楼主 # 2024-03-14 19:04:17
EKE
已发帖子: 28
v3s配置ov2640,生成script.bin文件失败
;vip (video input port) configuration
;vip_used: 0:disable 1:enable
;vip_mode: 0:sample one interface to one buffer 1:sample two interface to one buffer
;vip_dev_qty: The quantity of devices linked to capture bus
;vip_define_sensor_list: If you want use sensor detect function, please set vip_define_sensor_list = 1, and
;                                    verify that file /system/etc/hawkview/sensor_list_cfg.ini is properly configured!
;vip_dev(x)_pos: sensor position, "rear" or "front", if vip_define_sensor_list = 1,vip_dev(x)_pos must be configured!
;vip_dev(x)_isp_used 0:not use isp 1:use isp
;vip_dev(x)_fmt: 0:yuv 1:bayer raw rgb
;vip_dev(x)_stby_mode: 0:not shut down power at standby 1:shut down power at standby
;vip_dev(x)_vflip: flip in vertical direction 0:disable 1:enable
;vip_dev(x)_hflip: flip in horizontal direction 0:disable 1:enable
;vip_dev(x)_iovdd: camera module io power handle string, pmu power supply
;vip_dev(x)_iovdd_vol: camera module io power voltage, pmu power supply
;vip_dev(x)_avdd: camera module analog power handle string, pmu power supply
;vip_dev(x)_avdd_vol: camera module analog power voltage, pmu power supply
;vip_dev(x)_dvdd: camera module core power handle string, pmu power supply
;vip_dev(x)_dvdd_vol: camera module core power voltage, pmu power supply
;vip_dev(x)_afvdd: camera module vcm power handle string, pmu power supply
;vip_dev(x)_afvdd_vol: camera module vcm power voltage, pmu power supply
;x indicates the index of the devices which are linked to the same capture bus
;fill voltage in uV, e.g. iovdd = 2.8V, vip_devx_iovdd_vol = 2800000
;fill handle string as below:
;axp22_eldo3
;axp22_dldo4
;axp22_eldo2
;fill handle string "" when not using any pmu power supply
[csi0]
vip_used                 = 1
vip_mode                 = 0
vip_dev_qty              = 1
vip_define_sensor_list   = 0
vip_csi_mck              = port:PE20<3><default><default><default>
vip_csi_sck              = port:PE21<2><default><default><default>
vip_csi_sda              = port:PE22<2><default><default><default>
vip_dev0_mname           = "h22_mipi"
vip_dev0_pos             = "rear"
vip_dev0_lane            = 1
vip_dev0_twi_id          = 0
vip_dev0_twi_addr        = 0x60
vip_dev0_isp_used        = 1
vip_dev0_fmt             = 1
vip_dev0_stby_mode       = 0
vip_dev0_vflip           = 0
vip_dev0_hflip           = 0
vip_dev0_iovdd           = ""
vip_dev0_iovdd_vol       = 3000000
vip_dev0_avdd            = "csi-avdd"
vip_dev0_avdd_vol        = 3000000
vip_dev0_dvdd            = "csi-dvdd"
vip_dev0_dvdd_vol        = 3000000
vip_dev0_afvdd           = ""
vip_dev0_afvdd_vol       = 2800000
vip_dev0_power_en        =
vip_dev0_reset           = port:PG00<1><default><default><default>
vip_dev0_pwdn            = port:PG01<1><default><default><default>
vip_dev0_flash_en        =
vip_dev0_flash_mode      =
vip_dev0_af_pwdn         =
vip_dev0_act_used        = 0
vip_dev0_act_name        = "dw9714_act"
vip_dev0_act_slave       = 0x18
vip_dev1_mname           = ""
vip_dev1_pos                 = "front"
vip_dev1_lane            = 1
vip_dev1_twi_id          = 0
vip_dev1_twi_addr        =
vip_dev1_isp_used        = 0
vip_dev1_fmt             = 1
vip_dev1_stby_mode       = 0
vip_dev1_vflip           = 0
vip_dev1_hflip           = 0
vip_dev1_iovdd           = ""
vip_dev1_iovdd_vol       = 2800000
vip_dev1_avdd            = ""
vip_dev1_avdd_vol        = 2800000
vip_dev1_dvdd            = ""
vip_dev1_dvdd_vol        = 1500000
vip_dev1_afvdd           = ""
