f1c100s 跑linux液晶屏不显示,请问是哪里有问题,(Uboot可以显示)
U-Boot SPL 2018.01-05682-g6b6a8abcde-dirty (Feb 28 2024 - 12:27:44)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2018.01-05682-g6b6a8abcde-dirty (Feb 28 2024 - 12:27:44 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@1c25400
Out: serial@1c25400
Err: serial@1c25400
Net: No ethernet found.
No controllers found
reading zImage
5148560 bytes read in 499 ms (9.8 MiB/s)
9428 bytes read in 27 ms (340.8 KiB/s)
## Flattened Device Tree blob at 80c08000
Booting using the fdt blob at 0x80c08000
Loading Device Tree to 816fa000, end 816ff4d3 ... OK
[ 0.000000] Linux version 6.6.18 (root@LAPTOP-742J44QS) (arm-linux-gnueabi-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #15 Wed Feb 28 13:55:07 +08 2024
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x0000000083ffffff]
[ 0.000000] HighMem empty
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000083ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000083ffffff]
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Kernel command line: console=ttyS1,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw drm.debug=0x1f debug
[ 0.000000] Unknown kernel command line parameters "earlyprintk", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Memory: 51700K/65536K available (8192K kernel code, 611K rwdata, 1936K rodata, 1024K init, 258K bss, 13836K reserved, 0K cma-reserved, 0K highmem)
[ 0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000132] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000877] Console: colour dummy device 80x30
[ 0.001018] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070266] CPU: Testing write buffer coherency: ok
[ 0.070521] pid_max: default: 32768 minimum: 301
[ 0.071140] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.071216] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.078664] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.081447] devtmpfs: initialized
[ 0.089503] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.089597] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.089879] pinctrl core: initialized pinctrl subsystem
[ 0.095552] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.097542] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.100350] thermal_sys: Registered thermal governor 'step_wise'
[ 0.100478] cpuidle: using governor menu
[ 0.124986] SCSI subsystem initialized
[ 0.125392] usbcore: registered new interface driver usbfs
[ 0.125533] usbcore: registered new interface driver hub
[ 0.125714] usbcore: registered new device driver usb
[ 0.126433] pps_core: LinuxPPS API ver. 1 registered
[ 0.126465] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.126545] PTP clock support registered
[ 0.127242] Advanced Linux Sound Architecture Driver Initialized.
[ 0.132812] clocksource: Switched to clocksource timer
[ 0.184792] NET: Registered PF_INET protocol family
[ 0.185543] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.187530] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.187643] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.187691] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.187751] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.187846] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.188193] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.188286] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.188902] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.191215] RPC: Registered named UNIX socket transport module.
[ 0.191272] RPC: Registered udp transport module.
[ 0.191288] RPC: Registered tcp transport module.
[ 0.191300] RPC: Registered tcp-with-tls transport module.
[ 0.191311] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.197642] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.199789] Initialise system trusted keyrings
[ 0.201745] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.204765] NFS: Registering the id_resolver key type
[ 0.204946] Key type id_resolver registered
[ 0.204972] Key type id_legacy registered
[ 0.691538] Key type asymmetric registered
[ 0.691589] Asymmetric key parser 'x509' registered
[ 0.691926] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.691972] io scheduler mq-deadline registered
[ 0.691994] io scheduler kyber registered
[ 1.013214] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 1.027991] [drm:drm_core_init] Initialized
[ 1.028567] [drm:sun4i_drv_probe] Adding component /soc/display-backend@1e60000
[ 1.028812] [drm:sun4i_drv_probe] Adding component /soc/lcd-controller@1c0c000
[ 1.028977] [drm:sun4i_drv_traverse_endpoints] Endpoint is our panel... skipping
[ 1.041204] SCSI Media Changer driver v0.25
[ 1.044132] usbcore: registered new interface driver usb-storage
[ 1.045259] UDC core: g_cdc: couldn't find an available UDC
[ 1.045700] i2c_dev: i2c /dev entries driver
[ 1.048206] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.052525] usbcore: registered new interface driver usbhid
[ 1.052564] usbhid: USB HID core driver
[ 1.072684] NET: Registered PF_PACKET protocol family
[ 1.073155] Key type dns_resolver registered
[ 1.092494] Loading compiled-in X.509 certificates
[ 1.125626] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.139821] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 1.141988] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
[ 1.146306] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[ 1.148609] printk: console [ttyS1] disabled
[ 1.170299] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 116, base_baud = 6250000) is a 16550A
[ 1.170482] printk: console [ttyS1] enabled
[ 1.772524] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.785574] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin PE6 already requested by 1c21000.pwm; cannot claim for 1c20800.pinctrl:134
[ 1.797418] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin-134 (1c20800.pinctrl:134) status -22
[ 1.805873] panel-simple panel: error -EINVAL: failed to request GPIO
[ 1.812338] panel-simple: probe of panel failed with error -22
[ 1.825213] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.840549] usb_phy_generic usb_phy_generic.0.auto: dummy supplies not allowed for exclusive requests
[ 1.851611] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.857663] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.866267] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[ 1.882462] hub 1-0:1.0: USB hub found
[ 1.886625] hub 1-0:1.0: 1 port detected
[ 1.896229] g_cdc gadget.0: HOST MAC 36:d1:42:62:d8:5d
[ 1.901452] g_cdc gadget.0: MAC 5a:99:25:ca:1b:cb
[ 1.906515] g_cdc gadget.0: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.914300] g_cdc gadget.0: g_cdc ready
[ 1.920022] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.931130] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.940978] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.953609] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.965324] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.986692] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.999872] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 2.007372] clk: Disabling unused clocks
[ 2.011532] ALSA device list:
[ 2.014608] #0: Loopback 1
[ 2.018561] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.027337] cfg80211: failed to load regulatory.db
[ 2.033382] Waiting for root device /dev/mmcblk0p2...
[ 2.047387] mmc0: new high speed SD card at address 0007
[ 2.055279] mmcblk0: mmc0:0007 SD128 121 MiB
[ 2.066028] mmcblk0: p1 p2
[ 2.072197] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 2.107425] EXT4-fs (mmcblk0p2): mounted filesystem 8634e3c3-49ad-41b0-a0fb-f858b940c7cf r/w with ordered data mode. Quota mode: disabled.
[ 2.440109] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.449009] devtmpfs: mounted
[ 2.456446] Freeing unused kernel image (initmem) memory: 1024K
[ 2.462567] Run /sbin/init as init process
[ 2.466776] with arguments:
[ 2.469760] /sbin/init
[ 2.472470] earlyprintk
[ 2.475311] with environment:
[ 2.478460] HOME=/
[ 2.480825] TERM=linux
[ 2.759172] EXT4-fs (mmcblk0p2): re-mounted 8634e3c3-49ad-41b0-a0fb-f858b940c7cf r/w. Quota mode: disabled.
Saving 256 bits of non-creditable seed for next boot
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Starting network: OK
Welcome to Buildroot
buildroot login: [ 12.004051] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 12.014774] platform 1c0c000.lcd-controller: deferred probe pending离线
你用的是什么SDK,我开始弄亮了的
使用这个buildroot-tiny200 SDK,只需在uboot里面配置一下自己的屏幕参数即可自动点亮。
