项目节省功耗,不设SD卡,但需要用一块t113芯片通过USB启动下一块t113芯片。
查阅t113芯片手册,只内置了ehci和ohci两个usb-controller。
插入虚拟机(主机)获得的log如下
[1019819.266687] usb 1-2.1: new full-speed USB device number 19 using uhci_hcd
[1019819.538587] usb 1-2.1: New USB device found, idVendor=1f3a, idProduct=efe8, bcdDevice= 2.b3
[1019819.538594] usb 1-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0BROM的fel启动系统在虚拟机(主机)显示用uhci识别,且禁用uhci后虚拟机(主机)无法识别此设备。推测t113的fel只支持uhci协议,而uhci与ohci和ehci都不兼容。
以下为t113片上系统部分log
# dmesg |grep hci
[ 0.166027] Warning! fotg210_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 1.244036] ehci-platform 4200000.usb: EHCI Host Controller
[ 1.249662] ehci-platform 4200000.usb: new USB bus registered, assigned bus number 2
[ 1.257663] ehci-platform 4200000.usb: irq 241, io mem 0x04200000
[ 1.264949] ohci-platform 4200400.usb: Generic Platform OHCI controller
[ 1.271605] ohci-platform 4200400.usb: new USB bus registered, assigned bus number 3
[ 1.279541] ohci-platform 4200400.usb: irq 243, io mem 0x04200400
[ 1.292862] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
[ 1.319741] usb usb2: Manufacturer: Linux 6.1.0-rc3 ehci_hcd
[ 1.378907] usb usb3: Manufacturer: Linux 6.1.0-rc3 ohci_hcd
[ 2.238217] ehci-platform 4101000.usb: EHCI Host Controller
[ 2.238217] ohci-platform 4101400.usb: Generic Platform OHCI controller
[ 2.238261] ohci-platform 4101400.usb: new USB bus registered, assigned bus number 4
[ 2.243836] ehci-platform 4101000.usb: new USB bus registered, assigned bus number 5
[ 2.250573] ohci-platform 4101400.usb: irq 242, io mem 0x04101400
[ 2.258274] ehci-platform 4101000.usb: irq 240, io mem 0x04101000
[ 2.302824] ehci-platform 4101000.usb: USB 2.0 started, EHCI 1.00
[ 2.329533] usb usb5: Manufacturer: Linux 6.1.0-rc3 ehci_hcd
[ 2.370209] usb usb4: Manufacturer: Linux 6.1.0-rc3 ohci_hcd
//此时插入另一个未激活的t113设备
# [ 499.222812] usb 3-1: new full-speed USB device number 2 using ohci-platform
[ 499.487860] usb 3-1: New USB device found, idVendor=1f3a, idProduct=efe8, bcdDevice= 2.b3
[ 499.496084] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 512.702810] random: crng init done
# lsusb
Bus 005 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0001
Bus 001 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0001
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 003: ID 1f3a:efe8t113分配ohci来识别未激活的t113设备,却没有相应的驱动,搜了一下发现1f3a:efe8驱动都是windows系统上的,可否移植uhci的驱动给ohci使用?
以下摘录t113 user manual部分内容:
2.2.11.2 USB HOST
One USB 2.0 HOST (USB1), with integrated USB 2.0 analog PHY
Complies with USB2.0 Specification
Supports USB2.0 Host function - - - -
Compatible with Enhanced Host Controller Interface (EHCI) Specification, Version 1.0
Compatible with Open Host Controller Interface (OHCI) Specification, Version 1.0a
Supports High-Speed (HS, 480 Mbit/s), Full-Speed (FS, 12 Mbit/s) and Low-Speed (LS, 1.5 Mbit/s)
Device
Supports only 1 USB Root port shared between EHCI and OHCI
An internal DMA Controller for data transfer with memory
2.2.11.1 USB DRD
One USB 2.0 DRD (USB0), with integrated USB 2.0 analog PHY
Supports USB Host function - - - -
Supports High-Speed (HS, 480 Mbit/s), Full-Speed (FS, 12 Mbit/s), and Low-Speed (LS, 1.5 Mbit/s)
Supports USB Device function - - - - -
Supports bi-directional endpoint0 (EP0) for Control transfer
Up to (8 KB + 64 Bytes) FIFO for all EPs (including EP0)
Up to 10 user-configurable endpoints (EP1+, EP1-, EP2+, EP2-, EP3+, EP3-, EP4+, EP4-, EP5+, EP5-) for
Bulk transfer, Isochronous transfer and Interrupt transfer
Supports interface to an external Normal DMA controller for every EP
Supports an internal DMA controller for data transfer with memory
Supports High-Bandwidth Isochronous & Interrupt transfers
Automated splitting/combining of packets for Bulk transfers
Supports point-to-point and point-to-multipoint transfer in both Host and Peripheral modes
Includes automatic ping capabilities
Soft connect/disconnect function
Performs all transaction scheduling in hardware
Power optimization and power management capabilities
Device and host controller share a 8K SRAM and a physical PHY
如何实现一块t113启动另一块t113芯片?请提供一切思路
