楼主 # 2025-02-16 02:10:00
damifan
求助关于F1c100s SPI Flash 4.15.x 荔枝版,USB插入任何设备均无反应,但可以下载的问题
设备树修改如下:
dts:
#include "suniv-f1c100s.dtsi"
	model = "Lichee Pi Nano";
	compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
		     "allwinner,suniv";
	aliases {
		serial0 = &uart0;
		spi0 = &spi0;
	chosen {
	panel: panel {
		compatible = "qiaodian,qd43003c0-40", "simple-panel";
		#address-cells = <1>;
		#size-cells = <0>;
		enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
		port@0 {
			reg = <0>;
			#size-cells = <0>;
			panel_input: endpoint@0 {
				reg = <0>;
	panel: panel {
		compatible = "ampire,am-480272h3tmqw-t01h", "simple-panel";
		#size-cells = <0>;
		dclk-frequency = <30000>;
		port@0 {
			reg = <0>;
			#size-cells = <0>;
				reg = <0>;
	reg_vcc3v3: vcc3v3 {
		regulator-name = "vcc3v3";
&de {
&mmc0 {
	vmmc-supply = <&reg_vcc3v3>;
	bus-width = <4>;
	broken-cd;
&otg_sram {
&spi0 {
	pinctrl-names = "default";
	pinctrl-0 = <&spi0_pins_a>;
	flash@0 {
		#size-cells = <1>;
		reg = <0>;
&spi0 {
        flash@0 {
                #size-cells = <1>;
                compatible = "winbond,xt25f128b", "jedec,spi-nor";
                reg = <0>;
&spi0 {
    flash: xt25f128b@0 {
        #size-cells = <1>;
        reg = <0>;
        partitions {
            #size-cells = <1>;
            partition@0 {
                label = "u-boot";
                reg = <0x000000 0x100000>;
                read-only;
            partition@100000 {
                label = "dtb";
                reg = <0x100000 0x10000>;
                read-only;
            partition@110000 {
                label = "kernel";
                reg = <0x110000 0x400000>;
                read-only;
            partition@510000 {
                label = "rootfs";
                reg = <0x510000 0xAF0000>;
&tcon0 {
	pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
	tcon0_out_lcd: endpoint@0 {
		reg = <0>;
&i2c0 {
	pinctrl-0 = <&i2c0_pins>;
	pcf8563: pcf8563@51 {
		compatible = "nxp,pcf8563";
        reg = <0x51>;       // PCF8563 的 I2C 地址
&rtp {
	pinctrl-0 = <&rtp_pins>;
&uart0 {
	pinctrl-0 = <&uart0_pins_a>;
&uart2 {
	pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
	dr_mode = "host";
&usbphy {
	usb0_id_det = <&pio 4 2 GPIO_ACTIVE_HIGH>; /* PE2.我做了修改,在4.15内核中使用的名称是 usb0_id_det */
dtsi:
#include <dt-bindings/clock/suniv-ccu.h>
#include <dt-bindings/reset/suniv-ccu.h>
	#size-cells = <1>;
	interrupt-parent = <&intc>;
	clocks {
		#size-cells = <1>;
		ranges;
		osc24M: clk-24M {
			#clock-cells = <0>;
			compatible = "fixed-clock";
			clock-frequency = <24000000>;
		osc32k: clk-32k {
			#clock-cells = <0>;
			clock-frequency = <32768>;
		fake100M: clk-100M {
			#clock-cells = <0>;
			clock-frequency = <100000000>;
			clock-output-names = "fake-100M";
	cpus {
		#address-cells = <0>;
		#size-cells = <0>;
		cpu {
			device_type = "cpu";
	de: display-engine {
		compatible = "allwinner,suniv-display-engine";
		allwinner,pipelines = <&fe0>;
		status = "disabled";
	soc {
		compatible = "simple-bus";
		#size-cells = <1>;
		ranges;
		sram-controller@1c00000 {
			compatible = "allwinner,sun4i-a10-sram-controller";
			reg = <0x01c00000 0x30>;
			#size-cells = <1>;
			ranges;
			sram_d: sram@10000 {
				compatible = "mmio-sram";
				reg = <0x00010000 0x1000>;
				#size-cells = <1>;
				otg_sram: sram-section@0 {
					reg = <0x0000 0x1000>;
		spi0: spi@1c05000 {
				     "allwinner,sun8i-h3-spi";
			reg = <0x01c05000 0x1000>;
			interrupts = <10>;
			clock-names = "ahb", "mod";
			resets = <&ccu RST_BUS_SPI0>;
			#size-cells = <0>;
		spi1: spi@1c06000 {
			reg = <0x01c06000 0x1000>;
			interrupts = <11>;
			clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
			resets = <&ccu RST_BUS_SPI1>;
			#size-cells = <0>;
		tcon0: lcd-controller@1c0c000 {
			compatible = "allwinner,suniv-tcon";
			reg = <0x01c0c000 0x1000>;
			interrupts = <29>;
			clocks = <&ccu CLK_BUS_LCD>,
				 <&ccu CLK_TCON>,
				 <&osc24M>;	/* Still unknown */
				      "tcon-ch0",
				      "tcon-ch1";
			clock-output-names = "tcon-pixel-clock";
			resets = <&ccu RST_BUS_LCD>;
			reset-names = "lcd";
			ports {
				#size-cells = <0>;
				tcon0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					tcon0_in_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_out_tcon0>;
				tcon0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
		mmc0: mmc@1c0f000 {
			compatible = "allwinner,suniv-mmc",
				     "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <23>;
			pinctrl-0 = <&mmc0_pins>;
			#size-cells = <0>;
		mmc1: mmc@1c10000 {
			reg = <0x01c10000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC1>,
