楼主 # 2024-03-06 06:09:40
ming5689
licheepi zero, 为什么LCD只显示白色?
我一直试图用buildroot为licheepi zero板配置DRM库,但失败了。我在LCD上什么也看不到。
由于它变为白色,这意味着PWM正在工作,而不是DRM和framebuffer。启动时,根本没有关于C和sun4i-drm的消息。我不知道为什么,因为我在buildroot配置中打开了它们
我已经在下面发布了我的device tree和Buildroot config。我做错了什么?有人能帮我吗?谢谢
Buildroot config:
# Buildroot 2023.11 Configuration
BR2_HAVE_DOT_CONFIG=y
BR2_HOST_GCC_AT_LEAST_4_9=y
BR2_HOST_GCC_AT_LEAST_5=y
BR2_HOST_GCC_AT_LEAST_6=y
BR2_HOST_GCC_AT_LEAST_7=y
BR2_HOST_GCC_AT_LEAST_8=y
BR2_HOST_GCC_AT_LEAST_9=y
# Target options
BR2_USE_MMU=y
# BR2_arcle is not set
# BR2_arceb is not set
BR2_arm=y
# BR2_armeb is not set
# BR2_aarch64 is not set
# BR2_aarch64_be is not set
# BR2_i386 is not set
# BR2_m68k is not set
# BR2_microblazeel is not set
# BR2_microblazebe is not set
# BR2_mips is not set
# BR2_mipsel is not set
# BR2_mips64 is not set
# BR2_mips64el is not set
# BR2_nios2 is not set
# BR2_or1k is not set
# BR2_powerpc is not set
# BR2_powerpc64 is not set
# BR2_powerpc64le is not set
# BR2_riscv is not set
# BR2_s390x is not set
# BR2_sh is not set
# BR2_sparc is not set
# BR2_sparc64 is not set
# BR2_x86_64 is not set
# BR2_xtensa is not set
BR2_ARCH_HAS_TOOLCHAIN_BUILDROOT=y
BR2_ARCH="arm"
BR2_NORMALIZED_ARCH="arm"
BR2_ENDIAN="LITTLE"
BR2_GCC_TARGET_ABI="aapcs-linux"
BR2_GCC_TARGET_CPU="cortex-a7"
BR2_GCC_TARGET_FPU="vfpv4"
BR2_GCC_TARGET_FLOAT_ABI="hard"
BR2_GCC_TARGET_MODE="arm"
BR2_BINFMT_SUPPORTS_SHARED=y
BR2_READELF_ARCH_NAME="ARM"
BR2_ARM_CPU_HAS_NEON=y
BR2_ARM_CPU_HAS_FPU=y
BR2_ARM_CPU_HAS_VFPV2=y
BR2_ARM_CPU_HAS_VFPV3=y
BR2_ARM_CPU_HAS_VFPV4=y
BR2_ARM_CPU_HAS_ARM=y
BR2_ARM_CPU_HAS_THUMB2=y
BR2_ARM_CPU_ARMV7A=y
# armv4 cores
# BR2_arm920t is not set
# BR2_arm922t is not set
# BR2_fa526 is not set
# BR2_strongarm is not set
# armv5 cores
# BR2_arm926t is not set
# BR2_xscale is not set
# armv6 cores
# BR2_arm1136j_s is not set
# BR2_arm1136jf_s is not set
# BR2_arm1176jz_s is not set
# BR2_arm1176jzf_s is not set
# BR2_arm11mpcore is not set
# armv7a cores
# BR2_cortex_a5 is not set
BR2_cortex_a7=y
# BR2_cortex_a8 is not set
# BR2_cortex_a9 is not set
# BR2_cortex_a12 is not set
# BR2_cortex_a15 is not set
# BR2_cortex_a15_a7 is not set
# BR2_cortex_a17 is not set
# BR2_cortex_a17_a7 is not set
# BR2_pj4 is not set
# armv7m cores
# BR2_cortex_m3 is not set
# BR2_cortex_m4 is not set
# BR2_cortex_m7 is not set
# armv8 cores
# BR2_cortex_a32 is not set
# BR2_cortex_a35 is not set
# BR2_cortex_a53 is not set
# BR2_cortex_a57 is not set
# BR2_cortex_a57_a53 is not set
# BR2_cortex_a72 is not set
# BR2_cortex_a72_a53 is not set
# BR2_cortex_a73 is not set
# BR2_cortex_a73_a35 is not set
# BR2_cortex_a73_a53 is not set
# BR2_exynos_m1 is not set
# BR2_xgene1 is not set
# armv8.1a cores
# armv8.2a cores
# BR2_cortex_a76 is not set
# BR2_cortex_a76_a55 is not set
# BR2_neoverse_n1 is not set
# armv8.4a cores
# BR2_ARM_EABI is not set
BR2_ARM_EABIHF=y
# BR2_ARM_FPU_VFPV2 is not set
# BR2_ARM_FPU_VFPV3 is not set
# BR2_ARM_FPU_VFPV3D16 is not set
BR2_ARM_FPU_VFPV4=y
# BR2_ARM_FPU_VFPV4D16 is not set
# BR2_ARM_FPU_NEON is not set
# BR2_ARM_FPU_NEON_VFPV4 is not set
BR2_ARM_INSTRUCTIONS_ARM=y
# BR2_ARM_INSTRUCTIONS_THUMB2 is not set
BR2_BINFMT_ELF=y
# Toolchain
BR2_TOOLCHAIN=y
BR2_TOOLCHAIN_USES_GLIBC=y
BR2_TOOLCHAIN_BUILDROOT=y
# BR2_TOOLCHAIN_EXTERNAL is not set
# Toolchain Buildroot Options
BR2_TOOLCHAIN_BUILDROOT_VENDOR="buildroot"
# BR2_TOOLCHAIN_BUILDROOT_UCLIBC is not set
BR2_TOOLCHAIN_BUILDROOT_GLIBC=y
# BR2_TOOLCHAIN_BUILDROOT_MUSL is not set
BR2_TOOLCHAIN_BUILDROOT_LIBC="glibc"
# Kernel Header Options
BR2_KERNEL_HEADERS_AS_KERNEL=y
# BR2_KERNEL_HEADERS_4_14 is not set
# BR2_KERNEL_HEADERS_4_19 is not set
# BR2_KERNEL_HEADERS_5_4 is not set
# BR2_KERNEL_HEADERS_5_10 is not set
# BR2_KERNEL_HEADERS_5_15 is not set
# BR2_KERNEL_HEADERS_6_1 is not set
# BR2_KERNEL_HEADERS_6_5 is not set
# BR2_KERNEL_HEADERS_6_6 is not set
# BR2_KERNEL_HEADERS_VERSION is not set
# BR2_KERNEL_HEADERS_CUSTOM_TARBALL is not set
# BR2_KERNEL_HEADERS_CUSTOM_GIT is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_6_6 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_6_5 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_6_4 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_6_3 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_6_2 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_6_1 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_6_0 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_19 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_18 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_17 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_16 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_15 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_14 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_13 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_12 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_11 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_10 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_9 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_8 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_7 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_6 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_5 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_4 is not set
BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_3=y
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_2 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_1 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_5_0 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_20 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_19 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_18 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_17 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_16 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_15 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_14 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_13 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_12 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_11 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_10 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_9 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_8 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_7 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_6 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_5 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_4 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_3 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_2 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_1 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_4_0 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_19 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_18 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_17 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_16 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_15 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_14 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_13 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_12 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_11 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_10 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_9 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_8 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_7 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_6 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_5 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_4 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_3 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_2 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_1 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_3_0 is not set
# BR2_PACKAGE_HOST_LINUX_HEADERS_CUSTOM_REALLY_OLD is not set
BR2_PACKAGE_LINUX_HEADERS=y
BR2_PACKAGE_MUSL_ARCH_SUPPORTS=y
BR2_PACKAGE_MUSL_SUPPORTS=y
BR2_PACKAGE_UCLIBC_ARCH_SUPPORTS=y
BR2_PACKAGE_UCLIBC_SUPPORTS=y
BR2_PACKAGE_GLIBC_ARCH_SUPPORTS=y
BR2_PACKAGE_GLIBC_SUPPORTS=y
# Glibc Options
BR2_PACKAGE_GLIBC=y
# BR2_PACKAGE_GLIBC_KERNEL_COMPAT is not set
# BR2_PACKAGE_GLIBC_UTILS is not set
# Binutils Options
BR2_PACKAGE_HOST_BINUTILS_SUPPORTS_CFI=y
# BR2_BINUTILS_VERSION_2_39_X is not set
BR2_BINUTILS_VERSION_2_40_X=y
# BR2_BINUTILS_VERSION_2_41_X is not set
BR2_BINUTILS_VERSION="2.40"
# BR2_BINUTILS_GPROFNG is not set
BR2_BINUTILS_EXTRA_CONFIG_OPTIONS=""
# GCC Options
# BR2_GCC_VERSION_11_X is not set
BR2_GCC_VERSION_12_X=y
# BR2_GCC_VERSION_13_X is not set
BR2_GCC_VERSION="12.3.0"
BR2_EXTRA_GCC_CONFIG_OPTIONS=""
# BR2_TOOLCHAIN_BUILDROOT_CXX is not set
# BR2_TOOLCHAIN_BUILDROOT_FORTRAN is not set
# BR2_GCC_ENABLE_OPENMP is not set
# BR2_GCC_ENABLE_GRAPHITE is not set
BR2_PACKAGE_GCC_FINAL=y
BR2_PACKAGE_HOST_GDB_ARCH_SUPPORTS=y
# Host GDB Options
# BR2_PACKAGE_HOST_GDB is not set
# Toolchain Generic Options
BR2_TOOLCHAIN_SUPPORTS_ALWAYS_LOCKFREE_ATOMIC_INTS=y
BR2_TOOLCHAIN_SUPPORTS_VARIADIC_MI_THUNK=y
BR2_USE_WCHAR=y
BR2_ENABLE_LOCALE=y
BR2_TOOLCHAIN_HAS_THREADS=y
BR2_TOOLCHAIN_HAS_THREADS_DEBUG=y
BR2_TOOLCHAIN_HAS_THREADS_NPTL=y
BR2_TOOLCHAIN_HAS_SSP=y
BR2_TOOLCHAIN_HAS_SSP_STRONG=y
BR2_TOOLCHAIN_HAS_UCONTEXT=y
BR2_TOOLCHAIN_SUPPORTS_PIE=y
# BR2_TOOLCHAIN_GLIBC_GCONV_LIBS_COPY is not set
BR2_TOOLCHAIN_EXTRA_LIBS=""
BR2_TOOLCHAIN_HAS_FULL_GETTEXT=y
BR2_TARGET_OPTIMIZATION=""
BR2_TARGET_LDFLAGS=""
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_7=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_8=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_9=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_10=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_11=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_12=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_13=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_14=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_15=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_16=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_17=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_18=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_19=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_7=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_8=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_9=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_10=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_11=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_12=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_13=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_14=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_15=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_16=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_17=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_18=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_19=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_20=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_5_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST="5.3"
BR2_TOOLCHAIN_GCC_AT_LEAST_4_3=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_4=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_7=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_8=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_9=y
BR2_TOOLCHAIN_GCC_AT_LEAST_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST_7=y
BR2_TOOLCHAIN_GCC_AT_LEAST_8=y
BR2_TOOLCHAIN_GCC_AT_LEAST_9=y
BR2_TOOLCHAIN_GCC_AT_LEAST_10=y
BR2_TOOLCHAIN_GCC_AT_LEAST_11=y
BR2_TOOLCHAIN_GCC_AT_LEAST_12=y
BR2_TOOLCHAIN_GCC_AT_LEAST="12"
BR2_TOOLCHAIN_HAS_MNAN_OPTION=y
BR2_TOOLCHAIN_HAS_SYNC_1=y
BR2_TOOLCHAIN_HAS_SYNC_2=y
BR2_TOOLCHAIN_HAS_SYNC_4=y
BR2_TOOLCHAIN_ARM_HAS_SYNC_8=y
BR2_TOOLCHAIN_HAS_SYNC_8=y
BR2_TOOLCHAIN_HAS_LIBATOMIC=y
BR2_TOOLCHAIN_HAS_ATOMIC=y
# Build options
# Commands
BR2_WGET="wget --passive-ftp -nd -t 3"
BR2_SVN="svn --non-interactive"
BR2_BZR="bzr"
BR2_GIT="git"
BR2_CVS="cvs"
BR2_LOCALFILES="cp"
BR2_SCP="scp"
BR2_SFTP="sftp"
BR2_HG="hg"
BR2_ZCAT="gzip -d -c"
BR2_BZCAT="bzcat"
BR2_XZCAT="xzcat"
BR2_LZCAT="lzip -d -c"
BR2_TAR_OPTIONS=""
BR2_DEFCONFIG="/home/alireza/Documents/buildroot-2023.11_Orange/configs/sipeed_licheepi_zero_defconfig"
BR2_DL_DIR="$(TOPDIR)/dl"
BR2_HOST_DIR="$(BASE_DIR)/host"
# Mirrors and Download locations
BR2_PRIMARY_SITE=""
BR2_BACKUP_SITE="https://sources.buildroot.net"
BR2_KERNEL_MIRROR="https://cdn.kernel.org/pub"
BR2_GNU_MIRROR="http://ftpmirror.gnu.org"
BR2_LUAROCKS_MIRROR="http://rocks.moonscript.org"
BR2_CPAN_MIRROR="https://cpan.metacpan.org"
BR2_JLEVEL=0
# BR2_CCACHE is not set
# BR2_ENABLE_DEBUG is not set
# BR2_ENABLE_RUNTIME_DEBUG is not set
BR2_STRIP_strip=y
BR2_STRIP_EXCLUDE_FILES=""
BR2_STRIP_EXCLUDE_DIRS=""
# BR2_OPTIMIZE_0 is not set
# BR2_OPTIMIZE_1 is not set
# BR2_OPTIMIZE_2 is not set
# BR2_OPTIMIZE_3 is not set
# BR2_OPTIMIZE_G is not set
BR2_OPTIMIZE_S=y
# BR2_OPTIMIZE_FAST is not set
# BR2_ENABLE_LTO is not set
# static only needs a toolchain w/ uclibc or musl
BR2_SHARED_LIBS=y
# BR2_SHARED_STATIC_LIBS is not set
BR2_PACKAGE_OVERRIDE_FILE="$(CONFIG_DIR)/local.mk"
BR2_GLOBAL_PATCH_DIR=""
# Advanced
# BR2_FORCE_HOST_BUILD is not set
# Forcing all downloads to have a valid hash needs a global patch and hash directory
# BR2_REPRODUCIBLE is not set
# BR2_PER_PACKAGE_DIRECTORIES is not set
# BR2_TIME_BITS_64 is not set
# Security Hardening Options
BR2_PIC_PIE_ARCH_SUPPORTS=y
BR2_PIC_PIE=y
# BR2_SSP_NONE is not set
# BR2_SSP_REGULAR is not set
BR2_SSP_STRONG=y
# BR2_SSP_ALL is not set
BR2_SSP_OPTION="-fstack-protector-strong"
# BR2_RELRO_NONE is not set
# BR2_RELRO_PARTIAL is not set
BR2_RELRO_FULL=y
BR2_FORTIFY_SOURCE_ARCH_SUPPORTS=y
# BR2_FORTIFY_SOURCE_NONE is not set
BR2_FORTIFY_SOURCE_1=y
# BR2_FORTIFY_SOURCE_2 is not set
# BR2_FORTIFY_SOURCE_3 is not set
# System configuration
BR2_ROOTFS_SKELETON_DEFAULT=y
# BR2_ROOTFS_SKELETON_CUSTOM is not set
BR2_TARGET_GENERIC_HOSTNAME="licheepi-zero"
BR2_TARGET_GENERIC_ISSUE="Welcome to Buildroot for the LicheePi Zero"
BR2_TARGET_GENERIC_PASSWD_SHA256=y
# BR2_TARGET_GENERIC_PASSWD_SHA512 is not set
BR2_TARGET_GENERIC_PASSWD_METHOD="sha-256"
BR2_INIT_BUSYBOX=y
# BR2_INIT_SYSV is not set
# BR2_INIT_OPENRC is not set
# BR2_INIT_SYSTEMD is not set
# BR2_INIT_NONE is not set
# BR2_ROOTFS_DEVICE_CREATION_STATIC is not set
BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_DEVTMPFS=y
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_MDEV is not set
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV is not set
BR2_ROOTFS_DEVICE_TABLE="system/device_table.txt"
# BR2_ROOTFS_DEVICE_TABLE_SUPPORTS_EXTENDED_ATTRIBUTES is not set
# BR2_ROOTFS_MERGED_USR is not set
BR2_TARGET_ENABLE_ROOT_LOGIN=y
BR2_TARGET_GENERIC_ROOT_PASSWD=""
BR2_SYSTEM_BIN_SH_BUSYBOX=y
# bash, dash, mksh, zsh need BR2_PACKAGE_BUSYBOX_SHOW_OTHERS
# BR2_SYSTEM_BIN_SH_NONE is not set
BR2_TARGET_GENERIC_GETTY=y
BR2_TARGET_GENERIC_GETTY_PORT="ttyS0"
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_KEEP is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_9600 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_19200 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_38400 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_57600 is not set
BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200=y
BR2_TARGET_GENERIC_GETTY_BAUDRATE="115200"
BR2_TARGET_GENERIC_GETTY_TERM="vt100"
BR2_TARGET_GENERIC_GETTY_OPTIONS=""
BR2_TARGET_GENERIC_REMOUNT_ROOTFS_RW=y
BR2_SYSTEM_DHCP=""
BR2_SYSTEM_DEFAULT_PATH="/bin:/sbin:/usr/bin:/usr/sbin"
BR2_ENABLE_LOCALE_PURGE=y
BR2_ENABLE_LOCALE_WHITELIST="C en_US"
BR2_GENERATE_LOCALE=""
# BR2_SYSTEM_ENABLE_NLS is not set
# BR2_TARGET_TZ_INFO is not set
BR2_ROOTFS_USERS_TABLES=""
BR2_ROOTFS_OVERLAY=""
BR2_ROOTFS_PRE_BUILD_SCRIPT=""
BR2_ROOTFS_POST_BUILD_SCRIPT=""
BR2_ROOTFS_POST_FAKEROOT_SCRIPT=""
BR2_ROOTFS_POST_IMAGE_SCRIPT="support/scripts/genimage.sh"
BR2_ROOTFS_POST_SCRIPT_ARGS="-c board/sipeed/licheepi_zero/genimage.cfg"
# Kernel
BR2_LINUX_KERNEL=y
# BR2_LINUX_KERNEL_LATEST_VERSION is not set
# BR2_LINUX_KERNEL_LATEST_CIP_VERSION is not set
# BR2_LINUX_KERNEL_LATEST_CIP_RT_VERSION is not set
BR2_LINUX_KERNEL_CUSTOM_VERSION=y
# BR2_LINUX_KERNEL_CUSTOM_TARBALL is not set
# BR2_LINUX_KERNEL_CUSTOM_GIT is not set
# BR2_LINUX_KERNEL_CUSTOM_HG is not set
# BR2_LINUX_KERNEL_CUSTOM_SVN is not set
BR2_LINUX_KERNEL_CUSTOM_VERSION_VALUE="5.3.5"
BR2_LINUX_KERNEL_VERSION="5.3.5"
BR2_LINUX_KERNEL_PATCH=""
BR2_LINUX_KERNEL_USE_DEFCONFIG=y
# BR2_LINUX_KERNEL_USE_ARCH_DEFAULT_CONFIG is not set
# BR2_LINUX_KERNEL_USE_CUSTOM_CONFIG is not set
BR2_LINUX_KERNEL_DEFCONFIG="sunxi"
BR2_LINUX_KERNEL_CONFIG_FRAGMENT_FILES=""
BR2_LINUX_KERNEL_CUSTOM_LOGO_PATH=""
# BR2_LINUX_KERNEL_UIMAGE is not set
# BR2_LINUX_KERNEL_APPENDED_UIMAGE is not set
BR2_LINUX_KERNEL_ZIMAGE=y
# BR2_LINUX_KERNEL_APPENDED_ZIMAGE is not set
# BR2_LINUX_KERNEL_VMLINUX is not set
# BR2_LINUX_KERNEL_IMAGE_TARGET_CUSTOM is not set
BR2_LINUX_KERNEL_GZIP=y
# BR2_LINUX_KERNEL_LZ4 is not set
# BR2_LINUX_KERNEL_LZMA is not set
# BR2_LINUX_KERNEL_LZO is not set
# BR2_LINUX_KERNEL_XZ is not set
# BR2_LINUX_KERNEL_ZSTD is not set
BR2_LINUX_KERNEL_DTS_SUPPORT=y
