reset)
		return;
	fbtft_par_dbg(DEBUG_RESET, par, "%s()\n", __func__);
	gpiod_set_value_cansleep(par->gpio.reset, 1);
	usleep_range(20, 40);
	gpiod_set_value_cansleep(par->gpio.reset, 0);
	msleep(120);
	gpiod_set_value_cansleep(par->gpio.cs, 1);  /* Activate chip */
static void fbtft_update_display(struct fbtft_par *par, unsigned int start_line,
				 unsigned int end_line)
	size_t offset, len;
	ktime_t ts_start, ts_end;
	long fps, throughput;
	bool timeit = false;
	int ret = 0;
	if (unlikely(par->debug & (DEBUG_TIME_FIRST_UPDATE |
			DEBUG_TIME_EACH_UPDATE))) {
		if ((par->debug & DEBUG_TIME_EACH_UPDATE) ||
		    ((par->debug & DEBUG_TIME_FIRST_UPDATE) &&
		    !par->first_update_done)) {
			ts_start = ktime_get();
			timeit = true;
	/* Sanity checks */
	if (start_line > end_line) {
		dev_warn(par->info->device,
			 "%s: start_line=%u is larger than end_line=%u. Shouldn't happen, will do full display update\n",
			 __func__, start_line, end_line);
		start_line = 0;
		end_line = par->info->var.yres - 1;
	if (start_line > par->info->var.yres - 1 ||
	    end_line > par->info->var.yres - 1) {
			 "%s: start_line=%u or end_line=%u is larger than max=%d. Shouldn't happen, will do full display update\n",
			 end_line, par->info->var.yres - 1);
		start_line = 0;
	fbtft_par_dbg(DEBUG_UPDATE_DISPLAY, par, "%s(start_line=%u, end_line=%u)\n",
	if (par->fbtftops.set_addr_win)
		par->fbtftops.set_addr_win(par, 0, start_line,
				par->info->var.xres - 1, end_line);
	offset = start_line * par->info->fix.line_length;
	len = (end_line - start_line + 1) * par->info->fix.line_length;
	ret = par->fbtftops.write_vmem(par, offset, len);
	if (ret < 0)
			"%s: write_vmem failed to update display buffer\n",
			__func__);
	if (unlikely(timeit)) {
		ts_end = ktime_get();
		if (!ktime_to_ns(par->update_time))
			par->update_time = ts_start;
		fps = ktime_us_delta(ts_start, par->update_time);
		fps = fps ? 1000000 / fps : 0;
		throughput = ktime_us_delta(ts_end, ts_start);
		throughput = throughput ? (len * 1000) / throughput : 0;
		throughput = throughput * 1000 / 1024;
		dev_info(par->info->device,
			 "Display update: %ld kB/s, fps=%ld\n",
			 throughput, fps);
		par->first_update_done = true;
static void fbtft_mkdirty(struct fb_info *info, int y, int height)
	struct fbtft_par *par = info->par;
	struct fb_deferred_io *fbdefio = info->fbdefio;
	/* special case, needed ? */
	if (y == -1) {
		y = 0;
		height = info->var.yres;
	/* Mark display lines/area as dirty */
	spin_lock(&par->dirty_lock);
	if (y < par->dirty_lines_start)
		par->dirty_lines_start = y;
	if (y + height - 1 > par->dirty_lines_end)
		par->dirty_lines_end = y + height - 1;
	spin_unlock(&par->dirty_lock);
	/* Schedule deferred_io to update display (no-op if already on queue)*/
	schedule_delayed_work(&info->deferred_work, fbdefio->delay);
static void fbtft_deferred_io(struct fb_info *info, struct list_head *pagereflist)
	unsigned int dirty_lines_start, dirty_lines_end;
	struct fb_deferred_io_pageref *pageref;
	unsigned int y_low = 0, y_high = 0;
	int count = 0;
	dirty_lines_start = par->dirty_lines_start;
	dirty_lines_end = par->dirty_lines_end;
	/* set display line markers as clean */
	par->dirty_lines_start = par->info->var.yres - 1;
	par->dirty_lines_end = 0;
	/* Mark display lines as dirty */
	list_for_each_entry(pageref, pagereflist, list) {
		count++;
		y_low = pageref->offset / info->fix.line_length;
		y_high = (pageref->offset + PAGE_SIZE - 1) / info->fix.line_length;
		dev_dbg(info->device,
			"page->index=%lu y_low=%d y_high=%d\n",
