串口日志
[95]HELLO! BOOT0 is starting!
[98]BOOT0 commit : 4b419f21ba
[102]PMU: AXP21
[105]set pll start
[107]periph0 has been enabled
[110]set pll end
[111]board init ok
[113]rtc[0] value = 0x80000002
[116]rtc[3] value = 0x35dd66e6
[119]rtc[7] value = 0x100
[122]DRAM use external ZQ!!
[124]chip id check OK
[127]DRAM_VCC set to 1350 mv
[129]DRAM BOOT DRIVE INFO: V0.16
[132]DRAM CLK = 912 MHz
[135]DRAM Type = 3 (2:DDR2,3:DDR3)
[138]DRAMC ZQ value: 0x7b7bfb
[141]DRAM ODT value: 0x42.
[144]DRAM SIZE =256 M
[146]dram_tpr4:0x0
[153]DRAM simple test OK.
[155]rtc standby flag is 0x0, super standby flag is 0x0
[160]dram size =256
[163]audio:avcc calibration
[166]card no is 2
[167]sdcard 2 line count 8
[170][mmc]: mmc driver ver 2021-12-27 10:07
[179][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[185][mmc]: ***Try MMC card 2***
[199][mmc]: RMCA OK!
[201][mmc]: bias 104
[203][mmc]: mmc 2 bias 104
[206][mmc]: MMC 5.1
[208][mmc]: HSSDR52/SDR25 8 bit
[211][mmc]: 50000000 Hz
[213][mmc]: 7456 MB
[215][mmc]: ***SD/MMC 2 init OK!!!***
[268]Loading boot-pkg Succeed(index=0).
[272]Entry_name = optee
[275]Entry_name = u-boot
[282]Entry_name = dtb
[285]tunning data addr:0x430003e8
[288]Jump to second Boot.
M/TC: OP-TEE version: 15ee1539-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 21 03:06:15 UTC 2023 arm
U-Boot 2018.05-g929808e-dirty (May 08 2024 - 09:10:12 +0000) Allwinner Technology
[00.462]CPU: Allwinner Family
[00.465]Model: sun8iw21
I2C: ready
[00.515]DRAM: 256 MiB
[00.519]Relocation Offset is: 0ced1000
[00.544]secure enable bit: 0
E/TC:0 fdt_getprop_u32:343 prop trace_level not found
[00.560]PMU: AXP21
[00.562]BMU: AXP21
[00.564]+++++++++++++++eta9002 get id val: 0x0328
[00.570]+++++++++++++++eta9002 get vol = 4082, cap = 97
[00.575] ret 1 __LINE__104
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
bias_name:pc_bias bias_vol:1800
bias_name:pi_bias bias_vol:1800
[00.600]onoff:0, ntc_cur:0
[00.603]AXP2101_ADC_CH_EN0[0x30]:0x1
[00.607]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=300Mhz
[00.613]gic: sec monitor mode
sunxi flash map init
[00.618]flash init start
[00.620]workmode = 0,storage type = 2
[00.623][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.629][mmc]: get sdc_type fail and use default host:tm4.
[00.635][mmc]: SUNXI SDMMC Controller Version:0x50400
[00.661][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
[00.666]sunxi flash init ok
[00.669]line:724 init_clocks
[00.672]drv_disp_init
request pwm success, pwm9:pwm9:0x2000c00.
[00.687]drv_disp_init finish
[00.692]Loading Environment from SUNXI_FLASH... OK
[00.702]boot_gui_init:start
[00.705]set disp.dev2_output_type fail. using defval=0
[00.709][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_open_flow]-[131]:
[00.717][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_cfg_panel_info]-[85]:
[00.725][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_cfg_panel_info]-[92]:
[00.733][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_open_flow]-[131]:
[00.752][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_power_on]-[156]:++++++++++++++++++++++++++++++++++
[00.902][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_open_flow]-[131]:
[00.909][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_panel_init]-[749]:
[01.116]boot_gui_init:finish
partno erro : can't find partition bootloader
54 bytes read i[01.124][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_open_flow]-[131]:
n 0 ms
[01.132]bmp_name=bootlogo.bmp size 1238454
[01.142][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_open_flow]-[131]:
[01.150][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_open_flow]-[131]:
[01.158][drivers/video/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_open_flow]-[131]:
[01.165]LCD open finish
1238454 bytes read in 32 ms (36.9 MiB/s)
[01.195]Item0 (Map) magic is bad
[01.197]the secure storage item0 copy0 magic is bad
[01.214]Item0 (Map) magic is bad
[01.217]the secure storage item0 copy1 magic is bad
[01.222]Item0 (Map) magic is bad
[01.225]probe MP tools from boot
delay time 0
weak:otg_phy_config
[01.236]usb init ok
[01.739]usb overtime
[01.743]usb burn from boot
delay time 0
weak:otg_phy_config
[01.754]usb prepare ok
[02.557]overtime
[02.560]do_burn_from_boot usb : no usb exist
root_partition is rootfs
set root to /dev/mmcblk0p5
[02.569]update part info
[02.572]onoff:0, ntc_cur:50
[02.575]AXP2101_ADC_CH_EN0[0x30]:0x1
1238454 bytes read in 8 ms (147.6 MiB/s)
[02.594]update bootcmd
[02.597]change working_fdt 0x4de90e70 to 0x4de70e70
disable nand error: FDT_ERR_BADPATH
[02.613]The storage not support sample function
[02.619]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
[02.631]update dts
[02.666]no vendor_boot partition is found
Android's image name: v853-miaobao
[02.716]Starting kernel ...
[02.718][mmc]: mmc exit start
[02.737][mmc]: mmc 2 exit ok
▒{▒!▒O▒▒▒8N▒;▒
后面全部是乱码了
[ 0.000000] Linux version 4.9.191 (wy@hello-PowerEdge-R750xs) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #566 PREEMPT Tue Nov 26 11:08:26 UTC 2024
[ 0.000000] OF: fdt:Machine model: sun8iw21
[ 0.000000] ion_mem_reserve: err format for ion reserve list!
[ 0.000000] disp reserve base 0x4df1b000 ,size 0x384000
[ 0.000000] Reserved memory: created DMA memory pool at 0x47000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@47000000, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 64384
[ 0.000000] free_area_init_node: node 0, pgdat c0a4a664, node_mem_map cfdf8000
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 64384 pages, LIFO batch:15
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 63872
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,1500000 loglevel=8 root=/dev/mmcblk0p5 rootwait init=/pseudo_init partitions=boot-resource@mmcblk0p1:private@mmcblk0p2:boot@mmcblk0p3:bootlogo@mmcblk0p4:rootfs@mmcblk0p5:rootfs_data@mmcblk0p6:env@mmcblk0p7:extend@mmcblk0p8:UDISK@mmcblk0p9 cma= mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=32K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw21p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05-g929808e-dirty(05/08/2024-09:10:12) mbr_offset=1032192 disp_reserve=3686400,0x4df1b000 bootreason=unknow androidboot.dramsize=256
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 240252K/257536K available (6144K kernel code, 301K rwdata, 1528K rodata, 1024K init, 202K bss, 17284K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a4b730 ( 302 kB)
[ 0.000000] .bss : 0xc0a4b730 - 0xc0a7e0a4 ( 203 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] sunxi_parse_sdm_info failed: -1
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.000208] Console: colour dummy device 80x30
[ 0.000234] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000250] pid_max: default: 32768 minimum: 301
[ 0.000437] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000450] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000991] CPU: Testing write buffer coherency: ok
[ 0.001496] Setting up static identity map for 0x40100000 - 0x40100058
[ 0.003006] devtmpfs: initialized
[ 0.040685] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.041189] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.041221] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.041370] atomic64_test: passed
[ 0.041383] pinctrl core: initialized pinctrl subsystem
[ 0.042473] NET: Registered protocol family 16
[ 0.043178] DMA: preallocated 32 KiB pool for atomic coherent allocations
[ 0.044370] dump_class_init,857, success
[ 0.069441] cpuidle: using governor menu
[ 0.070662] platform 2010000.iommu: iova_base: 0x48400000
[ 0.071148] sunxi iommu: irq = 22
[ 0.091296] sun8iw21p1-pinctrl pio: initialized sunXi PIO driver
[ 0.093078] sunxi hwspinlock vbase:0xd0824000
[ 0.095623] iommu: Adding device npu to group 0
[ 0.097159] iommu: Adding device 1c0e000.ve to group 0
[ 0.111452] iommu: Adding device 5410000.g2d to group 0
[ 0.112241] iommu: Adding device 5000000.disp to group 0
[ 0.122086] iommu: Adding device 5908000.tdm to group 0
[ 0.122856] iommu: Adding device 5900000.isp to group 0
[ 0.123788] iommu: Adding device 58ffffc.isp to group 0
[ 0.124571] iommu: Adding device 58ffff8.isp to group 0
[ 0.125218] iommu: Adding device 58ffff4.isp to group 0
[ 0.125613] iommu: Adding device 5800800.vind:isp@4 to group 0
[ 0.126378] iommu: Adding device 5910000.scaler to group 0
[ 0.126805] iommu: Adding device 590fffc.scaler to group 0
[ 0.127414] iommu: Adding device 590fff8.scaler to group 0
[ 0.127853] iommu: Adding device 590fff4.scaler to group 0
[ 0.128659] iommu: Adding device 5910400.scaler to group 0
[ 0.129099] iommu: Adding device 59103fc.scaler to group 0
[ 0.129970] iommu: Adding device 59103f8.scaler to group 0
[ 0.130410] iommu: Adding device 59103f4.scaler to group 0
[ 0.131071] iommu: Adding device 5910800.scaler to group 0
[ 0.131686] iommu: Adding device 59107fc.scaler to group 0
[ 0.132281] iommu: Adding device 59107f8.scaler to group 0
[ 0.132792] iommu: Adding device 59107f4.scaler to group 0
[ 0.133437] iommu: Adding device 5910c00.scaler to group 0
[ 0.134041] iommu: Adding device 5910bfc.scaler to group 0
[ 0.134455] iommu: Adding device 5910bf8.scaler to group 0
[ 0.135030] iommu: Adding device 5910bf4.scaler to group 0
[ 0.136737] iommu: Adding device vinc0 to group 0
[ 0.137372] iommu: Adding device vinc1 to group 0
[ 0.138136] iommu: Adding device vinc4 to group 0
[ 0.138662] iommu: Adding device vinc5 to group 0
[ 0.139418] iommu: Adding device vinc8 to group 0
[ 0.140216] iommu: Adding device vinc9 to group 0
[ 0.140910] iommu: Adding device vinc12 to group 0
[ 0.141495] iommu: Adding device vinc13 to group 0
[ 0.148113] iommu: Adding device e907_rproc@0 to group 0
[ 0.148482] iommu: Adding device rpbuf_controller@0 to group 0
[ 0.187150] pwm module init!
[ 0.194432] sunxi-pm debug v3.10
[ 0.197150] SCSI subsystem initialized
[ 0.197879] usbcore: registered new interface driver usbfs
[ 0.198055] usbcore: registered new interface driver hub
[ 0.198208] usbcore: registered new device driver usb
[ 0.198506] sunxi_i2c_adap_init()2827 - init
[ 0.198969] sunxi_i2c_probe()2520 - [i2c1] twi_drv_used = 0
[ 0.198987] sunxi_i2c_probe()2527 - [i2c1] twi_pkt_interval = 0
[ 0.199062] twi_regulator_request()647 - [i2c1] regulator not found(isn't configured in dts)!
[ 0.199072] twi_request_gpio()463 - [i2c1] init name: (null)
[ 0.200878] sunxi_i2c_probe()2520 - [i2c2] twi_drv_used = 0
[ 0.200897] sunxi_i2c_probe()2527 - [i2c2] twi_pkt_interval = 0
[ 0.200975] twi_regulator_request()647 - [i2c2] regulator not found(isn't configured in dts)!
[ 0.200986] twi_request_gpio()463 - [i2c2] init name: (null)
[ 0.202711] sun8iw21p1-pinctrl pio: expect_func as:twi3, but muxsel(7) is func:uart3
[ 0.202736] sun8iw21p1-pinctrl pio: expect_func as:twi3, but muxsel(7) is func:uart3
[ 0.203062] sunxi_i2c_probe()2520 - [i2c3] twi_drv_used = 0
[ 0.203078] sunxi_i2c_probe()2527 - [i2c3] twi_pkt_interval = 0
[ 0.203155] twi_regulator_request()647 - [i2c3] regulator not found(isn't configured in dts)!
[ 0.203165] twi_request_gpio()463 - [i2c3] init name: (null)
[ 0.204413] sunxi_i2c_probe()2520 - [i2c4] twi_drv_used = 0
[ 0.204432] sunxi_i2c_probe()2527 - [i2c4] twi_pkt_interval = 0
[ 0.204509] twi_regulator_request()647 - [i2c4] regulator not found(isn't configured in dts)!
[ 0.204519] twi_request_gpio()463 - [i2c4] init name: (null)
[ 0.205625] axp20x-i2c 4-0034: AXP20x variant AXP2101 found
[ 0.235391] random: fast init done
[ 0.253069] axp20x-i2c 4-0034: AXP20X driver loaded
[ 0.253519] media: Linux media interface: v0.10
[ 0.253593] Linux video capture interface: v2.00
[ 0.257695] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[ 0.258020] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[ 0.259238] Advanced Linux Sound Architecture Driver Initialized.
[ 0.260309] Bluetooth: Core ver 2.22
[ 0.260459] NET: Registered protocol family 31
[ 0.260472] Bluetooth: HCI device and connection manager initialized
[ 0.260497] Bluetooth: HCI socket layer initialized
[ 0.260511] Bluetooth: L2CAP socket layer initialized
[ 0.260555] Bluetooth: SCO socket layer initialized
[ 0.263736] G2D: rcq version initialized.major:251
[ 0.265496] clocksource: Switched to clocksource arch_sys_counter
[ 0.293589] udc_init,0
[ 0.294910] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.295336] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.296143] NET: Registered protocol family 2
[ 0.315777] TCP established hash table entries: 16 (order: -6, 64 bytes)
[ 0.315796] TCP bind hash table entries: 16 (order: -6, 64 bytes)
[ 0.315806] TCP: Hash tables configured (established 16 bind 16)
[ 0.315871] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.315892] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.316101] NET: Registered protocol family 1
[ 0.320947] sunxi_sid_driver_init+0x0/0x10 complete comp.