# BR2_LINUX_KERNEL_DTB_IS_SELF_BUILT is not set
BR2_LINUX_KERNEL_INTREE_DTS_NAME="sun8i-v3s-licheepi-zero sun8i-v3s-licheepi-zero-dock"
BR2_LINUX_KERNEL_CUSTOM_DTS_PATH=""
# BR2_LINUX_KERNEL_DTB_KEEP_DIRNAME is not set
# BR2_LINUX_KERNEL_DTB_OVERLAY_SUPPORT is not set
# BR2_LINUX_KERNEL_INSTALL_TARGET is not set
# BR2_LINUX_KERNEL_NEEDS_HOST_OPENSSL is not set
# BR2_LINUX_KERNEL_NEEDS_HOST_LIBELF is not set
# BR2_LINUX_KERNEL_NEEDS_HOST_PAHOLE is not set
# Linux Kernel Extensions
# BR2_LINUX_KERNEL_EXT_XENOMAI is not set
# BR2_LINUX_KERNEL_EXT_RTAI is not set
# BR2_LINUX_KERNEL_EXT_EV3DEV_LINUX_DRIVERS is not set
# BR2_LINUX_KERNEL_EXT_FBTFT is not set
# BR2_LINUX_KERNEL_EXT_AUFS is not set
# Linux Kernel Tools
# BR2_PACKAGE_LINUX_TOOLS_CPUPOWER is not set
# BR2_PACKAGE_LINUX_TOOLS_GPIO is not set
# BR2_PACKAGE_LINUX_TOOLS_IIO is not set
# BR2_PACKAGE_LINUX_TOOLS_PCI is not set
# BR2_PACKAGE_LINUX_TOOLS_PERF is not set
# selftests needs BR2_PACKAGE_BUSYBOX_SHOW_OTHERS and a toolchain w/ dynamic library and headers >= 3.14
# BR2_PACKAGE_LINUX_TOOLS_USBTOOLS is not set
# BR2_PACKAGE_LINUX_TOOLS_TMON is not set
# Target packages
BR2_PACKAGE_BUSYBOX=y
BR2_PACKAGE_BUSYBOX_CONFIG="package/busybox/busybox.config"
BR2_PACKAGE_BUSYBOX_CONFIG_FRAGMENT_FILES=""
# BR2_PACKAGE_BUSYBOX_SHOW_OTHERS is not set
# BR2_PACKAGE_BUSYBOX_INDIVIDUAL_BINARIES is not set
# BR2_PACKAGE_BUSYBOX_WATCHDOG is not set
BR2_PACKAGE_SKELETON=y
BR2_PACKAGE_HAS_SKELETON=y
BR2_PACKAGE_PROVIDES_SKELETON="skeleton-init-sysv"
BR2_PACKAGE_SKELETON_INIT_COMMON=y
BR2_PACKAGE_SKELETON_INIT_SYSV=y
# Audio and video applications
# BR2_PACKAGE_ALSA_UTILS is not set
# BR2_PACKAGE_ATEST is not set
# BR2_PACKAGE_AUMIX is not set
# BR2_PACKAGE_BLUEZ_ALSA is not set
# BR2_PACKAGE_DVBLAST is not set
# BR2_PACKAGE_DVDAUTHOR is not set
# dvdrw-tools needs a toolchain w/ threads, C++, wchar
# espeak needs a toolchain w/ C++, wchar, threads, dynamic library
# BR2_PACKAGE_FAAD2 is not set
BR2_PACKAGE_FFMPEG_ARCH_SUPPORTS=y
# BR2_PACKAGE_FFMPEG is not set
# BR2_PACKAGE_FLAC is not set
# BR2_PACKAGE_FLITE is not set
# BR2_PACKAGE_FLUID_SOUNDFONT is not set
# fluidsynth needs a toolchain w/ threads, wchar, dynamic library, C++
# BR2_PACKAGE_GMRENDER_RESURRECT is not set
# BR2_PACKAGE_GSTREAMER1 is not set
# BR2_PACKAGE_JACK1 is not set
# jack2 needs a toolchain w/ threads, C++, dynamic library
BR2_PACKAGE_KODI_ARCH_SUPPORTS=y
# kodi needs python3 w/ .py modules, a uClibc or glibc toolchain w/ C++, threads, wchar, dynamic library, gcc >= 9.x
# kodi needs udev support for gbm
# kodi needs an OpenGL EGL backend with OpenGL or GLES support
# BR2_PACKAGE_LAME is not set
# BR2_PACKAGE_MADPLAY is not set
# BR2_PACKAGE_MIMIC is not set
# BR2_PACKAGE_MINIMODEM is not set
# miraclecast needs systemd and a glibc toolchain w/ threads and wchar
# mjpegtools needs a toolchain w/ C++, threads
# modplugtools needs a toolchain w/ C++
# BR2_PACKAGE_MOTION is not set
# mpd needs a toolchain w/ C++, threads, wchar, gcc >= 8, host gcc >= 8
# BR2_PACKAGE_MPD_MPC is not set
# BR2_PACKAGE_MPG123 is not set
# mpv needs a toolchain w/ C++, NPTL, gcc >= 4.9
# BR2_PACKAGE_MULTICAT is not set
# BR2_PACKAGE_MUSEPACK is not set
# ncmpc needs a toolchain w/ C++, wchar, threads, gcc >= 10
# omxplayer needs rpi-userland and a toolchain w/ C++, threads, wchar, dynamic library, gcc >= 4.9
# BR2_PACKAGE_OPUS_TOOLS is not set
# BR2_PACKAGE_PIPEWIRE is not set
BR2_PACKAGE_PULSEAUDIO_HAS_ATOMIC=y
# BR2_PACKAGE_PULSEAUDIO is not set
# BR2_PACKAGE_SOX is not set
# BR2_PACKAGE_SPEECHD is not set
# BR2_PACKAGE_SQUEEZELITE is not set
# BR2_PACKAGE_TINYCOMPRESS is not set
# BR2_PACKAGE_TSTOOLS is not set
# BR2_PACKAGE_TWOLAME is not set
# BR2_PACKAGE_UDPXY is not set
# upmpdcli needs a toolchain w/ C++, NPTL, gcc >= 4.9
# v4l2grab needs a toolchain w/ threads, dynamic library, C++ and headers >= 3.0
# BR2_PACKAGE_V4L2LOOPBACK is not set
# vlc needs a toolchain w/ C++, dynamic library, wchar, threads, gcc >= 4.9, headers >= 3.7
# BR2_PACKAGE_VORBIS_TOOLS is not set
# BR2_PACKAGE_WAVPACK is not set
# BR2_PACKAGE_YAVTA is not set
# BR2_PACKAGE_YMPD is not set
# zynaddsubfx needs a toolchain w/ C++11 and threads
# Compressors and decompressors
# BR2_PACKAGE_BROTLI is not set
# BR2_PACKAGE_BZIP2 is not set
# lrzip needs a toolchain w/ wchar, threads, C++
# lzip needs a toolchain w/ C++
# BR2_PACKAGE_LZOP is not set
# p7zip needs a toolchain w/ threads, wchar, C++
# BR2_PACKAGE_PIGZ is not set
# BR2_PACKAGE_PIXZ is not set
# unrar needs a toolchain w/ C++, wchar, threads, gcc >= 4.8
# BR2_PACKAGE_XZ is not set
# BR2_PACKAGE_ZIP is not set
# BR2_PACKAGE_ZSTD is not set
# Debugging, profiling and benchmark
# BR2_PACKAGE_BABELTRACE2 is not set
# BR2_PACKAGE_BLKTRACE is not set
# bonnie++ needs a toolchain w/ C++
BR2_PACKAGE_BPFTOOL_ARCH_SUPPORTS=y
# BR2_PACKAGE_BPFTOOL is not set
# BR2_PACKAGE_CACHE_CALIBRATOR is not set
# clinfo needs an OpenCL provider
# clpeak needs an OpenCL provider, a toolchain w/ C++, gcc >= 4.8
# BR2_PACKAGE_COREMARK is not set
# BR2_PACKAGE_COREMARK_PRO is not set
# dacapo needs OpenJDK
# BR2_PACKAGE_DHRYSTONE is not set
# BR2_PACKAGE_DIEHARDER is not set
# BR2_PACKAGE_DMALLOC is not set
# BR2_PACKAGE_DROPWATCH is not set
# BR2_PACKAGE_DSTAT is not set
# BR2_PACKAGE_DT is not set
# duma needs a toolchain w/ C++, threads, dynamic library
# BR2_PACKAGE_FIO is not set
BR2_PACKAGE_FWTS_ARCH_SUPPORTS=y
# BR2_PACKAGE_FWTS is not set
BR2_PACKAGE_GDB_ARCH_SUPPORTS=y
# gdb/gdbserver >= 8.x needs a toolchain w/ C++, gcc >= 4.8
BR2_PACKAGE_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y
# google-breakpad requires a glibc or uClibc toolchain w/ wchar, thread, C++, gcc >= 4.8
# BR2_PACKAGE_HYPERFINE is not set
# BR2_PACKAGE_IOZONE is not set
BR2_PACKAGE_KEXEC_ARCH_SUPPORTS=y
# BR2_PACKAGE_KEXEC is not set
BR2_PACKAGE_KVM_UNIT_TESTS_ARCH_SUPPORTS=y
# BR2_PACKAGE_KVM_UNIT_TESTS is not set
# BR2_PACKAGE_LATENCYTOP is not set
# BR2_PACKAGE_LIBBPF is not set
# BR2_PACKAGE_LMBENCH is not set
BR2_PACKAGE_LTP_TESTSUITE_ARCH_SUPPORTS=y
# BR2_PACKAGE_LTP_TESTSUITE is not set
BR2_PACKAGE_LTRACE_ARCH_SUPPORTS=y
# BR2_PACKAGE_LTRACE is not set
# BR2_PACKAGE_LTTNG_BABELTRACE is not set
# BR2_PACKAGE_LTTNG_MODULES is not set
# lttng-tools needs a toolchain w/ threads, dynamic library, C++
# BR2_PACKAGE_MBPOLL is not set
# BR2_PACKAGE_MBW is not set
# BR2_PACKAGE_MEMSTAT is not set
# BR2_PACKAGE_NETPERF is not set
# netsniff-ng needs a toolchain w/ NPTL, C++, headers >= 3.0
# BR2_PACKAGE_NMON is not set
BR2_PACKAGE_OPROFILE_ARCH_SUPPORTS=y
# oprofile needs a toolchain w/ C++, wchar
# BR2_PACKAGE_PAX_UTILS is not set
BR2_PACKAGE_PERFTEST_ARCH_SUPPORTS=y
# BR2_PACKAGE_PERFTEST is not set
# piglit needs a glibc or musl toolchain w/ C++, gcc >= 9, host gcc >= 9
BR2_PACKAGE_PLY_ARCH_SUPPORTS=y
# ply needs a toolchain w/ dynamic library, headers >= 5.5
# BR2_PACKAGE_POKE is not set
BR2_PACKAGE_PTM2HUMAN_ARCH_SUPPORTS=y
# BR2_PACKAGE_PTM2HUMAN is not set
# BR2_PACKAGE_PV is not set
# BR2_PACKAGE_RAMSMP is not set
# BR2_PACKAGE_RAMSPEED is not set
# BR2_PACKAGE_RT_TESTS is not set
# rwmem needs a toolchain w/ C++, wchar, gcc >= 10
# sentry-native needs a glibc toolchain with w/ wchar, thread, C++, gcc >= 4.8
# signal-estimator needs a toochain w/ C++, threads, gcc >= 7
# BR2_PACKAGE_SPIDEV_TEST is not set
# BR2_PACKAGE_STRACE is not set
# BR2_PACKAGE_STRESS is not set
# BR2_PACKAGE_STRESS_NG is not set
# sysdig needs a glibc toolchain w/ C++, threads, gcc >= 5, dynamic library, a Linux kernel, and luajit or lua 5.1 to be built
# BR2_PACKAGE_TCF_AGENT is not set
BR2_PACKAGE_TCF_AGENT_ARCH="arm"
BR2_PACKAGE_TCF_AGENT_ARCH_SUPPORTS=y
# BR2_PACKAGE_TINYMEMBENCH is not set
# BR2_PACKAGE_TRACE_CMD is not set
BR2_PACKAGE_TRINITY_ARCH_SUPPORTS=y
# BR2_PACKAGE_TRINITY is not set
# BR2_PACKAGE_UCLIBC_NG_TEST is not set
BR2_PACKAGE_UFTRACE_ARCH_SUPPORTS=y
# BR2_PACKAGE_UFTRACE is not set
BR2_PACKAGE_VALGRIND_ARCH_SUPPORTS=y
# BR2_PACKAGE_VALGRIND is not set
# BR2_PACKAGE_VMTOUCH is not set
# BR2_PACKAGE_WHETSTONE is not set
# Development tools
# BR2_PACKAGE_AVOCADO is not set
# BR2_PACKAGE_BINUTILS is not set
# BR2_PACKAGE_BITWISE is not set
# BR2_PACKAGE_BSDIFF is not set
# BR2_PACKAGE_CHECK is not set
BR2_PACKAGE_CMAKE_ARCH_SUPPORTS=y
# ctest needs a toolchain w/ C++, wchar, dynamic library, gcc >= 4.9, NPTL
# cppunit needs a toolchain w/ C++, dynamic library
# BR2_PACKAGE_CUKINIA is not set
# BR2_PACKAGE_CUNIT is not set
# BR2_PACKAGE_CVS is not set
# cxxtest needs a toolchain w/ C++ support
# BR2_PACKAGE_FLEX is not set
# BR2_PACKAGE_GETTEXT is not set
BR2_PACKAGE_PROVIDES_HOST_GETTEXT="host-gettext-tiny"
# BR2_PACKAGE_GIT is not set
# git-crypt needs a toolchain w/ C++, gcc >= 4.9
# gperf needs a toolchain w/ C++
# BR2_PACKAGE_JO is not set
# BR2_PACKAGE_JQ is not set
# BR2_PACKAGE_LIBTOOL is not set
# BR2_PACKAGE_MAKE is not set
# BR2_PACKAGE_MAWK is not set
# BR2_PACKAGE_PKGCONF is not set
# BR2_PACKAGE_RIPGREP is not set
# BR2_PACKAGE_SUBVERSION is not set
# BR2_PACKAGE_TREE is not set
# BR2_PACKAGE_UNIFDEF is not set
# Filesystem and flash utilities
# BR2_PACKAGE_ABOOTIMG is not set
# BR2_PACKAGE_AUFS_UTIL is not set
# BR2_PACKAGE_AUTOFS is not set
# BR2_PACKAGE_BTRFS_PROGS is not set
# BR2_PACKAGE_CIFS_UTILS is not set
# BR2_PACKAGE_CPIO is not set
# BR2_PACKAGE_CRAMFS is not set
# BR2_PACKAGE_CURLFTPFS is not set
# BR2_PACKAGE_DAVFS2 is not set
# BR2_PACKAGE_DOSFSTOOLS is not set
# BR2_PACKAGE_DUST is not set
# BR2_PACKAGE_E2FSPROGS is not set
# BR2_PACKAGE_E2TOOLS is not set
# BR2_PACKAGE_ECRYPTFS_UTILS is not set
# BR2_PACKAGE_EROFS_UTILS is not set
# BR2_PACKAGE_EXFAT is not set
# BR2_PACKAGE_EXFAT_UTILS is not set
# BR2_PACKAGE_EXFATPROGS is not set
# BR2_PACKAGE_F2FS_TOOLS is not set
# BR2_PACKAGE_FIRMWARE_UTILS is not set
# BR2_PACKAGE_FLASHBENCH is not set
# BR2_PACKAGE_FSCRYPTCTL is not set
# BR2_PACKAGE_FUSE_OVERLAYFS is not set
# BR2_PACKAGE_FWUP is not set
# BR2_PACKAGE_GENEXT2FS is not set
# BR2_PACKAGE_GENPART is not set
# BR2_PACKAGE_GENROMFS is not set
# BR2_PACKAGE_GOCRYPTFS is not set
# BR2_PACKAGE_IMX_USB_LOADER is not set
# BR2_PACKAGE_MMC_UTILS is not set
# BR2_PACKAGE_MTD is not set
# BR2_PACKAGE_MTOOLS is not set
# BR2_PACKAGE_NFS_UTILS is not set
# BR2_PACKAGE_NILFS_UTILS is not set
# BR2_PACKAGE_NTFS_3G is not set
# BR2_PACKAGE_SP_OOPS_EXTRACT is not set
# BR2_PACKAGE_SQUASHFS is not set
# BR2_PACKAGE_SSHFS is not set
# BR2_PACKAGE_SUNXI_TOOLS is not set
# BR2_PACKAGE_UDFTOOLS is not set
# BR2_PACKAGE_UNIONFS is not set
# xfsprogs needs a toolchain w/ threads, C++
# BR2_PACKAGE_ZEROFREE is not set
# zfs needs udev /dev management
# Fonts, cursors, icons, sounds and themes
# Cursors
# BR2_PACKAGE_COMIX_CURSORS is not set
# BR2_PACKAGE_OBSIDIAN_CURSORS is not set
# Fonts
# BR2_PACKAGE_BITSTREAM_VERA is not set
# BR2_PACKAGE_CANTARELL is not set
# BR2_PACKAGE_DEJAVU is not set
# BR2_PACKAGE_FONT_AWESOME is not set
# BR2_PACKAGE_GHOSTSCRIPT_FONTS is not set
# BR2_PACKAGE_INCONSOLATA is not set
# BR2_PACKAGE_LIBERATION is not set
# BR2_PACKAGE_WQY_ZENHEI is not set
# Icons
# BR2_PACKAGE_HICOLOR_ICON_THEME is not set
# Sounds
# BR2_PACKAGE_SOUND_THEME_BOREALIS is not set
# BR2_PACKAGE_SOUND_THEME_FREEDESKTOP is not set
# Themes
# Games
# BR2_PACKAGE_ASCII_INVADERS is not set
# BR2_PACKAGE_CHOCOLATE_DOOM is not set
# flare-engine needs a toolchain w/ C++, dynamic library
# BR2_PACKAGE_FROTZ is not set
# gnuchess needs a toolchain w/ C++, threads
# BR2_PACKAGE_LBREAKOUT2 is not set
# BR2_PACKAGE_LTRIS is not set
# minetest needs a toolchain w/ C++, gcc >= 5.1, threads
# BR2_PACKAGE_OPENTYRIAN is not set
# BR2_PACKAGE_PRBOOM is not set
# BR2_PACKAGE_SL is not set
# solarus needs OpenGL and a toolchain w/ C++, gcc >= 4.9, NPTL, dynamic library, and luajit or lua 5.1
# stella needs a toolchain w/ dynamic library, C++, threads, gcc >= 7
# BR2_PACKAGE_XORCURSES is not set
# Graphic libraries and applications (graphic/text)
# Graphic applications
# cage needs udev, EGL w/ Wayland backend and OpenGL ES support
# cog needs wpewebkit and a toolchain w/ threads
# BR2_PACKAGE_FSWEBCAM is not set
# BR2_PACKAGE_GHOSTSCRIPT is not set
# glmark2 needs a toolchain w/ C++, gcc >= 4.9
# glslsandbox-player needs openGL ES and EGL driver
# BR2_PACKAGE_GNUPLOT is not set
# BR2_PACKAGE_JHEAD is not set
# kmscube needs EGL, GBM and OpenGL ES, and a toolchain w/ thread support
# libva-utils needs a toolchain w/ C++, threads, dynamic library
BR2_PACKAGE_MIDORI_ARCH_SUPPORTS=y
# midori needs a glibc toolchain w/ C++, wchar, threads, dynamic library, gcc >= 7, host gcc >= 8
# midori needs libgtk3 w/ X11 or wayland backend
BR2_PACKAGE_NETSURF_ARCH_SUPPORTS=y
# BR2_PACKAGE_NETSURF is not set
# BR2_PACKAGE_PNGQUANT is not set
# BR2_PACKAGE_RRDTOOL is not set
# spirv-tools needs a toolchain w/ C++, gcc >= 7
# stellarium needs Qt5 and an OpenGL provider
# sway needs systemd, udev, EGL w/ Wayland backend and OpenGL ES support
# sway needs a toolchain w/ wchar, threads, C++, dynamic library, gcc >= 4.9
# BR2_PACKAGE_SWAYBG is not set
# tesseract-ocr needs a toolchain w/ threads, C++, gcc >= 7, dynamic library, wchar
# BR2_PACKAGE_TINIFIER is not set
# Graphic libraries
# cegui needs a toolchain w/ C++, threads, dynamic library, wchar, gcc >= 5
# directfb needs a glibc or uClibc toolchain w/ C++, NPTL, gcc >= 4.5, dynamic library
# efl needs a toolchain w/ C++, dynamic library, gcc >= 4.9, host gcc >= 4.9, threads, wchar
# BR2_PACKAGE_FB_TEST_APP is not set
# BR2_PACKAGE_FBDUMP is not set
# BR2_PACKAGE_FBGRAB is not set
# fbterm needs a toolchain w/ C++, wchar, locale
# BR2_PACKAGE_FBV is not set
# flutter-gallery needs flutter-engine
# flutter-pi needs flutter-engine
# flutter-pi needs GBM, systemd, and udev
# freerdp needs a toolchain w/ wchar, dynamic library, threads, C++
# BR2_PACKAGE_GRAPHICSMAGICK is not set
# BR2_PACKAGE_IMAGEMAGICK is not set
# BR2_PACKAGE_LIBGLVND is not set
# BR2_PACKAGE_LINUX_FUSION is not set
# mesa3d needs a toolchain w/ gcc >=8, C++, NPTL, dynamic library
# ocrad needs a toolchain w/ C++
# ogre needs a toolchain w/ C++, dynamic library, gcc >= 4.8, threads, wchar
# BR2_PACKAGE_PSPLASH is not set
# BR2_PACKAGE_SDL is not set
# BR2_PACKAGE_SDL2 is not set
# spirv-headers needs a toolchain w/ C++
# BR2_PACKAGE_VULKAN_HEADERS is not set
# vulkan-loader needs a toolchain w/ C++, dynamic library, threads
# vulkan-tools needs a toolchain w/ C++, dynamic library, threads, gcc >= 4.9
# Other GUIs
BR2_PACKAGE_QT5_JSCORE_AVAILABLE=y
# Qt5 needs host g++ >= 5.0, and a toolchain w/ gcc >= 5.0, wchar, NPTL, C++, dynamic library
BR2_PACKAGE_QT6_ARCH_SUPPORTS=y
# qt6 needs a toolchain w/ C++, threads, wchar, dynamic library, gcc >= 8, host gcc >= 8
# tekui needs a Lua interpreter and a toolchain w/ threads, dynamic library
# weston needs udev and a toolchain w/ locale, threads, dynamic library, headers >= 3.0
# BR2_PACKAGE_XORG7 is not set
# apitrace needs a toolchain w/ C++, wchar, dynamic library, threads, gcc >= 7
# mupdf needs a toolchain w/ C++, gcc >= 4.9
# vte needs a uClibc or glibc toolchain w/ wchar, threads, C++, gcc >= 10
# vte needs an OpenGL or an OpenGL-EGL/wayland backend
# BR2_PACKAGE_XKEYBOARD_CONFIG is not set
# Hardware handling
# Firmware
# BR2_PACKAGE_AM33X_CM3 is not set
# BR2_PACKAGE_ARMBIAN_FIRMWARE is not set
# BR2_PACKAGE_B43_FIRMWARE is not set
# BR2_PACKAGE_BRCMFMAC_SDIO_FIRMWARE_RPI is not set
BR2_PACKAGE_LINUX_FIRMWARE=y
# Audio firmware
# BR2_PACKAGE_LINUX_FIRMWARE_INTEL_SST_DSP is not set
# Video firmware
# BR2_PACKAGE_LINUX_FIRMWARE_AMDGPU is not set
# BR2_PACKAGE_LINUX_FIRMWARE_I915 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RADEON is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QCOM_VENUS is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QCOM_ADRENO is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MFC_V8 is not set
# Bluetooth firmware
# BR2_PACKAGE_LINUX_FIRMWARE_IBT is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MEDIATEK_MT7650 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QUALCOMM_6174A_BT is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QUALCOMM_9377_BT is not set
# BR2_PACKAGE_LINUX_FIRMWARE_AR3011 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_AR3012_USB is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_87XX_BT is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_88XX_BT is not set
# BR2_PACKAGE_LINUX_FIRMWARE_TI_CC2560 is not set
# WiFi firmware
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_6002 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_6003 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_6004 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_7010 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_9170 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_9271 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_10K_QCA9377 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_10K_QCA998X is not set