			pageref->page->index, y_low, y_high);
		if (y_high > info->var.yres - 1)
			y_high = info->var.yres - 1;
		if (y_low < dirty_lines_start)
			dirty_lines_start = y_low;
		if (y_high > dirty_lines_end)
			dirty_lines_end = y_high;
	par->fbtftops.update_display(info->par,
					dirty_lines_start, dirty_lines_end);
/* from pxafb.c */
static unsigned int chan_to_field(unsigned int chan, struct fb_bitfield *bf)
	chan &= 0xffff;
	chan >>= 16 - bf->length;
	return chan << bf->offset;
static int fbtft_fb_setcolreg(unsigned int regno, unsigned int red,
			      unsigned int green, unsigned int blue,
			      unsigned int transp, struct fb_info *info)
	unsigned int val;
	int ret = 1;
	dev_dbg(info->dev,
		"%s(regno=%u, red=0x%X, green=0x%X, blue=0x%X, trans=0x%X)\n",
		__func__, regno, red, green, blue, transp);
	switch (info->fix.visual) {
	case FB_VISUAL_TRUECOLOR:
		if (regno < 16) {
			u32 *pal = info->pseudo_palette;
			val  = chan_to_field(red,   &info->var.red);
			val |= chan_to_field(green, &info->var.green);
			val |= chan_to_field(blue,  &info->var.blue);
			pal[regno] = val;
			ret = 0;
		break;
	return ret;
static int fbtft_fb_blank(int blank, struct fb_info *info)
	int ret = -EINVAL;
	dev_dbg(info->dev, "%s(blank=%d)\n",
		__func__, blank);
	if (!par->fbtftops.blank)
		return ret;
	switch (blank) {
	case FB_BLANK_POWERDOWN:
	case FB_BLANK_VSYNC_SUSPEND:
	case FB_BLANK_HSYNC_SUSPEND:
	case FB_BLANK_NORMAL:
		ret = par->fbtftops.blank(par, true);
		break;
	case FB_BLANK_UNBLANK:
		ret = par->fbtftops.blank(par, false);
		break;
	return ret;
static void fbtft_ops_damage_range(struct fb_info *info, off_t off, size_t len)
	/* TODO: only mark changed area update all for now */
	par->fbtftops.mkdirty(info, -1, 0);
static void fbtft_ops_damage_area(struct fb_info *info, u32 x, u32 y, u32 width, u32 height)
	par->fbtftops.mkdirty(info, y, height);
FB_GEN_DEFAULT_DEFERRED_SYSMEM_OPS(fbtft_ops,
				   fbtft_ops_damage_range,
				   fbtft_ops_damage_area)
static const struct fb_ops fbtft_ops = {
	.owner        = THIS_MODULE,
	FB_DEFAULT_DEFERRED_OPS(fbtft_ops),
	.fb_setcolreg = fbtft_fb_setcolreg,
	.fb_blank     = fbtft_fb_blank,
static void fbtft_merge_fbtftops(struct fbtft_ops *dst, struct fbtft_ops *src)
	if (src->write)
		dst->write = src->write;
	if (src->read)
		dst->read = src->read;
	if (src->write_vmem)
		dst->write_vmem = src->write_vmem;
	if (src->write_register)
		dst->write_register = src->write_register;
	if (src->set_addr_win)
		dst->set_addr_win = src->set_addr_win;
	if (src->reset)
		dst->reset = src->reset;
	if (src->mkdirty)
		dst->mkdirty = src->mkdirty;
	if (src->update_display)
		dst->update_display = src->update_display;
	if (src->init_display)
		dst->init_display = src->init_display;
	if (src->blank)
		dst->blank = src->blank;
	if (src->request_gpios_match)
		dst->request_gpios_match = src->request_gpios_match;
	if (src->request_gpios)
		dst->request_gpios = src->request_gpios;
	if (src->verify_gpios)
		dst->verify_gpios = src->verify_gpios;
	if (src->register_backlight)
		dst->register_backlight = src->register_backlight;
	if (src->unregister_backlight)
		dst->unregister_backlight = src->unregister_backlight;
	if (src->set_var)
		dst->set_var = src->set_var;
	if (src->set_gamma)
		dst->set_gamma = src->set_gamma;
 * fbtft_framebuffer_alloc - creates a new frame buffer info structure
 * @display: pointer to structure describing the display
 * @dev: pointer to the device for this fb, this can be NULL
 * @pdata: platform data for the display in use
 * Creates a new frame buffer info structure.