[ 0.321205] workingset: timestamp_bits=29 max_order=16 bucket_order=0
[ 0.336183] exfat: init_exfat_fs: exFAT Filesystem version 1.2.24
[ 0.337594] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.338093] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.343232] io scheduler noop registered
[ 0.343249] io scheduler deadline registered
[ 0.343565] io scheduler cfq registered (default)
[ 0.344837] [DISP]disp_module_init
[ 0.346824] [DISP] disp_init,line:2346:
[ 0.346840] smooth display screen:0 type:1 mode:4
[ 0.384813] lcd 0, driver_name ft_03538_st7703, panel_name default_lcd
[ 0.384832] lcd 0, driver_name ft_03538_st7703, panel_name ft_03538_st7703
[ 0.384842] [drivers/video/fbdev/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_cfg_panel_info]-[85]:
[ 0.384850] [drivers/video/fbdev/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_cfg_panel_info]-[92]:
[ 0.384867] lcd 0, driver_name ft_03538_st7703, panel_name super_lcd_driver
[ 0.385003] display_fb_request,fb_id:0
[ 0.587566] [DISP] de_fcm_set_para,line:491:
[ 0.587583] fcm lut 0 not find, auto retry after init
[ 0.587598] rotation hw function is configed to 270 degree
[ 0.598275] [DISP] de_fcm_set_para,line:491:
[ 0.598288] fcm lut 0 not find, auto retry after init
[ 0.598313] [DISP] de_fcm_set_para,line:491:
[ 0.598319] fcm lut 0 not find, auto retry after init
[ 0.598335] [DISP] lcd_clk_config,line:701:
[ 0.598348] disp 0, clk: pll(372000000),clk(372000000),dclk(62000000) dsi_rate(62000000)
[ 0.598348] clk real:pll(372000000),clk(372000000),dclk(93000000) dsi_rate(150000000)
[ 0.599297] [DISP]disp_module_init finish
[ 0.609548] uart0 supply uart not found, using dummy regulator
[ 0.609908] uart0: ttyS0 at MMIO 0x2500000 (irq = 289, base_baud = 7500000) is a SUNXI
[ 0.609939] sw_console_setup()2050 - console setup baud 1500000 parity n bits 8, flow n
[ 0.730018] console [ttyS0] enabled
[ 0.732318] uart2: ttyS2 at MMIO 0x2500800 (irq = 290, base_baud = 7500000) is a SUNXI
[ 0.734100] uart3 supply uart not found, using dummy regulator
[ 0.735032] uart3: ttyS3 at MMIO 0x2500c00 (irq = 291, base_baud = 7500000) is a SUNXI
[ 0.737421] misc dump reg init
[ 0.738342] npu[1][1] vipcore, platform driver device=0xcf999610
[ 0.739050] npu[1][1] vipcore irq number is 292.
[ 0.739540] gckvip_drv_adjust_param 232 SUCCESS
[ 0.740070] Want set pclk rate(600000000) support(600000000) real(600000000)
[ 0.740865] Want set mclk rate(600000000) support(600000000) real(600000000)
[ 0.741611] npu[1][1] This device support 64bits DMA
[ 0.742919] npu[1][1] core_0, request irqline=292, name=vipcore_0
[ 0.743636] npu[1][1] =======vipcore parameter=====
[ 0.744157] npu[1][1] registerMemBase 0x03050000,
[ 0.744700] npu[1][1] registerMemSize 0x00020000,
[ 0.745244] npu[1][1] irqLine 0x00000124,
[ 0.745998] npu[1][1] contiguousSize 0x00100000
[ 0.746527] npu[1][1] contiguousBase 0x30000000
[ 0.747051] npu[1][1] vipContiguousBase 0x0
[ 0.747513] npu[1][1] drvType 0x00000000
[ 0.748038] npu[1][1] AXISramSize 0x00000000
[ 0.748562] npu[1][1] AXISramBaseAddress 0x00000000
[ 0.749087] npu[1][1] VIPSramSize 0x00020000
[ 0.749611] npu[1][1] VIPSramBaseAddress 0x00400000
[ 0.750135] npu[1][1] sysHeapSize 0x00200000
[ 0.750660] npu[1][1] ===============================
[ 0.751264] npu[1][1] VIPLite driver version 1.8.1.0-AW-2022-07-26
[ 0.752796] sunxi-bt soc@03000000:bt: bt_power_num (1)
[ 0.753353] sunxi-bt soc@03000000:bt: bt power voltage (330000)
[ 0.753980] sunxi-bt soc@03000000:bt: bt io voltage (3300000)
[ 0.754592] sunxi-bt soc@03000000:bt: bt_power_name (axp2101-dcdc1)
[ 0.755255] sunxi-bt soc@03000000:bt: io_regulator_name (axp2101-dcdc1)
[ 0.756178] sunxi-bt soc@03000000:bt: request pincrtl handle for device [soc@03000000:bt] failed
[ 0.757108] sunxi-bt soc@03000000:bt: get gpio bt_rst failed
[ 0.757710] sunxi-bt soc@03000000:bt: clk_name ()
[ 0.758235] sunxi-bt soc@03000000:bt: clk not config
[ 0.759651] sun8iw21p1-pinctrl pio: expect_func as:fanout0, but muxsel(5) is func:twi0
[ 0.760585] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
[ 0.761180] sunxi-wlan soc@03000000:wlan@0: wlan power voltage (3300000)
[ 0.761888] sunxi-wlan soc@03000000:wlan@0: wlan io voltage (3300000)
[ 0.762602] sunxi-wlan soc@03000000:wlan@0: wlan_power_num (1)
[ 0.763224] sunxi-wlan soc@03000000:wlan@0: wlan_power_name (axp2101-dcdc1)
[ 0.763961] sunxi-wlan soc@03000000:wlan@0: io_regulator_name (axp2101-dcdc1)
[ 0.764740] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=239 mul-sel=1 pull=1 drv_level=2 data=0
[ 0.766101] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[ 0.766799] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=199 mul-sel=14 pull=1 drv_level=2 data=0
[ 0.767837] sunxi-wlan soc@03000000:wlan@0: wakeup source is disabled!
[ 0.768534] sunxi-wlan soc@03000000:wlan@0: clk_name ()
[ 0.770238] [ADDR_MGT] addr_mgt_probe: success.
[ 0.770729] 374 addr_init378 addr_init381 addr_init392 addr_init410 addr_init424 addr_init
[ 0.774743] libphy: Fixed MDIO Bus: probed
[ 0.776330] usbcore: registered new interface driver cdc_ether
[ 0.777195] usbcore: registered new interface driver rndis_host
[ 0.777833] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.778907] get ehci0-controller, regulator_io is no nocare
[ 0.779535] get ehci0-controller wakeup-source is fail.
[ 0.780246] sunxi ehci0-controller don't init wakeup source
[ 0.780843] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a72890, 0x:d085b000, irq_no:137
[ 0.781972] [sunxi-ehci0]: Not init ehci0
[ 0.783161] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.784233] get ohci0-controller, regulator_io is no nocare
[ 0.784827] get ohci0-controller wakeup-source is fail.
[ 0.785624] sunxi ohci0-controller don't init wakeup source
[ 0.786305] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a72ab4
[ 0.787209] [sunxi-ohci0]: Not init ohci0
[ 0.788316] usbcore: registered new interface driver uas
[ 0.789071] usbcore: registered new interface driver usb-storage
[ 0.789825] usbcore: registered new interface driver ums-alauda
[ 0.790763] usbcore: registered new interface driver ums-cypress
[ 0.791669] usbcore: registered new interface driver ums-datafab
[ 0.792450] usbcore: registered new interface driver ums_eneub6250
[ 0.793313] usbcore: registered new interface driver ums-freecom
[ 0.794161] usbcore: registered new interface driver ums-isd200
[ 0.794994] usbcore: registered new interface driver ums-jumpshot
[ 0.796228] usbcore: registered new interface driver ums-karma
[ 0.796979] usbcore: registered new interface driver ums-onetouch
[ 0.797767] usbcore: registered new interface driver ums-realtek
[ 0.798636] usbcore: registered new interface driver ums-sddr09
[ 0.799528] usbcore: registered new interface driver ums-sddr55
[ 0.800415] usbcore: registered new interface driver ums-usbat
[ 0.801409] usbcore: registered new interface driver usbserial
[ 0.802153] usbcore: registered new interface driver usbserial_generic
[ 0.803046] usbserial: USB Serial support registered for generic
[ 0.803956] usbcore: registered new interface driver option
[ 0.804796] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.805902] usb_serial_number:20080411
[ 0.819835] input: axp2101-pek as /devices/platform/soc/twi4/i2c-4/4-0034/axp2101-pek.0/input/input0
[ 0.822660] input: sunxi-wiegand0 as /devices/virtual/input/input1
[ 0.824582] sunxi_gpadc_init,1957, success
[ 0.825412] sunxi_gpadc_setup: get channel scan data failed
[ 0.827517] input: sunxi-gpadc0 as /devices/virtual/input/input2
[ 0.828869] input: sunxi-gpadc1 as /devices/virtual/input/input3
[ 0.830321] input: sunxi-gpadc2 as /devices/virtual/input/input4
[ 0.833349] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[ 0.834046] sunxi-rtc rtc: RTC enabled
[ 0.834506] fix to hot reboot, save boot reason
[ 0.835780] i2c /dev entries driver
[ 0.837520] sunxi cedar version 0.1
[ 0.838196] VE: install start!!!
[ 0.838196]
[ 0.838767] VE: cedar-ve the get irq is 293
[ 0.839307] VE: regs_csi = d0897000
[ 0.840571] VE: ve_proc_mgr: flag = 1
[ 0.840571]
[ 0.841123] VE: install end!!!
[ 0.841123]
[ 0.842090] google_vp9: sunxi google vp9 version 0.1
[ 0.851695] axp2101_charger: read chipid = 4a
[ 0.851695]
[ 0.873980] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 0.917315] ETA9002 : eta_init-588 :
[ 0.917983] ETA9002 : eta9002_probe-478 : eta9002_probe start!
[ 0.919260] ETA9002 : eta9002_probe-530 : eta9002_probe success!
[ 0.923819] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.926230] Bluetooth: HCI UART driver ver 2.2.d448471.20181218-163903
[ 0.926939] Bluetooth: HCI UART protocol H4 registered
[ 0.927489] Bluetooth: HCI H4 protocol initialized
[ 0.928474] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 01.00.07
[ 0.929612] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 0.930252] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 0
[ 0.930881] [XR_BT_LPM] bluesleep_probe: uart_index(2)
[ 0.931896] bt_fdi debugfs_init
[ 0.976667] ETA9002 : eta9002_work-428 : eta9002_get_soc ret : 95
[ 0.977839] cpuidle: enable-method property 'psci' found operations
[ 0.978978] ETA9002 : eta9002_work-440 : eta9002_get_vcell ret : 406
[ 0.980743] ETA9002 : eta9002_work-443 : eta9002_get_ocv ret : 407
[ 0.981401] ETA9002 : eta9002_get_temp_die-300 : eta9002_get_temp_die start!
[ 0.984922] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
[ 0.986320] sunxi-mmc sdc2: ***ctl-spec-caps*** 308
[ 0.998795] sunxi-mmc sdc2: No vdmmc regulator found
[ 0.999321] sunxi-mmc sdc2: No vd33sw regulator found
[ 0.999845] sunxi-mmc sdc2: No vd18sw regulator found
[ 1.000368] sunxi-mmc sdc2: No vq33sw regulator found
[ 1.000891] sunxi-mmc sdc2: No vq18sw regulator found
[ 1.001824] sunxi-mmc sdc2: set host busy
[ 1.002302] mmc:failed to get gpios
[ 1.002959] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.025528] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.046044] eta9002_get_temp_die val: 24
[ 1.046457] ETA9002 : eta9002_work-445 : eta9002_get_temp_die : 24
[ 1.055689] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.057906] sunxi-mmc sdc2: detmode:alway in(non removable)
[ 1.059097] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
[ 1.060035] sunxi-mmc sdc0: ***ctl-spec-caps*** 408
[ 1.061693] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.063802] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.065202] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.066313] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.069751] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.078410] sunxi-mmc sdc0: No vqmmc regulator found
[ 1.078935] sunxi-mmc sdc0: No vdmmc regulator found
[ 1.079883] sunxi-mmc sdc0: set host busy
[ 1.080354] mmc:failed to get gpios
[ 1.081015] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.096756] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.110770] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing LEGACY(SDR12) dt B
[ 1.113875] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[ 1.115225] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[ 1.116433] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[ 1.117487] sunxi-mmc sdc2: sdc set ios:clk 52000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[ 1.118634] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[ 1.119633] sunxi_mmc_get_hs400_cmd_dly,222
[ 1.120080] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[ 1.121083] sunxi_mmc_get_hs400_cmd_dly,222
[ 1.121642] mmc0: new HS400 MMC card at address 0001
[ 1.122938] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 1.123675] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 1.124512] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 1.125363] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB
[ 1.127660] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 1.325671] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 1.355519] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.385518] sunxi-mmc sdc0: detmode:data3
[ 1.386386] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.59 2022-4-21 13:40)
[ 1.387326] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
[ 1.387877] sunxi-mmc sdc1: No vmmc regulator found
[ 1.388380] sunxi-mmc sdc1: No vqmmc regulator found
[ 1.388895] sunxi-mmc sdc1: No vdmmc regulator found
[ 1.389410] sunxi-mmc sdc1: No vd33sw regulator found
[ 1.389933] sunxi-mmc sdc1: No vd18sw regulator found
[ 1.390456] sunxi-mmc sdc1: No vq33sw regulator found
[ 1.390979] sunxi-mmc sdc1: No vq18sw regulator found
[ 1.391870] sunxi-mmc sdc1: set host busy
[ 1.392344] mmc:failed to get gpios
[ 1.393004] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.415542] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.445518] sunxi-mmc sdc1: detmode:manually by software
[ 1.446361] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 1.447751] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 1.448372] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.450808] usbcore: registered new interface driver usbhid
[ 1.452423] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.454518] usbhid: USB HID core driver
[ 1.458588] [sound 1158][DAUDIO snd_sunxi_regulator_init] regulator missing or invalid
[ 1.461134] sunxi-snd-mach soc@03000000:codec_mach: sunxi-snd-codec <-> soc@03000000:codec_plat mapping ok
[ 1.462145] mmc2: queuing unknown CIS tuple 0x10 (5 bytes)
[ 1.465163] sunxi-snd-mach soc@03000000:daudio0_mach: snd-soc-dummy-dai <-> 2032000.daudio0_plat mapping ok
[ 1.468437] auido_switch audio_switch: audio_switch_control_gpio=134 mul-sel=1 pull=1 drv_level=1 data=0
[ 1.469832] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.471033] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 1.472116] auido_switch audio_switch: audio_switch_detect_control=137 mul-sel=1 pull=1 drv_level=1 data=0
[ 1.473166] auido_switch audio_switch: get gpio audio_switch_detect_gpio0 failed
[ 1.473932] auido_switch audio_switch: get gpio audio_switch_detect_gpio1 failed
[ 1.475165] mmc2: queuing unknown CIS tuple 0x10 (5 bytes)
[ 1.476788] input: auido_switch as /devices/platform/audio_switch/input/input5
[ 1.477776] mmc2: new SDIO card at address 8abc
[ 1.505771] Netfilter messages via NETLINK v0.30.