# BR2_PACKAGE_LINUX_FIRMWARE_BRCM_BCM43XX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_BRCM_BCM43XXX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_BRCM_BCM4366B1 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_BRCM_BCM4366C0 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_CYPRESS_CYW43XX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_CYPRESS_CYW43XXX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_CYPRESS_CYW54XXX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_22000 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_22260 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3160 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3168 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3945 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_4965 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_5000 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_6000G2A is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_6000G2B is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_7260 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_7265 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_7265D is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_8000C is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_8265 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_9XXX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_6E is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_QUZ is not set
# BR2_PACKAGE_LINUX_FIRMWARE_LIBERTAS_SD8686_V8 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_LIBERTAS_SD8686_V9 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_LIBERTAS_SD8688 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_LIBERTAS_USB8388_V9 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_LIBERTAS_USB8388_OLPC is not set
# BR2_PACKAGE_LINUX_FIRMWARE_LIBERTAS_USB_THINFIRM is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_SD8787 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_SD8797 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_USB8797 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_USB8801 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_SD8887 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_SD8897 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_USB8897 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_PCIE8897 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_PCIEUART8997 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MWIFIEX_PCIEUSB8997 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MEDIATEK_MT7601U is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MEDIATEK_MT7610E is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MEDIATEK_MT76X2E is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QUALCOMM_6174 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RALINK_RT61 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RALINK_RT73 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RALINK_RT2XX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_81XX is not set
BR2_PACKAGE_LINUX_FIRMWARE_RTL_87XX=y
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_88XX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_RTW88 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_REDPINE_RS9113 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_TI_WL127X is not set
# BR2_PACKAGE_LINUX_FIRMWARE_TI_WL128X is not set
# BR2_PACKAGE_LINUX_FIRMWARE_TI_WL18XX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QUALCOMM_WIL6210 is not set
# Ethernet firmware
# BR2_PACKAGE_LINUX_FIRMWARE_BROADCOM_TIGON3 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_BNX2 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_BNX2X is not set
# BR2_PACKAGE_LINUX_FIRMWARE_CXGB4_T4 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_CXGB4_T5 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_INTEL_E100 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_INTEL_ICE is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MARVELL_PRESTERA is not set
# BR2_PACKAGE_LINUX_FIRMWARE_MICROCHIP_VSC85XX_PHY is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QLOGIC_4X is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_815X is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_8169 is not set
# DVB firmware
# BR2_PACKAGE_LINUX_FIRMWARE_AS102 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_DIB0700 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ITETECH_IT9135 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_H5_DRXK is not set
# BR2_PACKAGE_LINUX_FIRMWARE_XCx000 is not set
# Fibre Channel Adapter Firmware
# BR2_PACKAGE_LINUX_FIRMWARE_QLOGIC_2XXX is not set
# Intel QuickAssist Firmware
# BR2_PACKAGE_LINUX_FIRMWARE_QAT_DH895XCC is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QAT_C3XXX is not set
# BR2_PACKAGE_LINUX_FIRMWARE_QAT_C62X is not set
# USB to Serial Firmware
# BR2_PACKAGE_LINUX_FIRMWARE_USB_SERIAL_TI is not set
# V4L Firmware
# BR2_PACKAGE_LINUX_FIRMWARE_CX231XX is not set
# BR2_PACKAGE_MURATA_CYW_FW is not set
# BR2_PACKAGE_ODROIDC2_FIRMWARE is not set
# BR2_PACKAGE_QCOM_DB410C_FIRMWARE is not set
# BR2_PACKAGE_QORIQ_FM_UCODE is not set
# BR2_PACKAGE_RCW_SMARC_SAL28 is not set
# BR2_PACKAGE_RPI_FIRMWARE is not set
# BR2_PACKAGE_SUNXI_BOARDS is not set
# BR2_PACKAGE_TS4900_FPGA is not set
# BR2_PACKAGE_UX500_FIRMWARE is not set
# BR2_PACKAGE_WILC1000_FIRMWARE is not set
# BR2_PACKAGE_WILC3000_FIRMWARE is not set
# BR2_PACKAGE_WILINK_BT_FIRMWARE is not set
# BR2_PACKAGE_ZD1211_FIRMWARE is not set
# BR2_PACKAGE_18XX_TI_UTILS is not set
# BR2_PACKAGE_A10DISP is not set
# BR2_PACKAGE_ACPICA is not set
# BR2_PACKAGE_ACPID is not set
# acpitool needs a toolchain w/ threads, C++, dynamic library
# BR2_PACKAGE_AER_INJECT is not set
# BR2_PACKAGE_ALTERA_STAPL is not set
# BR2_PACKAGE_AM335X_PRU_PACKAGE is not set
# apcupsd needs a toolchain w/ C++, threads
# BR2_PACKAGE_AVRDUDE is not set
# bcache-tools needs udev /dev management
# brickd needs udev /dev management, a toolchain w/ threads, wchar
# BR2_PACKAGE_BRLTTY is not set
# BR2_PACKAGE_CBOOTIMAGE is not set
# cc-tool needs a toolchain w/ C++, threads, wchar, gcc >= 4.9
# BR2_PACKAGE_CDRKIT is not set
BR2_PACKAGE_CPUBURN_ARM_ARCH_SUPPORTS=y
# BR2_PACKAGE_CPUBURN_ARM is not set
# BR2_PACKAGE_CRUCIBLE is not set
# BR2_PACKAGE_CRYPTSETUP is not set
# BR2_PACKAGE_CWIID is not set
# BR2_PACKAGE_DAHDI_LINUX is not set
# BR2_PACKAGE_DAHDI_TOOLS is not set
# BR2_PACKAGE_DAVINCI_BOOTCOUNT is not set
# BR2_PACKAGE_DBUS is not set
# dbusbroker needs systemd and a toolchain w/ threads
# dbus-cxx needs a toolchain w/ C++, threads, gcc >= 7 and dynamic library support
# BR2_PACKAGE_DFU_PROGRAMMER is not set
# BR2_PACKAGE_DFU_UTIL is not set
# BR2_PACKAGE_DMRAID is not set
# dt-utils needs udev /dev management
# BR2_PACKAGE_DTBOCFG is not set
# BR2_PACKAGE_DTV_SCAN_TABLES is not set
# BR2_PACKAGE_DUMP1090 is not set
# BR2_PACKAGE_DVB_APPS is not set
# BR2_PACKAGE_DVBSNOOP is not set
# edid-decode needs a toolchain w/ C++, gcc >= 4.7
# BR2_PACKAGE_ESP_HOSTED is not set
# eudev needs eudev /dev management
# BR2_PACKAGE_EVEMU is not set
# BR2_PACKAGE_EVTEST is not set
# BR2_PACKAGE_FAN_CTRL is not set
# BR2_PACKAGE_FCONFIG is not set
BR2_PACKAGE_FLASHROM_ARCH_SUPPORTS=y
# BR2_PACKAGE_FLASHROM is not set
# BR2_PACKAGE_FMTOOLS is not set
# BR2_PACKAGE_FREEIPMI is not set
# BR2_PACKAGE_FREESCALE_IMX is not set
# BR2_PACKAGE_FXLOAD is not set
# BR2_PACKAGE_GCNANO_BINARIES is not set
# BR2_PACKAGE_GPM is not set
# BR2_PACKAGE_GPSD is not set
# gptfdisk needs a toolchain w/ C++
# BR2_PACKAGE_GVFS is not set
# BR2_PACKAGE_HDDTEMP is not set
# BR2_PACKAGE_HWDATA is not set
# BR2_PACKAGE_HWLOC is not set
# BR2_PACKAGE_INPUT_EVENT_DAEMON is not set
# BR2_PACKAGE_IPMITOOL is not set
# BR2_PACKAGE_IRDA_UTILS is not set
# BR2_PACKAGE_KBD is not set
# BR2_PACKAGE_LCDPROC is not set
# ledmon needs udev and a toolchain w/ threads
# libiec61850 needs a toolchain w/ C++, threads, dynamic library
# BR2_PACKAGE_LIBMANETTE is not set
# BR2_PACKAGE_LIBUBOOTENV is not set
# BR2_PACKAGE_LIBUIO is not set
# BR2_PACKAGE_LINUX_BACKPORTS is not set
# BR2_PACKAGE_LINUX_SERIAL_TEST is not set
# BR2_PACKAGE_LINUXCONSOLETOOLS is not set
# lirc-tools needs a toolchain w/ threads, dynamic library, C++
# BR2_PACKAGE_LM_SENSORS is not set
# lshw needs a toolchain w/ C++, wchar
# BR2_PACKAGE_LSSCSI is not set
# BR2_PACKAGE_LSUIO is not set
# BR2_PACKAGE_LUKSMETA is not set
# BR2_PACKAGE_LVM2 is not set
# BR2_PACKAGE_MALI_DRIVER is not set
# BR2_PACKAGE_MALI_T76X is not set
# BR2_PACKAGE_MBPFAN is not set
# BR2_PACKAGE_MDADM is not set
# BR2_PACKAGE_MDEVD is not set
# BR2_PACKAGE_MDIO_TOOLS is not set
# BR2_PACKAGE_MEMTESTER is not set
# BR2_PACKAGE_MEMTOOL is not set
# BR2_PACKAGE_MHZ is not set
# BR2_PACKAGE_MINICOM is not set
# BR2_PACKAGE_NANOCOM is not set
# BR2_PACKAGE_NEARD is not set
# BR2_PACKAGE_NVIDIA_MODPROBE is not set
# BR2_PACKAGE_NVIDIA_PERSISTENCED is not set
# BR2_PACKAGE_NVME is not set
# BR2_PACKAGE_OFONO is not set
# ola needs a toolchain w/ C++, threads, dynamic library, gcc >= 4.8
# BR2_PACKAGE_OPEN2300 is not set
# openfpgaloader needs a toolchain w/ threads, C++, gcc >= 4.9
# BR2_PACKAGE_OPENIPMI is not set
# BR2_PACKAGE_OPENOCD is not set
# owl-linux is only supported on ARM9 architecture
# BR2_PACKAGE_PARTED is not set
# BR2_PACKAGE_PCIUTILS is not set
# BR2_PACKAGE_PDBG is not set
# BR2_PACKAGE_PICOCOM is not set
# BR2_PACKAGE_PIFMRDS is not set
# BR2_PACKAGE_PIGPIO is not set
# powertop needs a toolchain w/ C++, threads, wchar
# BR2_PACKAGE_PPS_TOOLS is not set
# BR2_PACKAGE_PRU_SOFTWARE_SUPPORT is not set
# BR2_PACKAGE_QORIQ_CADENCE_DP_FIRMWARE is not set
# BR2_PACKAGE_RASPI_GPIO is not set
# BR2_PACKAGE_RDMA_CORE is not set
# BR2_PACKAGE_READ_EDID is not set
# BR2_PACKAGE_RNG_TOOLS is not set
# rockchip-mali needs a glibc toolchain w/ C++, threads
# BR2_PACKAGE_ROCKCHIP_RKBIN is not set
# rpi-userland needs a toolchain w/ C++, threads, dynamic library
# BR2_PACKAGE_RS485CONF is not set
# BR2_PACKAGE_RTC_TOOLS is not set
# BR2_PACKAGE_RTL8188EU is not set
# BR2_PACKAGE_RTL8189ES is not set
# BR2_PACKAGE_RTL8189FS is not set
# BR2_PACKAGE_RTL8192EU is not set
# BR2_PACKAGE_RTL8723BU is not set
# BR2_PACKAGE_RTL8723DS is not set
# BR2_PACKAGE_RTL8723DS_BT is not set
# BR2_PACKAGE_RTL8812AU_AIRCRACK_NG is not set
# BR2_PACKAGE_RTL8821AU is not set
# BR2_PACKAGE_RTL8821CU is not set
# BR2_PACKAGE_RTL8822CS is not set
# BR2_PACKAGE_SANE_BACKENDS is not set
# BR2_PACKAGE_SDPARM is not set
BR2_PACKAGE_SEDUTIL_ARCH_SUPPORTS=y
# sedutil needs a toolchain w/ C++, gcc >= 4.8, headers >= 3.12
# BR2_PACKAGE_SETSERIAL is not set
# BR2_PACKAGE_SG3_UTILS is not set
# BR2_PACKAGE_SIGROK_CLI is not set
# BR2_PACKAGE_SISPMCTL is not set
# smartmontools needs a toolchain w/ C++
# BR2_PACKAGE_SMSTOOLS3 is not set
# BR2_PACKAGE_SPI_TOOLS is not set
# BR2_PACKAGE_SREDIRD is not set
# BR2_PACKAGE_STATSERIAL is not set
# BR2_PACKAGE_STM32FLASH is not set
# BR2_PACKAGE_SUNXI_CEDARX is not set
# BR2_PACKAGE_SUNXI_MALI_UTGARD is not set
# BR2_PACKAGE_SYSSTAT is not set
# targetcli-fb depends on Python
# BR2_PACKAGE_TI_GFX is not set
# BR2_PACKAGE_TI_SGX_KM is not set
# ti-sgx-um needs udev and a glibc toolchain w/ threads
# BR2_PACKAGE_TI_UIM is not set
# BR2_PACKAGE_TI_UTILS is not set
# BR2_PACKAGE_TIO is not set
# BR2_PACKAGE_TRIGGERHAPPY is not set
# BR2_PACKAGE_UBOOT_TOOLS is not set
# BR2_PACKAGE_UBUS is not set
# udisks needs udev /dev management
# BR2_PACKAGE_UHUBCTL is not set
# BR2_PACKAGE_UMTPRD is not set
# upower needs udev /dev management
# BR2_PACKAGE_USB_MODESWITCH is not set
# BR2_PACKAGE_USB_MODESWITCH_DATA is not set
# usbguard needs a toolchain w/ C++, threads, dynamic library, gcc >= 8
# usbmount requires udev to be enabled
# usbutils needs udev /dev management and toolchain w/ threads, gcc >= 4.9
# BR2_PACKAGE_W_SCAN is not set
# BR2_PACKAGE_WF111 is not set
# BR2_PACKAGE_WILC_DRIVER is not set
# BR2_PACKAGE_WIPE is not set
# BR2_PACKAGE_XORRISO is not set
# BR2_PACKAGE_XR819_XRADIO is not set
# Interpreter languages and scripting
# BR2_PACKAGE_4TH is not set
# BR2_PACKAGE_ENSCRIPT is not set
BR2_PACKAGE_HOST_ERLANG_ARCH_SUPPORTS=y
BR2_PACKAGE_ERLANG_ARCH_SUPPORTS=y
# BR2_PACKAGE_ERLANG is not set
# BR2_PACKAGE_EXECLINE is not set
# BR2_PACKAGE_FICL is not set
BR2_PACKAGE_GAUCHE_ARCH_SUPPORTS=y
# BR2_PACKAGE_GAUCHE is not set
# BR2_PACKAGE_GUILE is not set
# BR2_PACKAGE_HASERL is not set
# BR2_PACKAGE_JANET is not set
# BR2_PACKAGE_JIMTCL is not set
# BR2_PACKAGE_LUA is not set
BR2_PACKAGE_PROVIDES_HOST_LUAINTERPRETER="host-lua"
BR2_PACKAGE_LUAJIT_ARCH_SUPPORTS=y
# BR2_PACKAGE_LUAJIT is not set
# BR2_PACKAGE_MICROPYTHON is not set
# BR2_PACKAGE_MOARVM is not set
BR2_PACKAGE_HOST_MONO_ARCH_SUPPORTS=y
BR2_PACKAGE_MONO_ARCH_SUPPORTS=y
# mono needs a toolchain w/ C++, NPTL, dynamic library
BR2_PACKAGE_NODEJS_ARCH_SUPPORTS=y
# nodejs needs a toolchain w/ C++, dynamic library, NPTL, gcc >= 10, wchar, host gcc >= 10
# octave needs a toolchain w/ C++ and fortran, gcc >= 4.8
BR2_PACKAGE_HOST_OPENJDK_BIN_ARCH_SUPPORTS=y
BR2_PACKAGE_OPENJDK_ARCH_SUPPORTS=y
# openjdk needs X.Org
# openjdk needs glibc, and a toolchain w/ wchar, dynamic library, threads, C++, gcc >= 4.9, host gcc >= 4.9
# BR2_PACKAGE_PERL is not set
BR2_PACKAGE_PHP_ARCH_SUPPORTS=y
# BR2_PACKAGE_PHP is not set
# BR2_PACKAGE_PYTHON3 is not set
# BR2_PACKAGE_QUICKJS is not set
# BR2_PACKAGE_RUBY is not set
# BR2_PACKAGE_TCL is not set
# Libraries
# Audio/Sound
# BR2_PACKAGE_ALSA_LIB is not set
# alure needs a toolchain w/ C++, gcc >= 4.9, NPTL, wchar
# BR2_PACKAGE_AUBIO is not set
# BR2_PACKAGE_BCG729 is not set
# caps needs a toolchain w/ C++, dynamic library
BR2_PACKAGE_FDK_AAC_ARCH_SUPPORTS=y
# fdk-aac needs a toolchain w/ C++
# BR2_PACKAGE_LIBAO is not set
# BR2_PACKAGE_LIBBROADVOICE is not set
# BR2_PACKAGE_LIBCANBERRA is not set
# BR2_PACKAGE_LIBCDAUDIO is not set
# BR2_PACKAGE_LIBCDDB is not set
# BR2_PACKAGE_LIBCDIO is not set
# BR2_PACKAGE_LIBCDIO_PARANOIA is not set
# BR2_PACKAGE_LIBCODEC2 is not set
# BR2_PACKAGE_LIBCUE is not set
# BR2_PACKAGE_LIBCUEFILE is not set
# BR2_PACKAGE_LIBEBUR128 is not set
# BR2_PACKAGE_LIBG7221 is not set
# BR2_PACKAGE_LIBGSM is not set
# BR2_PACKAGE_LIBID3TAG is not set
# BR2_PACKAGE_LIBILBC is not set
# BR2_PACKAGE_LIBLO is not set
# BR2_PACKAGE_LIBMAD is not set
# libmodplug needs a toolchain w/ C++
# BR2_PACKAGE_LIBMPD is not set
# BR2_PACKAGE_LIBMPDCLIENT is not set
# BR2_PACKAGE_LIBREPLAYGAIN is not set
# BR2_PACKAGE_LIBSAMPLERATE is not set
# libsidplay2 needs a toolchain w/ C++
# BR2_PACKAGE_LIBSILK is not set
# BR2_PACKAGE_LIBSNDFILE is not set
# libsoundtouch needs a toolchain w/ C++
# BR2_PACKAGE_LIBSOXR is not set
# BR2_PACKAGE_LIBVORBIS is not set
# BR2_PACKAGE_LILV is not set
# BR2_PACKAGE_LV2 is not set
# mp4v2 needs a toolchain w/ C++
BR2_PACKAGE_OPENAL_ARCH_SUPPORTS=y
# openal needs a toolchain w/ NPTL, C++, gcc >= 4.9
# opencore-amr needs a toolchain w/ C++
# BR2_PACKAGE_OPUS is not set
# BR2_PACKAGE_OPUSFILE is not set
# BR2_PACKAGE_PORTAUDIO is not set
# BR2_PACKAGE_SBC is not set
# BR2_PACKAGE_SPANDSP is not set
# BR2_PACKAGE_SPEEX is not set
# BR2_PACKAGE_SPEEXDSP is not set
# BR2_PACKAGE_SRATOM is not set
# taglib needs a toolchain w/ C++, wchar
# BR2_PACKAGE_TINYALSA is not set
# BR2_PACKAGE_TREMOR is not set
# BR2_PACKAGE_VO_AACENC is not set
BR2_PACKAGE_WEBRTC_AUDIO_PROCESSING_ARCH_SUPPORTS=y
# webrtc-audio-processing needs a toolchain w/ C++, NPTL, gcc >= 4.8
# Compression and decompression
# BR2_PACKAGE_LIBARCHIVE is not set
# BR2_PACKAGE_LIBDEFLATE is not set
# BR2_PACKAGE_LIBMSPACK is not set
# libsquish needs a toolchain w/ C++
# BR2_PACKAGE_LIBZIP is not set
# BR2_PACKAGE_LZ4 is not set
# BR2_PACKAGE_LZO is not set
# BR2_PACKAGE_MINIZIP is not set
# BR2_PACKAGE_MINIZIP_ZLIB is not set
# snappy needs a toolchain w/ C++
# BR2_PACKAGE_SZIP is not set
# BR2_PACKAGE_ZCHUNK is not set
BR2_PACKAGE_ZLIB_NG_ARCH_SUPPORTS=y
# BR2_PACKAGE_ZLIB is not set
BR2_PACKAGE_PROVIDES_HOST_ZLIB="host-libzlib"
# BR2_PACKAGE_ZZIPLIB is not set
# Crypto
# BR2_PACKAGE_BEARSSL is not set
# BR2_PACKAGE_BEECRYPT is not set
BR2_PACKAGE_BOTAN_ARCH_SUPPORTS=y
# botan needs a toolchain w/ C++, threads, gcc >= 4.8
# BR2_PACKAGE_CA_CERTIFICATES is not set
# BR2_PACKAGE_CRYPTODEV_LINUX is not set
# cryptopp needs a toolchain w/ C++, dynamic library, wchar
# BR2_PACKAGE_GCR is not set
# BR2_PACKAGE_GNUTLS is not set
# BR2_PACKAGE_LIBARGON2 is not set
# BR2_PACKAGE_LIBASSUAN is not set
# BR2_PACKAGE_LIBB2 is not set
# BR2_PACKAGE_LIBGCRYPT is not set
BR2_PACKAGE_LIBGPG_ERROR_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBGPG_ERROR is not set
BR2_PACKAGE_LIBGPG_ERROR_SYSCFG="arm-unknown-linux-gnueabi"
# BR2_PACKAGE_LIBGPGME is not set
# BR2_PACKAGE_LIBKCAPI is not set
# BR2_PACKAGE_LIBKSBA is not set
# BR2_PACKAGE_LIBMD is not set
# BR2_PACKAGE_LIBMHASH is not set
# BR2_PACKAGE_LIBNSS is not set
# libolm needs a toolchain w/ C++, gcc >= 4.8
# BR2_PACKAGE_LIBP11 is not set
# BR2_PACKAGE_LIBSCRYPT is not set
# BR2_PACKAGE_LIBSECRET is not set
# BR2_PACKAGE_LIBSHA1 is not set
# BR2_PACKAGE_LIBSODIUM is not set
# BR2_PACKAGE_LIBSSH is not set
# BR2_PACKAGE_LIBSSH2 is not set
# BR2_PACKAGE_LIBTOMCRYPT is not set
# BR2_PACKAGE_LIBUECC is not set
# BR2_PACKAGE_LIBXCRYPT is not set
# BR2_PACKAGE_MBEDTLS is not set
# BR2_PACKAGE_NETTLE is not set
# BR2_PACKAGE_OPENSSL is not set
BR2_PACKAGE_PROVIDES_HOST_OPENSSL="host-libopenssl"