 * Also creates and populates the following structures:
 *   info->fbdefio
 *   info->pseudo_palette
 *   par->fbtftops
 *   par->txbuf
 * Returns the new structure, or NULL if an error occurred.
struct fb_info *fbtft_framebuffer_alloc(struct fbtft_display *display,
					struct device *dev,
					struct fbtft_platform_data *pdata)
	struct fb_info *info;
	struct fbtft_par *par;
	struct fb_deferred_io *fbdefio = NULL;
	u8 *vmem = NULL;
	void *txbuf = NULL;
	void *buf = NULL;
	unsigned int width;
	unsigned int height;
	int txbuflen = display->txbuflen;
	unsigned int bpp = display->bpp;
	unsigned int fps = display->fps;
	int vmem_size;
	const s16 *init_sequence = display->init_sequence;
	char *gamma = display->gamma;
	u32 *gamma_curves = NULL;
	/* sanity check */
	if (display->gamma_num * display->gamma_len >
			FBTFT_GAMMA_MAX_VALUES_TOTAL) {
		dev_err(dev, "FBTFT_GAMMA_MAX_VALUES_TOTAL=%d is exceeded\n",
			FBTFT_GAMMA_MAX_VALUES_TOTAL);
		return NULL;
	/* defaults */
	if (!fps)
		fps = 20;
	if (!bpp)
		bpp = 16;
	if (!pdata) {
		dev_err(dev, "platform data is missing\n");
		return NULL;
	/* override driver values? */
	if (pdata->fps)
		fps = pdata->fps;
	if (pdata->txbuflen)
		txbuflen = pdata->txbuflen;
	if (pdata->display.init_sequence)
		init_sequence = pdata->display.init_sequence;
	if (pdata->gamma)
		gamma = pdata->gamma;
	if (pdata->display.debug)
		display->debug = pdata->display.debug;
	if (pdata->display.backlight)
		display->backlight = pdata->display.backlight;
	if (pdata->display.width)
		display->width = pdata->display.width;
	if (pdata->display.height)
		display->height = pdata->display.height;
	if (pdata->display.buswidth)
		display->buswidth = pdata->display.buswidth;
	if (pdata->display.regwidth)
		display->regwidth = pdata->display.regwidth;
	display->debug |= debug;
	fbtft_expand_debug_value(&display->debug);
	switch (pdata->rotate) {
	case 90:
	case 270:
		width =  display->height;
		height = display->width;
		break;
	default:
		width =  display->width;
		height = display->height;
	vmem_size = display->width * display->height * bpp / 8;
	vmem = vzalloc(vmem_size);
	if (!vmem)
		goto alloc_fail;
	fbdefio = devm_kzalloc(dev, sizeof(struct fb_deferred_io), GFP_KERNEL);
	if (!fbdefio)
		goto alloc_fail;
	buf = devm_kzalloc(dev, 128, GFP_KERNEL);
	if (!buf)
		goto alloc_fail;
	if (display->gamma_num && display->gamma_len) {
		gamma_curves = devm_kcalloc(dev,
					    display->gamma_len,
					    sizeof(gamma_curves[0]),
					    GFP_KERNEL);
		if (!gamma_curves)
			goto alloc_fail;
	info = framebuffer_alloc(sizeof(struct fbtft_par), dev);
	if (!info)
		goto alloc_fail;
	info->screen_buffer = vmem;
	info->fbops = &fbtft_ops;
	info->fbdefio = fbdefio;
	fbdefio->delay =            HZ / fps;
	fbdefio->sort_pagereflist = true;
	fbdefio->deferred_io =      fbtft_deferred_io;
	snprintf(info->fix.id, sizeof(info->fix.id), "%s", dev->driver->name);
	info->fix.type =           FB_TYPE_PACKED_PIXELS;
	info->fix.visual =         FB_VISUAL_TRUECOLOR;