[ 1.506538] nf_conntrack version 0.5.0 (4096 buckets, 16384 max)
[ 1.507299] ctnetlink v0.93: registering with nfnetlink.
[ 1.508138] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.509835] NET: Registered protocol family 10
[ 1.511675] NET: Registered protocol family 17
[ 1.512186] NET: Registered protocol family 15
[ 1.512807] Bluetooth: RFCOMM TTY layer initialized
[ 1.513331] Bluetooth: RFCOMM socket layer initialized
[ 1.513893] Bluetooth: RFCOMM ver 1.11
[ 1.515482] Registering SWP/SWPB emulation handler
[ 1.523158] get id is fail, 84
[ 1.524241] sunxi-rtc rtc: setting system clock to 2025-03-30 12:23:11 UTC (1743337391)
[ 1.525956] clk: Not disabling unused clocks
[ 1.526519] usb-vbus: disabling
[ 1.527411] axp2101-dcdc2: disabling
[ 1.529299] axp2101-rtcldo1: disabling
[ 1.530220] axp2101-aldo2: disabling
[ 1.532051] axp2101-aldo3: disabling
[ 1.533880] axp2101-bldo2: disabling
[ 1.535750] axp2101-dldo2: disabling
[ 1.537594] axp2101-cpusldo: disabling
[ 1.538921] ALSA device list:
[ 1.539232] #0: audiocodec
[ 1.539531] #1: snddaudio0
[ 1.540737] EXT4-fs (mmcblk0p5): couldn't mount as ext3 due to feature incompatibilities
[ 1.542123] EXT4-fs (mmcblk0p5): couldn't mount as ext2 due to feature incompatibilities
[ 1.546059] EXT4-fs (mmcblk0p5): mounted filesystem without journal. Opts: (null)
[ 1.546891] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
[ 1.549613] devtmpfs: mounted
[ 1.551488] Freeing unused kernel memory: 1024K
mount: mounting none on /dev failed: Resource busy
[ 1.625854] exfat: exfat_msg: (mmcblk0p8[259:0]): trying to mount...
[ 1.626920] exfat: exfat_msg: (mmcblk0p8[259:0]): failed to mount!
mount: mounting /dev/by-name/extend on /tmp/usr failed: Invalid argument
[ 1.707297] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
[ 1.711690] EXT4-fs (mmcblk0p6): mounted filesystem with journalled data mode. Opts: data=journal
starting pid 893, tty '': '/etc/preinit'
can't run '/etc/preinit': No such file or directory
starting pid 894, tty '': '/bin/mount -t proc proc /proc'
mount: mounting proc on /proc failed: Resource busy
starting pid 895, tty '': '/bin/mount -t tmpfs tmpfs /run'
starting pid 896, tty '': '/bin/mount -o remount,rw /'
starting pid 897, tty '': '/bin/mkdir -p /dev/pts'
starting pid 898, tty '': '/bin/mkdir -p /dev/shm'
starting pid 899, tty '': '/bin/mount -a'
starting pid 900, tty '': '/bin/hostname -F /etc/hostname'
hostname: can't open '/etc/hostname': No such file or directory
starting pid 902, tty '': '/etc/init.d/rcS boot'
------run rc.preboot file-----
[ 1.835675] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.839183] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.842091] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 1.844327] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.845746] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.847239] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.848655] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.849248] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.851203] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.852165] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 1.875564] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.890255] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[ 1.905630] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.909276] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.912470] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 1.914365] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.916067] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
ln: /mnt/private/factory: Operat[ 1.917749] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
ion not permitted
[ 1.919604] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.920197] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.922150] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.923117] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
ln: /etc/lib/bluetooth/bluetooth: File exists
------run rc.modules file-----
[ 1.939999] aicbsp_init
[ 1.940267] aicbsp_init, Driver Release Tag: aic-bsp-compatible(sdio)-20240422-001
[ 1.941729] -->aicbt_rfkill_init
[ 1.942379] <--aicbt_rfkill_init
[ 1.945611] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.952208] rwnx 20240422-004-6.4.3.0 - - 241c091M (master)
[ 1.952797] Driver Release Tag: aic-rwnx-compatible(sdio)-20240422-004
[ 1.953473] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 1.954130] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 1.954883] aicbsp: aicbsp_platform_power_on
[ 1.955333] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[ 1.956287] aicbsp: aicbsp_platform_power_on disable MMC_CAP_UHS_DDR50 for host cfba5800
[ 1.960190] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 3300000
[ 1.963737] sunxi-wlan soc@03000000:wlan@0: check wlan io_regulator voltage: 3300000
[ 1.975532] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.979391] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.983101] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 1.987208] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.989388] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.991562] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.993737] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 1.994298] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1.996253] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 1.997217] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 2.025514] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.049951] aicbsp: aicbsp_sdio_probe:2
[ 2.050358] aicbsp: aicbsp_sdio_probe:2, matched chip: aic8800dc
[ 2.050978] aicbsp: aicbsp_sdio_probe after replace:1
[ 2.051502] aicbsp: aicbsp_sdio_probe host max clock frequecy: 50000000
[ 2.052184] aicbsp: aicwf_sdio_reg_init
[ 2.052781] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 2.053857] aicbsp: Set SDIO Clock 50 MHz
[ 2.055375] aicbsp_8800dc_fw_init(1371), rev id: 0x7, subrev id: 0x1, mcu id: 0x0, is_chip_id_h: 0
[ 2.056383] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.060031] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 2.065396] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 2.066801] rwnx_request_firmware, name: aic8800dc/fw_patch_table_8800dc_u02.bin
[ 2.067598] aicbt_patch_info_unpack bt patch version: - Jul 11 2024 17:04:57 - git 2c7ffa3
[ 2.068957] rwnx_request_firmware, name: aic8800dc/fw_adid_8800dc_u02.bin
[ 2.069677] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 2.071532] rwnx_request_firmware, name: aic8800dc/fw_patch_8800dc_u02.bin
[ 2.073523] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 2.077383] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 2.078346] aicbt_patch_table_load bt uart baud: 1500000, flowctrl: 1, lpm_enable: 1, tx_pwr: 12079, bt mode:1.
[ 2.081250] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 2.081862] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.094800] aicbsp_patch_load_8800dc 1239, aicbsp_info.cpmode=0
[ 2.096310] rwnx_request_firmware, name: aic8800dc/fmacfw_patch_8800dc_u02.bin
[ 2.103312] dpd calib & write
[ 2.103630] aicwf_dpd_calib_8800dc
[ 2.104131] misc_ram_addr=120ebc
[ 2.105023] bit_mask:f7012b2b,ed6768ef,318ee477,c88becb6
[ 2.106590] rwnx_request_firmware, name: aic8800dc/fmacfw_calib_8800dc_u02.bin
[ 2.115447] Start app: 00130009, 4
[ 2.337659] wifisetting_cfg_addr=11019c, ldpc_cfg_addr=120980, agc_cfg_addr=120180, txgain_cfg_addr=120000
[ 2.341116] rwnx_request_firmware, name: aic8800dc/fmacfw_patch_tbl_8800dc_u02.bin
[ 2.341907] FMACFW_PATCH_TBL_8800DC_U02_DESCRIBE_BASE = 187c00
[ 2.342759] 8800DC PATCH VERSION: mi Jul 11 2024 20:16:05 - gbf5ef2fmRead FW mem: 00120000
[ 2.356203] cfm: [00120000] = 00ffd780
[ 2.356594] Start app: 00120000, 5
[ 2.361260] aicsdio: aicwf_sdio_probe:1
[ 2.361666] aicsdio: aicwf_sdio_reg_init
[ 2.362169] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 2.363267] aicsdio: Set SDIO Clock 50 MHz
[ 2.373808] aicbsp: aicbsp_resv_mem_alloc_skb, alloc resv_mem_txdata succuss, id: 0, size: 98304
[ 2.375022] rwnx_cfg80211_init sizeof(struct rwnx_hw):27656
[ 2.376619] is 5g support = 0, vendor_info = 0x00
[ 2.377280] Firmware Version: zh Aug 08 2022 14:54:51 - gcf79227userconfig file path:aic8800dc/aic_userconfig_8800dc.txt
[ 2.379281] rwnx_plat_userconfig_parsing, enable = 1
[ 2.379831] rwnx_plat_userconfig_parsing, lvl_11b_11ag_1m_2g4 = 20
[ 2.380478] rwnx_plat_userconfig_parsing, lvl_11b_11ag_2m_2g4 = 20
[ 2.381126] rwnx_plat_userconfig_parsing, lvl_11b_11ag_5m5_2g4 = 20
[ 2.381782] rwnx_plat_userconfig_parsing, lvl_11b_11ag_11m_2g4 = 20
[ 2.382436] rwnx_plat_userconfig_parsing, lvl_11b_11ag_6m_2g4 = 20
[ 2.383085] rwnx_plat_userconfig_parsing, lvl_11b_11ag_9m_2g4 = 20
[ 2.383731] rwnx_plat_userconfig_parsing, lvl_11b_11ag_12m_2g4 = 20
[ 2.384391] rwnx_plat_userconfig_parsing, lvl_11b_11ag_18m_2g4 = 20
[ 2.385047] rwnx_plat_userconfig_parsing, lvl_11b_11ag_24m_2g4 = 18
[ 2.385803] rwnx_plat_userconfig_parsing, lvl_11b_11ag_36m_2g4 = 18
[ 2.386469] rwnx_plat_userconfig_parsing, lvl_11b_11ag_48m_2g4 = 16
[ 2.387133] rwnx_plat_userconfig_parsing, lvl_11b_11ag_54m_2g4 = 16
[ 2.387792] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs0_2g4 = 20
[ 2.388466] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs1_2g4 = 20
[ 2.389140] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs2_2g4 = 20
[ 2.389815] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs3_2g4 = 20
[ 2.390491] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs4_2g4 = 18
[ 2.391167] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs5_2g4 = 18
[ 2.391845] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs6_2g4 = 16
[ 2.392523] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs7_2g4 = 16
[ 2.393203] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs8_2g4 = 16
[ 2.393882] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs9_2g4 = 16
[ 2.394561] rwnx_plat_userconfig_parsing, lvl_11ax_mcs0_2g4 = 20
[ 2.395205] rwnx_plat_userconfig_parsing, lvl_11ax_mcs1_2g4 = 20
[ 2.395844] aicbsp: err:<aicwf_sdio_bus_pwrctl,1256>: bus down
[ 2.396502] rwnx_plat_userconfig_parsing, lvl_11ax_mcs2_2g4 = 20
[ 2.397149] rwnx_plat_userconfig_parsing, lvl_11ax_mcs3_2g4 = 20
[ 2.397795] rwnx_plat_userconfig_parsing, lvl_11ax_mcs4_2g4 = 18
[ 2.398442] rwnx_plat_userconfig_parsing, lvl_11ax_mcs5_2g4 = 18
[ 2.399089] rwnx_plat_userconfig_parsing, lvl_11ax_mcs6_2g4 = 16
[ 2.399737] rwnx_plat_userconfig_parsing, lvl_11ax_mcs7_2g4 = 16
[ 2.400386] rwnx_plat_userconfig_parsing, lvl_11ax_mcs8_2g4 = 16
[ 2.401036] rwnx_plat_userconfig_parsing, lvl_11ax_mcs9_2g4 = 16
[ 2.401687] rwnx_plat_userconfig_parsing, lvl_11ax_mcs10_2g4 = 15
[ 2.402348] rwnx_plat_userconfig_parsing, lvl_11ax_mcs11_2g4 = 15
[ 2.403162] rwnx_plat_userconfig_parsing, ofst_enable = 0
[ 2.403798] rwnx_plat_userconfig_parsing, ofst_chan_1_4 = 0
[ 2.404457] rwnx_plat_userconfig_parsing, ofst_chan_5_9 = 0
[ 2.405117] rwnx_plat_userconfig_parsing, ofst_chan_10_13 = 0
[ 2.405848] rwnx_plat_userconfig_parsing, ofst_chan_36_64 = 0
[ 2.406531] rwnx_plat_userconfig_parsing, ofst_chan_100_120 = 0
[ 2.407227] rwnx_plat_userconfig_parsing, ofst_chan_122_140 = 0
[ 2.407928] rwnx_plat_userconfig_parsing, ofst_chan_142_165 = 0
[ 2.408747] rwnx_plat_userconfig_parsing, xtal_enable = 0
[ 2.409410] rwnx_plat_userconfig_parsing, xtal_cap = 24
[ 2.410060] rwnx_plat_userconfig_parsing, xtal_cap_fine = 31
[ 2.585506] +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++card_removed_powerctl_handle enter!
[ 2.586639] +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++card_removed_powerctl_handle exit!