# BR2_PACKAGE_PKCS11_HELPER is not set
# BR2_PACKAGE_RHASH is not set
# BR2_PACKAGE_TINYDTLS is not set
# BR2_PACKAGE_TPM2_PKCS11 is not set
# BR2_PACKAGE_TPM2_TSS is not set
# BR2_PACKAGE_TROUSERS is not set
# BR2_PACKAGE_USTREAM_SSL is not set
BR2_PACKAGE_WOLFSSL_ASM_SUPPORTS=y
# BR2_PACKAGE_WOLFSSL is not set
# BR2_PACKAGE_WOLFTPM is not set
# Database
# BR2_PACKAGE_BERKELEYDB is not set
# BR2_PACKAGE_GDBM is not set
# BR2_PACKAGE_HIREDIS is not set
# kompexsqlite needs a toolchain w/ C++, wchar, threads, dynamic library
# leveldb needs a toolchain w/ C++, threads, gcc >= 4.8
# BR2_PACKAGE_LIBDBI is not set
# BR2_PACKAGE_LIBDBI_DRIVERS is not set
# BR2_PACKAGE_LIBGIT2 is not set
# BR2_PACKAGE_LIBMDBX is not set
# libodb needs a toolchain w/ C++, threads
BR2_PACKAGE_MONGODB_ARCH_SUPPORTS=y
# mongodb needs a glibc toolchain w/ wchar, threads, C++, gcc >= 7
# mysql needs a toolchain w/ C++, threads
# BR2_PACKAGE_POSTGRESQL is not set
# BR2_PACKAGE_REDIS is not set
# redis-plus-plus needs a toolchain w/ C++
# BR2_PACKAGE_SQLCIPHER is not set
# BR2_PACKAGE_SQLITE is not set
# BR2_PACKAGE_UNIXODBC is not set
# Filesystem
# BR2_PACKAGE_GAMIN is not set
# BR2_PACKAGE_LIBCONFIG is not set
# BR2_PACKAGE_LIBCONFUSE is not set
# BR2_PACKAGE_LIBFUSE is not set
# BR2_PACKAGE_LIBFUSE3 is not set
# BR2_PACKAGE_LIBLOCKFILE is not set
# BR2_PACKAGE_LIBNFS is not set
# BR2_PACKAGE_LIBSYSFS is not set
# BR2_PACKAGE_LOCKDEV is not set
# physfs needs a toolchain w/ C++, threads
# Graphics
# assimp needs a toolchain w/ C++, wchar, gcc >= 7
# BR2_PACKAGE_AT_SPI2_CORE is not set
# atkmm needs a toolchain w/ C++, wchar, threads, gcc >= 7
# atkmm (2.28.x) needs a toolchain w/ C++, wchar, threads, gcc >= 4.9
BR2_PACKAGE_BAYER2RGB_NEON_ARCH_SUPPORTS=y
# bayer2rgb-neon needs a toolchain w/ C++, dynamic library, gcc >= 4.9
# bullet needs a toolchain w/ C++, dynamic library, threads, wchar
# BR2_PACKAGE_CAIRO is not set
# cairomm needs a toolchain w/ C++, wchar, threads, gcc >= 7
# cairomm (1.14.x) needs a toolchain w/ C++, wchar, threads, gcc >= 4.9
# chipmunk needs an OpenGL backend
# exempi needs a toolchain w/ C++, dynamic library, threads, wchar
# exiv2 needs a uClibc or glibc toolchain w/ C++, wchar, dynamic library, threads
BR2_PACKAGE_FLUTTER_ENGINE_ARCH_SUPPORTS=y
# flutter-engine needs an OpenGL or OpenGLES backend
# flutter-engine needs a glibc toolchain w/ wchar, C++, gcc >= 5, dynamic library, host gcc >= 5, NPTL
# BR2_PACKAGE_FONTCONFIG is not set
# BR2_PACKAGE_FREETYPE is not set
# BR2_PACKAGE_GD is not set
# BR2_PACKAGE_GDK_PIXBUF is not set
# BR2_PACKAGE_GIFLIB is not set
# granite needs libgtk3 and a toolchain w/ wchar, threads, gcc >= 4.9
# graphite2 needs a toolchain w/ C++
# gtkmm3 needs libgtk3 and a toolchain w/ C++, wchar, threads, gcc >= 4.9
# harfbuzz needs a toolchain w/ C++, gcc >= 4.9
# BR2_PACKAGE_IJS is not set
# BR2_PACKAGE_IMLIB2 is not set
# intel-gmmlib needs a toolchain w/ dynamic library, C++, threads
# irrlicht needs a toolchain w/ C++
# BR2_PACKAGE_JASPER is not set
# BR2_PACKAGE_JBIG2DEC is not set
BR2_PACKAGE_JPEG_SIMD_SUPPORT=y
# BR2_PACKAGE_JPEG is not set
# kms++ needs a toolchain w/ threads, C++, gcc >= 4.8, headers >= 4.11, wchar
# BR2_PACKAGE_LCMS2 is not set
# lensfun needs a toolchain w/ C++, threads, wchar
# BR2_PACKAGE_LEPTONICA is not set
# BR2_PACKAGE_LIBART is not set
# libdecor needs a toolchain w/ wchar, threads, C++, gcc >= 4.9
# BR2_PACKAGE_LIBDMTX is not set
BR2_PACKAGE_LIBDRM=y
BR2_PACKAGE_LIBDRM_HAS_ATOMIC=y
# BR2_PACKAGE_LIBDRM_RADEON is not set
# BR2_PACKAGE_LIBDRM_AMDGPU is not set
# BR2_PACKAGE_LIBDRM_NOUVEAU is not set
# BR2_PACKAGE_LIBDRM_OMAP is not set
# BR2_PACKAGE_LIBDRM_ETNAVIV is not set
# BR2_PACKAGE_LIBDRM_EXYNOS is not set
# BR2_PACKAGE_LIBDRM_FREEDRENO is not set
# BR2_PACKAGE_LIBDRM_TEGRA is not set
# BR2_PACKAGE_LIBDRM_VC4 is not set
BR2_PACKAGE_LIBDRM_INSTALL_TESTS=y
# libepoxy needs an OpenGL and/or OpenGL EGL backend
# BR2_PACKAGE_LIBEXIF is not set
# libfm needs X.org and a toolchain w/ wchar, threads, C++, gcc >= 4.9
# BR2_PACKAGE_LIBFM_EXTRA is not set
# libfreeglut depends on X.org and needs an OpenGL backend
# libfreeimage needs a toolchain w/ C++, dynamic library, wchar
# libgeotiff needs a toolchain w/ C++, gcc >= 4.7, threads, wchar
# libglew depends on X.org and needs an OpenGL backend
# libglfw depends on X.org or Wayland and an OpenGL or GLES backend
# libglu needs an OpenGL backend
# BR2_PACKAGE_LIBGTA is not set
# libgtk3 needs a toolchain w/ wchar, threads, C++, gcc >= 4.9
# libgtk3 needs an OpenGL or an OpenGL-EGL/wayland backend
# libjxl needs a toolchain with C++, threads, gcc >= 7, dynamic library
# BR2_PACKAGE_LIBMEDIAART is not set
# BR2_PACKAGE_LIBMNG is not set
# BR2_PACKAGE_LIBPNG is not set
# BR2_PACKAGE_LIBQRENCODE is not set
# libraw needs a toolchain w/ C++
# librsvg needs a toolchain w/ wchar, threads, C++, gcc >= 4.9
# BR2_PACKAGE_LIBSVG is not set
# BR2_PACKAGE_LIBSVG_CAIRO is not set
# BR2_PACKAGE_LIBSVGTINY is not set
# BR2_PACKAGE_LIBVA is not set
# libvips needs a toolchain w/ wchar, threads, C++
# libwpe needs a toolchain w/ C++, dynamic library and an OpenEGL-capable backend
# BR2_PACKAGE_MENU_CACHE is not set
BR2_PACKAGE_ONEVPL_ARCH_SUPPORTS=y
# onevpl needs a toolchain w/ dynamic library, gcc >= 7, C++, threads
# onevpl-intel-gpu needs a toolchain w/ dynamic library, gcc >= 7, C++, NPTL
# opencv3 needs a toolchain w/ C++, NPTL, wchar, dynamic library
# opencv4 needs a toolchain w/ C++, NPTL, wchar, dynamic library, gcc >= 4.8
# BR2_PACKAGE_OPENJPEG is not set
# pango needs a toolchain w/ wchar, threads, C++, gcc >= 4.9
# pangomm needs a toolchain w/ C++, wchar, threads, gcc >= 7
# pangomm (2.46.x) needs a toolchain w/ C++, wchar, threads, gcc >= 4.9
# BR2_PACKAGE_PIXMAN is not set
# poppler needs a toolchain w/ wchar, C++, threads, dynamic library, gcc >= 7
# BR2_PACKAGE_STB is not set
# BR2_PACKAGE_TIFF is not set
# BR2_PACKAGE_WAYLAND is not set
BR2_PACKAGE_WEBKITGTK_ARCH_SUPPORTS=y
# webkitgtk needs libgtk3 and a toolchain w/ C++, wchar, threads, dynamic library, gcc >= 9, host gcc >= 4.9
# BR2_PACKAGE_WEBP is not set
# wlroots needs udev, EGL w/ Wayland backend and OpenGL ES support
# woff2 needs a toolchain w/ C++
# wpebackend-fdo needs a toolchain w/ C++, wchar, threads, dynamic library and an OpenEGL-capable Wayland backend
BR2_PACKAGE_WPEWEBKIT_ARCH_SUPPORTS=y
# wpewebkit needs a toolchain w/ C++, wchar, threads, dynamic library, gcc >= 9, host gcc >= 4.9
# wpewebkit needs an OpenGL ES w/ EGL-capable Wayland backend
# zbar needs a toolchain w/ threads, C++ and headers >= 3.0
# zxing-cpp needs a toolchain w/ C++, wchar, dynamic library
# Hardware handling
# BR2_PACKAGE_ACSCCID is not set
# BR2_PACKAGE_BCM2835 is not set
# BR2_PACKAGE_C_PERIPHERY is not set
# BR2_PACKAGE_CCID is not set
# BR2_PACKAGE_DTC is not set
BR2_PACKAGE_GNU_EFI_ARCH_SUPPORTS=y
# BR2_PACKAGE_GNU_EFI is not set
# BR2_PACKAGE_HACKRF is not set
# hidapi needs udev /dev management and a toolchain w/ NPTL, threads, gcc >= 4.9
# BR2_PACKAGE_JITTERENTROPY_LIBRARY is not set
# lcdapi needs a toolchain w/ C++, threads
# let-me-create needs a toolchain w/ C++, threads, dynamic library
# BR2_PACKAGE_LIBAIO is not set
# libatasmart requires udev to be enabled
# libblockdev needs udev /dev management and a toolchain w/ wchar, threads, dynamic library, locale
# libcec needs a toolchain w/ C++, wchar, threads, dynamic library, gcc >= 4.7
# BR2_PACKAGE_LIBDISPLAY_INFO is not set
# BR2_PACKAGE_LIBFREEFARE is not set
# BR2_PACKAGE_LIBFTDI is not set
# BR2_PACKAGE_LIBFTDI1 is not set
# BR2_PACKAGE_LIBGPHOTO2 is not set
# BR2_PACKAGE_LIBGPIOD is not set
# libgudev needs udev /dev handling and a toolchain w/ wchar, threads
# BR2_PACKAGE_LIBHID is not set
# BR2_PACKAGE_LIBIIO is not set
# libinput needs udev /dev management
# BR2_PACKAGE_LIBIQRF is not set
# BR2_PACKAGE_LIBLLCP is not set
# BR2_PACKAGE_LIBMBIM is not set
# BR2_PACKAGE_LIBNFC is not set
# BR2_PACKAGE_LIBNVME is not set
# BR2_PACKAGE_LIBPCIACCESS is not set
# BR2_PACKAGE_LIBPHIDGET is not set
# BR2_PACKAGE_LIBPRI is not set
# BR2_PACKAGE_LIBQMI is not set
# BR2_PACKAGE_LIBQRTR_GLIB is not set
# BR2_PACKAGE_LIBRAW1394 is not set
# BR2_PACKAGE_LIBRTLSDR is not set
# libserial needs a toolchain w/ C++, gcc >= 5, threads, wchar
# BR2_PACKAGE_LIBSERIALPORT is not set
# BR2_PACKAGE_LIBSIGROK is not set
# BR2_PACKAGE_LIBSIGROKDECODE is not set
# BR2_PACKAGE_LIBSOC is not set
# BR2_PACKAGE_LIBSS7 is not set
# BR2_PACKAGE_LIBUSB is not set
# BR2_PACKAGE_LIBUSBGX is not set
# libv4l needs a toolchain w/ threads, C++ and headers >= 3.0
# BR2_PACKAGE_LIBXKBCOMMON is not set
BR2_PACKAGE_MRAA_ARCH_SUPPORTS=y
# BR2_PACKAGE_MRAA is not set
# BR2_PACKAGE_MTDEV is not set
# BR2_PACKAGE_NEARDAL is not set
BR2_PACKAGE_OPENCSD_ARCH_SUPPORTS=y
# opencsd needs a toolchain w/ C++11, gcc >= 4.8, dynamic library
# BR2_PACKAGE_OPENSC is not set
# BR2_PACKAGE_OWFS is not set
# BR2_PACKAGE_PCSC_LITE is not set
# rpi-rgb-led-matrix needs a toolchain w/ C++, threads, dynamic library
# BR2_PACKAGE_TSLIB is not set
# uhd needs a toolchain w/ C++, NPTL, wchar, dynamic library, gcc >= 5
# urg needs a toolchain w/ C++
# Javascript
# BR2_PACKAGE_ANGULARJS is not set
# BR2_PACKAGE_BOOTSTRAP is not set
# BR2_PACKAGE_CHARTJS is not set
# BR2_PACKAGE_DATATABLES is not set
# BR2_PACKAGE_DUKTAPE is not set
# BR2_PACKAGE_EXPLORERCANVAS is not set
# BR2_PACKAGE_FLOT is not set
# BR2_PACKAGE_FORGE is not set
# BR2_PACKAGE_JQUERY is not set
# BR2_PACKAGE_JSMIN is not set
# BR2_PACKAGE_JSON_JAVASCRIPT is not set
# BR2_PACKAGE_JSZIP is not set
# BR2_PACKAGE_OPENLAYERS is not set
# BR2_PACKAGE_POPPERJS is not set
# BR2_PACKAGE_VIS_NETWORK is not set
# BR2_PACKAGE_VUEJS is not set
# JSON/XML
# benejson needs a toolchain w/ C++
# BR2_PACKAGE_CJSON is not set
# BR2_PACKAGE_EXPAT is not set
# BR2_PACKAGE_JANSSON is not set
# BR2_PACKAGE_JOSE is not set
# BR2_PACKAGE_JSMN is not set
# BR2_PACKAGE_JSON_C is not set
# json-for-modern-cpp needs a toolchain w/ C++, gcc >= 4.9
# BR2_PACKAGE_JSON_GLIB is not set
# jsoncpp needs a toolchain w/ C++, gcc >= 4.7
# BR2_PACKAGE_LIBBSON is not set
# BR2_PACKAGE_LIBFASTJSON is not set
# libjson needs a toolchain w/ C++
# BR2_PACKAGE_LIBROXML is not set
# BR2_PACKAGE_LIBUCL is not set
# BR2_PACKAGE_LIBXML2 is not set
# libxml++ needs a toolchain w/ C++, wchar, threads, gcc >= 7
# BR2_PACKAGE_LIBXMLRPC is not set
# BR2_PACKAGE_LIBXSLT is not set
# BR2_PACKAGE_LIBYAML is not set
# BR2_PACKAGE_MXML is not set
# pugixml needs a toolchain w/ C++
# rapidjson needs a toolchain w/ C++
# BR2_PACKAGE_RAPIDXML is not set
# BR2_PACKAGE_RAPTOR is not set
# BR2_PACKAGE_SERD is not set
# BR2_PACKAGE_SORD is not set
# tinyxml needs a toolchain w/ C++
# tinyxml2 needs a toolchain w/ C++
# valijson needs a toolchain w/ C++
# xerces-c++ needs a toolchain w/ C++, dynamic library, wchar
# xml-security-c needs a toolchain w/ C++, wchar, dynamic library, threads, gcc >= 4.7
# BR2_PACKAGE_YAJL is not set
# yaml-cpp needs a toolchain w/ C++, gcc >= 4.7
# Logging
# glog needs a toolchain w/ C++
# hawktracer needs a toolchain w/ C++, gcc >= 4.8
# BR2_PACKAGE_LIBLOG4C_LOCALTIME is not set
# BR2_PACKAGE_LIBLOGGING is not set
# log4cplus needs a toolchain w/ C++, wchar, threads, gcc >= 4.8
# log4cpp needs a toolchain w/ C++, threads
# log4cxx needs a toolchain w/ C++, threads, dynamic library
# log4qt needs qt5
# opentracing-cpp needs a toolchain w/ C++, threads, dynamic library, gcc >= 4.8
# spdlog needs a toolchain w/ C++, threads, wchar
# ulog needs a toolchain w/ C++, threads
# BR2_PACKAGE_ZLOG is not set
# Multimedia
# bento4 support needs a toolchain with C++
# BR2_PACKAGE_BITSTREAM is not set
# BR2_PACKAGE_DAV1D is not set
# kvazaar needs a toolchain w/ C++, threads
# BR2_PACKAGE_LIBAACS is not set
# libass needs a toolchain w/ C++, gcc >= 4.9
# BR2_PACKAGE_LIBBDPLUS is not set
# BR2_PACKAGE_LIBBLURAY is not set
BR2_PACKAGE_LIBCAMERA_ARCH_SUPPORTS=y
# libcamera needs a toolchain w/ C++, threads, wchar, dynamic library, gcc >= 8
# libcamera-apps needs a toolchain w/ C++, threads, wchar, dynamic library, gcc >= 8
# libde265 needs a toolchain w/ threads, C++
# BR2_PACKAGE_LIBDVBCSA is not set
# BR2_PACKAGE_LIBDVBPSI is not set
# libdvbsi++ needs a toolchain w/ C++, wchar, threads
# BR2_PACKAGE_LIBDVDCSS is not set
# BR2_PACKAGE_LIBDVDNAV is not set
# BR2_PACKAGE_LIBDVDREAD is not set
# libebml needs a toolchain w/ C++, wchar, gcc >= 4.9
# BR2_PACKAGE_LIBHDHOMERUN is not set
# libheif needs a toolchain w/ C++, gcc >= 4.8
# libimxvpuapi needs an i.MX platform with VPU support
# libmatroska needs a toolchain w/ C++, wchar, gcc >= 4.9
# BR2_PACKAGE_LIBMMS is not set
# BR2_PACKAGE_LIBMPEG2 is not set
# BR2_PACKAGE_LIBOGG is not set
# BR2_PACKAGE_LIBOPENAPTX is not set
BR2_PACKAGE_LIBOPENH264_ARCH_SUPPORTS=y
# libopenh264 needs a toolchain w/ C++, dynamic library, threads
# BR2_PACKAGE_LIBOPUSENC is not set
# BR2_PACKAGE_LIBTHEORA is not set
# BR2_PACKAGE_LIBUDFREAD is not set
# BR2_PACKAGE_LIBVPX is not set
# libyuv needs a toolchain w/ C++, dynamic library
# live555 needs a toolchain w/ C++
# mediastreamer needs a toolchain w/ threads, C++, dynamic library, gcc >= 5
# BR2_PACKAGE_X264 is not set
# x265 needs a toolchain w/ C++, threads, dynamic library
# Networking
# agent++ needs a toolchain w/ threads, C++, dynamic library
# azmq needs a toolchain w/ C++11, wchar and threads
# azure-iot-sdk-c needs a toolchain w/ C++, NPTL and wchar
# BR2_PACKAGE_BATMAN_ADV is not set
# belle-sip needs a toolchain w/ threads, C++, dynamic library, wchar
# BR2_PACKAGE_C_ARES is not set
# BR2_PACKAGE_CGIC is not set
# BR2_PACKAGE_CNI_PLUGINS is not set
# cppzmq needs a toolchain w/ C++, threads
# curlpp needs a toolchain w/ C++, dynamic library
# czmq needs a toolchain w/ C++, threads
# BR2_PACKAGE_DAQ is not set
# BR2_PACKAGE_DAQ3 is not set
# BR2_PACKAGE_DAVICI is not set
# BR2_PACKAGE_DHT is not set
# BR2_PACKAGE_ENET is not set
# filemq needs a toolchain w/ C++, threads
# BR2_PACKAGE_FLICKCURL is not set
# BR2_PACKAGE_FREERADIUS_CLIENT is not set
# BR2_PACKAGE_GENSIO is not set
# BR2_PACKAGE_GEOIP is not set
# BR2_PACKAGE_GLIB_NETWORKING is not set
# grpc needs a toolchain w/ C++, threads, dynamic library, gcc >= 5
# BR2_PACKAGE_GSSDP is not set
# BR2_PACKAGE_GUPNP is not set
# BR2_PACKAGE_GUPNP_AV is not set
# BR2_PACKAGE_GUPNP_DLNA is not set
# ibrcommon needs a toolchain w/ C++, threads
# ibrdtn needs a toolchain w/ C++, threads
# BR2_PACKAGE_LIBCGI is not set
# libcgicc needs a toolchain w/ C++
# BR2_PACKAGE_LIBCOAP is not set
# libcpprestsdk needs a toolchain w/ NPTL, C++, wchar, locale
# BR2_PACKAGE_LIBCURL is not set
# BR2_PACKAGE_LIBDNET is not set
# BR2_PACKAGE_LIBEXOSIP2 is not set
# BR2_PACKAGE_LIBEST is not set
# BR2_PACKAGE_LIBFCGI is not set
# BR2_PACKAGE_LIBGSASL is not set
# BR2_PACKAGE_LIBHTP is not set
# BR2_PACKAGE_LIBHTTPPARSER is not set
# libhttpserver needs a toolchain w/ C++, threads, gcc >= 5
# BR2_PACKAGE_LIBIDN is not set
# BR2_PACKAGE_LIBIDN2 is not set
# BR2_PACKAGE_LIBISCSI is not set
# BR2_PACKAGE_LIBKRB5 is not set
# BR2_PACKAGE_LIBLDNS is not set
# BR2_PACKAGE_LIBMAXMINDDB is not set
# BR2_PACKAGE_LIBMBUS is not set
# libmemcached needs a toolchain w/ C++, threads
# BR2_PACKAGE_LIBMICROHTTPD is not set
# BR2_PACKAGE_LIBMINIUPNPC is not set
# BR2_PACKAGE_LIBMNL is not set
# BR2_PACKAGE_LIBMODBUS is not set
# libmodsecurity needs a toolchain w/ C++, threads, dynamic library
# BR2_PACKAGE_LIBNATPMP is not set
# BR2_PACKAGE_LIBNDP is not set
# BR2_PACKAGE_LIBNET is not set
# BR2_PACKAGE_LIBNETCONF2 is not set
# BR2_PACKAGE_LIBNETFILTER_ACCT is not set
# BR2_PACKAGE_LIBNETFILTER_CONNTRACK is not set
# BR2_PACKAGE_LIBNETFILTER_CTHELPER is not set
# BR2_PACKAGE_LIBNETFILTER_CTTIMEOUT is not set
# BR2_PACKAGE_LIBNETFILTER_LOG is not set
# BR2_PACKAGE_LIBNETFILTER_QUEUE is not set
# BR2_PACKAGE_LIBNFNETLINK is not set
# BR2_PACKAGE_LIBNFTNL is not set
# BR2_PACKAGE_LIBNICE is not set
# BR2_PACKAGE_LIBNIDS is not set
BR2_PACKAGE_LIBNL=y