	info->fix.xpanstep =	   0;
	info->fix.ypanstep =	   0;
	info->fix.ywrapstep =	   0;
	info->fix.line_length =    width * bpp / 8;
	info->fix.accel =          FB_ACCEL_NONE;
	info->fix.smem_len =       vmem_size;
	fb_deferred_io_init(info);
	info->var.rotate =         pdata->rotate;
	info->var.xres =           width;
	info->var.yres =           height;
	info->var.xres_virtual =   info->var.xres;
	info->var.yres_virtual =   info->var.yres;
	info->var.bits_per_pixel = bpp;
	info->var.nonstd =         1;
	/* RGB565 */
	info->var.red.offset =     11;
	info->var.red.length =     5;
	info->var.green.offset =   5;
	info->var.green.length =   6;
	info->var.blue.offset =    0;
	info->var.blue.length =    5;
	info->var.transp.offset =  0;
	info->var.transp.length =  0;
	info->flags =              FBINFO_VIRTFB;
	par = info->par;
	par->info = info;
	par->pdata = pdata;
	par->debug = display->debug;
	par->buf = buf;
	spin_lock_init(&par->dirty_lock);
	par->bgr = pdata->bgr;
	par->startbyte = pdata->startbyte;
	par->init_sequence = init_sequence;
	par->gamma.curves = gamma_curves;
	par->gamma.num_curves = display->gamma_num;
	par->gamma.num_values = display->gamma_len;
	mutex_init(&par->gamma.lock);
	info->pseudo_palette = par->pseudo_palette;
	if (par->gamma.curves && gamma) {
		if (fbtft_gamma_parse_str(par, par->gamma.curves, gamma,
					  strlen(gamma)))
			goto release_framebuf;
	/* Transmit buffer */
	if (txbuflen == -1)
		txbuflen = vmem_size + 2; /* add in case startbyte is used */
	if (txbuflen >= vmem_size + 2)
		txbuflen = 0;
#ifdef __LITTLE_ENDIAN
	if ((!txbuflen) && (bpp > 8))
		txbuflen = PAGE_SIZE; /* need buffer for byteswapping */
	if (txbuflen > 0) {
		txbuf = devm_kzalloc(par->info->device, txbuflen, GFP_KERNEL);
		if (!txbuf)
		par->txbuf.buf = txbuf;
		par->txbuf.len = txbuflen;
	/* default fbtft operations */
	par->fbtftops.write = fbtft_write_spi;
	par->fbtftops.read = fbtft_read_spi;
	par->fbtftops.write_vmem = fbtft_write_vmem16_bus8;
	par->fbtftops.write_register = fbtft_write_reg8_bus8;
	par->fbtftops.set_addr_win = fbtft_set_addr_win;
	par->fbtftops.reset = fbtft_reset;
	par->fbtftops.mkdirty = fbtft_mkdirty;
	par->fbtftops.update_display = fbtft_update_display;
	if (display->backlight)
		par->fbtftops.register_backlight = fbtft_register_backlight;
	/* use driver provided functions */
	fbtft_merge_fbtftops(&par->fbtftops, &display->fbtftops);
	return info;
release_framebuf:
	framebuffer_release(info);
alloc_fail:
	vfree(vmem);
	return NULL;
EXPORT_SYMBOL(fbtft_framebuffer_alloc);
 * fbtft_framebuffer_release - frees up all memory used by the framebuffer
 * @info: frame buffer info structure
void fbtft_framebuffer_release(struct fb_info *info)
	fb_deferred_io_cleanup(info);
	vfree(info->screen_buffer);
EXPORT_SYMBOL(fbtft_framebuffer_release);
 *	fbtft_register_framebuffer - registers a tft frame buffer device
 *	@fb_info: frame buffer info structure
 *  Sets SPI driverdata if needed
 *  Requests needed gpios.