[ 2.614120] filp_open /tmp/dragonkey/ULI/factory/WIFI.txt ok
[ 2.614721] filp_open /tmp/dragonkey/ULI/factory/WIFI.txt ok
[ 2.615764] mac_buf :
[ 2.616014] get macaddr: 00:97:07:f0:5d:28
[ 2.617493] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 1
[ 2.619376] rwnx_interface_add: wlan%d, 2, 10interface add:0 97 7 f0 5d 28
[ 2.661706] ieee80211 phy0: New interface create wlan0
[ 2.668448] [FTS_TS/I]fts_ts_probe:Touch Screen(I2C BUS) driver prboe...
[ 2.669152] [FTS_TS/I]fts_ts_probe_entry:Focaltech V3.4 20211214
[ 2.669778] [FTS_TS/I]fts_get_dt_coords:display x(0 1279) y(0 719)
[ 2.670602] [FTS_TS/I]fts_parse_dt:max touch number:10, irq gpio:231, reset gpio:232
[ 2.671926] input: fts_ts as /devices/platform/soc/twi2/i2c-2/2-0038/input/input6
[ 2.674109] [FTS_TS/I]fts_get_chip_types:verify id:0x8756
[ 2.674676] [FTS_TS/I]fts_get_ic_information:get ic information, chip id = 0x8756(cid type=0x0)
[ 2.676040] [FTS_TS/I]fts_create_apk_debug_channel:Create proc entry success!
[ 2.676863] [FTS_TS/I]fts_create_sysfs:[EX]: sysfs_create_group() succeeded!!
[ 2.677651] [FTS_TS/I]fts_irq_registration:irq:231, flag:2002
[ 2.678393] [FTS_TS/I]fts_fwupg_init:fw upgrade init function
[ 2.679002] [FTS_TS/I]fts_fwupg_work:FTS_AUTO_UPGRADE_EN is disabled, not upgrade when power on
[ 2.679958] [FTS_TS/I]fts_ts_probe:Touch Screen(I2C BUS) driver prboe successfully
------run rc.final file-----
Load mpp modules
[ 2.712205] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
insmod: can't insert '/lib/modules/4.9.191/gc2053_mipi.ko': No such file or directory
insmod: can't insert '/lib/modules/4.9.191/gc2093_mipi.ko': No such file or directory
insmod: can't insert '/lib/modules/4.9.191/gc05a2_mipi.ko': No such file or directory
[ 2.758107] [ov8856_mipi]PWR_ON!
[ 2.824873] [ov8856_mipi]sensor_detect read 0x300A value is 0x0
[ 2.825799] [ov8856_mipi]sensor_detect read 0x300B value is 0x88
[ 2.826675] [ov8856_mipi]sensor_detect read 0x300C value is 0x5a
[ 3.096329] random: crng init done
[ 3.603305] [ov8856_mipi]Data_Check: 0xd 0xd 0xd 0x27
[ 3.603833] [ov8856_mipi]AF_OTP enable
[ 3.604220] [ov8856_mipi]sensor ckeck OTP success
[ 3.604726] --- awb otp ----
[ 3.605025] 91
[ 3.605208] 171
[ 3.605400] 171
[ 3.605641] 116
[ 3.605836] 92
[ 3.606019] 171
[ 3.606211] 171
[ 3.606403] 119
[ 3.606595] ---- msc ----
[ 3.606870] 1766, 1580, 1429, 1298, 1201, 1122, 1063, 1005, 961, 927, 896, 876, 864, 858, 855, 861,
[ 3.607933] 1601, 1421, 1291, 1189, 1102, 1031, 968, 920, 876, 840, 814, 790, 777, 772, 772, 780,
[ 3.608996] 1464, 1312, 1201, 1102, 1026, 957, 899, 852, 806, 772, 743, 721, 706, 700, 700, 704,
[ 3.610058] 1372, 1231, 1127, 1040, 964, 899, 843, 790, 746, 710, 682, 662, 646, 639, 637, 642,
[ 3.611120] 1298, 1177, 1077, 992, 917, 852, 793, 743, 698, 663, 634, 611, 596, 587, 586, 591,
[ 3.612183] 1251, 1127, 1035, 953, 876, 811, 755, 704, 662, 625, 596, 573, 558, 551, 549, 555,
[ 3.613265] 1213, 1102, 1009, 927, 852, 787, 730, 678, 637, 602, 572, 548, 534, 527, 525, 530,
[ 3.614328] 1201, 1087, 996, 910, 837, 772, 713, 663, 622, 587, 555, 530, 520, 515, 516, 522,
[ 3.615391] 1195, 1082, 992, 906, 834, 770, 710, 662, 619, 586, 553, 528, 514, 512, 516, 523,
[ 3.616469] 1207, 1091, 1001, 920, 846, 780, 721, 671, 630, 594, 564, 541, 527, 520, 522, 528,
[ 3.617532] 1238, 1117, 1022, 942, 867, 800, 743, 694, 649, 616, 587, 566, 549, 541, 545, 546,
[ 3.618595] 1284, 1160, 1063, 976, 899, 834, 780, 728, 684, 649, 620, 599, 580, 574, 574, 580,
[ 3.619658] 1357, 1225, 1122, 1026, 953, 886, 828, 775, 732, 698, 669, 647, 627, 614, 616, 620,
[ 3.620721] 1464, 1305, 1195, 1096, 1017, 949, 889, 834, 790, 758, 728, 706, 692, 684, 684, 690,
[ 3.621784] 1590, 1413, 1284, 1177, 1091, 1022, 961, 906, 861, 825, 798, 777, 760, 755, 755, 760,
[ 3.622846] 1740, 1569, 1421, 1291, 1195, 1117, 1049, 996, 949, 913, 886, 864, 849, 843, 843, 849,
[ 3.623909] 1809, 1626, 1470, 1341, 1242, 1164, 1099, 1044, 997, 959, 928, 905, 891, 882, 880, 886,
[ 3.624971] 1641, 1470, 1336, 1229, 1142, 1069, 1008, 956, 909, 871, 840, 818, 804, 795, 796, 805,
[ 3.626044] 1508, 1352, 1238, 1142, 1063, 994, 933, 880, 836, 796, 764, 743, 727, 718, 717, 724,
[ 3.627107] 1405, 1264, 1160, 1072, 997, 928, 869, 815, 769, 730, 700, 677, 661, 652, 651, 657,
[ 3.628170] 1326, 1204, 1102, 1020, 943, 875, 815, 762, 716, 677, 645, 622, 606, 597, 596, 602,
[ 3.629232] 1274, 1153, 1059, 977, 902, 834, 774, 720, 675, 636, 605, 581, 564, 556, 555, 560,
[ 3.630309] 1238, 1123, 1031, 948, 873, 805, 746, 692, 646, 609, 577, 554, 537, 529, 528, 534,
[ 3.631371] 1221, 1106, 1017, 933, 856, 789, 729, 676, 631, 594, 559, 533, 522, 517, 517, 523,
[ 3.632434] 1216, 1102, 1017, 931, 856, 786, 727, 675, 630, 593, 558, 530, 516, 512, 517, 524,
[ 3.633497] 1229, 1116, 1025, 941, 867, 798, 738, 686, 640, 603, 570, 545, 530, 523, 525, 530,
[ 3.634560] 1264, 1145, 1053, 966, 893, 824, 764, 711, 664, 628, 598, 575, 556, 546, 550, 554,
[ 3.635634] 1316, 1188, 1092, 1005, 931, 863, 804, 749, 703, 664, 634, 611, 590, 583, 585, 591,
[ 3.636697] 1389, 1251, 1149, 1056, 980, 912, 852, 798, 752, 714, 685, 662, 640, 625, 629, 634,
[ 3.637759] 1488, 1331, 1216, 1123, 1041, 977, 914, 860, 813, 775, 744, 723, 707, 699, 700, 707,
[ 3.638822] 1611, 1446, 1311, 1208, 1120, 1050, 988, 933, 889, 850, 820, 798, 782, 774, 774, 780,
[ 3.639884] 1764, 1596, 1446, 1321, 1221, 1145, 1079, 1025, 977, 941, 909, 886, 871, 863, 863, 869,
[ 3.640946] 1822, 1647, 1480, 1353, 1246, 1162, 1089, 1030, 982, 938, 906, 885, 869, 861, 857, 865,
[ 3.642009] 1662, 1492, 1344, 1230, 1141, 1064, 997, 942, 894, 853, 820, 799, 783, 773, 776, 783,
[ 3.643072] 1516, 1363, 1238, 1141, 1058, 987, 924, 865, 820, 780, 746, 726, 710, 699, 699, 704,
[ 3.644134] 1403, 1271, 1162, 1070, 992, 920, 857, 799, 755, 715, 684, 660, 647, 638, 636, 640,
[ 3.645197] 1325, 1199, 1101, 1008, 929, 861, 803, 749, 702, 665, 634, 611, 594, 587, 585, 590,
[ 3.646270] 1263, 1148, 1052, 967, 885, 820, 758, 707, 662, 625, 598, 574, 557, 551, 549, 554,
[ 3.647345] 1230, 1114, 1018, 933, 857, 789, 729, 677, 634, 599, 571, 551, 535, 528, 526, 531,
[ 3.648408] 1207, 1095, 1002, 915, 838, 770, 712, 660, 619, 587, 556, 531, 522, 518, 516, 520,
[ 3.649470] 1207, 1095, 1002, 915, 838, 770, 710, 658, 619, 585, 552, 529, 516, 512, 516, 523,
[ 3.650533] 1222, 1108, 1013, 924, 853, 783, 720, 672, 627, 596, 564, 541, 528, 522, 522, 528,
[ 3.651595] 1255, 1134, 1041, 952, 877, 806, 746, 694, 651, 617, 590, 569, 551, 541, 544, 549,
[ 3.652658] 1306, 1184, 1083, 997, 920, 846, 789, 734, 689, 653, 625, 603, 583, 576, 578, 585,
[ 3.653720] 1383, 1255, 1148, 1052, 971, 902, 842, 783, 737, 702, 672, 651, 629, 615, 617, 623,
[ 3.654783] 1492, 1344, 1222, 1121, 1041, 967, 906, 850, 803, 764, 731, 710, 694, 686, 686, 696,
[ 3.655857] 1633, 1457, 1325, 1214, 1128, 1052, 987, 929, 881, 838, 810, 786, 770, 761, 764, 770,
[ 3.656919] 1770, 1605, 1457, 1334, 1230, 1148, 1076, 1018, 971, 929, 898, 877, 861, 850, 853, 861,
[ 3.657982] 861, 858, 855, 861, 873, 896, 924, 957, 1001, 1058, 1122, 1195, 1291, 1404, 1539, 1715,
[ 3.659045] 777, 772, 772, 782, 790, 811, 837, 873, 917, 968, 1031, 1096, 1177, 1271, 1396, 1549,
[ 3.660108] 706, 700, 700, 706, 717, 739, 765, 800, 849, 899, 961, 1026, 1096, 1177, 1284, 1421,
[ 3.661171] 646, 639, 637, 644, 658, 676, 704, 741, 787, 840, 899, 964, 1031, 1112, 1207, 1327,
[ 3.662233] 596, 587, 586, 593, 605, 625, 656, 692, 737, 787, 849, 913, 984, 1063, 1149, 1257,
[ 3.663306] 557, 551, 549, 555, 565, 589, 616, 653, 696, 739, 800, 876, 949, 1022, 1107, 1213,
[ 3.664369] 534, 527, 525, 531, 542, 562, 590, 624, 669, 713, 782, 852, 924, 1001, 1087, 1189,
[ 3.665431] 520, 515, 516, 522, 530, 549, 574, 611, 658, 710, 772, 840, 910, 988, 1072, 1171,
[ 3.666505] 514, 512, 516, 523, 531, 546, 574, 611, 656, 710, 772, 837, 906, 980, 1067, 1166,
[ 3.667568] 527, 520, 523, 528, 536, 555, 587, 622, 669, 721, 782, 849, 920, 996, 1077, 1183,
[ 3.668631] 548, 541, 545, 546, 553, 580, 608, 646, 690, 746, 803, 870, 942, 1017, 1107, 1207,
[ 3.669694] 579, 574, 574, 580, 587, 616, 644, 682, 728, 780, 840, 906, 976, 1053, 1143, 1257,
[ 3.670757] 625, 614, 616, 622, 635, 665, 694, 732, 777, 828, 889, 953, 1026, 1107, 1207, 1327,
[ 3.671820] 692, 684, 684, 692, 706, 728, 755, 793, 837, 889, 949, 1013, 1091, 1177, 1284, 1421,
[ 3.672883] 760, 755, 755, 762, 775, 798, 825, 861, 906, 961, 1022, 1091, 1171, 1271, 1396, 1549,
[ 3.673945] 846, 843, 843, 849, 864, 886, 913, 949, 996, 1049, 1117, 1195, 1291, 1413, 1549, 1715,
[ 3.675008] 891, 882, 882, 889, 905, 926, 956, 997, 1044, 1102, 1168, 1247, 1346, 1470, 1618, 1791,
[ 3.676080] 804, 795, 796, 805, 817, 838, 869, 907, 956, 1011, 1076, 1149, 1233, 1336, 1464, 1626,
[ 3.677142] 726, 718, 717, 724, 740, 762, 793, 832, 880, 936, 999, 1069, 1149, 1242, 1352, 1495,
[ 3.678205] 661, 652, 651, 658, 673, 696, 726, 765, 813, 869, 933, 1002, 1079, 1164, 1264, 1394,
[ 3.679268] 605, 597, 596, 602, 617, 640, 672, 711, 759, 813, 878, 946, 1023, 1109, 1204, 1316,
[ 3.680345] 563, 556, 555, 561, 573, 598, 629, 667, 714, 759, 820, 905, 983, 1066, 1157, 1269,
[ 3.681408] 536, 529, 528, 534, 546, 569, 599, 638, 682, 727, 800, 875, 953, 1038, 1131, 1238,
[ 3.682471] 521, 517, 517, 523, 534, 555, 585, 623, 671, 726, 791, 863, 938, 1023, 1113, 1216,
[ 3.683533] 516, 512, 517, 525, 535, 553, 585, 623, 672, 727, 791, 860, 936, 1017, 1109, 1216,
[ 3.684596] 530, 523, 525, 531, 541, 564, 597, 638, 685, 740, 804, 873, 951, 1031, 1123, 1233,
[ 3.685690] 555, 546, 550, 554, 563, 593, 622, 664, 711, 765, 828, 900, 977, 1059, 1153, 1264,
[ 3.686753] 589, 584, 585, 592, 601, 631, 662, 703, 749, 804, 867, 938, 1014, 1099, 1196, 1311,
[ 3.687816] 638, 625, 629, 634, 650, 684, 714, 752, 800, 854, 916, 988, 1066, 1153, 1255, 1383,
[ 3.688878] 707, 699, 700, 708, 723, 747, 777, 817, 863, 919, 980, 1050, 1131, 1225, 1336, 1476,
[ 3.689941] 782, 774, 774, 782, 798, 822, 852, 891, 938, 994, 1056, 1131, 1216, 1321, 1452, 1603,
[ 3.691004] 869, 863, 863, 871, 886, 912, 943, 980, 1028, 1085, 1153, 1233, 1331, 1458, 1596, 1755,
[ 3.692066] 869, 861, 857, 865, 881, 906, 938, 982, 1030, 1089, 1162, 1246, 1353, 1480, 1633, 1804,
[ 3.693129] 783, 773, 776, 786, 796, 820, 850, 889, 942, 1002, 1070, 1148, 1238, 1344, 1480, 1633,
[ 3.694191] 707, 699, 699, 707, 720, 743, 773, 813, 861, 920, 992, 1064, 1148, 1246, 1363, 1503,
[ 3.695254] 644, 638, 636, 642, 658, 679, 707, 746, 796, 853, 920, 992, 1076, 1169, 1271, 1393,
[ 3.696329] 594, 587, 585, 590, 603, 625, 656, 694, 740, 796, 861, 938, 1018, 1108, 1207, 1316,
[ 3.697405] 557, 551, 549, 554, 564, 587, 613, 651, 699, 743, 806, 894, 971, 1058, 1162, 1263,
[ 3.698467] 534, 528, 526, 531, 540, 559, 588, 623, 667, 710, 786, 865, 947, 1035, 1128, 1230,
[ 3.699530] 520, 518, 516, 520, 529, 548, 574, 609, 656, 710, 773, 850, 929, 1013, 1108, 1214,
[ 3.700593] 515, 512, 516, 523, 531, 546, 574, 609, 656, 710, 773, 846, 929, 1013, 1108, 1214,
[ 3.701656] 528, 522, 522, 528, 538, 557, 587, 625, 669, 726, 789, 865, 947, 1030, 1128, 1230,
[ 3.702719] 549, 541, 544, 549, 556, 585, 611, 651, 696, 752, 820, 894, 976, 1064, 1155, 1271,
[ 3.703781] 581, 576, 578, 585, 592, 621, 653, 691, 740, 796, 861, 938, 1018, 1108, 1207, 1325,
[ 3.704845] 627, 615, 617, 623, 640, 672, 704, 743, 793, 850, 915, 987, 1070, 1162, 1271, 1403,
[ 3.705920] 694, 686, 686, 696, 712, 737, 767, 810, 857, 915, 982, 1058, 1141, 1246, 1363, 1503,
[ 3.706983] 770, 761, 764, 770, 789, 813, 846, 885, 938, 997, 1064, 1141, 1238, 1344, 1480, 1633,
[ 3.708045] 861, 850, 853, 861, 877, 902, 938, 982, 1035, 1095, 1169, 1255, 1363, 1492, 1633, 1804,
[ 3.709108] ---- af ----
[ 3.709371] 296 100
[ 3.709601] [ov8856_mipi]PWR_OFF!
