楼主 # 2024-03-04 19:41:38
iufly
已发帖子: 22
求助,全志H6,使用香橙派3的镜像,上电卡在内核启动
下面是输出日志
U-Boot 2014.07-orangepi (Oct 13 2021 - 11:35:05) Xunlong Software
[2.066]uboot commit : b65841975dcb31f64a2c69344f60db12b98791ae
[2.066]secure enable bit: 0
[2.066]normal mode: with secure monitor
I2C:   ready
[2.068]pmbus:   ready
[2.068][ARISC] :arisc initialize
[2.094][ARISC] :arisc para ok
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :arisc version: []
[SCP] :sunxi-arisc driver v1.10 is starting
[2.107][ARISC] :sunxi-arisc driver startup succeeded
[2.108]PMU: AXP806
[2.108]PMU: AXP806 found
[2.109]bat_vol=0, ratio=0
[2.109]set pc_bias(1) bias:1800
[2.109]set pg_bias(5) bias:1800
[2.109]set power on vol to default
[2.109]dcdca_vol = 1000, onoff=1
[2.113]aldo2_vol = 3300, onoff=1
[2.117]bldo3_vol = 1800, onoff=1
[2.122]cldo2_vol = 3300, onoff=1
[2.126]cldo3_vol = 3300, onoff=1
[2.130]find power_sply to end
[2.130]cant find pll setting(1320M) from  pll table,use default(408M)
[2.132]PMU: cpux 408 Mhz,AXI=204 Mhz
[2.132]PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz MBus=400Mhz
[2.137]DRAM:  1 GiB
[2.141]fdt addr: 0x79ccb0e0
[2.141]gd->fdt_size: 0x1a6c0
[2.144]Relocation Offset is: 34d85000
[2.230]gic: sec monitor mode
[2.230]line:180 func:check_ir_boot_recovery start
[2.230]ir boot recovery not used
[2.230][key recovery] no use
[2.231][box standby] read rtc = 0x0
[2.231][box standby] start_type = 0x1
[2.231][box standby] to kernel
[2.231]workmode = 0,storage type = 1
[2.233]MMC:      2
SUNXI SD/MMC: 2
MMC init failed
[2.254]MMC:      0
SUNXI SD/MMC: 2, SUNXI SD/MMC: 0
[2.286]sunxi flash init ok
[2.286]hdmi hdcp not enable!
[2.286]display init start
[2.286]drv_disp_init
[2.303]init_clocks: finish init_clocks.
[2.322]__clk_enable: clk is null.
[2.322]hdmi cec clk enable failed!
[2.328]request pwm success, pwm1:pwm1:0x300a000.
[2.335]key emac have not been burned yet
[2.335][ac200] tv_read_sid,line:188
 [2.335]sunxi_efuse_readn failed:-1
twi_send_slave_addr error
[2.347]drv_disp_init finish
[2.347]hdmi hdcp not enable!
196 bytes read in 7 ms (27.3 KiB/s)
Set HDMI disp_mode to 1080p60
[2.360]hdmi hpd out, force open?
196 bytes read in 8 ms (23.4 KiB/s)
Set fb0_width to 1280
Set fb0_height to 720
[2.370]display init end
Using default environment
bmp_name=/boot/boot.bmp
230456 bytes read in 18 ms (12.2 MiB/s)
[2.398]show bmp on ok
[2.398]inter uboot shell
mmc0 is current device
2615 bytes read in 10 ms (254.9 KiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
102337 bytes read in 19 ms (5.1 MiB/s)
7355145 bytes read in 327 ms (21.5 MiB/s)
22476872 bytes read in 972 ms (22.1 MiB/s)
## Booting kernel from Legacy Image at 41000000 ...
   Image Name:
   Data Size:    22476808 Bytes = 21.4 MiB
   Load Address: 41000000
   Entry Point:  41000000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    7355081 Bytes = 7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Loading Kernel Image ... OK
   reserving fdt memory region: addr=40020000 size=800
   reserving fdt memory region: addr=48000000 size=1000000
   reserving fdt memory region: addr=48100000 size=4000
   reserving fdt memory region: addr=48104000 size=1000
   reserving fdt memory region: addr=48105000 size=1000
   reserving fdt memory region: addr=43000000 size=1a000
   Loading Ramdisk to 498fc000, end 49fffac9 ... OK
   Using Device Tree in place at 44000000, end 4401d6bf
INFO:    BL3-1: Next image address = 0x41000000
INFO:    BL3-1: Next image spsr = 0x3c5
卡在这里不知道是什么原因,自己画的板子,重新焊接了两遍H6感觉不像是焊接问题,原理图照抄的https://oshwhub.com/logicworld/h6_board#P6这个项目,求大佬看看是什么原因。
#2 2026-03-29 21:46:38
达芬骐
Re: 求助,全志H6,使用香橙派3的镜像,上电卡在内核启动
请问楼主解决了这个问题吗,我也遇到了这个情况,期待回复,感谢!
