楼主 # 2024-04-02 17:37:16
sxlyq_666
已发帖子: 70
如何向内核中添加ch340驱动?
在内核配置菜单中,没有看到340的驱动。
  --- USB Serial Converter support        │ │
  │ │        [*]   USB Serial Console device support        │ │
  │ │        [*]   USB Generic Serial Driver        │ │
  │ │        < >   USB Serial Simple Driver        │ │
  │ │        < >   USB AIRcable Bluetooth Dongle Driver        │ │
  │ │        < >   USB ARK Micro 3116 USB Serial Driver        │ │
  │ │        < >   USB Belkin and Peracom Single Port Serial Driver        │ │
  │ │        < >   USB Winchiphead CH341 Single Port Serial Driver        │ │
  │ │        < >   USB ConnectTech WhiteHEAT Serial Driver        │ │
  │ │        < >   USB Digi International AccelePort USB Serial Driver        │ │
  │ │        < >   USB CP210x family of UART Bridge Controllers        │ │
  │ │        < >   USB Cypress M8 USB Serial Driver        │ │
  │ │        < >   USB Empeg empeg-car Mark I/II Driver        │ │
  │ │        < >   USB FTDI Single Port Serial Driver        │ │
  │ │        < >   USB Handspring Visor / Palm m50x / Sony Clie Driver        │ │
  │ │        < >   USB PocketPC PDA Driver        │ │
  │ │        < >   USB IR Dongle Serial Driver        │ │
  │ │        < >   USB Inside Out Edgeport Serial Driver        │ │
  │ │        < >   USB Inside Out Edgeport Serial Driver (TI devices)        │ │
  │ │        < >   USB Fintek F81232 Single Port Serial Driver        │ │
  │ │        < >   USB Fintek F81532/534 Multi-Ports Serial Driver        │ │
  │ │        < >   USB Garmin GPS driver        │ │
  │ │        < >   USB IPWireless (3G UMTS TDD) Driver        │ │
  │ │        < >   USB Infinity USB Unlimited Phoenix Driver        │ │
  │ │        < >   USB Keyspan PDA Single Port Serial Driver        │ │
  │ │        < >   USB Keyspan USA-xxx Serial Driver        │ │
  │ │        < >   USB KL5KUSB105 (Palmconnect) Driver        │ │
  │ │        < >   USB KOBIL chipcard reader        │ │
  │ │        < >   USB MCT Single Port Serial Driver        │ │
  │ │        < >   USB Metrologic Instruments USB-POS Barcode Scanner Driver        │ │
  │ │        < >   USB Moschip 7720 Serial Driver        │ │
  │ │        < >   USB Moschip 7840/7820 USB Serial Driver        │ │
  │ │        < >   USB Moxa UPORT Serial Driver        │ │
  │ │        < >   USB Navman GPS device        │ │
  │ │        <*>   USB Prolific 2303 Single Port Serial Driver        │ │
  │ │        < >   USB Ours Technology Inc. OTi-6858 USB To RS232 Bridge Controller        │ │
  │ │        < >   USB Qualcomm Auxiliary Serial Port Driver        │ │
楼主 #1 2024-04-02 17:47:42
sxlyq_666
已发帖子: 70
Re: 如何向内核中添加ch340驱动?
我在drivers目录下,发现有ch341.c,但是没有ch341.o。
#2 2024-04-02 18:23:28
marcus
已发帖子: 65
Makefile 里面加
obj-y += ch341.o
进一步的话也要修改 config 那个文件。
最近编辑记录 marcus (2024-04-02 18:24:10)
楼主 #3 2024-04-03 09:05:47
sxlyq_666
已发帖子: 70
marcus 说:
Makefile 里面加
obj-y += ch341.o
是内核根目录下的 .config文件吗?
楼主 #4 2024-04-03 09:15:51
sxlyq_666
已发帖子: 70
marcus 说:
Makefile 里面加
obj-y += ch341.o
我在drivers/serial/目录下的Makefile文件中,发现是有该编译指令的,具体如下:,比较奇怪的是,为什么没有编译?谢谢。
obj-$(CONFIG_USB_SERIAL_AIRCABLE)               += aircable.o
obj-$(CONFIG_USB_SERIAL_ARK3116)                += ark3116.o
obj-$(CONFIG_USB_SERIAL_BELKIN)                 += belkin_sa.o
obj-$(CONFIG_USB_SERIAL_CH341)                  += ch341.o
#5 2024-04-04 14:24:00
marcus
已发帖子: 65
CONFIG_USB_SERIAL_CH341 这个宏没有选上,可以去config文件里面查,在哪个子菜单选项里面,然后打开就好了。
楼主 #6 2024-04-04 15:44:52
sxlyq_666
已发帖子: 70
marcus 说:
谢谢,已经弄好了。但是网卡eth0却找不到了。郁闷。