insmod: can't insert '/lib/modules/4.9.191/sunxi_aio.ko': No such file or directory
insmod: can't insert '/lib/modules/4.9.191/sunxi_eise.ko': No such file or directory
Starting logging: start-stop-daemon: unrecognized option: exec
OK
Starting audio: no /home/res/audio director
Populating /dev using udev: [ 3.816490] udevd[1305]: starting version 3.2.9
[ 3.820783] udevd[1305]: specified group 'tty' unknown
[ 3.821642] udevd[1305]: specified group 'dialout' unknown
[ 3.822401] udevd[1305]: specified group 'kmem' unknown
[ 3.823107] udevd[1305]: specified group 'input' unknown
[ 3.823830] udevd[1305]: specified group 'video' unknown
[ 3.824746] udevd[1305]: specified group 'lp' unknown
[ 3.825481] udevd[1305]: specified group 'disk' unknown
[ 3.826395] udevd[1305]: specified group 'cdrom' unknown
[ 3.827185] udevd[1305]: specified group 'tape' unknown
[ 3.839224] udevd[1306]: starting eudev-3.2.9
[ 3.846679] bat_stat reset guage v1
done
mkdir: can't create directory '/dev/pts': File exists
mkdir: can't create directory '/dev/shm': File exists
Starting network: Failed to connect to ubus
/sbin/ifup: line 51: /sbin/wifi: not found
FAIL
ifconfig: invalid hw-addr 00:
udhcpc: SIOCGIFINDEX: No such device
Starting telnetd: OK
enable android usb
insmod: can't insert '/lib/modules/4.9.191/sunxi_usb_udc.ko': No such file or directory
insmod: can't insert '/lib/modules/4.9.191/sunxi_usbc.ko': No such file or directory
Unknown group "lp" in message bus configuration file
[ 4.988678] file system registered
[ 5.000524] configfs-gadget 4100000.udc-controller: failed to start g1: -19
sh: write error: No such device
[ 5.926576] bat_stat reset guage v1
[ 6.085516]
[ 6.085516] insmod_device_driver
[ 6.085516]
device_chose finished!
/etc/init.d/S50wifideamon: line 11: syntax error: unexpected "}"
mkdir: can't create directory '/rom/mnt/UDISK/coredump': Read-only file system
insmod: can't insert '/lib/modules/4.9.191/aic8800_bsp.ko': File exists
insmod: can't insert '/lib/modules/4.9.191/aic8800_fdrv.ko': File exists
insmod: can't insert '/lib/modules/4.9.191/focaltech_ts.ko': File exists
Close IRCUT........sh: write error: Resource busy
/etc/init.d/rcS: /etc/init.d/rc.final: line 38: powerkey_daemon: not found
starting pid 1418, tty '/dev/console': '-/bin/sh'
------run profile file-----
Trying to connect to SWUpdate...
-----link UDSIK failed-------
info-init.c[1016]:property init
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (Neptune, 5C1C9C53)
get wordspace -1225719808 0xb6f10000
info-property_service.c[213]:init_property ok
info-init.c[1051]:property init
info-init.c[1055]:reading config file
[ import /data/res/mcu.rc ]
info-init_parser.c[319]:found import '/data/res/mcu.rc', adding to import list[ on init ]
[ service mbapp ]
[ service mbcam ]
[ service ST03_app ]
[ service wifi_server ]
[ service wpa_supplicant ]
[ service ota_server ]
[ service wav_server ]
[ service dlamPrinter ]
[ service print_server ]
[ service video_server ]
[ service udhcp ]
[ service udhcp_lte ]
[ service udhcp_lte2 ]
[ service bluetooth_on ]
[ service bluetooth_off ]
[ service autotest ]
[ service board_test ]
[ service screen_test ]
[ service adbdebug ]
[ service adbd ]
error-parser.c[65]:/data/dlam/init.rc: 83: ignored duplicate definition of service 'adbd'
[ service wavmixer ]
[ on property:init.svc.ST03_app=running ]
[ on property:init.svc.board_test=running ]
info-init_parser.c[398]:importing '/data/res/mcu.rc'[ on init ]
info-init.c[584]:processing action 0xb6f1ba90 (signal_init)
info-init.c[594]:command 'signal_init' r=0
info-init.c[584]:processing action 0xb6f1bad0 (property_service_init)
root@TinaLinux:/# info-util.c[137]:Created socket '/data//property_service' with mode '666', user '0', group '0'
info-init.c[594]:command 'property_service_init' r=0
info-init.c[584]:processing action 0xb6d87f80 (init)
info-init.c[594]:command 'export' r=0
info-init.c[594]:command 'setrlimit' r=0
notice-init.c[253]:starting 'wifi_server'
notice-init.c[253]:starting 'dlamPrinter'
info-init.c[594]:command 'class_start' r=0
notice-init.c[253]:starting 'ST03_app'
notice-init.c[253]:starting 'adbdebug'
info-init.c[594]:command 'mkdir' r=0
init adb main
Handling main()
[ 6.301385] read descriptors
[ 6.304325] read strings
info-init.c[584]:processing action 0xb6f1ba20 (init)
info-init.c[594]:command 'setprop' r=0
info-init.c[584]:processing action 0xb6f1bb30 (queue_property_triggers)
info-init.c[594]:command 'queue_property_triggers' r=0
info-init.c[584]:processing action 0xb6f18d30 (property:init.svc.ST03_app=running)
info-init.c[594]:command 'start' r=0
info-init.c[584]:processing action 0xb6f1b970 (property:init.svc.ST03_app=running)
info-init.c[594]:command 'stop' r=0
swu_param: ####
swu_software: ####
swu_mode: ####
no swupdate_cmd to run, wait for next swupdate
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/main.c[100]:main:hello dlamPrinter server!
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/main.c[111]:main:---app compiled:Nov 26 2024 11:01:23---
iniparser: cannot open /etc/printer_config.ini
can not open /etc/printer_config.ini
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[616]:lte_server_thread:
DEBUG : awplayer <ReadPluginEntry:194>: read plugin entry adecoder-0 fail!
DEBUG : awplayer <CdxPluginLoadList:221>: have config 0 entry
DEBUG : awplayer <CdxPluginLoadList:222>: start to open adecoder lib
DEBUG : awplayer <CdxPluginLoadList:202>: Load Plugin list vdecoder
DEBUG : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-0 ok.
DEBUG : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-1 ok.
DEBUG : awplayer <ReadPluginEntry:178>: read plugin entry vdecoder-2 ok.
DEBUG : awplayer <ReadPluginEntry:194>: read plugin entry vdecoder-3 fail!
DEBUG : awplayer <CdxPluginLoadList:221>: have config 3 entry
DEBUG : awplayer <CdxPluginLoadList:222>: start to open vdecoder lib
DEBUG : awplayer <DlOpenPlugin:96>: plugin vdecoder.h264 comment is "h264_vdecoder"
DEBUG : awplayer <DlOpenPlugin:97>: plugin open lib: libawh264.so
DEBUG : awplayer <DlOpenPlugin:116>: plugin init : CedarPluginVDInit
INFO : cedarc <CedarPluginVDInit:73>: register h264 decoder success!
DEBUG : awplayer <DlOpenPlugin:96>: plugin vdecoder.h265 comment is "h265_vdecoder"
DEBUG : awplayer <DlOpenPlugin:97>: plugin open lib: libawh265.so
INFO : cedarc <CedarPluginVDInit:82>: register h265 decoder success!
DEBUG : awplayer <DlOpenPlugin:96>: plugin vdecoder.mjpegplus comment is "mjpegplus_vdecoder"
DEBUG : awplayer <DlOpenPlugin:97>: plugin open lib: libawmjpegplus.so
ERROR : awplayer <DlOpenPlugin:103>: dlopen 'libawmjpegplus.so' fail: Error loading shared library libawmjpegplus.so: No such file or directory
DEBUG : awplayer <CdxPluginLoadList:231>: load vdecoder id vdecoder.mjpegplus fail!
DEBUG : awplayer <CdxPluginLoadList:202>: Load Plugin list plugin
DEBUG : awplayer <ReadPluginEntry:194>: read plugin entry plugin-0 fail!
DEBUG : awplayer <CdxPluginLoadList:222>: start to open plugin lib
DEBUG : awplayer <AwStreamInit:95>: aw stream init...
DEBUG : awplayer <AwStreamInit:131>: stream list size:8
INFO : awplayer <AwParserInit:397>: aw parser init...
AwParserInit :407
DEBUG : awplayer <AwParserInit:468>: aw parser size:12
WARNING: Logging before InitGoogleLogging() is written to STDERR
I0330 20:23:16.825770 1432 dup2SeldomUsedFd.c:20] <dup2SeldomUsedFdInit> gFdLock init
src/stApp.cpp[790]:main:
================= app start new! ====================
src/stApp.cpp[318]:msg_init:g_video_mp4_2_gui_msg:491535
fb_var_screeninfo: [1280,720], [1280,2880], [0,0], bitsPerPixel[32], grayscale[0]
src/sysconfig/sysconfig.cpp[296]:sysconfig_init:file size = 942
src/sysconfig/sysconfig.cpp[923]:sysconfig_init:sysconfig_info.backlight_brightness = 54
src/sysconfig/sysconfig.cpp[924]:sysconfig_init:sysconfig_info.volume = 27
src/sysconfig/sysconfig.cpp[925]:sysconfig_init:sysconfig_info.auto_pronunciation = 1
src/sysconfig/sysconfig.cpp[926]:sysconfig_init:sysconfig_info.word_pronunciation = 1
src/sysconfig/sysconfig.cpp[927]:sysconfig_init:sysconfig_info.china_speed = 1
src/sysconfig/sysconfig.cpp[928]:sysconfig_init:sysconfig_info.english_speed = 1
src/sysconfig/sysconfig.cpp[929]:sysconfig_init:sysconfig_info.pen_dir = 0
src/sysconfig/sysconfig.cpp[930]:sysconfig_init:sysconfig_info.close_screen = 300
src/sysconfig/sysconfig.cpp[931]:sysconfig_init:sysconfig_info.wallpaper_index = 12
src/sysconfig/sysconfig.cpp[932]:sysconfig_init:sysconfig_info.shutdown = 3600
src/sysconfig/sysconfig.cpp[933]:sysconfig_init:sysconfig_info.more_line_scan = 1
src/sysconfig/sysconfig.cpp[934]:sysconfig_init:sysconfig_info.wifi_switch = 0
src/sysconfig/sysconfig.cpp[935]:sysconfig_init:sysconfig_info.cellular_switch = 0
src/sysconfig/sysconfig.cpp[936]:sysconfig_init:sysconfig_info.eye_switch = 1
src/sysconfig/sysconfig.cpp[937]:sysconfig_init:sysconfig_info.ocr_host_name = stseries.com
src/sysconfig/sysconfig.cpp[938]:sysconfig_init:sysconfig_info.ocr_host_port = 11000
src/sysconfig/sysconfig.cpp[939]:sysconfig_init:sysconfig_info.bluetooth_switch = 1
src/sysconfig/sysconfig.cpp[940]:sysconfig_init:sysconfig_info.scan_switch = 0
src/sysconfig/sysconfig.cpp[941]:sysconfig_init:sysconfig_info.video_guide = 1
src/sysconfig/sysconfig.cpp[942]:sysconfig_init:sysconfig_info.show_guide = 0
src/sysconfig/sysconfig.cpp[943]:sysconfig_init:sysconfig_info.gray_print = 0
src/sysconfig/sysconfig.cpp[944]:sysconfig_init:sysconfig_info.secure_password =
src/sysconfig/sysconfig.cpp[945]:sysconfig_init:sysconfig_info.printer_work_mode = 0
src/sysconfig/sysconfig.cpp[946]:sysconfig_init:sysconfig_info.password_err_num = 0
src/sysconfig/sysconfig.cpp[947]:sysconfig_init:sysconfig_info.erase_handwriting_switch = 1
backlightGetBrightness:58
src/sysconfig/sysconfig.cpp[949]:sysconfig_init:sysconfig_info.grade_for_dict_select = 10013
val:46
test 70
brightness value 46
backlightGetBrightness:69
--------updata_sysconfig_info---------1018--
userVersion : 1
onCreate
gui_init =========== 1280x720
src/stApp.cpp[805]:main:++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++!
src/zyb/zyb_build_point.cpp[356]:zyb_build_point_check_index:---- g_zyb_up_file.index:0 time:1743408000all good, pass
all good, pass
all good, pass
src/stApp.cpp[605]:StMain:keytmp.value is N2C0HB4C034363 ...
src/stApp.cpp[628]:StMain:userinfo->Mac:50:97:07:F0:5D:28
--------EventManager creat!!!---------src/stApp.cpp[834]:main:++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++!
src/stApp.cpp[836]:main:++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++!
