楼主 # 2024-07-24 12:29:12
Peter Mei
R329代码里找不到BOOT0启动打印“HELLO! BOOT0 is starting!”
软硬件环境:
peter@u14:~/share/r329-evb5$ lunch r329_evb5-tina
TINA_BUILD_TOP=/home/peter/share/r329-evb5
TINA_TARGET_ARCH=aarch64
TARGET_PRODUCT=r329_evb5
TARGET_PLATFORM=r329
TARGET_BOARD=r329-evb5
TARGET_PLAN=evb5
TARGET_BUILD_VARIANT=tina
TARGET_BUILD_TYPE=release
TARGET_KERNEL_VERSION=4.9
TARGET_UBOOT=u-boot-2018
TARGET_CHIP=sun50iw11p1
其中,~/share/r329-evb5是SDK顶层目录
启动打印:
[65]HELLO! BOOT0 is starting!
[68]BOOT0 commit : 97444f5
[70]set pll start
[73]periph0 has been enabled
代码里搜索第一行里的“starting!”:
peter@u14:~/share/r329-evb5$  grep "starting!" --binary-files=without-match --exclude-dir=\.git --exclude-dir=\.repo --exclude=*tags -nwr ./
peter@u14:~/share/r329-evb5$  grep "starting!" --exclude-dir=\.git --exclude-dir=\.repo --exclude=*tags -nwr ./
Binary file ./device/config/chips/r329/bin/boot0_nand_sun50iw11p1.bin matches
Binary file ./device/config/chips/r329/bin/sboot_sun50iw11p1.bin matches
Binary file ./device/config/chips/r329/bin/boot0_spinor_sun50iw11p1.bin matches
Binary file ./device/config/chips/r329/bin/boot0_sdcard_sun50iw11p1.bin matches
大佬们,是代码文件里本身没有“HELLO! BOOT0 is starting!”,还是我搜索的问题?还是其他的原因?
#1 2024-07-25 23:18:43
shaoxi2010
已发帖子: 398
Re: R329代码里找不到BOOT0启动打印“HELLO! BOOT0 is starting!”
没有问题,boot0是闭源代码,全志就没打算让你折腾