 *  Initializes display
 *  Updates display.
 *	Registers a frame buffer device @fb_info.
 *	Returns negative errno on error, or zero for success.
int fbtft_register_framebuffer(struct fb_info *fb_info)
	int ret;
	char text1[50] = "";
	char text2[50] = "";
	struct fbtft_par *par = fb_info->par;
	struct spi_device *spi = par->spi;
	/* sanity checks */
	if (!par->fbtftops.init_display) {
		dev_err(fb_info->device, "missing fbtftops.init_display()\n");
		return -EINVAL;
	if (spi)
		spi_set_drvdata(spi, fb_info);
	if (par->pdev)
		platform_set_drvdata(par->pdev, fb_info);
	ret = par->fbtftops.request_gpios(par);
	if (ret < 0)
		goto reg_fail;
	if (par->fbtftops.verify_gpios) {
		ret = par->fbtftops.verify_gpios(par);
		if (ret < 0)
			goto reg_fail;
	ret = par->fbtftops.init_display(par);
	if (ret < 0)
		goto reg_fail;
	if (par->fbtftops.set_var) {
		ret = par->fbtftops.set_var(par);
		if (ret < 0)
			goto reg_fail;
	/* update the entire display */
	par->fbtftops.update_display(par, 0, par->info->var.yres - 1);
	if (par->fbtftops.set_gamma && par->gamma.curves) {
		ret = par->fbtftops.set_gamma(par, par->gamma.curves);
		if (ret)
			goto reg_fail;
	if (par->fbtftops.register_backlight)
		par->fbtftops.register_backlight(par);
	ret = register_framebuffer(fb_info);
	if (ret < 0)
		goto reg_fail;
	fbtft_sysfs_init(par);
	if (par->txbuf.buf && par->txbuf.len >= 1024)
		sprintf(text1, ", %zu KiB buffer memory", par->txbuf.len >> 10);
	if (spi)
		sprintf(text2, ", spi%d.%d at %d MHz", spi->master->bus_num,
			spi_get_chipselect(spi, 0), spi->max_speed_hz / 1000000);
	dev_info(fb_info->dev,
		 "%s frame buffer, %dx%d, %d KiB video memory%s, fps=%lu%s\n",
		 fb_info->fix.id, fb_info->var.xres, fb_info->var.yres,
		 fb_info->fix.smem_len >> 10, text1,
		 HZ / fb_info->fbdefio->delay, text2);
	/* Turn on backlight if available */
	if (fb_info->bl_dev) {
		fb_info->bl_dev->props.power = FB_BLANK_UNBLANK;
		fb_info->bl_dev->ops->update_status(fb_info->bl_dev);
reg_fail:
	if (par->fbtftops.unregister_backlight)
		par->fbtftops.unregister_backlight(par);
	return ret;
EXPORT_SYMBOL(fbtft_register_framebuffer);
 *	fbtft_unregister_framebuffer - releases a tft frame buffer device
 *  Frees SPI driverdata if needed
 *  Frees gpios.
