详情:
INFO: build dts ...
INFO: Prepare toolchain ...
removed '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt/.board.dtb.d.dtc.tmp'
removed '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt/.board.dtb.dts.tmp'
'/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/kernel/build/arch/arm/boot/dts/.board.dtb.d.dtc.tmp' -> '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt/.board.dtb.d.dtc.tmp'
'/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/kernel/build/arch/arm/boot/dts/.board.dtb.dts.tmp' -> '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt/.board.dtb.dts.tmp'
'/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/kernel/staging/sunxi.dtb' -> '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt/sunxi.dtb'
INFO: build rootfs ...
==mkcmd.sh: build_openwrt_rootfs with -j1 V=s==
make: Entering directory '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt'
make[1]: Entering directory '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt'
CreateSoftLink /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt/tmp link to /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt/tmp
CreateSoftLink /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt/staging_dir link to /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt/staging_dir
make[2]: Entering directory '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt'
make[2]: Leaving directory '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt'
Check Vendor Package...
CreateSoftLink /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt/package/subpackage link to /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/package
end
WARNING: Makefile 'package/subpackage/feeds/libs/cairo/Makefile' has a dependency on 'libgpu', which does not exist
WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia_demo/camerapreviewerdemo/Makefile' has a build dependency on 'libcedarx', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/flutter/flutter-sunxi/Makefile' has a dependency on 'libgpu', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libgst1gl', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'opencv', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1wayland', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1badvideo', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1gl', which does not exist
WARNING: Makefile 'package/subpackage/allwinner/display/libuapi/Makefile' has a dependency on 'libgpu', which does not exist
WARNING: Makefile 'package/kernel/linux/Makefile' has a dependency on 'ap6256-firmware', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'libgpu', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'weston', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'wayland', which does not exist
WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a build dependency on 'libstdcpp', which does not exist
WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia/Makefile' has a dependency on 'libgpu', which does not exist
WARNING: Makefile 'package/subpackage/allwinner/multimedia/tina_multimedia/Makefile' has a dependency on 'libkeystone', which does not exist
copy from /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/target/t113/t113-evb1_auto/defconfig
# No change to .config
copy to /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/target/t113/t113-evb1_auto/defconfig
Makefile:26: "NOTE: Will skip kernel build."
Makefile:253: "==/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/out/t113/evb1_auto/openwrt=="
The command image-prereq(include/kernel-build.mk) execute.
time: target/linux/prereq#0.09#0.05#0.14
make[1]: Leaving directory '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt'
make[1]: *** No rule to make target 'with'. Stop.
/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt/include/toplevel.mk:238: recipe for target 'with' failed
make: *** [with] Error 2
make: Leaving directory '/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt'
INFO: build_openwrt_rootfs failed
这里是一段源代码内容。大概
make[3] -C package/system/fstools compile
make[3] -C /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/package/allwinner/wireless/btmanager compile
make[3] -C /home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/package/feeds/net/openssh compile
make[3] -C package/boot/uboot-envtools compile
make[3] -C package/base-files compile
ERROR: package/subpackage/feeds/libs/nspr [host] failed to build.
ERROR: package/subpackage/feeds/libs/nspr failed to build.
make -r world: build failed. Please re-run make with -j1 V=s or V=sc for a higher verbosity level to see what's going on
/home/zh/Desktop/Linux/T113-S3/SDK/T113-Tina/openwrt/openwrt/include/toplevel.mk:238: recipe for target 'world' failed
make: *** [world] Error 1
这里是一段源代码内容。离线
应该是tina里面本身的编译脚本有问题,这个是编的qt开发sdk,直接放到t113上没有意义,flash也没那么大。
大佬有没有有Tina5.0的板级配置插件啊