Opened database successfully
SQL error: table audio_table already exists
SQL error: table video_table already exists
------------------------------------------486 gui_task
-------ueventLoop-------
src/lsPrinter/lsPrinter.cpp[867]:local_printer_send:
src/lsPrinter/lsPrinter.cpp[151]:lsLink_lte_server:
---------------connect lte server!-------------------------
src/lsPrinter/lsPrinter.cpp[900]:local_printer_send:
src/lsPrinter/lsPrinter.cpp[906]:local_printer_send:--------use print socket cmd = 3
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:9 data: {"cmd":3}
src/lsPrinter/lsPrinter.cpp[906]:local_printer_send:--------use print socket cmd = 4
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:9 data: {"cmd":4}
src/lsPrinter/lsPrinter.cpp[906]:local_printer_send:--------use print socket cmd = 5
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:9 data: {"cmd":5}
------------------------------------------493 gui_task
src/lsPrinter/lsPrinter.cpp[897]:local_printer_send:
src/lsPrinter/lsPrinter.cpp[906]:local_printer_send:--------use print socket cmd = 66
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:20 data: {"cmd":66,"data":79}
--------EventManager creat!!!---------src/wlan/wlan.cpp[1101]:wlan_task:msg type = 2
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devWiFiCtrl","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337396","time":"2025-03-30 20:23:16","power":"off"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:280330 ZYB_BUILD_POINT_FILE_MAX:52428800
src/page/ToLoginPage.cpp[102]:ToLoginPage:accessToken = 08b70d017d3eed554c840ae46e7a13d2
src/page/ToLoginPage.cpp[111]:ToLoginPage:aeskey = 4e93625fc0b1a1429b5e609fc39d61ab
src/page/ToLoginPage.cpp[120]:ToLoginPage:refreshToken = 5a28a9dd3bbc9c4548a6b4051e1f108e
src/page/ToLoginPage.cpp[134]:ToLoginPage:ftell(p_config_file) = 752
src/page/TakeTopicShowLoadPage.cpp[177]:checkDirIsExist:EXTSD_CACHE /rom/mnt/extsd/cache/
src/page/TakeTopicShowLoadPage.cpp[201]:checkDirIsExist:SYNC_VIDEO_ROOT /mnt/UDISK/cache/jxw/
src/page/TakeTopicShowLoadPage.cpp[259]:checkDirIsExist:before
ctrl_interface=/var/run/wpa_supplicant in 1 :ctrl_interface=/var/run/wpa_supplicant
/home/wangzhimin/workspace/N1/V853/out/v853s-miaobao/compile_dir/target/wifi_zpl01/src/wifi_sta.c[114]:wpa_cli_cmd:Do wpa_ctrl_open error! PATH:/var/run/wpa_supplicant/wlan0 err_count = 0
/home/wangzhimin/workspace/N1/V853/out/v853s-miaobao/compile_dir/target/wifi_zpl01/src/wifi_sta.c[1860]:wifi_sta_disconnect:Do DISCONNECT fail! ret:-1
/home/wangzhimin/workspace/N1/V853/out/v853s-miaobao/compile_dir/target/wifi_zpl01/src/wifi_sta.c[1441]:wifi_sta_close:The wifi sta mode have closed yet!
src/page/TakeTopicShowLoadPage.cpp[276]:checkDirIsExist:after
+++++++++++++++++++++++++++++++++++构造函数++++++++++++++++++++++++++++++
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[640]:lte_server_thread:accept
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[532]:local_server_thread:accept
检测 162 uart_init
cfg_get(buadrate) -1
rate 921600
uart_end
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[61]:get_int_from_json:data:79
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[250]:parse_ls_socket_pack:---MM_SET_PAGE_WIDTH :79----
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[272]:parse_ls_socket_pack:---MM_SET_PAGE_WIDTH :{"TPPaperWide":79}----
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[277]:parse_ls_socket_pack:---MM_SET_PAGE_WIDTH :79----
--------EventManager creat!!!---------src/page/MainPage.cpp[3147]:gui_main_drag_create:----------ac_status = 0 batCap = 95
src/page/MainPage.cpp[3175]:gui_main_drag_create: 125/ 2/30 20:23:17
src/page/MainPage.cpp[3177]:gui_main_drag_create:time 3月30日 20:23
src/page/MainPage.cpp[3271]:gui_main_drag_create:---------bt_status = 0
src/page/MainPage.cpp[3551]:gui_main_drag_create:file_name:/data/picture/control/drag_paper.png
src/page/MainPage.cpp[3556]:gui_main_drag_create:file_name:/data/picture/control/no_drag_paper.png
src/page/MainPage.cpp[3590]:gui_main_drag_create:file_name:/data/picture/control/drag_change.png
src/page/MainPage.cpp[3708]:gui_main_drag_create:file_name:/data/picture/control/vinyl_bg.png
src/page/MainPage.cpp[3777]:gui_main_drag_create:file_name:/data/picture/control/music.png
src/page/MainPage.cpp[3832]:gui_main_drag_create:file_name:/data/picture/control/drag_bright_height.png
src/page/MainPage.cpp[3837]:gui_main_drag_create:file_name:/data/picture/control/drag_brightness_min.png
src/page/MainPage.cpp[3866]:gui_main_drag_create:file_name:/data/picture/control/drag_volume.png
src/page/MainPage.cpp[3871]:gui_main_drag_create:file_name:/data/picture/control/drag_volume_min.png
src/page/MainPage.cpp[3876]:gui_main_drag_create:file_name:/data/picture/control/drag_volume_height.png
src/page/MainPage.cpp[5336]:link_page_create:file:/data/picture/control/popup_close.png
-----------------------------temp_buff = https://paperang.com/app/device?cid=509707F05D28
qrCode->width:41 qrCode->width:41
src/page/MainPage.cpp[7331]:password_page_create: 125/ 2/30 20:23:17
src/page/MainPage.cpp[7333]:password_page_create:time 3月30日 20:23
src/page/MainPage.cpp[7341]:password_page_create:----------ac_status = 0 batter_value = 95
src/page/MainPage.cpp[7459]:password_page_create:---------bt_status = 0
src/page/MainPage.cpp[5815]:wallpaper_page_create: 125/ 2/30 20:23:17
src/page/MainPage.cpp[5824]:wallpaper_page_create:hour temp_buff:20:23
/data/freetype/font/N1_time_font.ttf, size=240, lv_ft_font_init fail
src/page/MainPage.cpp[5833]:wallpaper_page_create:----------ac_status = 0 batCap = 95
src/page/MainPage.cpp[5951]:wallpaper_page_create:---------bt_status = 0
src/page/MainPage.cpp[6275]:shutdown_page_create: 125/ 2/30 20:23:17
src/page/MainPage.cpp[6277]:shutdown_page_create:time 3月30日 20:23
src/page/MainPage.cpp[6285]:shutdown_page_create:----------ac_status = 0 batCap = 95
src/page/MainPage.cpp[6402]:shutdown_page_create:---------bt_status = 0
src/page/MainPage.cpp[8437]:createPage:----------acStatus = 0 batter_value = 95
src/page/MainPage.cpp[8465]:createPage: 125/ 2/30 20:23:17
src/page/MainPage.cpp[8467]:createPage:time 3月30日 20:23
src/page/MainPage.cpp[8555]:createPage:this->offset_x = 1104
src/page/MainPage.cpp[8563]:createPage:---------bt_status = 0
src/page/MainPage.cpp[8580]:createPage:this->offset_x = 1104
src/page/MainPage.cpp[8595]:createPage:this->offset_x = 1104
src/page/MainPage.cpp[8610]:createPage:this->offset_x = 1104
========463================================src/page/ToLoginPage.cpp[2023]:getLoginUserIdForDouble:mToLoginPage->user_info = {
"area": "CN",
"cityId": 0,
"cityName": "",
"country": "CN",
"nickName": "喵宝宝",
"personalSign": "",
"pic": "",
"protocolIds": "",
"sex": -1,
"userAge": "",
"userId": 30014225128,
"identityId": 2,
"stageId": 10002,
"gradeId": 10013,
"isAuthor": false,
"createDate": "2025-03-30 12:57:47",
"studyTime": "2017-09-01 00:00:00",
"identityCheck": true,
"ipAddress": "14.26.129.152",
"ipArea": "广东省",
"countryNumber": 86,
"userName": "",
"email": "",
"mobile": "135****2345",
"zuid": 2322751422,
"openType": 0,
"openId": "",
"unionId": "",
"identityName": "家长",
"oldStageId": 10002,
"stageName": "初中",
"gradeName": "初二",
"subjects": [],
"newGradeId": 10013,
"newGradeName": "初二",
"isAdult": 1
----------------1743337397----------------------
[ 8.006659] bat_stat reset guage v1
src/page/MainPage.cpp[8121]:TabviewEventHandler:-----------event---:17
src/gui/gui_dev/tpdev.cpp[696]:GetTpPosition:----------open tp ok
src/page/MainPage.cpp[9721]:proMsg:----------msg_type = 1 status = 5
src/page/MainPage.cpp[9730]:proMsg:---batter event disconnect
src/page/MainPage.cpp[9050]:proPage:st->userinfo->batCap :95
src/page/MainPage.cpp[9051]:proPage:old_batcap_level :95
src/page/ToLoginPage.cpp[653]:proPage:
check device status
src/page/ToLoginPage.cpp[655]:proPage:body:{"deviceSN": "N2C0HB4C034363"}
src/zyb/zyb_post_task.cpp[403]:_zyb_post_task:src/page/ToLoginPage.cpp[833]:proPage:----------------------------------------------wlan is disconnect
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devPowerOn","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337398","time":"2025-03-30 20:23:18"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:280584 ZYB_BUILD_POINT_FILE_MAX:52428800
read file '/sys/class/power_supply/battery/batcurrent'=0
read file '/sys/class/power_supply/battery/voltage_now'=4189000
read file '/sys/class/power_supply/battery/charger'=1
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devBatSta","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337398","time":"2025-03-30 20:23:18","batcurrent":"0","voltage_now":"4189000","charger":"1"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:280823 ZYB_BUILD_POINT_FILE_MAX:52428800
Failed to connect to non-global ctrl_ifname: (nil) error: No such file or directory
Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devWiFiStatus","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337398","time":"2025-03-30 20:23:18","status":"r0 null r1 null ssid whycan rssi null sta null ip rxflow 0"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:281116 ZYB_BUILD_POINT_FILE_MAX:52428800
src/lsPrinter/lsPrinter.cpp[918]:local_printer_send:--------use lte socket cmd = 281
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:11 data: {"cmd":281}
src/lsPrinter/lsPrinter.cpp[918]:local_printer_send:--------use lte socket cmd = 280
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:11 data: {"cmd":280}
src/lsPrinter/lsPrinter.cpp[918]:local_printer_send:--------use lte socket cmd = 282
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:11 data: {"cmd":282}
src/page/MainPage.cpp[9721]:proMsg:----------msg_type = 2 status = 95
src/page/MainPage.cpp[9794]:proMsg:---batter event level 95
src/wlan/wlan.cpp[1101]:wlan_task:msg type = 27
src/wlan/wlan.cpp[1114]:wlan_task:p_send_data = {
"cmd": 9
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devBLECtrl","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337398","time":"2025-03-30 20:23:18","power":"on"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:281440 ZYB_BUILD_POINT_FILE_MAX:52428800
-----------open_bluetooth_dev
-----------property_set end
notice-init.c[253]:starting 'bluetooth_on'
[uart thread] receive data:
0xa5 0x01 0x10 0x00 0x01 0x07 0x02 0x0b 0x00 0x01 0x08 0x00 0x30 0x31 0x2e 0x30 0x30 0x2e 0x31 0x37 0x15 0xbc 0xa4 0x2e 0x5a
src/lsPrinter/lsPrinter.cpp[295]:ls_printer_parse:lsPrinter get data:{"cmd":100,"ack":3,"type":1,"data":"01.00.17"}
src/lsPrinter/lsPrinter.cpp[587]:ls_printer_parse:mcu version:data
------------newVersion:1:0:11--------------
------------MCUVersion:1:0:11--------------
-------------version match-------------
src/lsPrinter/lsPrinter.cpp[906]:local_printer_send:--------use print socket cmd = 10
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:10 data: {"cmd":10}
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[115]:ls_printer_ack_str:ls printer ack:{"cmd":100,"ack":3,"type":1,"data":"01.00.17"}
0xa5 0x01 0x09 0x00 0x05 0x0c 0x02 0x04 0x00 0x01 0x01 0x00 0x01 0x2f 0x75 0xa3 0x10 0x5a
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":102,"type":1,"data":0}
0xa5 0x01 0x09 0x00 0x05 0x0d 0x02 0x04 0x00 0x01 0x01 0x00 0x01 0xb1 0x75 0x09 0xdc 0x5a
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":101,"type":1,"data":0}
0xa5 0x01 0x08 0x00 0x05 0x35 0x02 0x03 0x00 0x01 0x00 0x00 0x6d 0x08 0xa5 0xe0 0x5a
0xa5 0x00 0x07 0x00 0x05 0x36 0x01 0x02 0x00 0x4f 0x00 0xbc 0x0e 0xf9 0x68 0x5a
0xa5 0x01 0x14 0x00 0x05 0x27 0x02 0x0f 0x00 0x01 0x0c 0x00 0x01 0x02 0x03 0x00 0x05 0x06 0x07 0x00 0x09 0x0a 0x0b 0x00 0xe9 0x98 0x17 0x57 0x5a
[printer]:/[ 8.561928] [XR_BT_LPM] bluedroid_write_proc_btwake: bluedroid_write_proc_btwake 1
home/wy/v853/N2/out/v853-miaobao[ 8.562895] [XR_BT_LPM] bluedroid_write_proc_btwake: wakeup bt device
/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[142]:cmd_get_event:get ack data lenth 15
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[147]:cmd_get_event:p0: Tag:1, len:770, value:0
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":106,"type":1,"data":0}
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[147]:cmd_get_event:p1: Tag:5, len:1798, value:0
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[147]:cmd_get_event:p2: Tag:9, len:2826, value:0
dev_open dev_path /dev/ttyS2
set baudrate:1500000
bt dev open successful
COMMAND(4):
01 03 0C 00
src/lsPrinter/lsPrinter.cpp[295]:ls_printer_parse:lsPrinter get data:{"cmd":100,"ack":102,"type":1,"data":0}{"cmd":100,"ack":101,"type":1,"data":0}{"cmd":100,"a[ 8.648810] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
src/lsPrinter/lsPrinter.cpp[464]:ls_printer_parse:开盖
src/lsPrinter/lsPrinter.cpp[62]:ls_printer_tips:----local printer state:0x0----
src/page/MainPage.cpp[10019]:isPrintTip:tip text =
src/lsPrinter/lsPrinter.cpp[507]:ls_printer_parse:sleep_status :0
src/lsPrinter/lsPrinter.cpp[508]:ls_printer_parse:lpState.state.open :0
src/lsPrinter/lsPrinter.cpp[509]:ls_printer_parse:lpState.state.lossPaper :0
src/lsPrinter/lsPrinter.cpp[510]:ls_printer_parse:last_paper_status :0
src/lsPrinter/lsPrinter.cpp[511]:ls_printer_parse:lpState.state.overTemp :0
src/lsPrinter/lsPrinter.cpp[514]:ls_printer_parse:local_printer_status :0
src/lsPrinter/lsPrinter.cpp[436]:ls_printer_parse:缺纸
src/lsPrinter/lsPrinter.cpp[554]:ls_printer_parse:温度
EVENT(7):
04 0E 04 05 03 0C 00
to_read_addr read mac form BT_POST_PATH
BT_POST_PATH :/tmp/dragonkey/ULI/factory/BT_POST.txt
BT_POST_PATH to_read_addr 50:97:07:f0:5d:28
to_write_addr set mac 50:97:07:f0:5d:28 in chip
COMMAND(10):
01 70 FC 06 28 5D F0 07 97 50
EVENT(7):
04 0E 04 05 70 FC 00
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":222,"type":0,"data":0}
src/lsPrinter/lsPrinter.cpp[295]:ls_printer_parse:lsPrinter get data:{"cmd":100,"ack":222,"type":0,"data":0}
[ 8.804798]
[ 8.804798] rmmod_device_driver
[ 8.804798]
[ 8.805783] android_work: did not send uevent (0 0 (null))
[ 8.806485]
[ 8.806485] insmod_host_driver
[ 8.806485]
[ 8.807312] [ehci0-controller]: sunxi_usb_enable_ehci
[ 8.807906] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a72890, 0x:d085b000, irq_no:137
[ 8.810249] sunxi-ehci 4101000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.811404] sunxi-ehci 4101000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 8.812479] sunxi-ehci 4101000.ehci0-controller: irq 311, io mem 0x00000000