 *	Unregisters frame buffer device.
int fbtft_unregister_framebuffer(struct fb_info *fb_info)
	fbtft_sysfs_exit(par);
	unregister_framebuffer(fb_info);
EXPORT_SYMBOL(fbtft_unregister_framebuffer);
 * fbtft_init_display_from_property() - Device Tree init_display() function
 * @par: Driver data
 * Return: 0 if successful, negative if error
static int fbtft_init_display_from_property(struct fbtft_par *par)
	int buf[64], count, index, i, j, ret;
	u32 *values;
	u32 val;
	count = device_property_count_u32(dev, "init");
	if (count < 0)
		return count;
	if (count == 0)
		return -EINVAL;
	values = kmalloc_array(count + 1, sizeof(*values), GFP_KERNEL);
	if (!values)
		return -ENOMEM;
	ret = device_property_read_u32_array(dev, "init", values, count);
	if (ret)
		goto out_free;
	index = -1;
	val = values[++index];
	while (index < count) {
		if (val & FBTFT_OF_INIT_CMD) {
			val &= 0xFFFF;
			i = 0;
			while ((index < count) && !(val & 0xFFFF0000)) {
				if (i > 63) {
					dev_err(dev,
						"%s: Maximum register values exceeded\n",
						__func__);
					ret = -EINVAL;
					goto out_free;
				buf[i++] = val;
			/* make debug message */
			fbtft_par_dbg(DEBUG_INIT_DISPLAY, par,
				      "init: write_register:\n");
			for (j = 0; j < i; j++)
					      "buf[%d] = %02X\n", j, buf[j]);
			par->fbtftops.write_register(par, i,
				buf[0], buf[1], buf[2], buf[3],
				buf[4], buf[5], buf[6], buf[7],
				buf[8], buf[9], buf[10], buf[11],
				buf[12], buf[13], buf[14], buf[15],
				buf[16], buf[17], buf[18], buf[19],
				buf[20], buf[21], buf[22], buf[23],
				buf[24], buf[25], buf[26], buf[27],
				buf[28], buf[29], buf[30], buf[31],
				buf[32], buf[33], buf[34], buf[35],
				buf[36], buf[37], buf[38], buf[39],
				buf[40], buf[41], buf[42], buf[43],
				buf[44], buf[45], buf[46], buf[47],
				buf[48], buf[49], buf[50], buf[51],
				buf[52], buf[53], buf[54], buf[55],
				buf[56], buf[57], buf[58], buf[59],
				buf[60], buf[61], buf[62], buf[63]);
		} else if (val & FBTFT_OF_INIT_DELAY) {
				      "init: msleep(%u)\n", val & 0xFFFF);
			msleep(val & 0xFFFF);
		} else {
			dev_err(dev, "illegal init value 0x%X\n", val);
			ret = -EINVAL;
			goto out_free;
out_free:
	kfree(values);
	return ret;
 * fbtft_init_display() - Generic init_display() function
 * @par: Driver data
 * Uses par->init_sequence to do the initialization
int fbtft_init_display(struct fbtft_par *par)
	int buf[64];
	int i;
	int j;
	/* sanity check */
	if (!par->init_sequence) {
			"error: init_sequence is not set\n");
		return -EINVAL;
	/* make sure stop marker exists */
	for (i = 0; i < FBTFT_MAX_INIT_SEQUENCE; i++) {
		if (par->init_sequence[i] == -3)
			break;
	if (i == FBTFT_MAX_INIT_SEQUENCE) {
			"missing stop marker at end of init sequence\n");
		return -EINVAL;
	i = 0;
	while (i < FBTFT_MAX_INIT_SEQUENCE) {
		if (par->init_sequence[i] == -3) {
			/* done */
		if (par->init_sequence[i] >= 0) {
				"missing delimiter at position %d\n", i);
			return -EINVAL;
		if (par->init_sequence[i + 1] < 0) {
				"missing value after delimiter %d at position %d\n",
				par->init_sequence[i], i);
			return -EINVAL;
		switch (par->init_sequence[i]) {
		case -1:
			i++;
			for (j = 0; par->init_sequence[i + 1 + j] >= 0; j++)