# BR2_PACKAGE_LIBNL_TOOLS is not set
# libnpupnp needs a toolchain w/ C++, threads, gcc >= 4.9
# BR2_PACKAGE_LIBOAUTH is not set
# BR2_PACKAGE_LIBOPING is not set
# BR2_PACKAGE_LIBOSIP2 is not set
# BR2_PACKAGE_LIBPAGEKITE is not set
# BR2_PACKAGE_LIBPCAP is not set
# libpjsip needs a toolchain w/ C++, threads
# BR2_PACKAGE_LIBPSL is not set
# BR2_PACKAGE_LIBRELP is not set
# BR2_PACKAGE_LIBRSYNC is not set
# BR2_PACKAGE_LIBSHAIRPLAY is not set
# BR2_PACKAGE_LIBSHOUT is not set
# BR2_PACKAGE_LIBSOCKETCAN is not set
# BR2_PACKAGE_LIBSOUP is not set
# BR2_PACKAGE_LIBSOUP3 is not set
# BR2_PACKAGE_LIBSRTP is not set
# BR2_PACKAGE_LIBSTROPHE is not set
# BR2_PACKAGE_LIBTEAM is not set
# BR2_PACKAGE_LIBTELNET is not set
# BR2_PACKAGE_LIBTIRPC is not set
# libtorrent needs a toolchain w/ C++, threads
# libtorrent-rasterbar needs a toolchain w/ C++, threads, wchar, gcc >= 4.9
# BR2_PACKAGE_LIBUEV is not set
# BR2_PACKAGE_LIBUHTTPD is not set
# BR2_PACKAGE_LIBUPNP is not set
# libupnpp needs a toolchain w/ C++, threads, gcc >= 4.9
# BR2_PACKAGE_LIBURIPARSER is not set
# libutp support needs a toolchain with C++
# BR2_PACKAGE_LIBUWSC is not set
# BR2_PACKAGE_LIBVNCSERVER is not set
# BR2_PACKAGE_LIBWEBSOCK is not set
# BR2_PACKAGE_LIBWEBSOCKETS is not set
# BR2_PACKAGE_LIBYANG is not set
# BR2_PACKAGE_LIBZENOH_PICO is not set
# BR2_PACKAGE_LKSCTP_TOOLS is not set
# BR2_PACKAGE_MBUFFER is not set
# BR2_PACKAGE_MDNSD is not set
# BR2_PACKAGE_MONGOOSE is not set
# BR2_PACKAGE_NANOMSG is not set
# BR2_PACKAGE_NEON is not set
# netopeer2 needs a toolchain w/ gcc >= 4.8, C++, threads, dynamic library
# BR2_PACKAGE_NGHTTP2 is not set
# norm needs a toolchain w/ C++, threads, dynamic library
# BR2_PACKAGE_NSS_MYHOSTNAME is not set
# BR2_PACKAGE_NSS_PAM_LDAPD is not set
# oatpp needs a toolchain w/ C++, threads
# omniORB needs a toolchain w/ C++, threads
# BR2_PACKAGE_OPEN_ISNS is not set
# BR2_PACKAGE_OPEN62541 is not set
# BR2_PACKAGE_OPENLDAP is not set
# openmpi needs a toolchain w/ dynamic library, NPTL, wchar, C++
# BR2_PACKAGE_OPENPGM is not set
# openzwave needs a toolchain w/ C++, dynamic library, NPTL, wchar
# ortp needs a toolchain w/ C++, threads
# BR2_PACKAGE_PAHO_MQTT_C is not set
# paho-mqtt-cpp needs a toolchain w/ threads, C++
# pistache needs a toolchain w/ C++, gcc >= 7, threads, wchar, not binutils bug 27597
# BR2_PACKAGE_QDECODER is not set
# qpid-proton needs a toolchain w/ C++, dynamic library, threads
# BR2_PACKAGE_RABBITMQ_C is not set
# resiprocate needs a toolchain w/ C++, threads, wchar
# restclient-cpp needs a toolchain w/ C++, gcc >= 4.8
# BR2_PACKAGE_RTMPDUMP is not set
# BR2_PACKAGE_SIPROXD is not set
# BR2_PACKAGE_SLIRP is not set
# BR2_PACKAGE_SLIRP4NETNS is not set
# snmp++ needs a toolchain w/ threads, C++, dynamic library
# BR2_PACKAGE_SOFIA_SIP is not set
# BR2_PACKAGE_SSCEP is not set
# sysrepo needs a toolchain w/ C++, NPTL, dynamic library, gcc >= 4.8
# thrift needs a toolchain w/ C++, wchar, threads
# BR2_PACKAGE_USBREDIR is not set
# wampcc needs a toolchain w/ C++, NPTL, dynamic library, gcc >= 4.9
# websocketpp needs a toolchain w/ C++ and gcc >= 4.8
# zeromq needs a toolchain w/ C++, threads
# zmqpp needs a toolchain w/ C++, threads, gcc >= 4.7
# zyre needs a toolchain w/ C++, threads
# Other
# ACE needs a glibc toolchain, dynamic library, C++, gcc >= 4.9
# BR2_PACKAGE_APR is not set
# BR2_PACKAGE_APR_UTIL is not set
# armadillo needs a toolchain w/ C++
# atf needs a toolchain w/ C++
# BR2_PACKAGE_AVRO_C is not set
# bctoolbox needs a toolchain w/ C++, threads
# BR2_PACKAGE_BDWGC is not set
# belr needs a toolchain w/ threads, C++
# boost needs a toolchain w/ C++, threads, wchar
# c-capnproto needs host and target gcc >= 5 w/ C++14, threads, atomic, ucontext and not gcc bug 64735
# capnproto needs host and target gcc >= 5 w/ C++14, threads, atomic, ucontext and not gcc bug 64735
# catch2 needs a toolchain w/ C++, wchar, threads, gcc >= 5
# cctz needs a toolchain w/ C++, threads, gcc >= 4.8
# cereal needs a toolchain w/ C++, gcc >= 4.7, threads, wchar
# clang needs a toolchain w/ wchar, threads, C++, gcc >= 7, dynamic library, host gcc >= 7
# BR2_PACKAGE_CMOCKA is not set
# cppcms needs a toolchain w/ C++, NPTL, wchar, dynamic library
# BR2_PACKAGE_CRACKLIB is not set
# dawgdic needs a toolchain w/ C++, gcc >= 4.6
# BR2_PACKAGE_DING_LIBS is not set
# BR2_PACKAGE_DOTCONF is not set
# double-conversion needs a toolchain w/ C++
# eigen needs a toolchain w/ C++
# BR2_PACKAGE_ELFUTILS is not set
# BR2_PACKAGE_ELL is not set
# BR2_PACKAGE_FFTW is not set
# flann needs a toolchain w/ C++, dynamic library, gcc >= 4.7
# flatbuffers needs a toolchain w/ C++, gcc >= 4.7
# BR2_PACKAGE_FLATCC is not set
# BR2_PACKAGE_FXDIV is not set
# BR2_PACKAGE_GCONF is not set
# gdal needs a toolchain w/ C++, dynamic library, gcc >= 4.7, not binutils bug 27597, threads, wchar
# gflags needs a toolchain w/ C++
# gli needs a toolchain w/ C++
# glibmm needs a toolchain w/ C++, wchar, threads, gcc >= 7
# glibmm (2.66.x) needs a toolchain w/ C++, wchar, threads, gcc >= 4.9
# glm needs a toolchain w/ C++
# BR2_PACKAGE_GMP is not set
BR2_PACKAGE_GOBJECT_INTROSPECTION_ARCH_SUPPORTS=y
# gobject-introspection needs python3
# BR2_PACKAGE_GSL is not set
# gtest needs a toolchain w/ C++, wchar, threads, gcc >= 5
# BR2_PACKAGE_GUMBO_PARSER is not set
# highway needs a toolchain w/ C++, gcc >= 7
BR2_PACKAGE_JEMALLOC_ARCH_SUPPORTS=y
# BR2_PACKAGE_JEMALLOC is not set
BR2_PACKAGE_LAPACK_ARCH_SUPPORTS=y
# lapack/blas needs a toolchain w/ fortran
BR2_PACKAGE_LIBABSEIL_CPP_ARCH_SUPPORTS=y
# libabseil-cpp needs a toolchain w/ gcc >= 4.9, C++, threads, dynamic library
# BR2_PACKAGE_LIBARGTABLE2 is not set
BR2_PACKAGE_LIBATOMIC_OPS_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBATOMIC_OPS is not set
# BR2_PACKAGE_LIBAVL is not set
# BR2_PACKAGE_LIBB64 is not set
# BR2_PACKAGE_LIBBACKTRACE is not set
BR2_PACKAGE_LIBBSD_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBBSD is not set
# BR2_PACKAGE_LIBBYTESIZE is not set
# BR2_PACKAGE_LIBCAP is not set
# BR2_PACKAGE_LIBCAP_NG is not set
# libcgroup needs a toolchain w/ C++
# BR2_PACKAGE_LIBCLC is not set
# BR2_PACKAGE_LIBCOFI is not set
# BR2_PACKAGE_LIBCORRECT is not set
# libcrossguid needs a toolchain w/ C++, gcc >= 4.7
# BR2_PACKAGE_LIBCSV is not set
# BR2_PACKAGE_LIBDAEMON is not set
# BR2_PACKAGE_LIBDILL is not set
# BR2_PACKAGE_LIBEE is not set
# BR2_PACKAGE_LIBEV is not set
# BR2_PACKAGE_LIBEVDEV is not set
# BR2_PACKAGE_LIBEVENT is not set
# libexecinfo needs a musl or uclibc toolchain w/ dynamic library
# BR2_PACKAGE_LIBFFI is not set
# libfutils needs a toolchain w/ C++, threads
# BR2_PACKAGE_LIBGEE is not set
# libgeos needs a toolchain w/ C++, wchar, gcc >= 4.9, threads not binutils bug 27597
# BR2_PACKAGE_LIBGLIB2 is not set
# BR2_PACKAGE_LIBGLOB is not set
# libical needs a toolchain w/ C++, dynamic library, wchar
# BR2_PACKAGE_LIBITE is not set
# libks needs a toolchain w/ C++, NPTL, dynamic library
# liblinear needs a toolchain w/ C++
# libloki needs a toolchain w/ C++, threads
# BR2_PACKAGE_LIBNPTH is not set
BR2_PACKAGE_LIBNSPR_ARCH_SUPPORT=y
# BR2_PACKAGE_LIBNSPR is not set
# libosmium needs a toolchain w/ C++, wchar, threads, gcc >= 4.7
# libpeas needs python3
# BR2_PACKAGE_LIBPFM4 is not set
# libplist needs a toolchain w/ C++, threads
BR2_PACKAGE_LIBPTHREAD_STUBS=y
# BR2_PACKAGE_LIBPTHSEM is not set
# BR2_PACKAGE_LIBPWQUALITY is not set
# BR2_PACKAGE_LIBQB is not set
BR2_PACKAGE_LIBSECCOMP_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBSECCOMP is not set
# libshdata needs a toolchain w/ C++, threads
# libsigc++ needs a toolchain w/ C++, gcc >= 7
# libsigc++ (2.x.x) needs a toolchain w/ C++, gcc >= 4.9
BR2_PACKAGE_LIBSIGSEGV_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBSIGSEGV is not set
# BR2_PACKAGE_LIBSOLV is not set
# libspatialindex needs a toolchain w/ C++, gcc >= 4.7
# BR2_PACKAGE_LIBTALLOC is not set
# BR2_PACKAGE_LIBTASN1 is not set
# BR2_PACKAGE_LIBTOMMATH is not set
# BR2_PACKAGE_LIBTPL is not set
# BR2_PACKAGE_LIBUBOX is not set
# BR2_PACKAGE_LIBUCI is not set
BR2_PACKAGE_LIBUNWIND_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBUNWIND is not set
BR2_PACKAGE_LIBURCU_ARCH_SUPPORTS=y
# liburcu needs a toolchain w/ threads, C++
# BR2_PACKAGE_LIBURING is not set
# BR2_PACKAGE_LIBUV is not set
# BR2_PACKAGE_LIGHTNING is not set
# BR2_PACKAGE_LINUX_PAM is not set
# BR2_PACKAGE_LIQUID_DSP is not set
BR2_PACKAGE_LLVM_ARCH_SUPPORTS=y
BR2_PACKAGE_LLVM_TARGET_ARCH="ARM"
# llvm needs a toolchain w/ wchar, threads, C++, gcc >= 7, dynamic library, host gcc >= 7
# lttng-libust needs a toolchain w/ dynamic library, wchar, threads, C++
# BR2_PACKAGE_MATIO is not set
# BR2_PACKAGE_MPC is not set
# BR2_PACKAGE_MPDECIMAL is not set
# BR2_PACKAGE_MPFR is not set
# BR2_PACKAGE_MPIR is not set
# msgpack needs a toolchain w/ C++
# BR2_PACKAGE_NEON_2_SSE is not set
BR2_PACKAGE_OPENBLAS_DEFAULT_TARGET="ARMV7"
BR2_PACKAGE_OPENBLAS_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPENBLAS is not set
# BR2_PACKAGE_ORC is not set
# BR2_PACKAGE_P11_KIT is not set
BR2_PACKAGE_POCO_ARCH_SUPPORTS=y
# poco needs a toolchain w/ wchar, NPTL, C++, dynamic library, gcc >= 5 w/ C++14
BR2_PACKAGE_HOST_PROTOBUF_ARCH_SUPPORTS=y
BR2_PACKAGE_PROTOBUF_ARCH_SUPPORTS=y
# protobuf needs a toolchain w/ C++, threads, dynamic library, gcc >= 4.8
# protobuf-c needs a toolchain w/ C++, threads
# protozero needs a toolchain w/ C++, gcc >= 4.7
# qhull needs a toolchain w/ C++, gcc >= 4.4
# BR2_PACKAGE_QLIBC is not set
# BR2_PACKAGE_REPROC is not set
# riemann-c-client needs a toolchain w/ C++, threads
# shapelib needs a toolchain w/ C++, threads
# BR2_PACKAGE_SKALIBS is not set
# BR2_PACKAGE_SPHINXBASE is not set
# tbb needs a glibc or musl toolchain w/ dynamic library, threads, C++
# BR2_PACKAGE_TINYCBOR is not set
# tl-expected needs a toolchain w/ C++, gcc >= 4.8
# uvw needs a toolchain w/ NPTL, dynamic library, C++, gcc >= 7
# volk needs a toolchain w/ C++, NPTL, wchar, dynamic library
# xapian needs a toolchain w/ C++
# Security
# BR2_PACKAGE_LIBAPPARMOR is not set
# BR2_PACKAGE_LIBSELINUX is not set
# BR2_PACKAGE_LIBSEMANAGE is not set
# BR2_PACKAGE_LIBSEPOL is not set
# BR2_PACKAGE_SAFECLIB is not set
# softhsm2 needs a toolchain w/ C++, threads, gcc >= 4.8 and dynamic library support
# Text and terminal handling
# BR2_PACKAGE_AUGEAS is not set
# cli11 needs a toolchain w/ C++, gcc >= 4.8
# docopt-cpp needs a toolchain w/ C++, gcc >= 4.7
# enchant needs a toolchain w/ C++, threads, wchar
# fmt needs a toolchain w/ C++, wchar
# BR2_PACKAGE_FSTRCMP is not set
# icu needs a toolchain w/ C++, wchar, threads, gcc >= 4.9, host gcc >= 4.9
# BR2_PACKAGE_INIH is not set
# BR2_PACKAGE_LIBCLI is not set
# BR2_PACKAGE_LIBEDIT is not set
# BR2_PACKAGE_LIBENCA is not set
# BR2_PACKAGE_LIBESTR is not set
# BR2_PACKAGE_LIBFRIBIDI is not set
# BR2_PACKAGE_LIBUNIBREAK is not set
# BR2_PACKAGE_LIBUNISTRING is not set
# BR2_PACKAGE_LINENOISE is not set
# BR2_PACKAGE_NCURSES is not set
# BR2_PACKAGE_NEWT is not set
# BR2_PACKAGE_ONIGURUMA is not set
# BR2_PACKAGE_PCRE is not set
# BR2_PACKAGE_PCRE2 is not set
# BR2_PACKAGE_POPT is not set
# re2 needs a toolchain w/ C++, threads, gcc >= 4.8
# BR2_PACKAGE_READLINE is not set
# BR2_PACKAGE_SLANG is not set
# tclap needs a toolchain w/ C++
# termcolor needs a toolchain w/ C++, gcc >= 4.8
# BR2_PACKAGE_UTF8PROC is not set
# Mail
# BR2_PACKAGE_DOVECOT is not set
# BR2_PACKAGE_EXIM is not set
# BR2_PACKAGE_FETCHMAIL is not set
# BR2_PACKAGE_HEIRLOOM_MAILX is not set
# BR2_PACKAGE_LIBESMTP is not set
# BR2_PACKAGE_MSMTP is not set
# BR2_PACKAGE_MUTT is not set
# Miscellaneous
# BR2_PACKAGE_AESPIPE is not set
# BR2_PACKAGE_BC is not set
BR2_PACKAGE_BITCOIN_ARCH_SUPPORTS=y
# bitcoin needs a toolchain w/ C++, threads, wchar
# clamav needs a toolchain w/ C++, dynamic library, threads, wchar
# BR2_PACKAGE_COLLECTD is not set
# BR2_PACKAGE_COLLECTL is not set
# domoticz needs lua 5.3 and a toolchain w/ C++, gcc >= 6, NPTL, wchar, dynamic library
# BR2_PACKAGE_EMPTY is not set
# BR2_PACKAGE_FFT_EVAL is not set
# BR2_PACKAGE_GITLAB_RUNNER is not set
# gnuradio needs a toolchain w/ C++, NPTL, wchar, dynamic library, gcc >= 8
# BR2_PACKAGE_GOOGLEFONTDIRECTORY is not set
# gqrx needs a toolchain w/ C++, threads, wchar, dynamic library, gcc >= 8
# gqrx needs qt5
# BR2_PACKAGE_GSETTINGS_DESKTOP_SCHEMAS is not set
# BR2_PACKAGE_HAVEGED is not set
# BR2_PACKAGE_LINUX_SYSCALL_SUPPORT is not set
# BR2_PACKAGE_MOBILE_BROADBAND_PROVIDER_INFO is not set
# BR2_PACKAGE_NETDATA is not set
# proj needs a toolchain w/ C++, gcc >= 4.7, threads, wchar
BR2_PACKAGE_QEMU_ARCH_SUPPORTS_TARGET=y
# BR2_PACKAGE_QEMU is not set
# qpdf needs a toolchain w/ C++, gcc >= 5
# BR2_PACKAGE_RTL_433 is not set
# BR2_PACKAGE_SHARED_MIME_INFO is not set
# sunwait needs a toolchain w/ C++
# taskd needs a toolchain w/ C++, wchar, dynamic library
BR2_PACKAGE_XMRIG_ARCH_SUPPORTS=y
# xmrig needs a glibc or musl toolchain w/ NPTL, dynamic library, C++, gcc >= 4.9
# BR2_PACKAGE_XUTIL_UTIL_MACROS is not set
BR2_PACKAGE_Z3_ARCH_SUPPORTS=y
# Networking applications
# aircrack-ng needs a toolchain w/ dynamic library, threads, C++
# BR2_PACKAGE_ALFRED is not set
# BR2_PACKAGE_AOETOOLS is not set
# BR2_PACKAGE_APACHE is not set
# BR2_PACKAGE_ARGUS is not set
# BR2_PACKAGE_ARP_SCAN is not set
# BR2_PACKAGE_ARPTABLES is not set
# asterisk needs a glibc or uClibc toolchain w/ C++, dynamic library, threads, wchar
# BR2_PACKAGE_ATFTP is not set
# BR2_PACKAGE_AVAHI is not set
# BR2_PACKAGE_AXEL is not set
# BR2_PACKAGE_BABELD is not set
# BR2_PACKAGE_BANDWIDTHD is not set
# BR2_PACKAGE_BATCTL is not set
# bcusdk needs a toolchain w/ C++
# BR2_PACKAGE_BIND is not set
# BR2_PACKAGE_BIRD is not set
# BR2_PACKAGE_BLUEZ5_UTILS is not set
# BR2_PACKAGE_BMON is not set
# BR2_PACKAGE_BMX7 is not set
# boinc needs a toolchain w/ dynamic library, C++, threads, gcc >= 4.8
# BR2_PACKAGE_BRCM_PATCHRAM_PLUS is not set
# BR2_PACKAGE_BRIDGE_UTILS is not set
# BR2_PACKAGE_BWM_NG is not set
# BR2_PACKAGE_C_ICAP is not set
# BR2_PACKAGE_CAN_UTILS is not set
# cannelloni needs a toolchain w/ C++, threads, dynamic library, gcc >= 4.8
# BR2_PACKAGE_CASYNC is not set
# BR2_PACKAGE_CFM is not set
# BR2_PACKAGE_CHRONY is not set
# BR2_PACKAGE_CIVETWEB is not set
# BR2_PACKAGE_CONNMAN is not set
# connman-gtk needs libgtk3 and a glibc or uClibc toolchain w/ wchar, threads, resolver, dynamic library
# BR2_PACKAGE_CONNTRACK_TOOLS is not set
# BR2_PACKAGE_CORKSCREW is not set
# BR2_PACKAGE_CRDA is not set
# ctorrent needs a toolchain w/ C++
# cups needs a toolchain w/ C++, threads
# cups-filters needs a toolchain w/ wchar, C++, threads and dynamic library, gcc >= 5
# BR2_PACKAGE_DANTE is not set
# BR2_PACKAGE_DARKHTTPD is not set
# BR2_PACKAGE_DEHYDRATED is not set
# BR2_PACKAGE_DHCPCD is not set
# BR2_PACKAGE_DHCPDUMP is not set
# BR2_PACKAGE_DNSMASQ is not set
# BR2_PACKAGE_DRBD_UTILS is not set
# BR2_PACKAGE_DROPBEAR is not set
# BR2_PACKAGE_EASYFRAMES is not set
# BR2_PACKAGE_EBTABLES is not set
# ejabberd needs erlang, toolchain w/ C++
# BR2_PACKAGE_ETHTOOL is not set
# BR2_PACKAGE_FAIFA is not set
# BR2_PACKAGE_FASTD is not set
# BR2_PACKAGE_FCGIWRAP is not set
# BR2_PACKAGE_FIREWALLD is not set
# BR2_PACKAGE_FLANNEL is not set
# BR2_PACKAGE_FPING is not set
# BR2_PACKAGE_FREERADIUS_SERVER is not set
# freeswitch needs a toolchain w/ C++, dynamic library, threads, wchar
# BR2_PACKAGE_FRR is not set
# gerbera needs a toolchain w/ C++, dynamic library, threads, wchar, gcc >= 8
# BR2_PACKAGE_GESFTPSERVER is not set
# gloox needs a toolchain w/ C++
# BR2_PACKAGE_GLORYTUN is not set
# gupnp-tools needs libgtk3
# hans needs a toolchain w/ C++
BR2_PACKAGE_HAPROXY_ARCH_SUPPORTS=y
# BR2_PACKAGE_HAPROXY is not set
# BR2_PACKAGE_HIAWATHA is not set
# BR2_PACKAGE_HOSTAPD is not set
# BR2_PACKAGE_HTPDATE is not set
# BR2_PACKAGE_HTTPING is not set
# i2pd needs a toolchain w/ C++, NPTL, wchar
# ibrdtn-tools needs a toolchain w/ C++, threads
# ibrdtnd needs a toolchain w/ C++, threads
# BR2_PACKAGE_IFMETRIC is not set
# BR2_PACKAGE_IFTOP is not set
BR2_PACKAGE_IFUPDOWN_SCRIPTS=y
# BR2_PACKAGE_IGD2_FOR_LINUX is not set
# BR2_PACKAGE_IGH_ETHERCAT is not set
# BR2_PACKAGE_IGMPPROXY is not set
# BR2_PACKAGE_INADYN is not set
# BR2_PACKAGE_IODINE is not set
# iperf needs a toolchain w/ C++
# BR2_PACKAGE_IPERF3 is not set
# BR2_PACKAGE_IPROUTE2 is not set
# BR2_PACKAGE_IPSET is not set
# BR2_PACKAGE_IPTABLES is not set
# BR2_PACKAGE_IPTRAF_NG is not set
# BR2_PACKAGE_IPUTILS is not set
# BR2_PACKAGE_IRSSI is not set
# BR2_PACKAGE_IW is not set
# BR2_PACKAGE_IWD is not set
# BR2_PACKAGE_JANUS_GATEWAY is not set
# BR2_PACKAGE_KEEPALIVED is not set
# kismet needs a toolchain w/ threads, C++, gcc >= 5
# BR2_PACKAGE_KNOCK is not set
# BR2_PACKAGE_KSMBD_TOOLS is not set
# BR2_PACKAGE_LEAFNODE2 is not set
# BR2_PACKAGE_LFT is not set
# lftp requires a toolchain w/ C++, wchar
# BR2_PACKAGE_LIGHTTPD is not set
# linknx needs a toolchain w/ C++
# BR2_PACKAGE_LINKS is not set
# linphone needs a toolchain w/ threads, C++, dynamic library, wchar, gcc >= 5
# BR2_PACKAGE_LINUX_ZIGBEE is not set
# BR2_PACKAGE_LINUXPTP is not set
# BR2_PACKAGE_LLDPD is not set
# BR2_PACKAGE_LRZSZ is not set
# BR2_PACKAGE_LYNX is not set
# BR2_PACKAGE_MACCHANGER is not set
# BR2_PACKAGE_MEMCACHED is not set
# BR2_PACKAGE_MII_DIAG is not set
# BR2_PACKAGE_MINI_SNMPD is not set
# BR2_PACKAGE_MINIDLNA is not set
# BR2_PACKAGE_MINISSDPD is not set
# BR2_PACKAGE_MJPG_STREAMER is not set
# BR2_PACKAGE_MODEM_MANAGER is not set
BR2_PACKAGE_MONGREL2_LIBC_SUPPORTS=y
# mongrel2 needs a uClibc or glibc toolchain w/ C++, threads, dynamic library
# mosh needs a toolchain w/ C++, threads, dynamic library, wchar, gcc >= 4.8
# BR2_PACKAGE_MOSQUITTO is not set
# BR2_PACKAGE_MROUTED is not set
# BR2_PACKAGE_MRP is not set
# BR2_PACKAGE_MSTPD is not set
# BR2_PACKAGE_MTR is not set
# BR2_PACKAGE_NBD is not set
# BR2_PACKAGE_NCFTP is not set
# BR2_PACKAGE_NDISC6 is not set
# BR2_PACKAGE_NETATALK is not set
# BR2_PACKAGE_NETCALC is not set
# BR2_PACKAGE_NETPLUG is not set
# BR2_PACKAGE_NETSNMP is not set
# BR2_PACKAGE_NETSTAT_NAT is not set
# NetworkManager needs udev /dev management and a glibc toolchain w/ headers >= 4.6, dynamic library, wchar, threads, gcc >= 4.9