[ 8.835555] sunxi-ehci 4101000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 8.841668] hub 1-0:1.0: USB hub found
[ 8.842121] hub 1-0:1.0: 1 port detected
[ 8.843064] [ohci0-controller]: sunxi_usb_enable_ohci
[ 8.843941] [sunxi-ohci0]: probe, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a72ab4
[ 8.845408] sunxi-ohci 4101000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 8.846464] sunxi-ohci 4101000.ohci0-controller: new USB bus registered, assigned bus number 2
[ 8.847414] sunxi-ohci 4101000.ohci0-controller: irq 312, io mem 0x00000000
--------check hci0 success find bluetooth thread ing
[ 8.895777] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 8.925584] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 8.927759] hub 2-0:1.0: USB hub found
[ 8.929638] hub 2-0:1.0: 1 port detected
host_chose finished!
[ 8.955558] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 8.959057] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 8.961960] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 8.963354] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 8.964740] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 8.966154] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 8.967567] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 8.968179] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 8.970128] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 8.971177] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 9.005554] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.035564] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.040161] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.046710] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 9.048890] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.050687] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.052370] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.054169] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.054848] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.056884] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.061187] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
hciconfig hci0 up successed
[ 9.085592] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.115576] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.119611] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.126745] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 9.128979] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.131507] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.133738] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.136162] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.136844] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.138849] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.139841] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 9.165597] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
bluetoothd[1518]: Bluetooth daemon 5.54
bluetoothd[1518]: Unknown key AlwaysPairable for group General in /etc/bluetooth/main.conf
bluetoothd[1518]: Unknown key PairableTimeout for group General in /etc/bluetooth/main.conf
bluetoothd[1518]: Starting SDP server
bluetoothd[1518]: Failed to init battery plugin
bluetoothd[1518]: kernel lacks bnep-protocol support
bluetoothd[1518]: System does not support network plugin
bluetoothd[1518]: Bluetooth management interface 1.14 initialized
[ 9.195700] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.202255] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.213593] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 9.216874] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
bluetoothd[1518]: Failed to set privacy: Rejected (0x0b)
[ 9.220722] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.224592] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.228454] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.229072] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.405563] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.406578] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 9.435559] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.446663] ETA9002 : eta9002_work-428 : eta9002_get_soc ret : 95
[ 9.448398] ETA9002 : eta9002_work-440 : eta9002_get_vcell ret : 406
[ 9.450223] ETA9002 : eta9002_work-443 : eta9002_get_ocv ret : 407
[ 9.450874] ETA9002 : eta9002_get_temp_die-300 : eta9002_get_temp_die start!
[ 9.465547] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.469073] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.472649] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 9.473919] sunxi-ehci 4101000.ehci0-controller: ehci_irq: highspeed device connect
[ 9.474732] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.476471] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.477858] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.479231] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.480053] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.482310] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.483324] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 9.505575] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.516073] eta9002_get_temp_die val: 25
[ 9.516501] ETA9002 : eta9002_work-445 : eta9002_get_temp_die : 25
[ 9.535564] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.539197] sunxi-mmc sdc0: sdc set ios:clk 300000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.542362] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 9.544053] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.545721] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.547378] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.549033] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.549601] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":109,"type":0,"data":0}
Started listening on ATT channel. Waiting for connections
src/lsPrinter[ 9.552457] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
/lsPrinter.cpp[295]:ls_printer_p[ 9.553513] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
arse:lsPrinter get data:{"cmd":100,"ack":109,"type":0,"data":0}
[ 9.575571] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.605605] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.609717] sunxi-mmc sdc0: sdc set ios:clk 200000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
register_profile called!
object path is good!
running for SPP!
[ 9.621955] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
[ 9.625465] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.627736] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.630072] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.632298] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.633130] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.635189] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.636235] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
src/lsPrinter/lsPrinter.cpp[295]:ls_printer_parse:lsPrinter get data:{"cmd":100,"ack":109,"type":0,"data":0}
[ 9.665678] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.695557] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[ 9.700210] sunxi-mmc sdc0: sdc set ios:clk 100000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
src/lsPrinter/lsPrinter.cpp[918]:local_printer_send:--------use lte socket cmd = 28[ 9.705638] sunxi-mmc sdc0: smc 1 p0 err, cmd 8, RTO !!
0
[ 9.709615] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.713426] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.717247] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.721094] sunxi-mmc sdc0: smc 1 p0 err, cmd 55, RTO !!
[ 9.721685] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.735546] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
src/wlan/wlan.cpp[1101]:wlan_task:msg type = 42
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devBLEBCCtrl","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337399","time":"2025-03-30 20:23:19","broadcast":"start"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:281692 ZYB_BUILD_POINT_FILE_MAX:52428800
[ 10.086623] bat_stat reset guage v1
[ 10.225571] +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++card_removed_powerctl_handle enter!
[ 10.225672] +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++card_removed_powerctl_handle exit!
Bluetooth init has been completed!!
info-signal_handler.c[95]:waitpid returned pid 1478, status = 00000000
notice-signal_handler.c[103]:process 'bluetooth_on', pid 1478 exited
[ 10.355064] sunxi-ehci 4101000.ehci0-controller: ehci_irq: highspeed device connect
[ 10.356093] usb 1-1: USB disconnect, device number 2
[ 10.360790] sunxi-ehci 4101000.ehci0-controller: ehci_irq: highspeed device disconnect
bluetoothd[1518]: Endpoint registered: sender=:1.2 path=/org/bluez/hci0/A2DP/SBC/source/1
bluetoothd[1518]: Endpoint registered: sender=:1.2 path=/org/bluez/hci0/A2DP/SBC/source/2
< HCI Command: ogf 0x08, ocf 0x0008, plen 32
1E 02 01 02 03 03 E7 FE 09 FF 00 00 50 97 07 F0 5D 28 0C 09
50 61 70 65 72 61 6E 67 5F 4E 32 00
> HCI Event: 0x0e plen 4
05 08 20 00
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devBLEBCCtrl","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337400","time":"2025-03-30 20:23:20","broadcast":"start"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:281953 ZYB_BUILD_POINT_FILE_MAX:52428800
----------count = 92
-----------start bluetooth thread
-----------wait bluetooth thread
run_bluetooth_shell set agent DisplayOnly
--------default_ctrl = 0xf04f20
+++++++++++++++++++++++bluetooth_advertise_switch is already 0
0xa5 0x00 0x05 0x00 0x01 0x0c 0x01 0x00 0x00 0x54 0xca 0x24 0x34 0x5a
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[303]:cmd_ack_for_mcu_bat:MM_SYS_GET_DEV_BAT_VOL
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[311]:cmd_ack_for_mcu_bat:MM_SYS_GET_DEV_BAT_VOL volTmp :407
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[313]:cmd_ack_for_mcu_bat:MM_SYS_GET_DEV_BAT_VOL volSendBuf :
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[316]:cmd_ack_for_mcu_bat:MM_SYS_GET_DEV_BAT_VOL temp_vol :8140
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[319]:cmd_ack_for_mcu_bat:MM_SYS_GET_DEV_BAT_VOL temp_vol :8140
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/utils/cmd_sys.c[348]:cmd_ack_for_mcu_bat:--------------get mcu ack data 0
+++++++++++++++++++++++bluetooth_advertise_switch 1
+++++++++++++++++++++++bluetooth_advertise_switch is already 1
src/wlan/wlan.cpp[826]:wlan_task:recv buff = 9
{"cmd":9}
src/wlan/wlan.cpp[289]:parse_socket_pack:buff===================:{"cmd":9}
src/wlan/wlan.cpp[867]:wlan_task:i = 8 9
src/wlan/wlan.cpp[876]:wlan_task:parse end
src/lsPrinter/lsPrinter.cpp[906]:local_printer_send:--------use print socket cmd = 12
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":111,"type":0,"data":0}
src/lsPrinter/lsPrinter.cpp[295]:ls_printer_parse:lsPrinter get data:{"cmd":100,"ack":111,"type":0,"data":0}
src/lsPrinter/lsPrinter.cpp[929]:local_printer_send:len:10 data: {"cmd":12}
[ 12.166707] bat_stat reset guage v1
Agent registered
Failed to stop discovery: org.bluez.Error.Failed
Advertising object registered
Tx Power: off
Apperance: off
Discoverable: off
[ 12.437415] sunxi-ehci 4101000.ehci0-controller: ehci_irq: highspeed device connect
src/wlan/wlan.cpp[1101]:wlan_task:msg type = 30
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devBLEScanCtrl","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337402","time":"2025-03-30 20:23:22","scan":"stop"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:282214 ZYB_BUILD_POINT_FILE_MAX:52428800
-----------------BLUETOOTH_DEVICE_STOP_SCAN
+++++++++++++++++++++++bluetooth_advertise_switch 0
Advertising object unregistered
[ 12.695553] usb 1-1: new high-speed USB device number 3 using sunxi-ehci
[ 12.891125] cdc_ether 1-1:1.0 eth0: register 'cdc_ether' at usb-sunxi-ehci-1, CDC Ethernet Device, ac:0c:29:a3:9b:6d
[ 12.895617] option 1-1:1.2: GSM modem (1-port) converter detected
[ 12.897789] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 12.901345] option 1-1:1.3: GSM modem (1-port) converter detected
[ 12.904156] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devBLEBCCtrl","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337402","time":"2025-03-30 20:23:22","broadcast":"start"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:282471 ZYB_BUILD_POINT_FILE_MAX:52428800
[ 13.202121] [drivers/video/fbdev/sunxi/disp2/disp/lcd/ft_03538_st7703.c]-[lcd_close_flow]-[141]:
[ 13.405742] [DISP] de_fcm_set_para,line:491:
[ 13.406175] fcm lut 0 not find, auto retry after init
[ 13.406803] [DISP] de_fcm_set_para,line:491:
[ 13.407229] fcm lut 0 not find, auto retry after init
[ 13.407793] Frame bad
[ 13.425691] [FTS_TS/I]fts_ts_suspend:make TP enter into sleep mode
[ 13.426665] sunxi_i2c_do_xfer()2045 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
[ 13.427555] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-70
[ 13.428407] sunxi_i2c_do_xfer()2045 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
[ 13.429363] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-70
[ 13.430219] sunxi_i2c_do_xfer()2045 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
[ 13.431100] [FTS_TS/E]fts_write:i2c_transfer(write) fail,ret:-70
[ 13.431722] [FTS_TS/E]fts_ts_suspend:set TP to sleep mode fail, ret=-70
src/zyb/zyb_build_point.cpp[1845]:zyb_dev_build_point_fmt:data:{"action": "devScreenLock","devPoint":"1","paid":"38781dda0108a26900005c0000000000","network": "wifi","sn": "N2C0HB4C034363","version":"2.0.3","deviceType": "错题打印机","deviceMc":"N2","stamp":"1743337403","time":"2025-03-30 20:23:23"}
src/zyb/zyb_build_point.cpp[584]:_zyb_build_point_add:size====:282732 ZYB_BUILD_POINT_FILE_MAX:52428800
src/wlan/wlan.cpp[906]:wlan_task:msg type = 1
src/page/MainPage.cpp[9854]:proMsg:----------msg_type = 46
[ 13.594421] cdc_ether 1-1:1.0 eth0: kevent 12 may have been dropped
notice-init.c[253]:starting 'udhcp_lte2'
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":220,"type":0,"data":0}
---------ttyusb send start-----------
ttyusb send:
AT+QAUGDCNT=60
-----------ttyusb send end---------------
src/lsPrinter/lsPrinter.cpp[295]:ls_printer_parse:lsPrinter get data:{"cmd":100,"ack":220,"type":0,"data":0}
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: sending select for 192.168.0.100
ttyusb send:
AT+CPIN?