			fbtft_par_dbg_hex(DEBUG_INIT_DISPLAY, par, par->info->device,
					  s16, &par->init_sequence[i + 1], j,
					  "init: write(0x%02X)", par->init_sequence[i]);
			/* Write */
			j = 0;
			while (par->init_sequence[i] >= 0) {
				if (j > 63) {
						__func__);
					return -EINVAL;
				buf[j++] = par->init_sequence[i++];
			par->fbtftops.write_register(par, j,
			break;
		case -2:
			i++;
				      "init: mdelay(%d)\n",
			mdelay(par->init_sequence[i++]);
			break;
		default:
				"unknown delimiter %d at position %d\n",
			return -EINVAL;
		"%s: something is wrong. Shouldn't get here.\n", __func__);
	return -EINVAL;
EXPORT_SYMBOL(fbtft_init_display);
 * fbtft_verify_gpios() - Generic verify_gpios() function
 * @par: Driver data
 * Uses @spi, @pdev and @buswidth to determine which GPIOs is needed
static int fbtft_verify_gpios(struct fbtft_par *par)
	struct fbtft_platform_data *pdata = par->pdata;
	int i;
	fbtft_par_dbg(DEBUG_VERIFY_GPIOS, par, "%s()\n", __func__);
	if (pdata->display.buswidth != 9 &&  par->startbyte == 0 &&
	    !par->gpio.dc) {
			"Missing info about 'dc' gpio. Aborting.\n");
		return -EINVAL;
	if (!par->pdev)
	if (!par->gpio.wr) {
		dev_err(par->info->device, "Missing 'wr' gpio. Aborting.\n");
		return -EINVAL;
	for (i = 0; i < pdata->display.buswidth; i++) {
		if (!par->gpio.db[i]) {
				"Missing 'db%02d' gpio. Aborting.\n", i);
			return -EINVAL;
/* returns 0 if the property is not present */
static u32 fbtft_property_value(struct device *dev, const char *propname)
	int ret;
	u32 val = 0;
	ret = device_property_read_u32(dev, propname, &val);
	if (ret == 0)
		dev_info(dev, "%s: %s = %u\n", __func__, propname, val);
	return val;
static struct fbtft_platform_data *fbtft_properties_read(struct device *dev)
	struct fbtft_platform_data *pdata;
	if (!dev_fwnode(dev)) {
		dev_err(dev, "Missing platform data or properties\n");
		return ERR_PTR(-EINVAL);
	pdata = devm_kzalloc(dev, sizeof(*pdata), GFP_KERNEL);
	if (!pdata)
		return ERR_PTR(-ENOMEM);
	pdata->display.width = fbtft_property_value(dev, "width");
	pdata->display.height = fbtft_property_value(dev, "height");
	pdata->display.regwidth = fbtft_property_value(dev, "regwidth");
	pdata->display.buswidth = fbtft_property_value(dev, "buswidth");
	pdata->display.backlight = fbtft_property_value(dev, "backlight");
	pdata->display.bpp = fbtft_property_value(dev, "bpp");
	pdata->display.debug = fbtft_property_value(dev, "debug");
	pdata->rotate = fbtft_property_value(dev, "rotate");
	pdata->bgr = device_property_read_bool(dev, "bgr");
	pdata->fps = fbtft_property_value(dev, "fps");
	pdata->txbuflen = fbtft_property_value(dev, "txbuflen");
	pdata->startbyte = fbtft_property_value(dev, "startbyte");
	device_property_read_string(dev, "gamma", (const char **)&pdata->gamma);
	if (device_property_present(dev, "led-gpios"))
		pdata->display.backlight = 1;
	if (device_property_present(dev, "init"))
		pdata->display.fbtftops.init_display =
			fbtft_init_display_from_property;
	pdata->display.fbtftops.request_gpios = fbtft_request_gpios;
	return pdata;
 * fbtft_probe_common() - Generic device probe() helper function
 * @display: Display properties
 * @sdev: SPI device
 * @pdev: Platform device