vip_dev1_afvdd_vol       = 2800000
vip_dev1_power_en        =
vip_dev1_reset           =
vip_dev1_pwdn            =
vip_dev1_flash_en        =
;axp22_eldo3
;axp22_dldo4
;axp22_eldo2
[csi0]
vip_used                 = 1
vip_mode                 = 0
vip_dev_qty              = 1
vip_dev0_lane            = 1
vip_dev0_twi_id          = 0
vip_dev0_fmt             = 1
vip_dev0_vflip           = 0
vip_dev0_hflip           = 0
vip_dev0_iovdd           = ""
vip_dev0_afvdd           = ""
vip_dev0_power_en        =
vip_dev0_flash_en        =
vip_dev0_af_pwdn         =
vip_dev1_mname           = ""
vip_dev1_lane            = 1
vip_dev1_twi_id          = 0
vip_dev1_twi_addr        =
vip_dev1_fmt             = 1
vip_dev1_vflip           = 0
vip_dev1_hflip           = 0
vip_dev1_iovdd           = ""
vip_dev1_avdd            = ""
vip_dev1_dvdd            = ""
vip_dev1_afvdd           = ""
vip_dev1_power_en        =
vip_dev1_reset           =
vip_dev1_pwdn            =
vip_dev1_flash_en        =
vip_dev1_flash_mode      =
vip_dev1_af_pwdn         =
[csi1]
[csi1]
vip_used                 = 1
vip_mode                 = 0
vip_dev_qty              = 1
vip_csi_pck              = port:PE00<2><default><default><default>
vip_csi_mck              = port:PE01<2><default><default><default>
vip_csi_hsync            = port:PE02<2><default><default><default>
vip_csi_vsync            = port:PE03<2><default><default><default>
vip_csi_d0               = port:PE04<2><default><default><default>
vip_csi_d1               = port:PE05<2><default><default><default>
vip_csi_d2               = port:PE06<2><default><default><default>
vip_csi_d3               = port:PE07<2><default><default><default>
vip_csi_d4               = port:PE08<2><default><default><default>
vip_csi_d5               = port:PE09<2><default><default><default>
vip_csi_d6               = port:PE10<2><default><default><default>
vip_csi_d7               = port:PE11<2><default><default><default>
vip_csi_d8               = port:PE12<2><default><default><default>
;vip_csi_d9               = port:PE13<2><default><default><default>
vip_csi_d10               = port:PE14<2><default><default><default>
vip_csi_d11               = port:PE15<2><default><default><default>
vip_dev0_mname           = "ov2640"
vip_dev0_pos             = "front"
vip_dev0_twi_id          = 1
vip_dev0_isp_used        = 0
vip_dev0_fmt             = 0
vip_dev0_vflip           = 0
vip_dev0_hflip           = 0
vip_dev0_iovdd           = ""
vip_dev0_iovdd_vol       = 2800000
vip_dev0_avdd            = ""
vip_dev0_avdd_vol        = 2800000
vip_dev0_dvdd            = ""
vip_dev0_dvdd_vol        = 1500000
vip_dev0_afvdd           = ""
vip_dev0_power_en        =
vip_dev0_reset           =
vip_dev0_pwdn            =
vip_dev0_flash_en        =
vip_dev0_af_pwdn         =
vip_dev0_act_name        = "ad5820_act"
vip_dev1_mname           = "gc2035"
vip_dev1_lane            = 1
vip_dev1_twi_id          = 4
vip_dev1_twi_addr        = 0x78
vip_dev1_fmt             = 1
vip_dev1_vflip           = 0
vip_dev1_hflip           = 0
vip_dev1_iovdd           = ""
vip_dev1_avdd            = ""
vip_dev1_dvdd            = ""
vip_dev1_afvdd           = ""
vip_dev1_power_en        =
vip_dev1_reset           =
vip_dev1_pwdn            =
vip_dev1_flash_en        =
vip_dev1_af_pwdn         =
将其中的摄像头信息改成自己使用的摄像头信息。
保存,并使用 fex2bin sys_config.fex script.bin 生成script.bin文件。
如果提示E: sys_config.fex:165: invalid character at 4.
就注释掉165 166两行。
请问为什么按照荔枝派官方文档要求注释掉165 166两行:
可还是提示E: sys_config.fex:165: invalid character at 4.
有大佬知道问题出在哪吗?谢谢!