# BR2_PACKAGE_NFACCT is not set
# BR2_PACKAGE_NFTABLES is not set
# BR2_PACKAGE_NGINX is not set
# BR2_PACKAGE_NGIRCD is not set
# BR2_PACKAGE_NGREP is not set
# nload needs a toolchain w/ C++
# nmap-nmap needs a toolchain w/ C++, threads
# BR2_PACKAGE_NOIP is not set
# BR2_PACKAGE_NTP is not set
# BR2_PACKAGE_NTPSEC is not set
# BR2_PACKAGE_NUTTCP is not set
# BR2_PACKAGE_ODHCP6C is not set
# BR2_PACKAGE_ODHCPLOC is not set
# BR2_PACKAGE_OLSR is not set
# BR2_PACKAGE_OPEN_ISCSI is not set
# BR2_PACKAGE_OPEN_LLDP is not set
# BR2_PACKAGE_OPEN_PLC_UTILS is not set
# BR2_PACKAGE_OPENNTPD is not set
# BR2_PACKAGE_OPENOBEX is not set
# BR2_PACKAGE_OPENRESOLV is not set
# BR2_PACKAGE_OPENSSH is not set
# BR2_PACKAGE_OPENSWAN is not set
# BR2_PACKAGE_OPENVPN is not set
# BR2_PACKAGE_P910ND is not set
# BR2_PACKAGE_PARPROUTED is not set
# BR2_PACKAGE_PHIDGETWEBSERVICE is not set
# BR2_PACKAGE_PHYTOOL is not set
# BR2_PACKAGE_PIMD is not set
# BR2_PACKAGE_PIXIEWPS is not set
# BR2_PACKAGE_POUND is not set
# BR2_PACKAGE_PPPD is not set
# BR2_PACKAGE_PPTP_LINUX is not set
# BR2_PACKAGE_PRIVOXY is not set
# BR2_PACKAGE_PROFTPD is not set
# prosody needs the lua interpreter, dynamic library
# BR2_PACKAGE_PROXYCHAINS_NG is not set
# BR2_PACKAGE_PTPD is not set
# BR2_PACKAGE_PTPD2 is not set
# BR2_PACKAGE_PURE_FTPD is not set
# BR2_PACKAGE_PUTTY is not set
# BR2_PACKAGE_QUAGGA is not set
# BR2_PACKAGE_RADVD is not set
# BR2_PACKAGE_REAVER is not set
# BR2_PACKAGE_REDIR is not set
# BR2_PACKAGE_RP_PPPOE is not set
# BR2_PACKAGE_RPCBIND is not set
# BR2_PACKAGE_RSH_REDONE is not set
# BR2_PACKAGE_RSYNC is not set
# rtorrent needs a toolchain w/ C++, threads, wchar, gcc >= 4.9
# BR2_PACKAGE_RTPTOOLS is not set
# rygel needs python3 and a glibc toolchain w/ wchar, threads, gcc >= 4.9, host gcc >= 8
# BR2_PACKAGE_S6_DNS is not set
# BR2_PACKAGE_S6_NETWORKING is not set
# BR2_PACKAGE_SAMBA4 is not set
# sconeserver needs a toolchain with dynamic library, C++, NPTL
# BR2_PACKAGE_SER2NET is not set
# BR2_PACKAGE_SHADOWSOCKS_LIBEV is not set
# shairport-sync needs a toolchain w/ C++, NPTL
# BR2_PACKAGE_SHELLINABOX is not set
# BR2_PACKAGE_SMCROUTE is not set
# BR2_PACKAGE_SNGREP is not set
# BR2_PACKAGE_SNORT is not set
# snort3 needs a toolchain w/ C++, wchar, threads, dynamic library, gcc >= 4.9
# BR2_PACKAGE_SOCAT is not set
# BR2_PACKAGE_SOCKETCAND is not set
# BR2_PACKAGE_SOFTETHER is not set
# BR2_PACKAGE_SPAWN_FCGI is not set
# BR2_PACKAGE_SPICE_PROTOCOL is not set
# squid needs a toolchain w/ C++, threads, gcc >= 4.8 not affected by bug 64735
# BR2_PACKAGE_SSDP_RESPONDER is not set
# BR2_PACKAGE_SSHGUARD is not set
# BR2_PACKAGE_SSHPASS is not set
# BR2_PACKAGE_SSLH is not set
# BR2_PACKAGE_STRONGSWAN is not set
# BR2_PACKAGE_STUNNEL is not set
# BR2_PACKAGE_SURICATA is not set
# BR2_PACKAGE_TCPDUMP is not set
# BR2_PACKAGE_TCPING is not set
# BR2_PACKAGE_TCPREPLAY is not set
# BR2_PACKAGE_THTTPD is not set
# BR2_PACKAGE_TINC is not set
# BR2_PACKAGE_TINYPROXY is not set
# BR2_PACKAGE_TINYSSH is not set
# BR2_PACKAGE_TOR is not set
# BR2_PACKAGE_TRACEROUTE is not set
# transmission needs a toolchain w/ dynamic library, threads, C++, gcc >= 7
# BR2_PACKAGE_TUNCTL is not set
# BR2_PACKAGE_TVHEADEND is not set
# BR2_PACKAGE_UACME is not set
# BR2_PACKAGE_UDPCAST is not set
# BR2_PACKAGE_UFTP is not set
# BR2_PACKAGE_UHTTPD is not set
# BR2_PACKAGE_ULOGD is not set
# BR2_PACKAGE_UNBOUND is not set
# BR2_PACKAGE_UQMI is not set
# BR2_PACKAGE_UREDIR is not set
# BR2_PACKAGE_USHARE is not set
# BR2_PACKAGE_USSP_PUSH is not set
# BR2_PACKAGE_VDE2 is not set
# vdr needs a toolchain w/ C++, dynamic library, NPTL, wchar, headers >= 3.9
# BR2_PACKAGE_VNSTAT is not set
# BR2_PACKAGE_VPNC is not set
# BR2_PACKAGE_VSFTPD is not set
# BR2_PACKAGE_VTUN is not set
# BR2_PACKAGE_WAVEMON is not set
# BR2_PACKAGE_WIREGUARD_LINUX_COMPAT is not set
# BR2_PACKAGE_WIREGUARD_TOOLS is not set
# BR2_PACKAGE_WIRELESS_REGDB is not set
# BR2_PACKAGE_WIRELESS_TOOLS is not set
# wireshark needs a toolchain w/ wchar, threads, dynamic library, C++
BR2_PACKAGE_WPA_SUPPLICANT=y
BR2_PACKAGE_WPA_SUPPLICANT_NL80211=y
# BR2_PACKAGE_WPA_SUPPLICANT_WEXT is not set
# BR2_PACKAGE_WPA_SUPPLICANT_WIRED is not set
# BR2_PACKAGE_WPA_SUPPLICANT_IBSS_RSN is not set
# BR2_PACKAGE_WPA_SUPPLICANT_AP_SUPPORT is not set
# BR2_PACKAGE_WPA_SUPPLICANT_OVERRIDES is not set
BR2_PACKAGE_WPA_SUPPLICANT_AUTOSCAN=y
# BR2_PACKAGE_WPA_SUPPLICANT_EAP is not set
# BR2_PACKAGE_WPA_SUPPLICANT_HOTSPOT is not set
# BR2_PACKAGE_WPA_SUPPLICANT_DEBUG_SYSLOG is not set
# BR2_PACKAGE_WPA_SUPPLICANT_WPS is not set
# BR2_PACKAGE_WPA_SUPPLICANT_WPA3 is not set
# BR2_PACKAGE_WPA_SUPPLICANT_CLI is not set
# BR2_PACKAGE_WPA_SUPPLICANT_WPA_CLIENT_SO is not set
# BR2_PACKAGE_WPA_SUPPLICANT_PASSPHRASE is not set
# BR2_PACKAGE_WPA_SUPPLICANT_CTRL_IFACE is not set
# BR2_PACKAGE_WPA_SUPPLICANT_DBUS is not set
# BR2_PACKAGE_WPAN_TOOLS is not set
# BR2_PACKAGE_XINETD is not set
# BR2_PACKAGE_XL2TP is not set
# BR2_PACKAGE_XTABLES_ADDONS is not set
# BR2_PACKAGE_ZABBIX is not set
# zeek needs a toolchain w/ C++, wchar, threads, dynamic library, gcc >= 7, host gcc >= 7
# znc needs a toolchain w/ C++, dynamic library, gcc >= 4.8, threads
# Package managers
# Please note:
# - Buildroot does *not* generate binary packages,
# - Buildroot does *not* install any package database.
# It is up to you to provide those by yourself if you
# want to use any of those package managers.
# See the manual:
# http://buildroot.org/manual.html#faq-no-binary-packages
# BR2_PACKAGE_OPKG is not set
# BR2_PACKAGE_OPKG_UTILS is not set
# Real-Time
BR2_PACKAGE_XENOMAI_COBALT_ARCH_SUPPORTS=y
# BR2_PACKAGE_XENOMAI is not set
# Security
# apparmor needs a toolchain w/ headers >= 3.16, threads, C++
# BR2_PACKAGE_CHECKPOLICY is not set
# BR2_PACKAGE_IMA_EVM_UTILS is not set
# BR2_PACKAGE_OPTEE_CLIENT is not set
# BR2_PACKAGE_PAXTEST is not set
# BR2_PACKAGE_POLICYCOREUTILS is not set
# BR2_PACKAGE_REFPOLICY is not set
# BR2_PACKAGE_RESTORECOND is not set
# BR2_PACKAGE_SELINUX_PYTHON is not set
# BR2_PACKAGE_SEMODULE_UTILS is not set
# setools needs python3
BR2_PACKAGE_URANDOM_SCRIPTS=y
# Shell and utilities
# Shells
# BR2_PACKAGE_MKSH is not set
# BR2_PACKAGE_NUSHELL is not set
# BR2_PACKAGE_ZSH is not set
# Utilities
# BR2_PACKAGE_APG is not set
# BR2_PACKAGE_AT is not set
# BR2_PACKAGE_CATATONIT is not set
# BR2_PACKAGE_CCRYPT is not set
# BR2_PACKAGE_DIALOG is not set
# BR2_PACKAGE_DTACH is not set
# BR2_PACKAGE_EASY_RSA is not set
# BR2_PACKAGE_EZA is not set
# BR2_PACKAGE_FILE is not set
# BR2_PACKAGE_GNUPG is not set
BR2_PACKAGE_GNUPG2_DEPENDS=y
# BR2_PACKAGE_GNUPG2 is not set
# BR2_PACKAGE_INOTIFY_TOOLS is not set
# BR2_PACKAGE_LOCKFILE_PROGS is not set
# BR2_PACKAGE_LOGROTATE is not set
# BR2_PACKAGE_LOGSURFER is not set
# BR2_PACKAGE_PDMENU is not set
# BR2_PACKAGE_PINENTRY is not set
# BR2_PACKAGE_QPRINT is not set
# BR2_PACKAGE_RANGER is not set
# BR2_PACKAGE_RTTY is not set
# BR2_PACKAGE_SCREEN is not set
# BR2_PACKAGE_SEXPECT is not set
# BR2_PACKAGE_SUDO is not set
# BR2_PACKAGE_TINI is not set
# BR2_PACKAGE_TMUX is not set
# BR2_PACKAGE_TTYD is not set
# BR2_PACKAGE_WTFUTIL is not set
# BR2_PACKAGE_XMLSTARLET is not set
# BR2_PACKAGE_XXHASH is not set
# BR2_PACKAGE_YTREE is not set
# System tools
# BR2_PACKAGE_ACL is not set
# BR2_PACKAGE_ANDROID_TOOLS is not set
# BR2_PACKAGE_ATOP is not set
# BR2_PACKAGE_ATTR is not set
BR2_PACKAGE_AUDIT_ARCH_SUPPORTS=y
# BR2_PACKAGE_AUDIT is not set
# BR2_PACKAGE_BALENA_ENGINE is not set
# BR2_PACKAGE_BUBBLEWRAP is not set
# BR2_PACKAGE_CGROUPFS_MOUNT is not set
# circus needs Python 3 and a toolchain w/ C++, threads
# BR2_PACKAGE_CONMON is not set
# BR2_PACKAGE_CONTAINERD is not set
# BR2_PACKAGE_CPULIMIT is not set
# BR2_PACKAGE_CPULOAD is not set
BR2_PACKAGE_CRIU_ARCH_SUPPORTS=y
# BR2_PACKAGE_CRUN is not set
# BR2_PACKAGE_DAEMON is not set
# BR2_PACKAGE_DC3DD is not set
# ddrescue needs a toolchain w/ C++
# BR2_PACKAGE_DOCKER_CLI is not set
# docker-compose needs docker-cli and a toolchain w/ threads
# BR2_PACKAGE_DOCKER_ENGINE is not set
# BR2_PACKAGE_EARLYOOM is not set
# BR2_PACKAGE_EFIBOOTMGR is not set
BR2_PACKAGE_EFIVAR_ARCH_SUPPORTS=y
# BR2_PACKAGE_EFIVAR is not set
# BR2_PACKAGE_EMBIGGEN_DISK is not set
# BR2_PACKAGE_EMLOG is not set
# BR2_PACKAGE_FLUENT_BIT is not set
# BR2_PACKAGE_FTOP is not set
# BR2_PACKAGE_GETENT is not set
# BR2_PACKAGE_GKRELLM is not set
# BR2_PACKAGE_HTOP is not set
# BR2_PACKAGE_IBM_SW_TPM2 is not set
BR2_PACKAGE_INITSCRIPTS=y
# iotop depends on python3
# BR2_PACKAGE_IPRUTILS is not set
# BR2_PACKAGE_IRQBALANCE is not set
# BR2_PACKAGE_KEYUTILS is not set
# BR2_PACKAGE_KMOD is not set
# BR2_PACKAGE_KVMTOOL is not set
# libostree needs a uClibc or glibc toolchain w/ threads, dynamic library, wchar, headers >= 5.4
# BR2_PACKAGE_LXC is not set
BR2_PACKAGE_MAKEDUMPFILE_ARCH_SUPPORTS=y
# BR2_PACKAGE_MAKEDUMPFILE is not set
# BR2_PACKAGE_MENDER is not set
# BR2_PACKAGE_MENDER_CONNECT is not set
# BR2_PACKAGE_MFOC is not set
# BR2_PACKAGE_MOBY_BUILDKIT is not set
# BR2_PACKAGE_MONIT is not set
# multipath-tools needs udev and a toolchain w/ threads, dynamic library, C++
# BR2_PACKAGE_NCDU is not set
# BR2_PACKAGE_NERDCTL is not set
# netifrc needs openrc as init system
# BR2_PACKAGE_NUMACTL is not set
# nut needs a toolchain w/ C++
# pamtester depends on linux-pam
# petitboot needs a toolchain w/ wchar, dynamic library, threads, udev /dev management
# BR2_PACKAGE_POLKIT is not set
# BR2_PACKAGE_PROCRANK_LINUX is not set
# BR2_PACKAGE_PROCS is not set
# BR2_PACKAGE_PWGEN is not set
# BR2_PACKAGE_QUOTA is not set
# BR2_PACKAGE_QUOTATOOL is not set
# BR2_PACKAGE_RAUC is not set
# BR2_PACKAGE_RAUC_HAWKBIT_UPDATER is not set
# BR2_PACKAGE_RUNC is not set
# BR2_PACKAGE_S6 is not set
# BR2_PACKAGE_S6_LINUX_INIT is not set
# BR2_PACKAGE_S6_LINUX_UTILS is not set
# BR2_PACKAGE_S6_PORTABLE_UTILS is not set
# BR2_PACKAGE_S6_RC is not set
# BR2_PACKAGE_SCRUB is not set
# BR2_PACKAGE_SCRYPT is not set
# sdbus-c++ needs systemd and a toolchain w/ C++, gcc >= 7
# sdbusplus needs systemd and a toolchain w/ C++, gcc >= 7
# BR2_PACKAGE_SEATD is not set
# BR2_PACKAGE_SHADOW is not set
# BR2_PACKAGE_SMACK is not set
# supervisor needs a python interpreter
# BR2_PACKAGE_SWUPDATE is not set
BR2_PACKAGE_SYSTEMD_ARCH_SUPPORTS=y
BR2_PACKAGE_SYSTEMD_BOOTCHART_ARCH_SUPPORTS=y
# BR2_PACKAGE_TEALDEER is not set
# BR2_PACKAGE_TPM_TOOLS is not set
# BR2_PACKAGE_TPM2_ABRMD is not set
# BR2_PACKAGE_TPM2_TOOLS is not set
# BR2_PACKAGE_TPM2_TOTP is not set
# BR2_PACKAGE_UNSCD is not set
# BR2_PACKAGE_UTIL_LINUX is not set
# BR2_PACKAGE_WATCHDOG is not set
# BR2_PACKAGE_WATCHDOGD is not set
# BR2_PACKAGE_XDG_DBUS_PROXY is not set
# BR2_PACKAGE_XEN is not set
BR2_PACKAGE_XVISOR_ARCH_SUPPORTS=y
# BR2_PACKAGE_XVISOR is not set
# Text editors and viewers
# BR2_PACKAGE_BAT is not set
# BR2_PACKAGE_ED is not set
# BR2_PACKAGE_JOE is not set
# BR2_PACKAGE_MC is not set
# BR2_PACKAGE_MG is not set
# BR2_PACKAGE_MOST is not set
# BR2_PACKAGE_NANO is not set
# BR2_PACKAGE_UEMACS is not set
# Filesystem images
# BR2_TARGET_ROOTFS_AXFS is not set
# BR2_TARGET_ROOTFS_BTRFS is not set
# BR2_TARGET_ROOTFS_CLOOP is not set
# BR2_TARGET_ROOTFS_CPIO is not set
# BR2_TARGET_ROOTFS_CRAMFS is not set
# BR2_TARGET_ROOTFS_EROFS is not set
BR2_TARGET_ROOTFS_EXT2=y
# BR2_TARGET_ROOTFS_EXT2_2r0 is not set
# BR2_TARGET_ROOTFS_EXT2_2r1 is not set
# BR2_TARGET_ROOTFS_EXT2_3 is not set
BR2_TARGET_ROOTFS_EXT2_4=y
BR2_TARGET_ROOTFS_EXT2_GEN=4
BR2_TARGET_ROOTFS_EXT2_REV=1
BR2_TARGET_ROOTFS_EXT2_LABEL="rootfs"
BR2_TARGET_ROOTFS_EXT2_SIZE="60M"
BR2_TARGET_ROOTFS_EXT2_INODES=0
BR2_TARGET_ROOTFS_EXT2_INODE_SIZE=256
BR2_TARGET_ROOTFS_EXT2_RESBLKS=5
BR2_TARGET_ROOTFS_EXT2_MKFS_OPTIONS="-O ^64bit"
BR2_TARGET_ROOTFS_EXT2_NONE=y
# BR2_TARGET_ROOTFS_EXT2_GZIP is not set
# BR2_TARGET_ROOTFS_EXT2_BZIP2 is not set
# BR2_TARGET_ROOTFS_EXT2_LZ4 is not set
# BR2_TARGET_ROOTFS_EXT2_LZMA is not set
# BR2_TARGET_ROOTFS_EXT2_LZO is not set
# BR2_TARGET_ROOTFS_EXT2_XZ is not set
# BR2_TARGET_ROOTFS_EXT2_ZSTD is not set
# BR2_TARGET_ROOTFS_F2FS is not set
# BR2_TARGET_ROOTFS_INITRAMFS is not set
# BR2_TARGET_ROOTFS_JFFS2 is not set
# BR2_TARGET_ROOTFS_OCI is not set
# BR2_TARGET_ROOTFS_ROMFS is not set
# BR2_TARGET_ROOTFS_SQUASHFS is not set
BR2_TARGET_ROOTFS_TAR=y
BR2_TARGET_ROOTFS_TAR_NONE=y
# BR2_TARGET_ROOTFS_TAR_GZIP is not set
# BR2_TARGET_ROOTFS_TAR_BZIP2 is not set
# BR2_TARGET_ROOTFS_TAR_LZ4 is not set
# BR2_TARGET_ROOTFS_TAR_LZMA is not set
# BR2_TARGET_ROOTFS_TAR_LZO is not set
# BR2_TARGET_ROOTFS_TAR_XZ is not set
# BR2_TARGET_ROOTFS_TAR_ZSTD is not set
BR2_TARGET_ROOTFS_TAR_OPTIONS=""
# BR2_TARGET_ROOTFS_UBI is not set
# BR2_TARGET_ROOTFS_UBIFS is not set
# BR2_TARGET_ROOTFS_YAFFS2 is not set
# Bootloaders
# BR2_TARGET_AFBOOT_STM32 is not set
# BR2_TARGET_AT91BOOTSTRAP3 is not set
# BR2_TARGET_ARM_TRUSTED_FIRMWARE is not set
# BR2_TARGET_BAREBOX is not set
BR2_TARGET_GRUB2_ARCH_SUPPORTS=y
# BR2_TARGET_GRUB2 is not set
# BR2_TARGET_MXS_BOOTLETS is not set
# BR2_TARGET_OPTEE_OS is not set
# BR2_TARGET_S500_BOOTLOADER is not set
BR2_PACKAGE_SHIM_ARCH_SUPPORTS=y
# BR2_TARGET_SHIM is not set
BR2_TARGET_UBOOT=y
BR2_TARGET_UBOOT_BUILD_SYSTEM_KCONFIG=y
# BR2_TARGET_UBOOT_BUILD_SYSTEM_LEGACY is not set
# BR2_TARGET_UBOOT_LATEST_VERSION is not set
BR2_TARGET_UBOOT_CUSTOM_VERSION=y
# BR2_TARGET_UBOOT_CUSTOM_TARBALL is not set
# BR2_TARGET_UBOOT_CUSTOM_GIT is not set
# BR2_TARGET_UBOOT_CUSTOM_HG is not set
# BR2_TARGET_UBOOT_CUSTOM_SVN is not set
BR2_TARGET_UBOOT_CUSTOM_VERSION_VALUE="2022.01"
BR2_TARGET_UBOOT_VERSION="2022.01"
BR2_TARGET_UBOOT_PATCH=""
BR2_TARGET_UBOOT_USE_DEFCONFIG=y
# BR2_TARGET_UBOOT_USE_CUSTOM_CONFIG is not set
BR2_TARGET_UBOOT_BOARD_DEFCONFIG="LicheePi_Zero"
BR2_TARGET_UBOOT_CONFIG_FRAGMENT_FILES=""
BR2_TARGET_UBOOT_NEEDS_DTC=y
BR2_TARGET_UBOOT_NEEDS_PYTHON3=y
BR2_TARGET_UBOOT_NEEDS_PYLIBFDT=y
# BR2_TARGET_UBOOT_NEEDS_PYELFTOOLS is not set
BR2_TARGET_UBOOT_NEEDS_OPENSSL=y
# BR2_TARGET_UBOOT_NEEDS_LZOP is not set
# BR2_TARGET_UBOOT_NEEDS_GNUTLS is not set
# BR2_TARGET_UBOOT_NEEDS_UTIL_LINUX is not set
# BR2_TARGET_UBOOT_NEEDS_XXD is not set
# U-Boot binary format
# BR2_TARGET_UBOOT_FORMAT_AIS is not set
BR2_TARGET_UBOOT_FORMAT_BIN=y
# BR2_TARGET_UBOOT_FORMAT_DTB is not set
# BR2_TARGET_UBOOT_FORMAT_DTB_BIN is not set
# BR2_TARGET_UBOOT_FORMAT_NAND_BIN is not set
# BR2_TARGET_UBOOT_FORMAT_ELF is not set
# BR2_TARGET_UBOOT_FORMAT_REMAKE_ELF is not set
# BR2_TARGET_UBOOT_FORMAT_IMG is not set
# BR2_TARGET_UBOOT_FORMAT_DTB_IMG is not set
# BR2_TARGET_UBOOT_FORMAT_IMX is not set
# BR2_TARGET_UBOOT_FORMAT_DTB_IMX is not set
# BR2_TARGET_UBOOT_FORMAT_ITB is not set
# BR2_TARGET_UBOOT_FORMAT_KWB is not set
# BR2_TARGET_UBOOT_FORMAT_NAND is not set
# BR2_TARGET_UBOOT_FORMAT_SB is not set
# BR2_TARGET_UBOOT_FORMAT_SD is not set
# BR2_TARGET_UBOOT_FORMAT_STM32 is not set
BR2_TARGET_UBOOT_FORMAT_CUSTOM=y
BR2_TARGET_UBOOT_FORMAT_CUSTOM_NAME="u-boot-sunxi-with-spl.bin"
# BR2_TARGET_UBOOT_OMAP_IFT is not set
# BR2_TARGET_UBOOT_SPL is not set
BR2_TARGET_UBOOT_CUSTOM_DTS_PATH=""
BR2_TARGET_UBOOT_CUSTOM_MAKEOPTS=""
# Host utilities
# BR2_PACKAGE_HOST_ABOOTIMG is not set
# BR2_PACKAGE_HOST_AESPIPE is not set
# BR2_PACKAGE_HOST_AGENT_PROXY is not set
# BR2_PACKAGE_HOST_AMLOGIC_BOOT_FIP is not set
# BR2_PACKAGE_HOST_ANDROID_TOOLS is not set
# BR2_PACKAGE_HOST_ASN1C is not set
# BR2_PACKAGE_HOST_BABELTRACE2 is not set
# BR2_PACKAGE_HOST_BMAP_TOOLS is not set
# BR2_PACKAGE_HOST_BOOTGEN is not set
# BR2_PACKAGE_HOST_BTRFS_PROGS is not set
# BR2_PACKAGE_HOST_CBOOTIMAGE is not set
# BR2_PACKAGE_HOST_CHECKPOLICY is not set
# BR2_PACKAGE_HOST_CHECKSEC is not set
# BR2_PACKAGE_HOST_CMAKE is not set
BR2_HOST_CMAKE_AT_LEAST="3.18"
# BR2_PACKAGE_HOST_COMPOSER is not set
# BR2_PACKAGE_HOST_CRAMFS is not set
# BR2_PACKAGE_HOST_CRUDINI is not set
# BR2_PACKAGE_HOST_CRYPTSETUP is not set
# BR2_PACKAGE_HOST_DBUS_PYTHON is not set
# BR2_PACKAGE_HOST_DELVE is not set
# BR2_PACKAGE_HOST_DEPOT_TOOLS is not set
# BR2_PACKAGE_HOST_DFU_UTIL is not set
# BR2_PACKAGE_HOST_DOS2UNIX is not set
BR2_PACKAGE_HOST_DOSFSTOOLS=y
# BR2_PACKAGE_HOST_DOXYGEN is not set
BR2_PACKAGE_HOST_DTC=y
BR2_PACKAGE_HOST_E2FSPROGS=y
# BR2_PACKAGE_HOST_E2TOOLS is not set
# BR2_PACKAGE_HOST_ENVIRONMENT_SETUP is not set
# BR2_PACKAGE_HOST_EROFS_UTILS is not set
# BR2_PACKAGE_HOST_EXFATPROGS is not set
# BR2_PACKAGE_HOST_F2FS_TOOLS is not set
# BR2_PACKAGE_HOST_FAKETIME is not set
# BR2_PACKAGE_HOST_FATCAT is not set
# BR2_PACKAGE_HOST_FIRMWARE_UTILS is not set
BR2_PACKAGE_HOST_FLUTTER_SDK_BIN_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_FLUTTER_SDK_BIN is not set
# BR2_PACKAGE_HOST_FWUP is not set
# BR2_PACKAGE_HOST_GENEXT2FS is not set
BR2_PACKAGE_HOST_GENIMAGE=y
# BR2_PACKAGE_HOST_GENPART is not set
# BR2_PACKAGE_HOST_GNUPG is not set
BR2_PACKAGE_HOST_GO_TARGET_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GO_TARGET_CGO_LINKING_SUPPORTS=y
BR2_PACKAGE_HOST_GO_HOST_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GO_BOOTSTRAP_STAGE1_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GO_BOOTSTRAP_STAGE2_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_GPTFDISK is not set
# BR2_PACKAGE_HOST_IMAGEMAGICK is not set
# BR2_PACKAGE_HOST_IMX_MKIMAGE is not set
# BR2_PACKAGE_HOST_IMX_USB_LOADER is not set
# BR2_PACKAGE_HOST_JQ is not set
# BR2_PACKAGE_HOST_JSMIN is not set
BR2_PACKAGE_HOST_KMOD=y
# BR2_PACKAGE_HOST_KMOD_GZ is not set
# BR2_PACKAGE_HOST_KMOD_ZSTD is not set
# BR2_PACKAGE_HOST_KMOD_XZ is not set
# BR2_PACKAGE_HOST_LIBP11 is not set
# BR2_PACKAGE_HOST_LLD is not set
# BR2_PACKAGE_HOST_LPC3250LOADER is not set
# BR2_PACKAGE_HOST_LTTNG_BABELTRACE is not set
# BR2_PACKAGE_HOST_LZMA_ALONE is not set
# BR2_PACKAGE_HOST_MENDER_ARTIFACT is not set
# BR2_PACKAGE_HOST_MESON_TOOLS is not set
# BR2_PACKAGE_HOST_MFGTOOLS is not set
# BR2_PACKAGE_HOST_MICROCHIP_HSS_PAYLOAD_GENERATOR is not set
# BR2_PACKAGE_HOST_MKPASSWD is not set
# BR2_PACKAGE_HOST_MOBY_BUILDKIT is not set
# BR2_PACKAGE_HOST_MOSQUITTO is not set
# BR2_PACKAGE_HOST_MTD is not set
BR2_PACKAGE_HOST_MTOOLS=y
# BR2_PACKAGE_HOST_MXSLDR is not set
BR2_PACKAGE_HOST_NODEJS_BIN_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_NODEJS is not set
BR2_PACKAGE_PROVIDES_HOST_NODEJS="host-nodejs-bin"
# BR2_PACKAGE_HOST_ODB is not set
# BR2_PACKAGE_HOST_OMAP_U_BOOT_UTILS is not set
# BR2_PACKAGE_HOST_OPENOCD is not set
# BR2_PACKAGE_HOST_OPKG_UTILS is not set
# BR2_PACKAGE_HOST_PAHOLE is not set
# BR2_PACKAGE_HOST_PARTED is not set
BR2_PACKAGE_HOST_PATCHELF=y
# BR2_PACKAGE_HOST_PIGZ is not set
# BR2_PACKAGE_HOST_PKGCONF is not set
# BR2_PACKAGE_HOST_PRU_SOFTWARE_SUPPORT is not set
# BR2_PACKAGE_HOST_PWGEN is not set
# BR2_PACKAGE_HOST_PYTHON_CYTHON is not set
# BR2_PACKAGE_HOST_PYTHON_GREENLET is not set
# BR2_PACKAGE_HOST_PYTHON_INIPARSE is not set
# BR2_PACKAGE_HOST_PYTHON_LXML is not set
# BR2_PACKAGE_HOST_PYTHON_PYYAML is not set
# BR2_PACKAGE_HOST_PYTHON_SIX is not set
# BR2_PACKAGE_HOST_PYTHON_XLRD is not set
# BR2_PACKAGE_HOST_PYTHON3 is not set
BR2_PACKAGE_HOST_QEMU_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_QEMU_SYSTEM_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_QEMU_USER_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_QEMU is not set
# BR2_PACKAGE_HOST_QORIQ_RCW is not set
# BR2_PACKAGE_HOST_RASPBERRYPI_USBBOOT is not set
# BR2_PACKAGE_HOST_RAUC is not set
# BR2_PACKAGE_HOST_RISCV_ISA_SIM is not set
# BR2_PACKAGE_HOST_RUNC is not set
BR2_PACKAGE_HOST_RUSTC_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_RUSTC_TARGET_TIER2_HOST_TOOLS_PLATFORMS=y
