设备树修改如下:
dts:
#include "suniv-f1c100s.dtsi"
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
"allwinner,suniv";
aliases {
serial0 = &uart0;
spi0 = &spi0;
chosen {
panel: panel {
compatible = "qiaodian,qd43003c0-40", "simple-panel";
#address-cells = <1>;
#size-cells = <0>;
enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
port@0 {
reg = <0>;
#size-cells = <0>;
panel_input: endpoint@0 {
reg = <0>;
panel: panel {
compatible = "ampire,am-480272h3tmqw-t01h", "simple-panel";
#size-cells = <0>;
dclk-frequency = <30000>;
port@0 {
reg = <0>;
#size-cells = <0>;
reg = <0>;
reg_vcc3v3: vcc3v3 {
regulator-name = "vcc3v3";
&de {
&mmc0 {
vmmc-supply = <®_vcc3v3>;
bus-width = <4>;
broken-cd;
&otg_sram {
&spi0 {
pinctrl-names = "default";
pinctrl-0 = <&spi0_pins_a>;
flash@0 {
#size-cells = <1>;
reg = <0>;
&spi0 {
flash@0 {
#size-cells = <1>;
compatible = "winbond,xt25f128b", "jedec,spi-nor";
reg = <0>;
&spi0 {
flash: xt25f128b@0 {
#size-cells = <1>;
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0x000000 0x100000>;
read-only;
partition@100000 {
label = "dtb";
reg = <0x100000 0x10000>;
read-only;
partition@110000 {
label = "kernel";
reg = <0x110000 0x400000>;
read-only;
partition@510000 {
label = "rootfs";
reg = <0x510000 0xAF0000>;
&tcon0 {
pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
tcon0_out_lcd: endpoint@0 {
reg = <0>;
&i2c0 {
pinctrl-0 = <&i2c0_pins>;
pcf8563: pcf8563@51 {
compatible = "nxp,pcf8563";
reg = <0x51>; // PCF8563 的 I2C 地址
&rtp {
pinctrl-0 = <&rtp_pins>;
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
&uart2 {
pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
dr_mode = "host";
&usbphy {
usb0_id_det = <&pio 4 2 GPIO_ACTIVE_HIGH>; /* PE2.我做了修改,在4.15内核中使用的名称是 usb0_id_det */
dtsi:
#include <dt-bindings/clock/suniv-ccu.h>
#include <dt-bindings/reset/suniv-ccu.h>
#size-cells = <1>;
interrupt-parent = <&intc>;
clocks {
#size-cells = <1>;
ranges;
osc24M: clk-24M {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
osc32k: clk-32k {
#clock-cells = <0>;
clock-frequency = <32768>;
fake100M: clk-100M {
#clock-cells = <0>;
clock-frequency = <100000000>;
clock-output-names = "fake-100M";
cpus {
#address-cells = <0>;
#size-cells = <0>;
cpu {
device_type = "cpu";
de: display-engine {
compatible = "allwinner,suniv-display-engine";
allwinner,pipelines = <&fe0>;
status = "disabled";
soc {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
sram-controller@1c00000 {
compatible = "allwinner,sun4i-a10-sram-controller";
reg = <0x01c00000 0x30>;
#size-cells = <1>;
ranges;
sram_d: sram@10000 {
compatible = "mmio-sram";
reg = <0x00010000 0x1000>;
#size-cells = <1>;
otg_sram: sram-section@0 {
reg = <0x0000 0x1000>;
spi0: spi@1c05000 {
"allwinner,sun8i-h3-spi";
reg = <0x01c05000 0x1000>;
interrupts = <10>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
#size-cells = <0>;
spi1: spi@1c06000 {
reg = <0x01c06000 0x1000>;
interrupts = <11>;
clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
resets = <&ccu RST_BUS_SPI1>;
#size-cells = <0>;
tcon0: lcd-controller@1c0c000 {
compatible = "allwinner,suniv-tcon";
reg = <0x01c0c000 0x1000>;
interrupts = <29>;
clocks = <&ccu CLK_BUS_LCD>,
<&ccu CLK_TCON>,
<&osc24M>; /* Still unknown */
"tcon-ch0",
"tcon-ch1";
clock-output-names = "tcon-pixel-clock";
resets = <&ccu RST_BUS_LCD>;
reset-names = "lcd";
ports {
#size-cells = <0>;
tcon0_in: port@0 {
#size-cells = <0>;
reg = <0>;
tcon0_in_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_out_tcon0>;
tcon0_out: port@1 {
#size-cells = <0>;
reg = <1>;
mmc0: mmc@1c0f000 {
compatible = "allwinner,suniv-mmc",
"allwinner,sun7i-a20-mmc";
reg = <0x01c0f000 0x1000>;
clocks = <&ccu CLK_BUS_MMC0>,
<&ccu CLK_MMC0>,
<&ccu CLK_MMC0_OUTPUT>,
<&ccu CLK_MMC0_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC0>;
reset-names = "ahb";
interrupts = <23>;
pinctrl-0 = <&mmc0_pins>;
#size-cells = <0>;
mmc1: mmc@1c10000 {
reg = <0x01c10000 0x1000>;
clocks = <&ccu CLK_BUS_MMC1>,
<&ccu CLK_MMC1>,
<&ccu CLK_MMC1_OUTPUT>,
<&ccu CLK_MMC1_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC1>;