ttyusb send:
AT+QAUGDCNT=60
ttyusb send:
AT+CPIN?
ttyusb send:
AT+QAUGDCNT=60
Tx Power: off
Apperance: off
Discoverable: off
ttyusb send:
AT+CPIN?
ttyusb send:
AT+QAUGDCNT=60
[ 14.246734] bat_stat reset guage v1
ttyusb send:
AT+CPIN?
ttyusb send:
AT+QAUGDCNT=60
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
[ttyusb thread] receive data:
ttyusb read 4 chars
OK
++++++++++++++++++RET_OK:OK
com_type = 0
ttyusb read 2 chars
ttyusb read 16 chars
+CME ERROR: 13
++++++++++++++++++RET_SIM_CARD_NOT_INSERT3:+CME ERROR: 13
[printer]:/home/wy/v853/N2/out/v853-miaobao/compile_dir/target/dlamPrinter/src/localserver/localServer.c[84]:ls_printer_ack_int:ls printer ack:{"cmd":100,"ack":224,"type":0,"data":0}
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb read 2 chars
+CME ERROR: 13
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb read 2 chars
+CME ERROR: 13
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb read 2 chars
+CME ERROR: 13
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb read 2 chars
+CME ERROR: 13
src/lsPrinter/lsPrinter.cpp[295]:ls_printer_parse:lsPrinter get data:{"cmd":100,"ack":224,"type":0,"data":0}{"cmd":100,"ack":224,"type":0,"data":0}{"cmd":100,"ack":224,"type":0,"data":0}{"cmd":100,"ack":224,"type":0,"data":0}{"cmd":100,"ack":224,"type":0,"data":0}
src/lsPrinter/lsPrinter.cpp[674]:ls_printer_parse:st->userinfo->simStatus :0
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 13
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 13
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 13
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 13
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb read 2 chars
ttyusb read 18 chars
+CPIN: NOT READY
++++++++++++++++++RET_SIM_CARD_NOT_READY:+CPIN: NOT READY
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 10
++++++++++++++++++RET_SIM_CARD_NOT_INSERT2:+CME ERROR: 10
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 10
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 10
ttyusb send:
AT+QAUGDCNT=60
ttyusb read 2 chars
ttyusb read 4 chars
OK
com_type = 0
ttyusb send:
AT+CPIN?
ttyusb read 2 chars
+CME ERROR: 10
ifconfig: SIOCGIFFLAGS: No such device
ttyusb read 2 chars
[ 16.326609] bat_stat reset guage v1
[ 16.497900] sunxi-ehci 4101000.ehci0-controller: ehci_irq: highspeed device disconnect
[ 16.498884] usb 1-1: USB disconnect, device number 3
[ 16.501045] cdc_ether 1-1:1.0 eth0: unregister 'cdc_ether' usb-sunxi-ehci-1, CDC Ethernet Device
udhcpc: read error: Network is down, reopening socket
[ 16.529781] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 16.532063] option 1-1:1.2: device disconnected
[ 16.535637] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 16.537794] option 1-1:1.3: device disconnected
4G LTE mode poweroff
[ 17.384352]
[ 17.384352] rmmod_host_driver
[ 17.384352]
[ 17.385054] [ehci0-controller]: sunxi_usb_disable_ehci
[ 17.385685] [sunxi-ehci0]: remove, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0a72890
[ 17.387234] sunxi-ehci 4101000.ehci0-controller: remove, state 4
[ 17.387915] usb usb1: USB disconnect, device number 1
[ 17.391254] sunxi-ehci 4101000.ehci0-controller: USB bus 1 deregistered
[ 17.392160] [ohci0-controller]: sunxi_usb_disable_ohci
[ 17.393016] [sunxi-ohci0]: remove, pdev->name: 4101000.ohci0-controller, sunxi_ohci: 0xc0a72ab4
[ 17.393952] sunxi-ohci 4101000.ohci0-controller: remove, state 4
[ 17.394631] usb usb2: USB disconnect, device number 1
[ 17.398428] sunxi-ohci 4101000.ohci0-controller: USB bus 2 deregistered
[ 17.399266]
[ 17.399266] insmod_device_driver
[ 17.399266]
[ 17.766666] ETA9002 : eta9002_work-428 : eta9002_get_soc ret : 95
[ 17.768382] ETA9002 : eta9002_work-440 : eta9002_get_vcell ret : 406
[ 17.770152] ETA9002 : eta9002_work-443 : eta9002_get_ocv ret : 407
[ 17.770806] ETA9002 : eta9002_get_temp_die-300 : eta9002_get_temp_die start!
[ 17.836090] eta9002_get_temp_die val: 25
[ 17.836517] ETA9002 : eta9002_work-445 : eta9002_get_temp_die : 25
[ 18.406606] bat_stat reset guage v1
udhcpc: bind: No such device
info-signal_handler.c[95]:waitpid returned pid 1619, status = 00000100
notice-signal_handler.c[103]:process 'udhcp_lte2', pid 1619 exited
[ 20.486605] bat_stat reset guage v1
[ 22.566655] bat_stat reset guage v1
[ 24.646606] bat_stat reset guage v1
[ 26.086670] ETA9002 : eta9002_work-428 : eta9002_get_soc ret : 95
[ 26.088379] ETA9002 : eta9002_work-440 : eta9002_get_vcell ret : 406
[ 26.090103] ETA9002 : eta9002_work-443 : eta9002_get_ocv ret : 407
[ 26.090762] ETA9002 : eta9002_get_temp_die-300 : eta9002_get_temp_die start!
[ 26.156091] eta9002_get_temp_die val: 25
[ 26.156529] ETA9002 : eta9002_work-445 : eta9002_get_temp_die : 25
[ 26.726606] bat_stat reset guage v1
[ 28.806625] bat_stat reset guage v1
[ 30.886641] bat_stat reset guage v1
[ 32.966649] bat_stat reset guage v1
[ 34.406654] ETA9002 : eta9002_work-428 : eta9002_get_soc ret : 95
[ 34.408356] ETA9002 : eta9002_work-440 : eta9002_get_vcell ret : 406
[ 34.410130] ETA9002 : eta9002_work-443 : eta9002_get_ocv ret : 407
[ 34.410790] ETA9002 : eta9002_get_temp_die-300 : eta9002_get_temp_die start!
[ 34.476088] eta9002_get_temp_die val: 25
[ 34.476515] ETA9002 : eta9002_work-445 : eta9002_get_temp_die : 25
[ 35.046625] bat_stat reset guage v1
root@TinaLinux:/# [ 37.126606] bat_stat reset guage v1
[ 39.206603] bat_stat reset guage v1
[ 41.286620] bat_stat reset guage v1
[ 42.726670] ETA9002 : eta9002_work-428 : eta9002_get_soc ret : 95
[ 42.728398] ETA9002 : eta9002_work-440 : eta9002_get_vcell ret : 406
[ 42.730175] ETA9002 : eta9002_work-443 : eta9002_get_ocv ret : 407
[ 42.730830] ETA9002 : eta9002_get_temp_die-300 : eta9002_get_temp_die start!
[ 42.796095] eta9002_get_temp_die val: 25
[ 42.796523] ETA9002 : eta9002_work-445 : eta9002_get_temp_die : 25
[ 43.366640] bat_stat reset guage v1
[ 45.446688] bat_stat reset guage v1
[ 47.526617] bat_stat reset guage v1
[ 49.606605] bat_stat reset guage v1
root@TinaLinux:/#
root@TinaLinux:/# lsmod
Module Size Used by
vin_v4l2 223812 0
dw9714_act 3855 0
actuator 943 1 dw9714_act
ov8856_mipi 14993 0
vin_io 26106 5 vin_v4l2,dw9714_act,ov8856_mipi
videobuf2_v4l2 9304 1 vin_v4l2
videobuf2_dma_contig 8734 1 vin_v4l2
videobuf2_memops 948 1 videobuf2_dma_contig
videobuf2_core 21976 2 vin_v4l2,videobuf2_v4l2
focaltech_ts 68505 0
aic8800_fdrv 226916 0
aic8800_bsp 56102 1 aic8800_fdrv
root@TinaLinux:/#
root@TinaLinux:/# cat /proc/meminfo
MemTotal: 241276 kB
MemFree: 137760 kB
MemAvailable: 165880 kB
Buffers: 3836 kB
Cached: 28360 kB
SwapCached: 0 kB
Active: 40104 kB
Inactive: 23704 kB
Active(anon): 31624 kB
Inactive(anon): 84 kB
Active(file): 8480 kB
Inactive(file): 23620 kB
Unevictable: 0 kB
Mlocked: 0 kB
HighTotal: 0 kB
HighFree: 0 kB
LowTotal: 241276 kB
LowFree: 137760 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 31616 kB
Mapped: 16020 kB
Shmem: 104 kB
Slab: 10312 kB
SReclaimable: 3320 kB
SUnreclaim: 6992 kB
KernelStack: 832 kB
PageTables: 404 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 120636 kB
Committed_AS: 43240 kB
VmallocTotal: 770048 kB
VmallocUsed: 912 kB
VmallocChunk: 0 kB
CmaTotal: 0 kB
CmaFree: 0 kB
root@TinaLinux:/#cat /data/dlam/init.rc
on init
#看门狗喂狗定义,单位s,关闭看门狗将该宏注释掉就可以
#export WATCHDOG "10"
export TZ "GMT-8"
export LD_LIBRARY_PATH /usr/lib/dlam:/usr/lib/eyesee-mpp:/data/tts:/data/dlam:/data/ocr/lib:/data/itrans/lib:${LD_LIBRARY_PATH}
export PATH /bin:/sbin:/usr/bin:/usr/sbin:${PATH}
setrlimit 3 2048000 2048000
class_start core
class_start main
mkdir /mnt/UDISK/cache
mkdir /mnt/UDISK/download
mkdir /mnt/UDISK/cache/data
mkdir /mnt/UDISK/reciteword
mkdir /mnt/UDISK/reciteword/picture
mkdir /mnt/UDISK/reciteword/cache_json
mkdir /mnt/UDISK/privatebook
mkdir /mnt/UDISK/privatebook/book
mkdir /mnt/UDISK/DCIM
mkdir /mnt/UDISK/sql
mkdir /mnt/UDISK/coredump
service mbapp /usr/bin/mbapp
service mbcam /usr/bin/mbcam
service ST03_app /usr/bin/ST03_app
class main
user root
critical
service wifi_server /usr/bin/wifi_server > /dev/null &
class core
user root
service wpa_supplicant /usr/sbin/wpa_supplicant -iwlan0 -Dnl80211 -c /mnt/UDISK/data/wpa_supplicant.conf > /dev/null &
service ota_server /data/ota/ota_server
critical
service wav_server /usr/bin/wavmixer
oneshot
service dlamPrinter /usr/bin/dlamPrinter
class core
user root
service print_server /usr/bin/print_server
oneshot
service video_server /usr/bin/video_server
oneshot
service udhcp /sbin/udhcpc -f -i wlan0 > /dev/null &
oneshot
service udhcp_lte /sbin/udhcpc -f -i usb0 > /dev/null &
oneshot
service udhcp_lte2 /sbin/udhcpc -f -i eth0 > /dev/null &
oneshot
service bluetooth_on /etc/bluetooth/bt_init.sh start
oneshot
service bluetooth_off /etc/bluetooth/bt_init.sh stop
oneshot
service autotest /usr/bin/autotest
critical
service board_test /usr/bin/board_test
oneshot
service screen_test /usr/bin/board_test --screen_test
oneshot
#产测adb
service adbdebug /bin/adbd ZYBN1
class main
user root
critical
#用户adb
service adbd /bin/adbd
oneshot
service wavmixer /bin/wavmixer
oneshot
#service fota_download /usr/bin/fota_download
# oneshot
#service recovery /usr/bin/recovery
# oneshot
start dlamPrinter
start dlamPrinter
stop video_server
root@TinaLinux:/#
root@TinaLinux:/#
修改一下 /data/dlam/init.rc 实现 adb 功能:
sudo sed -i 's/^service adbdebug \/bin\/adbd ZYBN1/service adbdebug \/bin\/adbd/' /data/dlam/init.rc
截屏获取界面:
echo /tmp/screen2.bmp > /sys/class/disp/disp/attr/capture_dump
电脑获取界面:
adb pull /tmp/screen2.bmp
请问这个方案主控是什么,有电路照片吗。