BR2_PACKAGE_HOST_RUSTC_TARGET_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_RUSTC_ARCH="armv7"
BR2_PACKAGE_HOST_RUSTC_ABI="eabihf"
# BR2_PACKAGE_HOST_RUSTC is not set
BR2_PACKAGE_PROVIDES_HOST_RUSTC="host-rust-bin"
# BR2_PACKAGE_HOST_SAM_BA is not set
# BR2_PACKAGE_HOST_SDBUS_CPP is not set
# BR2_PACKAGE_HOST_SDBUSPLUS is not set
# BR2_PACKAGE_HOST_SENTRY_CLI is not set
# BR2_PACKAGE_HOST_SLOCI_IMAGE is not set
# BR2_PACKAGE_HOST_SQUASHFS is not set
# BR2_PACKAGE_HOST_SUNXI_TOOLS is not set
# BR2_PACKAGE_HOST_SWIG is not set
# BR2_PACKAGE_HOST_SWUGENERATOR is not set
# BR2_PACKAGE_HOST_TEGRARCM is not set
BR2_PACKAGE_HOST_TI_CGT_PRU_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_TI_CGT_PRU is not set
BR2_PACKAGE_HOST_UBOOT_TOOLS=y
# BR2_PACKAGE_HOST_UBOOT_TOOLS_FIT_SUPPORT is not set
# BR2_PACKAGE_HOST_UBOOT_TOOLS_ENVIMAGE is not set
BR2_PACKAGE_HOST_UBOOT_TOOLS_BOOT_SCRIPT=y
BR2_PACKAGE_HOST_UBOOT_TOOLS_BOOT_SCRIPT_SOURCE="board/sipeed/licheepi_zero/boot.cmd"
BR2_PACKAGE_HOST_UTIL_LINUX=y
# BR2_PACKAGE_HOST_UTP_COM is not set
# BR2_PACKAGE_HOST_UUU is not set
# BR2_PACKAGE_HOST_VBOOT_UTILS is not set
# BR2_PACKAGE_HOST_XORRISO is not set
# BR2_PACKAGE_HOST_ZIP is not set
# BR2_PACKAGE_HOST_ZSTD is not set
# Legacy config options
# Legacy options removed in 2023.11
# BR2_PACKAGE_PYTHON_PYXB is not set
# BR2_PACKAGE_OPENJDK_VERSION_11 is not set
# BR2_KERNEL_HEADERS_6_4 is not set
# BR2_PACKAGE_GOOGLE_MATERIAL_DESIGN_ICONS is not set
# BR2_GDB_VERSION_10 is not set
# Legacy options removed in 2023.08
# BR2_TARGET_LPC32XXCDL is not set
# BR2_BINUTILS_VERSION_2_38_X is not set
# BR2_GCC_VERSION_10_X is not set
# BR2_KERNEL_HEADERS_6_3 is not set
# BR2_PACKAGE_TOVID is not set
# BR2_PACKAGE_LIBASPLIB is not set
# BR2_PACKAGE_OCF_LINUX is not set
# BR2_BINUTILS_VERSION_2_37_X is not set
# Legacy options removed in 2023.05
# BR2_KERNEL_HEADERS_6_2 is not set
# BR2_PACKAGE_ATK is not set
# BR2_PACKAGE_AT_SPI2_ATK is not set
# BR2_PACKAGE_OPTEE_BENCHMARK is not set
# BR2_PACAKGE_OPENFPGALOADER_CMSIS is not set
# Legacy options removed in 2023.02
# BR2_PACKAGE_PUGIXML_HEADER_ONLY is not set
# BR2_PACKAGE_UCCP420WLAN is not set
# BR2_PACKAGE_IMX_GPU_G2D_EXAMPLES is not set
# BR2_KERNEL_HEADERS_6_0 is not set
# BR2_KERNEL_HEADERS_4_9 is not set
# BR2_PACKAGE_DOCKER_PROXY is not set
# BR2_PACKAGE_PYTHON_BUNCH is not set
# BR2_TARGET_GUMMIBOOT is not set
# BR2_PACKAGE_IPUTILS_NINFOD is not set
# BR2_PACKAGE_IPUTILS_RARPD is not set
# BR2_PACKAGE_IPUTILS_RDISC is not set
# BR2_PACKAGE_IPUTILS_RDISC_SERVER is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_XINGMUX is not set
# BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VIDEOSCALE is not set
# BR2_PACKAGE_GST1_PLUGINS_BASE_PLUGIN_VIDEOCONVERT is not set
# BR2_PACKAGE_IMX_GPU_VIV_OUTPUT_X11 is not set
# BR2_PACKAGE_XDRIVER_XF86_VIDEO_IMX_VIV is not set
BR2_PACKAGE_QEMU_CUSTOM_TARGETS=""
# BR2_PACKAGE_XDRIVER_XF86_INPUT_KEYBOARD is not set
# BR2_TARGET_SUN20I_D1_SPL is not set
# BR2_PACKAGE_PYTHON_M2R is not set
# BR2_PACKAGE_MESA3D_XVMC is not set
# BR2_KERNEL_HEADERS_5_19 is not set
# BR2_PACKAGE_XDRIVER_XF86_VIDEO_TGA is not set
# BR2_PACKAGE_XDRIVER_XF86_VIDEO_GLINT is not set
# BR2_PACKAGE_USBREDIR_SERVER is not set
# Legacy options removed in 2022.11
# BR2_BINUTILS_VERSION_2_36_X is not set
# BR2_PACKAGE_RABBITMQ_SERVER is not set
# BR2_PACKAGE_LIBOPENSSL_ENABLE_RC5 is not set
# BR2_PACKAGE_LIBDCADEC is not set
# BR2_KERNEL_HEADERS_5_17 is not set
# BR2_iwmmxt is not set
# BR2_PACKAGE_UHD_N230 is not set
# BR2_PACKAGE_UHD_RFNOC is not set
# BR2_PACKAGE_GPSD_OLDSTYLE is not set
# BR2_GDB_VERSION_9_2 is not set
# Legacy options removed in 2022.08
# BR2_ECLIPSE_REGISTER is not set
# BR2_csky is not set
# BR2_PACKAGE_MESA3D_DRI_DRIVER_I915 is not set
# BR2_PACKAGE_MESA3D_DRI_DRIVER_I965 is not set
# BR2_PACKAGE_MESA3D_DRI_DRIVER_NOUVEAU is not set
# BR2_PACKAGE_MESA3D_DRI_DRIVER_RADEON is not set
# BR2_GCC_VERSION_9_X is not set
# BR2_PACKAGE_PHP_EXT_WDDX is not set
# BR2_nds32 is not set
# BR2_PACKAGE_RTL8723BS is not set
# Legacy options removed in 2022.05
# BR2_PACKAGE_KTAP is not set
# BR2_KERNEL_HEADERS_5_16 is not set
# BR2_KERNEL_HEADERS_4_4 is not set
# BR2_BINUTILS_VERSION_2_32_X is not set
# BR2_sh2a is not set
# BR2_BINUTILS_VERSION_2_35_X is not set
# BR2_PACKAGE_BOOST_LAYOUT_TAGGED is not set
# BR2_PACKAGE_BOOST_LAYOUT_VERSIONED is not set
# Legacy options removed in 2022.02
BR2_TARGET_ROOTFS_OCI_ENTRYPOINT_ARGS=""
# BR2_PACKAGE_LIBCURL_LIBNSS is not set
# BR2_PACKAGE_WESTON_DEFAULT_FBDEV is not set
# BR2_PACKAGE_WESTON_FBDEV is not set
# BR2_PACKAGE_PYTHON_PYCLI is not set
# BR2_PACKAGE_LINUX_TOOLS_BPFTOOL is not set
# BR2_TARGET_UBOOT_NEEDS_PYTHON2 is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_LIBMMS is not set
# BR2_PACKAGE_PYTHON_FUNCTOOLS32 is not set
# BR2_PACKAGE_PYTHON_ENUM34 is not set
# BR2_PACKAGE_PYTHON_ENUM is not set
# BR2_PACKAGE_PYTHON_DIALOG is not set
# BR2_PACKAGE_PYTHON_CONFIGOBJ is not set
# BR2_PACKAGE_PYTHON_YIELDFROM is not set
# BR2_PACKAGE_PYTHON_TYPING is not set
# BR2_PACKAGE_PYTHON_SUBPROCESS32 is not set
# BR2_PACKAGE_PYTHON_SINGLEDISPATCH is not set
# BR2_PACKAGE_PYTHON_PYRO is not set
# BR2_PACKAGE_PYTHON_PYPCAP is not set
# BR2_PACKAGE_PYTHON_PATHLIB2 is not set
# BR2_PACKAGE_PYTHON_PAM is not set
# BR2_PACKAGE_PYTHON_NFC is not set
# BR2_PACKAGE_PYTHON_MAD is not set
# BR2_PACKAGE_PYTHON_IPADDRESS is not set
# BR2_PACKAGE_PYTHON_IPADDR is not set
# BR2_PACKAGE_PYTHON_ID3 is not set
# BR2_PACKAGE_PYTHON_FUTURES is not set
# BR2_PACKAGE_PYTHON_BACKPORTS_SSL_MATCH_HOSTNAME is not set
# BR2_PACKAGE_PYTHON_BACKPORTS_SHUTIL_GET_TERMINAL_SIZE is not set
# BR2_PACKAGE_PYTHON_BACKPORTS_ABC is not set
# BR2_PACKAGE_PYTHON is not set
# BR2_TARGET_UBOOT_ZYNQ_IMAGE is not set
# BR2_PACKAGE_RPI_BT_FIRMWARE is not set
# BR2_PACKAGE_RPI_WIFI_FIRMWARE is not set
# BR2_PACKAGE_HOST_GDB_PYTHON is not set
# BR2_PACKAGE_GSTREAMER1_MM is not set
# BR2_KERNEL_HEADERS_5_14 is not set
# BR2_PACKAGE_PYTHON_BACKPORTS_FUNCTOOLS_LRU_CACHE is not set
# BR2_PACKAGE_CIVETWEB_WITH_LUA is not set
# BR2_PACKAGE_SUNXI_MALI_MAINLINE_DRIVER is not set
# BR2_PACKAGE_SUNXI_MALI_MAINLINE is not set
# BR2_PACKAGE_SUNXI_MALI_MAINLINE_R6P2 is not set
# BR2_PACKAGE_SUNXI_MALI_MAINLINE_R8P1 is not set
# BR2_PACKAGE_QT5WEBKIT_EXAMPLES is not set
# BR2_TOOLCHAIN_EXTERNAL_BOOTLIN_RISCV64_GLIBC_BLEEDING_EDGE is not set
# BR2_TOOLCHAIN_EXTERNAL_BOOTLIN_RISCV64_MUSL_BLEEDING_EDGE is not set
# BR2_PACKAGE_IPUTILS_TFTPD is not set
# BR2_PACKAGE_IPUTILS_TRACEROUTE6 is not set
# BR2_PACKAGE_LIBMEDIAART_BACKEND_NONE is not set
# BR2_PACKAGE_MPD_UPNP is not set
# Legacy options removed in 2021.11
# BR2_OPENJDK_VERSION_LTS is not set
# BR2_OPENJDK_VERSION_LATEST is not set
# BR2_PACKAGE_MPD_TIDAL is not set
# BR2_PACKAGE_MROUTED_RSRR is not set
# BR2_BINUTILS_VERSION_CSKY is not set
# BR2_GCC_VERSION_CSKY is not set
# BR2_PACKAGE_CANFESTIVAL is not set
# BR2_PACKAGE_NMAP_NDIFF is not set
# BR2_GDB_VERSION_8_3 is not set
# BR2_PACKAGE_PYTHON_MELD3 is not set
# BR2_PACKAGE_STRONGSWAN_EAP is not set
# BR2_PACKAGE_GNURADIO_PAGER is not set
# BR2_KERNEL_HEADERS_5_11 is not set
# BR2_KERNEL_HEADERS_5_12 is not set
# BR2_KERNEL_HEADERS_5_13 is not set
# Legacy options removed in 2021.08
BR2_TARGET_GRUB2_BUILTIN_MODULES=""
BR2_TARGET_GRUB2_BUILTIN_CONFIG=""
# BR2_PACKAGE_LIBMCRYPT is not set
# BR2_PACKAGE_MCRYPT is not set
# BR2_PACKAGE_PHP_EXT_MCRYPT is not set
# BR2_BINUTILS_VERSION_2_34_X is not set
# BR2_PACKAGE_LIBSOIL is not set
# BR2_PACKAGE_CLAPACK is not set
# BR2_PACKAGE_SPIDERMONKEY is not set
# BR2_PACKAGE_KODI_LIBVA is not set
# BR2_PACKAGE_PYTHON_COHERENCE is not set
# BR2_PACKAGE_PHP_EXT_XMLRPC is not set
# BR2_GCC_VERSION_8_X is not set
# Legacy options removed in 2021.05
# BR2_PACKAGE_UDISKS_LVM2 is not set
# BR2_PACKAGE_LVM2_APP_LIBRARY is not set
# BR2_PACKAGE_LVM2_LVMETAD is not set
# BR2_PACKAGE_MONKEY is not set
# BR2_PACKAGE_DOCKER_CONTAINERD is not set
# BR2_PACKAGE_IOSTAT is not set
# BR2_PACKAGE_SCONESERVER_HTTP_SCONESITE_IMAGE is not set
# BR2_PACKAGE_XSERVER_XORG_SERVER_KDRIVE_EVDEV is not set
# BR2_PACKAGE_XSERVER_XORG_SERVER_KDRIVE_KBD is not set
# BR2_PACKAGE_XSERVER_XORG_SERVER_KDRIVE_MOUSE is not set
# BR2_PACKAGE_MESA3D_OSMESA_CLASSIC is not set
# BR2_PACKAGE_MESA3D_DRI_DRIVER_SWRAST is not set
# BR2_PACKAGE_KODI_SCREENSAVER_CRYSTALMORPH is not set
# Legacy options removed in 2021.02
# BR2_PACKAGE_MPD_AUDIOFILE is not set
# BR2_PACKAGE_AUDIOFILE is not set
# BR2_BINUTILS_VERSION_2_33_X is not set
# BR2_PACKAGE_LIBUPNP18 is not set
# BR2_PACKAGE_BOA is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IMX_SDMA is not set
# BR2_GDB_VERSION_8_2 is not set
# BR2_PACKAGE_HOST_RCW is not set
# BR2_KERNEL_HEADERS_5_9 is not set
# BR2_KERNEL_HEADERS_5_8 is not set
# BR2_powerpc_601 is not set
# BR2_PACKAGE_TI_SGX_LIBGBM is not set
# BR2_PACKAGE_IPSEC_TOOLS is not set
# Legacy options removed in 2020.11
# BR2_PACKAGE_GPSD_FIXED_PORT_SPEED is not set
# BR2_PACKAGE_GPSD_RECONFIGURE is not set
# BR2_PACKAGE_GPSD_CONTROLSEND is not set
# BR2_PACKAGE_OPENCV is not set
# BR2_PACKAGE_LIBCROCO is not set
# BR2_PACKAGE_BELLAGIO is not set
# BR2_PACKAGE_SYSTEMD_JOURNAL_GATEWAY is not set
# BR2_TARGET_UBOOT_BOOT_SCRIPT is not set
# BR2_TARGET_UBOOT_ENVIMAGE is not set
# BR2_PACKAGE_KISMET_CLIENT is not set
# BR2_PACKAGE_KISMET_DRONE is not set
# BR2_GCC_VERSION_7_X is not set
# BR2_PACKAGE_GST1_VALIDATE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_YADIF is not set
# BR2_PACKAGE_GQVIEW is not set
# BR2_PACKAGE_WESTON_IMX is not set
# BR2_KERNEL_HEADERS_5_7 is not set
# BR2_PACKAGE_TINYHTTPD is not set
# BR2_PACKAGE_XSERVER_XORG_SERVER_AIGLX is not set
# BR2_PACKAGE_AMD_CATALYST is not set
# BR2_PACKAGE_NVIDIA_TEGRA23 is not set
# BR2_GDB_VERSION_8_1 is not set
# Legacy options removed in 2020.08
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_AMD64 is not set
# BR2_KERNEL_HEADERS_5_6 is not set
# BR2_KERNEL_HEADERS_5_5 is not set
# BR2_BINUTILS_VERSION_2_31_X is not set
# BR2_PACKAGE_KODI_PERIPHERAL_STEAMCONTROLLER is not set
# Legacy options removed in 2020.05
# BR2_PACKAGE_WIRINGPI is not set
# BR2_PACKAGE_PYTHON_PYCRYPTO is not set
# BR2_PACKAGE_MTDEV2TUIO is not set
# BR2_PACKAGE_EZXML is not set
# BR2_PACKAGE_COLLECTD_LVM is not set
# BR2_PACKAGE_PYTHON_PYASN is not set
# BR2_PACKAGE_PYTHON_PYASN_MODULES is not set
# BR2_PACKAGE_LINUX_FIRMWARE_ATHEROS_10K_QCA6174 is not set
# BR2_PACKAGE_QT5CANVAS3D is not set
# BR2_PACKAGE_KODI_LIBTHEORA is not set
# BR2_PACKAGE_CEGUI06 is not set
# BR2_GCC_VERSION_5_X is not set
# Legacy options removed in 2020.02
# BR2_PACKAGE_JAMVM is not set
# BR2_PACKAGE_CLASSPATH is not set
# BR2_PACKAGE_QT5_VERSION_5_6 is not set
# BR2_PACKAGE_CURL is not set
# BR2_PACKAGE_GSTREAMER is not set
# BR2_PACKAGE_NVIDIA_TEGRA23_BINARIES_GSTREAMER_PLUGINS is not set
# BR2_PACKAGE_NVIDIA_TEGRA23_BINARIES_NV_SAMPLE_APPS is not set
# BR2_PACKAGE_FREERDP_GSTREAMER is not set
# BR2_PACKAGE_OPENCV3_WITH_GSTREAMER is not set
# BR2_PACKAGE_OPENCV_WITH_GSTREAMER is not set
# BR2_PACKAGE_LIBPLAYER is not set
# BR2_GCC_VERSION_OR1K is not set
# BR2_PACKAGE_BLUEZ_UTILS is not set
# BR2_PACKAGE_GADGETFS_TEST is not set
# BR2_PACKAGE_FIS is not set
BR2_PACKAGE_REFPOLICY_POLICY_VERSION=""
# BR2_PACKAGE_CELT051 is not set
# BR2_PACKAGE_WIREGUARD is not set
# BR2_PACKAGE_PERL_NET_PING is not set
# BR2_PACKAGE_PERL_MIME_BASE64 is not set
# BR2_PACKAGE_PERL_DIGEST_MD5 is not set
# BR2_PACKAGE_ERLANG_P1_ICONV is not set
# BR2_KERNEL_HEADERS_5_3 is not set
# BR2_PACKAGE_PYTHON_SCAPY3K is not set
# BR2_BINUTILS_VERSION_2_30_X is not set
# BR2_PACKAGE_RPI_USERLAND_START_VCFILED is not set
# BR2_PACKAGE_TI_SGX_KM_AM335X is not set
# BR2_PACKAGE_TI_SGX_KM_AM437X is not set
# BR2_PACKAGE_TI_SGX_KM_AM4430 is not set
# BR2_PACKAGE_TI_SGX_KM_AM5430 is not set
# Legacy options removed in 2019.11
# BR2_PACKAGE_OPENVMTOOLS_PROCPS is not set
# BR2_PACKAGE_ALLJOYN is not set
# BR2_PACKAGE_ALLJOYN_BASE is not set
# BR2_PACKAGE_ALLJOYN_BASE_CONTROLPANEL is not set
# BR2_PACKAGE_ALLJOYN_BASE_NOTIFICATION is not set
# BR2_PACKAGE_ALLJOYN_BASE_ONBOARDING is not set
# BR2_PACKAGE_ALLJOYN_TCL_BASE is not set
# BR2_PACKAGE_ALLJOYN_TCL is not set
BR2_TOOLCHAIN_EXTRA_EXTERNAL_LIBS=""
# BR2_PACKAGE_PYTHON_PYSNMP_APPS is not set
# BR2_KERNEL_HEADERS_5_2 is not set
# BR2_TARGET_RISCV_PK is not set
# BR2_PACKAGE_SQLITE_STAT3 is not set
# BR2_KERNEL_HEADERS_5_1 is not set
# BR2_PACKAGE_DEVMEM2 is not set
# BR2_PACKAGE_USTR is not set
# BR2_PACKAGE_KODI_SCREENSAVER_PLANESTATE is not set
# BR2_PACKAGE_KODI_VISUALISATION_WAVEFORHUE is not set
# BR2_PACKAGE_KODI_AUDIODECODER_OPUS is not set
# BR2_PACKAGE_MESA3D_OSMESA is not set
# BR2_PACKAGE_HOSTAPD_DRIVER_RTW is not set
# BR2_PACKAGE_WPA_SUPPLICANT_DBUS_NEW is not set
# BR2_PACKAGE_WPA_SUPPLICANT_DBUS_OLD is not set
# Legacy options removed in 2019.08
# BR2_TARGET_TS4800_MBRBOOT is not set
# BR2_PACKAGE_LIBAMCODEC is not set
# BR2_PACKAGE_ODROID_SCRIPTS is not set
# BR2_PACKAGE_ODROID_MALI is not set
# BR2_PACKAGE_KODI_PLATFORM_AML is not set
# BR2_GCC_VERSION_6_X is not set
# BR2_GCC_VERSION_4_9_X is not set
# BR2_GDB_VERSION_7_12 is not set
# BR2_PACKAGE_XAPP_MKFONTDIR is not set
# BR2_GDB_VERSION_8_0 is not set
# BR2_KERNEL_HEADERS_4_20 is not set
# BR2_KERNEL_HEADERS_5_0 is not set
# Legacy options removed in 2019.05
# BR2_CSKY_DSP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_COMPOSITOR is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_IQA is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_OPENCV is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_STEREO is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VCD is not set
# BR2_PACKAGE_LUNIT is not set
# BR2_PACKAGE_FFMPEG_FFSERVER is not set
# BR2_PACKAGE_LIBUMP is not set
# BR2_PACKAGE_SUNXI_MALI is not set
# BR2_BINUTILS_VERSION_2_29_X is not set
# BR2_BINUTILS_VERSION_2_28_X is not set
# BR2_PACKAGE_GST_PLUGINS_BAD_PLUGIN_APEXSINK is not set
# Legacy options removed in 2019.02
# BR2_PACKAGE_QT is not set
# BR2_PACKAGE_QTUIO is not set
# BR2_PACKAGE_PINENTRY_QT4 is not set
# BR2_PACKAGE_POPPLER_QT is not set
# BR2_PACKAGE_OPENCV3_WITH_QT is not set
# BR2_PACKAGE_OPENCV_WITH_QT is not set
# BR2_PACKAGE_AMD_CATALYST_CCCLE is not set
# BR2_PACKAGE_SDL_QTOPIA is not set
# BR2_PACKAGE_PYTHON_PYQT is not set
# BR2_PACKAGE_LUACRYPTO is not set
# BR2_PACKAGE_TN5250 is not set
# BR2_PACKAGE_BOOST_SIGNALS is not set
# BR2_PACKAGE_FFTW_PRECISION_SINGLE is not set
# BR2_PACKAGE_FFTW_PRECISION_DOUBLE is not set
# BR2_PACKAGE_FFTW_PRECISION_LONG_DOUBLE is not set
# BR2_PACKAGE_LUA_5_2 is not set
# BR2_TARGET_GENERIC_PASSWD_MD5 is not set
# Legacy options removed in 2018.11
# BR2_TARGET_XLOADER is not set
# BR2_PACKAGE_TIDSP_BINARIES is not set
# BR2_PACKAGE_DSP_TOOLS is not set
# BR2_PACKAGE_GST_DSP is not set
# BR2_PACKAGE_BOOTUTILS is not set
# BR2_PACKAGE_EXPEDITE is not set
# BR2_PACKAGE_MESA3D_OPENGL_TEXTURE_FLOAT is not set
# BR2_KERNEL_HEADERS_4_10 is not set
# BR2_KERNEL_HEADERS_4_11 is not set
# BR2_KERNEL_HEADERS_4_12 is not set
# BR2_KERNEL_HEADERS_4_13 is not set
# BR2_KERNEL_HEADERS_4_15 is not set
# BR2_KERNEL_HEADERS_4_17 is not set
# BR2_PACKAGE_LIBNFTNL_XML is not set
# BR2_KERNEL_HEADERS_3_2 is not set
# BR2_KERNEL_HEADERS_4_1 is not set
# BR2_KERNEL_HEADERS_4_16 is not set
# BR2_KERNEL_HEADERS_4_18 is not set
# Legacy options removed in 2018.08
# BR2_PACKAGE_DOCKER_ENGINE_STATIC_CLIENT is not set
# BR2_PACKAGE_XPROTO_APPLEWMPROTO is not set
# BR2_PACKAGE_XPROTO_BIGREQSPROTO is not set
# BR2_PACKAGE_XPROTO_COMPOSITEPROTO is not set
# BR2_PACKAGE_XPROTO_DAMAGEPROTO is not set
# BR2_PACKAGE_XPROTO_DMXPROTO is not set
# BR2_PACKAGE_XPROTO_DRI2PROTO is not set
# BR2_PACKAGE_XPROTO_DRI3PROTO is not set
# BR2_PACKAGE_XPROTO_FIXESPROTO is not set
# BR2_PACKAGE_XPROTO_FONTCACHEPROTO is not set
# BR2_PACKAGE_XPROTO_FONTSPROTO is not set
# BR2_PACKAGE_XPROTO_GLPROTO is not set
# BR2_PACKAGE_XPROTO_INPUTPROTO is not set
# BR2_PACKAGE_XPROTO_KBPROTO is not set
# BR2_PACKAGE_XPROTO_PRESENTPROTO is not set
# BR2_PACKAGE_XPROTO_RANDRPROTO is not set
# BR2_PACKAGE_XPROTO_RECORDPROTO is not set
# BR2_PACKAGE_XPROTO_RENDERPROTO is not set
# BR2_PACKAGE_XPROTO_RESOURCEPROTO is not set
# BR2_PACKAGE_XPROTO_SCRNSAVERPROTO is not set
# BR2_PACKAGE_XPROTO_VIDEOPROTO is not set
# BR2_PACKAGE_XPROTO_WINDOWSWMPROTO is not set
# BR2_PACKAGE_XPROTO_XCMISCPROTO is not set
# BR2_PACKAGE_XPROTO_XEXTPROTO is not set
# BR2_PACKAGE_XPROTO_XF86BIGFONTPROTO is not set
# BR2_PACKAGE_XPROTO_XF86DGAPROTO is not set
# BR2_PACKAGE_XPROTO_XF86DRIPROTO is not set
# BR2_PACKAGE_XPROTO_XF86VIDMODEPROTO is not set
# BR2_PACKAGE_XPROTO_XINERAMAPROTO is not set
# BR2_PACKAGE_XPROTO_XPROTO is not set
# BR2_PACKAGE_XPROTO_XPROXYMANAGEMENTPROTOCOL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_OPENGL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLES2 is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_GLX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_EGL is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_X11 is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_WAYLAND is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_LIB_OPENGL_DISPMANX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_AUDIOMIXER is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_LAME is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MPG123 is not set
# BR2_GDB_VERSION_7_11 is not set
# BR2_GDB_VERSION_7_10 is not set
# Legacy options removed in 2018.05
# BR2_PACKAGE_MEDIAART_BACKEND_NONE is not set
# BR2_PACKAGE_MEDIAART_BACKEND_GDK_PIXBUF is not set
# BR2_PACKAGE_MEDIAART_BACKEND_QT is not set
# BR2_PACKAGE_TI_SGX_AM335X is not set
# BR2_PACKAGE_TI_SGX_AM437X is not set
# BR2_PACKAGE_TI_SGX_AM4430 is not set
# BR2_PACKAGE_TI_SGX_AM5430 is not set
# BR2_PACKAGE_JANUS_AUDIO_BRIDGE is not set
# BR2_PACKAGE_JANUS_ECHO_TEST is not set
# BR2_PACKAGE_JANUS_RECORDPLAY is not set
# BR2_PACKAGE_JANUS_SIP_GATEWAY is not set
# BR2_PACKAGE_JANUS_STREAMING is not set
# BR2_PACKAGE_JANUS_TEXT_ROOM is not set
# BR2_PACKAGE_JANUS_VIDEO_CALL is not set
# BR2_PACKAGE_JANUS_VIDEO_ROOM is not set
# BR2_PACKAGE_JANUS_MQTT is not set
# BR2_PACKAGE_JANUS_RABBITMQ is not set
# BR2_PACKAGE_JANUS_REST is not set
# BR2_PACKAGE_JANUS_UNIX_SOCKETS is not set
# BR2_PACKAGE_JANUS_WEBSOCKETS is not set
# BR2_PACKAGE_IPSEC_SECCTX_DISABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_ENABLE is not set
# BR2_PACKAGE_IPSEC_SECCTX_KERNEL is not set
# BR2_PACKAGE_LIBTFDI_CPP is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLACK_TIE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_BLITZER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_CUPERTINO is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DARK_HIVE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_DOT_LUV is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EGGPLANT is not set
# BR2_PACKAGE_JQUERY_UI_THEME_EXCITE_BIKE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_FLICK is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HOT_SNEAKS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_HUMANITY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_LE_FROG is not set
# BR2_PACKAGE_JQUERY_UI_THEME_MINT_CHOC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_OVERCAST is not set
# BR2_PACKAGE_JQUERY_UI_THEME_PEPPER_GRINDER is not set
# BR2_PACKAGE_JQUERY_UI_THEME_REDMOND is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SMOOTHNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SOUTH_STREET is not set
# BR2_PACKAGE_JQUERY_UI_THEME_START is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SUNNY is not set
# BR2_PACKAGE_JQUERY_UI_THEME_SWANKY_PURSE is not set
# BR2_PACKAGE_JQUERY_UI_THEME_TRONTASTIC is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_DARKNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_UI_LIGHTNESS is not set
# BR2_PACKAGE_JQUERY_UI_THEME_VADER is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_HEALTH is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_MIDI is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_NFC is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SAP is not set
# BR2_PACKAGE_BLUEZ5_PLUGINS_SIXAXIS is not set
# BR2_PACKAGE_TRANSMISSION_REMOTE is not set
# BR2_PACKAGE_LIBKCAPI_APPS is not set
# BR2_PACKAGE_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MPLAYER is not set
# BR2_PACKAGE_MPLAYER_MENCODER is not set
# BR2_PACKAGE_LIBPLAYER_MPLAYER is not set
# BR2_PACKAGE_IQVLINUX is not set
# BR2_BINFMT_FLAT_SEP_DATA is not set
# BR2_bfin is not set
# BR2_PACKAGE_KODI_ADSP_BASIC is not set
# BR2_PACKAGE_KODI_ADSP_FREESURROUND is not set
# Legacy options removed in 2018.02
# BR2_KERNEL_HEADERS_3_4 is not set
# BR2_KERNEL_HEADERS_3_10 is not set
# BR2_KERNEL_HEADERS_3_12 is not set
# BR2_BINUTILS_VERSION_2_27_X is not set
# BR2_PACKAGE_EEPROG is not set
# BR2_PACKAGE_GNUPG2_GPGV2 is not set
# BR2_PACKAGE_IMX_GPU_VIV_APITRACE is not set
# BR2_PACKAGE_IMX_GPU_VIV_G2D is not set
# Legacy options removed in 2017.11
# BR2_PACKAGE_RFKILL is not set
# BR2_PACKAGE_UTIL_LINUX_RESET is not set
# BR2_PACKAGE_POLICYCOREUTILS_AUDIT2ALLOW is not set
# BR2_PACKAGE_POLICYCOREUTILS_RESTORECOND is not set
# BR2_PACKAGE_SEPOLGEN is not set
# BR2_PACKAGE_OPENOBEX_BLUEZ is not set
# BR2_PACKAGE_OPENOBEX_LIBUSB is not set
# BR2_PACKAGE_OPENOBEX_APPS is not set
# BR2_PACKAGE_OPENOBEX_SYSLOG is not set
# BR2_PACKAGE_OPENOBEX_DUMP is not set
# BR2_PACKAGE_AICCU is not set
# BR2_PACKAGE_UTIL_LINUX_LOGIN_UTILS is not set
# Legacy options removed in 2017.08
# BR2_TARGET_GRUB is not set
# BR2_PACKAGE_SIMICSFS is not set
# BR2_BINUTILS_VERSION_2_26_X is not set
BR2_XTENSA_OVERLAY_DIR=""