 * Allocates, initializes and registers a framebuffer
 * Either @sdev or @pdev should be NULL
int fbtft_probe_common(struct fbtft_display *display,
		       struct spi_device *sdev,
		       struct platform_device *pdev)
	struct device *dev;
	int ret;
	if (sdev)
		dev = &sdev->dev;
		dev = &pdev->dev;
	if (unlikely(display->debug & DEBUG_DRIVER_INIT_FUNCTIONS))
		dev_info(dev, "%s()\n", __func__);
	pdata = dev->platform_data;
	if (!pdata) {
		pdata = fbtft_properties_read(dev);
		if (IS_ERR(pdata))
			return PTR_ERR(pdata);
	info = fbtft_framebuffer_alloc(display, dev, pdata);
	if (!info)
		return -ENOMEM;
	par = info->par;
	par->spi = sdev;
	par->pdev = pdev;
	if (display->buswidth == 0) {
		dev_err(dev, "buswidth is not set\n");
		return -EINVAL;
	/* write register functions */
	if (display->regwidth == 8 && display->buswidth == 8)
	else if (display->regwidth == 8 && display->buswidth == 9 && par->spi)
		par->fbtftops.write_register = fbtft_write_reg8_bus9;
	else if (display->regwidth == 16 && display->buswidth == 8)
		par->fbtftops.write_register = fbtft_write_reg16_bus8;
	else if (display->regwidth == 16 && display->buswidth == 16)
		par->fbtftops.write_register = fbtft_write_reg16_bus16;
		dev_warn(dev,
			 "no default functions for regwidth=%d and buswidth=%d\n",
			 display->regwidth, display->buswidth);
	/* write_vmem() functions */
	if (display->buswidth == 8)
	else if (display->buswidth == 9)
		par->fbtftops.write_vmem = fbtft_write_vmem16_bus9;
	else if (display->buswidth == 16)
		par->fbtftops.write_vmem = fbtft_write_vmem16_bus16;
	/* GPIO write() functions */
	if (par->pdev) {
			par->fbtftops.write = fbtft_write_gpio8_wr;
			par->fbtftops.write = fbtft_write_gpio16_wr;
	/* 9-bit SPI setup */
	if (par->spi && display->buswidth == 9) {
		if (par->spi->master->bits_per_word_mask & SPI_BPW_MASK(9)) {
			par->spi->bits_per_word = 9;
		} else {
			dev_warn(&par->spi->dev,
				 "9-bit SPI not available, emulating using 8-bit.\n");
			/* allocate buffer with room for dc bits */
			par->extra = devm_kzalloc(par->info->device,
						  par->txbuf.len +
						  (par->txbuf.len / 8) + 8,
						  GFP_KERNEL);
			if (!par->extra) {
				ret = -ENOMEM;
				goto out_release;
			par->fbtftops.write = fbtft_write_spi_emulate_9;
	if (!par->fbtftops.verify_gpios)
		par->fbtftops.verify_gpios = fbtft_verify_gpios;
	/* make sure we still use the driver provided functions */
	/* use init_sequence if provided */
	if (par->init_sequence)
		par->fbtftops.init_display = fbtft_init_display;
	/* use platform_data provided functions above all */
	fbtft_merge_fbtftops(&par->fbtftops, &pdata->display.fbtftops);
	ret = fbtft_register_framebuffer(info);
	if (ret < 0)
		goto out_release;
out_release:
	fbtft_framebuffer_release(info);
	return ret;
EXPORT_SYMBOL(fbtft_probe_common);
 * fbtft_remove_common() - Generic device remove() helper function
 * @dev: Device
 * @info: Framebuffer
 * Unregisters and releases the framebuffer
void fbtft_remove_common(struct device *dev, struct fb_info *info)
	par = info->par;
	if (par)
		fbtft_par_dbg(DEBUG_DRIVER_INIT_FUNCTIONS, par,
	fbtft_unregister_framebuffer(info);
EXPORT_SYMBOL(fbtft_remove_common);
最近编辑记录 hech (2024-02-09 20:36:57)