interrupts = <24>;
#size-cells = <0>;
ccu: clock@1c20000 {
compatible = "allwinner,suniv-ccu";
reg = <0x01c20000 0x400>;
clock-names = "hosc", "losc";
#clock-cells = <1>;
#reset-cells = <1>;
compatible = "allwinner,suniv-ic";
reg = <0x01c20400 0x400>;
interrupt-controller;
#interrupt-cells = <1>;
i2c0: i2c@1C27000 {
compatible = "allwinner,sun6i-a31-i2c";
reg = <0x01C27000 0x400>;
interrupts = <7>;
clocks = <&ccu CLK_BUS_I2C0>;
resets = <&ccu RST_BUS_I2C0>;
#size-cells = <0>;
pio: pinctrl@1c20800 {
compatible = "allwinner,suniv-pinctrl";
reg = <0x01c20800 0x400>;
gpio-controller;
#interrupt-cells = <3>;
#gpio-cells = <3>;
i2c0_pins: i2c0 {
pins = "PE11", "PE12";
function = "i2c0";
spi0_pins_a: spi0-pins-pc {
function = "spi0";
lcd_rgb666_pins: lcd-rgb666-pins {
pins = "PD0", "PD1", "PD2", "PD3", "PD4",
"PD5", "PD6", "PD7", "PD8", "PD9",
"PD10", "PD11", "PD12", "PD13", "PD14",
"PD15", "PD16", "PD17", "PD18", "PD19",
"PD20", "PD21";
function = "lcd";
rtp_pins: rtp-pins {
pins = "PA0", "PA1", "PA2", "PA3";
function = "rtp";
uart0_pins_a: uart-pins-pe {
pins = "PE0", "PE1";
function = "uart0";
uart2_pins_a: uart2-pins-pe {
pins = "PE7", "PE8";
function = "uart2";
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
function = "mmc0";
timer@1c20c00 {
compatible = "allwinner,suniv-timer";
reg = <0x01c20c00 0x90>;
interrupts = <13>;
clocks = <&osc24M>;
wdt: watchdog@1c20ca0 {
reg = <0x01c20ca0 0x20>;
rtp: rtp@1c24800 {
compatible = "allwinner,sun4i-a10-ts";
reg = <0x01c24800 0x100>;
interrupts = <20>;
allwinner,ts-attached;
#thermal-sensor-cells = <0>;
uart0: serial@1c25000 {
reg = <0x01c25000 0x400>;
interrupts = <1>;
reg-shift = <2>;
reg-io-width = <4>;
uart1: serial@1c25400 {
reg = <0x01c25400 0x400>;
interrupts = <2>;
reg-shift = <2>;
reg-io-width = <4>;
uart2: serial@1c25800 {
reg = <0x01c25800 0x400>;
interrupts = <3>;
reg-shift = <2>;
reg-io-width = <4>;
usb_otg: usb@1c13000 {
reg = <0x01c13000 0x0400>;
clocks = <&ccu CLK_BUS_OTG>;
resets = <&ccu RST_BUS_OTG>;
interrupts = <26>;
interrupt-names = "mc";
phys = <&usbphy 0>;
phy-names = "usb";
extcon = <&usbphy 0>;
usbphy: phy@1c13400 {
reg = <0x01c13400 0x10>;
reg-names = "phy_ctrl";
clocks = <&ccu CLK_USB_PHY0>;
clock-names = "usb0_phy";
resets = <&ccu RST_USB_PHY0>;
reset-names = "usb0_reset";
#phy-cells = <1>;
fe0: display-frontend@1e00000 {
compatible = "allwinner,suniv-display-frontend";
reg = <0x01e00000 0x20000>;
interrupts = <30>;
clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
<&ccu CLK_DRAM_DE_FE>;
clock-names = "ahb", "mod",
"ram";
resets = <&ccu RST_BUS_DE_FE>;
ports {
#size-cells = <0>;
fe0_out: port@1 {
#size-cells = <0>;
reg = <1>;
fe0_out_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_in_fe0>;
be0: display-backend@1e60000 {
compatible = "allwinner,suniv-display-backend";
reg = <0x01e60000 0x10000>;
reg-names = "be";
interrupts = <31>;
clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
<&ccu CLK_DRAM_DE_BE>;
"ram";
resets = <&ccu RST_BUS_DE_BE>;
reset-names = "be";
assigned-clocks = <&ccu CLK_DE_BE>;
assigned-clock-rates = <300000000>;
ports {
#size-cells = <0>;
be0_in: port@0 {
#size-cells = <0>;
reg = <0>;
be0_in_fe0: endpoint@0 {
reg = <0>;
remote-endpoint = <&fe0_out_be0>;
be0_out: port@1 {
#size-cells = <0>;
reg = <1>;
be0_out_tcon0: endpoint@0 {
reg = <0>;
remote-endpoint = <&tcon0_in_be0>;
dmesg 输入关于开机过程中打印的log
# dmesg | grep -E 'musb|usb|phy'
[ 0.115649] usbcore: registered new interface driver usbfs
[ 0.115799] usbcore: registered new interface driver hub
[ 0.116041] usbcore: registered new device driver usb
[ 1.005230] usbcore: registered new interface driver usb-storage
[ 1.012313] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.024307] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.030252] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.156649] usbcore: registered new interface driver usbhid
[ 1.162376] usbhid: USB HID core driver
目前问题是PE2无论是拉高还是拉低都有测试,插入U盘、键盘、无线网卡均没有任何反应,日志也没有打印,但是可以通过USB进行下载固件,线路应是没有任何问题,特来求助,还望有经验的朋友能不吝赐教,指点一二
最近编辑记录 damifan (2025-02-16 02:49:58)