BR2_XTENSA_CUSTOM_NAME=""
# BR2_PACKAGE_HOST_MKE2IMG is not set
BR2_TARGET_ROOTFS_EXT2_BLOCKS=0
BR2_TARGET_ROOTFS_EXT2_EXTRA_INODES=0
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_CDXAPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DATAURISRC is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DCCP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_HDVPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MVE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_NUVDEMUX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_PATCHDETECT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDI is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_TTA is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VIDEOMEASURE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_APEXSINK is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDL is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MAD is not set
# BR2_STRIP_none is not set
# BR2_PACKAGE_BEECRYPT_CPP is not set
# BR2_PACKAGE_SPICE_CLIENT is not set
# BR2_PACKAGE_SPICE_GUI is not set
# BR2_PACKAGE_SPICE_TUNNEL is not set
# BR2_PACKAGE_INPUT_TOOLS is not set
# BR2_PACKAGE_INPUT_TOOLS_INPUTATTACH is not set
# BR2_PACKAGE_INPUT_TOOLS_JSCAL is not set
# BR2_PACKAGE_INPUT_TOOLS_JSTEST is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_SH is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_X86 is not set
# BR2_GCC_VERSION_4_8_X is not set
# Legacy options removed in 2017.05
# BR2_PACKAGE_SUNXI_MALI_R2P4 is not set
# BR2_PACKAGE_NODEJS_MODULES_COFFEESCRIPT is not set
# BR2_PACKAGE_NODEJS_MODULES_EXPRESS is not set
# BR2_PACKAGE_BLUEZ5_UTILS_GATTTOOL is not set
# BR2_PACKAGE_OPENOCD_FT2XXX is not set
# BR2_PACKAGE_KODI_RTMPDUMP is not set
# BR2_PACKAGE_KODI_VISUALISATION_FOUNTAIN is not set
# BR2_PACKAGE_PORTMAP is not set
# BR2_BINUTILS_VERSION_2_25_X is not set
# BR2_TOOLCHAIN_BUILDROOT_INET_RPC is not set
BR2_TARGET_ROOTFS_EXT2_EXTRA_BLOCKS=0
# BR2_PACKAGE_SYSTEMD_KDBUS is not set
# BR2_PACKAGE_POLARSSL is not set
# BR2_NBD_CLIENT is not set
# BR2_NBD_SERVER is not set
# BR2_PACKAGE_GMOCK is not set
# BR2_KERNEL_HEADERS_4_8 is not set
# BR2_KERNEL_HEADERS_3_18 is not set
# BR2_GLIBC_VERSION_2_22 is not set
# Legacy options removed in 2017.02
# BR2_PACKAGE_PERL_DB_FILE is not set
# BR2_KERNEL_HEADERS_4_7 is not set
# BR2_KERNEL_HEADERS_4_6 is not set
# BR2_KERNEL_HEADERS_4_5 is not set
# BR2_KERNEL_HEADERS_3_14 is not set
# BR2_TOOLCHAIN_EXTERNAL_MUSL_CROSS is not set
# BR2_UCLIBC_INSTALL_TEST_SUITE is not set
# BR2_TOOLCHAIN_EXTERNAL_BLACKFIN_UCLINUX is not set
# BR2_PACKAGE_MAKEDEVS is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV7A is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV5TE is not set
# BR2_PACKAGE_SNOWBALL_HDMISERVICE is not set
# BR2_PACKAGE_SNOWBALL_INIT is not set
# BR2_GDB_VERSION_7_9 is not set
# Legacy options removed in 2016.11
# BR2_PACKAGE_PHP_SAPI_CLI_CGI is not set
# BR2_PACKAGE_PHP_SAPI_CLI_FPM is not set
# BR2_PACKAGE_WVSTREAMS is not set
# BR2_PACKAGE_WVDIAL is not set
# BR2_PACKAGE_WEBKITGTK24 is not set
# BR2_PACKAGE_TORSMO is not set
# BR2_PACKAGE_SSTRIP is not set
# BR2_KERNEL_HEADERS_4_3 is not set
# BR2_KERNEL_HEADERS_4_2 is not set
# BR2_PACKAGE_KODI_ADDON_XVDR is not set
# BR2_PACKAGE_IPKG is not set
# BR2_GCC_VERSION_4_7_X is not set
# BR2_BINUTILS_VERSION_2_24_X is not set
# BR2_PACKAGE_WESTON_RPI is not set
# BR2_LINUX_KERNEL_TOOL_CPUPOWER is not set
# BR2_LINUX_KERNEL_TOOL_PERF is not set
# BR2_LINUX_KERNEL_TOOL_SELFTESTS is not set
# BR2_GCC_VERSION_4_8_ARC is not set
# BR2_KERNEL_HEADERS_4_0 is not set
# BR2_KERNEL_HEADERS_3_19 is not set
# BR2_PACKAGE_LIBEVAS_GENERIC_LOADERS is not set
# BR2_PACKAGE_ELEMENTARY is not set
# BR2_LINUX_KERNEL_CUSTOM_LOCAL is not set
# Legacy options removed in 2016.08
# BR2_PACKAGE_EFL_JP2K is not set
# BR2_PACKAGE_SYSTEMD_COMPAT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_LIVEADDER is not set
# BR2_PACKAGE_LIBFSLVPUWRAP is not set
# BR2_PACKAGE_LIBFSLPARSER is not set
# BR2_PACKAGE_LIBFSLCODEC is not set
# BR2_PACKAGE_UBOOT_TOOLS_MKIMAGE_FIT_SIGNATURE_SUPPORT is not set
# BR2_PTHREADS_OLD is not set
# BR2_BINUTILS_VERSION_2_23_X is not set
# BR2_TOOLCHAIN_BUILDROOT_EGLIBC is not set
# BR2_GDB_VERSION_7_8 is not set
# Legacy options removed in 2016.05
# BR2_PACKAGE_OPENVPN_CRYPTO_POLARSSL is not set
# BR2_PACKAGE_NGINX_HTTP_SPDY_MODULE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_RTP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MPG123 is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC_E500V2 is not set
# BR2_x86_i386 is not set
# BR2_PACKAGE_QT5QUICK1 is not set
BR2_TARGET_UBOOT_CUSTOM_PATCH_DIR=""
# BR2_PACKAGE_XDRIVER_XF86_INPUT_VOID is not set
# BR2_KERNEL_HEADERS_3_17 is not set
# BR2_GDB_VERSION_7_7 is not set
# BR2_PACKAGE_FOOMATIC_FILTERS is not set
# BR2_PACKAGE_SAMBA is not set
# BR2_PACKAGE_KODI_WAVPACK is not set
# BR2_PACKAGE_KODI_RSXS is not set
# BR2_PACKAGE_KODI_GOOM is not set
# BR2_PACKAGE_SYSTEMD_ALL_EXTRAS is not set
# BR2_GCC_VERSION_4_5_X is not set
# BR2_PACKAGE_SQLITE_READLINE is not set
# Legacy options removed in 2016.02
# BR2_PACKAGE_DOVECOT_BZIP2 is not set
# BR2_PACKAGE_DOVECOT_ZLIB is not set
# BR2_PACKAGE_E2FSPROGS_FINDFS is not set
# BR2_PACKAGE_OPENPOWERLINK_DEBUG_LEVEL is not set
# BR2_PACKAGE_OPENPOWERLINK_KERNEL_MODULE is not set
# BR2_PACKAGE_OPENPOWERLINK_LIBPCAP is not set
# BR2_LINUX_KERNEL_SAME_AS_HEADERS is not set
# BR2_PACKAGE_CUPS_PDFTOPS is not set
# BR2_KERNEL_HEADERS_3_16 is not set
# BR2_PACKAGE_PYTHON_PYXML is not set
# BR2_ENABLE_SSP is not set
# BR2_PACKAGE_DIRECTFB_CLE266 is not set
# BR2_PACKAGE_DIRECTFB_UNICHROME is not set
# BR2_PACKAGE_LIBELEMENTARY is not set
# BR2_PACKAGE_LIBEINA is not set
# BR2_PACKAGE_LIBEET is not set
# BR2_PACKAGE_LIBEVAS is not set
# BR2_PACKAGE_LIBECORE is not set
# BR2_PACKAGE_LIBEDBUS is not set
# BR2_PACKAGE_LIBEFREET is not set
# BR2_PACKAGE_LIBEIO is not set
# BR2_PACKAGE_LIBEMBRYO is not set
# BR2_PACKAGE_LIBEDJE is not set
# BR2_PACKAGE_LIBETHUMB is not set
# BR2_PACKAGE_INFOZIP is not set
# BR2_BR2_PACKAGE_NODEJS_0_10_X is not set
# BR2_BR2_PACKAGE_NODEJS_0_12_X is not set
# BR2_BR2_PACKAGE_NODEJS_4_X is not set
# Legacy options removed in 2015.11
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_REAL is not set
# BR2_PACKAGE_MEDIA_CTL is not set
# BR2_PACKAGE_SCHIFRA is not set
# BR2_PACKAGE_ZXING is not set
# BR2_PACKAGE_BLACKBOX is not set
# BR2_KERNEL_HEADERS_3_0 is not set
# BR2_KERNEL_HEADERS_3_11 is not set
# BR2_KERNEL_HEADERS_3_13 is not set
# BR2_KERNEL_HEADERS_3_15 is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_ANDI is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_BLTLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_CPULOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DATABUFFER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DIOLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DOK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DRIVERTEST is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FIRE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FLIP is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FONTS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_INPUT is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_JOYSTICK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_KNUCKLES is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_LAYER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX_WATER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NETLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PALETTE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PORTER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_STRESS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_TEXTURE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_WINDOW is not set
# BR2_PACKAGE_KOBS_NG is not set
# BR2_PACKAGE_SAWMAN is not set
# BR2_PACKAGE_DIVINE is not set
# Legacy options removed in 2015.08
# BR2_PACKAGE_KODI_PVR_ADDONS is not set
# BR2_BINUTILS_VERSION_2_23_2 is not set
# BR2_BINUTILS_VERSION_2_24 is not set
# BR2_BINUTILS_VERSION_2_25 is not set
# BR2_PACKAGE_PERF is not set
# BR2_BINUTILS_VERSION_2_22 is not set
# BR2_PACKAGE_GPU_VIV_BIN_MX6Q is not set
# BR2_TARGET_UBOOT_NETWORK is not set
sun8i-v3s-licheepi-zero.dts
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
#include "sun8i-v3s.dtsi"
	model = "Lichee Pi Zero";
	compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	aliases {
		serial0 = &uart0;
	chosen {
	leds {
		compatible = "gpio-leds";
		blue_led {
			label = "licheepi:blue:usr";
			gpios = <&pio 6 1 GPIO_ACTIVE_LOW>; /* PG1 */
		green_led {
			label = "licheepi:green:usr";
			gpios = <&pio 6 0 GPIO_ACTIVE_LOW>; /* PG0 */
			default-state = "on";
		red_led {
			label = "licheepi:red:usr";
			gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; /* PG2 */
    backlight: backlight {
		compatible = "pwm-backlight";
		pwms = <&pwm 0 1000000 0>;
		brightness-levels = <0 30 40 50 60 70 100>;
		default-brightness-level = <6>;
    panel: panel {
        compatible = "qiaodian,qd43003c0-40", "simple-panel";
		#address-cells = <1>;
		#size-cells = <0>;
		port@0 {
			reg = <0>;
			backlight = <&backlight>;
			#size-cells = <0>;
			panel_input: endpoint@0 {
				reg = <0>;
&de {
&pwm {
	pinctrl-names = "default";
	pinctrl-0 = <&pwm0_pins>;
&mmc0 {
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
&tcon0 {
	pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
	tcon0_out_lcd: endpoint@0 {
		reg = <0>;
&uart0 {
	pinctrl-0 = <&uart0_pb_pins>;
&usb_otg {
	dr_mode = "otg";
&usbphy {
	usb0_id_det-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>;
sun8i-v3s.dtsi
 * whole.
 *     conditions:
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/clock/sun8i-v3s-ccu.h>
#include <dt-bindings/reset/sun8i-v3s-ccu.h>
	#size-cells = <1>;
	interrupt-parent = <&gic>;
    chosen {
		#size-cells = <1>;
		ranges;
		simplefb_lcd: framebuffer@0 {
			compatible = "allwinner,simple-framebuffer",
				     "simple-framebuffer";
			allwinner,pipeline = "de0-lcd0";
			clocks = <&ccu CLK_BUS_TCON0>, <&display_clocks 0>,
				 <&display_clocks 6>, <&ccu CLK_TCON0>;
	cpus {
		#size-cells = <0>;
		cpu@0 {
			compatible = "arm,cortex-a7";
			device_type = "cpu";
			reg = <0>;
			clocks = <&ccu CLK_CPU>;
	de: display-engine {
		compatible = "allwinner,sun8i-v3s-display-engine";
		allwinner,pipelines = <&mixer0>;
		status = "disabled";
	timer {
		compatible = "arm,armv7-timer";
		interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
			     <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>;
	clocks {
		#size-cells = <1>;
		ranges;
		osc24M: osc24M_clk {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
			clock-accuracy = <50000>;
		osc32k: osc32k_clk {
			#clock-cells = <0>;
			clock-frequency = <32768>;
			clock-output-names = "ext-osc32k";
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		display_clocks: clock@1000000 {
			compatible = "allwinner,sun8i-v3s-de2-clk";
			reg = <0x01000000 0x100000>;
			clocks = <&ccu CLK_DE>,
				 <&ccu CLK_BUS_DE>;
			clock-names = "mod",
				      "bus";
			resets = <&ccu RST_BUS_DE>;
			#clock-cells = <1>;
			#reset-cells = <1>;
		mixer0: mixer@1100000 {
			compatible = "allwinner,sun8i-v3s-de2-mixer";
			reg = <0x01100000 0x100000>;
			clocks = <&display_clocks 0>,
				 <&display_clocks 6>;
			clock-names = "bus",
				      "mod";
			resets = <&display_clocks 0>;
			assigned-clocks = <&display_clocks 6>;
			assigned-clock-rates = <150000000>;
			ports {
				#size-cells = <0>;
				mixer0_out: port@1 {
					reg = <1>;
					mixer0_out_tcon0: endpoint {
						remote-endpoint = <&tcon0_in_mixer0>;
        syscon: syscon@1c00000 {
			compatible = "allwinner,sun8i-v3s-system-controller",
				"syscon";
			reg = <0x01c00000 0x1000>;
		tcon0: lcd-controller@1c0c000 {
			compatible = "allwinner,sun8i-v3s-tcon";
			reg = <0x01c0c000 0x1000>;
			interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
				 <&ccu CLK_TCON0>;
			clock-names = "ahb",
				      "tcon-ch0";
			clock-output-names = "tcon-pixel-clock";
			resets = <&ccu RST_BUS_TCON0>;
			reset-names = "lcd";
			ports {
				#size-cells = <0>;
				tcon0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					tcon0_in_mixer0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&mixer0_out_tcon0>;
				tcon0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
		mmc0: mmc@1c0f000 {
			compatible = "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-0 = <&mmc0_pins>;
			#size-cells = <0>;
		mmc1: mmc@1c10000 {
			reg = <0x01c10000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC1>,
				 <&ccu CLK_MMC1>,
				 <&ccu CLK_MMC1_OUTPUT>,
				 <&ccu CLK_MMC1_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC1>;
			interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
			pinctrl-0 = <&mmc1_pins>;
			#size-cells = <0>;
		mmc2: mmc@1c11000 {
			reg = <0x01c11000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC2>,
				 <&ccu CLK_MMC2>,
				 <&ccu CLK_MMC2_OUTPUT>,
				 <&ccu CLK_MMC2_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC2>;
			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
		usb_otg: usb@1c19000 {
			compatible = "allwinner,sun8i-h3-musb";
			reg = <0x01c19000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
		usbphy: phy@1c19400 {
			compatible = "allwinner,sun8i-v3s-usb-phy";
			reg = <0x01c19400 0x2c>,
			      <0x01c1a800 0x4>;
			reg-names = "phy_ctrl",
				    "pmu0";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		ccu: clock@1c20000 {
			compatible = "allwinner,sun8i-v3s-ccu";
			reg = <0x01c20000 0x400>;
			clocks = <&osc24M>, <&rtc 0>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
		rtc: rtc@1c20400 {
			#clock-cells = <1>;
			compatible = "allwinner,sun8i-v3-rtc";
			reg = <0x01c20400 0x54>;
			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&osc32k>;
			clock-output-names = "osc32k", "osc32k-out";
		pio: pinctrl@1c20800 {
			compatible = "allwinner,sun8i-v3s-pinctrl";
			reg = <0x01c20800 0x400>;
			interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&rtc 0>;
			gpio-controller;
			#gpio-cells = <3>;
			interrupt-controller;
			#interrupt-cells = <3>;
			i2c0_pins: i2c0-pins {
				pins = "PB6", "PB7";
				function = "i2c0";
            lcd_rgb666_pins: lcd-rgb666-pins {
							pins =	"PE4", "PE5", "PE6", "PE7", "PE8", "PE9",
									"PE10", "PE11", "PE12", "PE13" , "PE14", "PE15",
									"PE16", "PE17", "PE18", "PE19", "PE23", "PE24",//data信号
									"PE3",//VSYNC
									"PE2",//HSYNC
									"PE1",//DE
									"PE0";//CLK
							function = "lcd";
            pwm0_pins: pwm0 {
				pins = "PB4";
				function = "pwm0";
			uart0_pb_pins: uart0-pb-pins {
				pins = "PB8", "PB9";
				function = "uart0";
			mmc0_pins: mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3",
				       "PF4", "PF5";
				function = "mmc0";
				drive-strength = <30>;
				bias-pull-up;
			mmc1_pins: mmc1-pins {
				pins = "PG0", "PG1", "PG2", "PG3",
				       "PG4", "PG5";
				function = "mmc1";
				bias-pull-up;
			spi0_pins: spi0-pins {
				function = "spi0";
		timer@1c20c00 {
			compatible = "allwinner,sun4i-a10-timer";
			reg = <0x01c20c00 0xa0>;
			interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&osc24M>;
		wdt0: watchdog@1c20ca0 {
			reg = <0x01c20ca0 0x20>;
			interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
        pwm: pwm@1c21400 {
			compatible = "allwinner,sun8i-v3s-pwm",
				     "allwinner,sun7i-a20-pwm";
			reg = <0x01c21400 0x400>;
			clocks = <&osc24M>;
			#pwm-cells = <3>;
		lradc: lradc@1c22800 {
			compatible = "allwinner,sun4i-a10-lradc-keys";
			reg = <0x01c22800 0x400>;
			interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
		uart0: serial@1c28000 {
			reg = <0x01c28000 0x400>;
			interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart1: serial@1c28400 {
			reg = <0x01c28400 0x400>;
			interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart2: serial@1c28800 {
			reg = <0x01c28800 0x400>;
			interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
			reg-shift = <2>;
			reg-io-width = <4>;
		i2c0: i2c@1c2ac00 {
			compatible = "allwinner,sun6i-a31-i2c";
			reg = <0x01c2ac00 0x400>;
			interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_I2C0>;
			resets = <&ccu RST_BUS_I2C0>;
			pinctrl-0 = <&i2c0_pins>;
			#size-cells = <0>;
		i2c1: i2c@1c2b000 {
			reg = <0x01c2b000 0x400>;
			interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_I2C1>;
			resets = <&ccu RST_BUS_I2C1>;
			#size-cells = <0>;
		spi0: spi@1c68000 {
			compatible = "allwinner,sun8i-h3-spi";
			reg = <0x01c68000 0x1000>;
			interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
			clock-names = "ahb", "mod";
			pinctrl-0 = <&spi0_pins>;
			resets = <&ccu RST_BUS_SPI0>;
			#size-cells = <0>;
		gic: interrupt-controller@1c81000 {
			compatible = "arm,gic-400";
			reg = <0x01c81000 0x1000>,
			      <0x01c82000 0x1000>,
			      <0x01c84000 0x2000>,
			      <0x01c86000 0x2000>;
			interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