				 <&ccu CLK_MMC1>,
				 <&ccu CLK_MMC1_OUTPUT>,
				 <&ccu CLK_MMC1_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC1>;
			interrupts = <24>;
			#size-cells = <0>;
		ccu: clock@1c20000 {
			compatible = "allwinner,suniv-ccu";
			reg = <0x01c20000 0x400>;
			clock-names = "hosc", "losc";
			#clock-cells = <1>;
			#reset-cells = <1>;
			compatible = "allwinner,suniv-ic";
			reg = <0x01c20400 0x400>;
			interrupt-controller;
			#interrupt-cells = <1>;
				i2c0: i2c@1C27000 {
			compatible = "allwinner,sun6i-a31-i2c";
			reg = <0x01C27000 0x400>;
			interrupts = <7>;
			clocks = <&ccu CLK_BUS_I2C0>;
			resets = <&ccu RST_BUS_I2C0>;
			#size-cells = <0>;
		pio: pinctrl@1c20800 {
			compatible = "allwinner,suniv-pinctrl";
			reg = <0x01c20800 0x400>;
			gpio-controller;
			#interrupt-cells = <3>;
			#gpio-cells = <3>;
			i2c0_pins: i2c0 {
				pins = "PE11", "PE12";
				function = "i2c0";
			spi0_pins_a: spi0-pins-pc {
				function = "spi0";
			lcd_rgb666_pins: lcd-rgb666-pins {
				pins = "PD0", "PD1", "PD2", "PD3", "PD4",
				       "PD5", "PD6", "PD7", "PD8", "PD9",
				       "PD10", "PD11", "PD12", "PD13", "PD14",
				       "PD15", "PD16", "PD17", "PD18", "PD19",
				       "PD20", "PD21";
				function = "lcd";
			rtp_pins: rtp-pins {
				pins = "PA0", "PA1", "PA2", "PA3";
				function = "rtp";
			uart0_pins_a: uart-pins-pe {
				pins = "PE0", "PE1";
				function = "uart0";
			uart2_pins_a: uart2-pins-pe {
				pins = "PE7", "PE8";
				function = "uart2";
			mmc0_pins: mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
				function = "mmc0";
		timer@1c20c00 {
			compatible = "allwinner,suniv-timer";
			reg = <0x01c20c00 0x90>;
			interrupts = <13>;
			clocks = <&osc24M>;
		wdt: watchdog@1c20ca0 {
			reg = <0x01c20ca0 0x20>;
		rtp: rtp@1c24800 {
			compatible = "allwinner,sun4i-a10-ts";
			reg = <0x01c24800 0x100>;
			interrupts = <20>;
			allwinner,ts-attached;
			#thermal-sensor-cells = <0>;
		uart0: serial@1c25000 {
			reg = <0x01c25000 0x400>;
			interrupts = <1>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart1: serial@1c25400 {
			reg = <0x01c25400 0x400>;
			interrupts = <2>;
			reg-shift = <2>;
			reg-io-width = <4>;
		uart2: serial@1c25800 {
			reg = <0x01c25800 0x400>;
			interrupts = <3>;
			reg-shift = <2>;
			reg-io-width = <4>;
		usb_otg: usb@1c13000 {
			reg = <0x01c13000 0x0400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <26>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
		usbphy: phy@1c13400 {
			reg = <0x01c13400 0x10>;
			reg-names = "phy_ctrl";
			clocks = <&ccu CLK_USB_PHY0>;
			clock-names = "usb0_phy";
			resets = <&ccu RST_USB_PHY0>;
			reset-names = "usb0_reset";
			#phy-cells = <1>;
		fe0: display-frontend@1e00000 {
			compatible = "allwinner,suniv-display-frontend";
			reg = <0x01e00000 0x20000>;
			interrupts = <30>;
			clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
				 <&ccu CLK_DRAM_DE_FE>;
			clock-names = "ahb", "mod",
				      "ram";
			resets = <&ccu RST_BUS_DE_FE>;
			ports {
				#size-cells = <0>;
				fe0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					fe0_out_be0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&be0_in_fe0>;
		be0: display-backend@1e60000 {
			compatible = "allwinner,suniv-display-backend";
			reg = <0x01e60000 0x10000>;
			reg-names = "be";
			interrupts = <31>;
			clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
				 <&ccu CLK_DRAM_DE_BE>;
				      "ram";
			resets = <&ccu RST_BUS_DE_BE>;
			reset-names = "be";
			assigned-clocks = <&ccu CLK_DE_BE>;
			assigned-clock-rates = <300000000>;
			ports {
				#size-cells = <0>;
				be0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					be0_in_fe0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&fe0_out_be0>;
				be0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					be0_out_tcon0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&tcon0_in_be0>;
dmesg 输入关于开机过程中打印的log
# dmesg | grep -E 'musb|usb|phy'
[    0.115649] usbcore: registered new interface driver usbfs
[    0.115799] usbcore: registered new interface driver hub
[    0.116041] usbcore: registered new device driver usb
[    1.005230] usbcore: registered new interface driver usb-storage
[    1.012313] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.024307] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.030252] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.156649] usbcore: registered new interface driver usbhid
[    1.162376] usbhid: USB HID core driver
目前问题是PE2无论是拉高还是拉低都有测试,插入U盘、键盘、无线网卡均没有任何反应,日志也没有打印,但是可以通过USB进行下载固件,线路应是没有任何问题,特来求助,还望有经验的朋友能不吝赐教,指点一二
最近编辑记录 damifan (2025-02-16 02:49:58)
