楼主 # 2025-04-23 15:15:24
gugou
编译问题 gitee下载下来的编译报 python错误
E:\luban-lite-master\kernel\rt-thread
scons: done reading SConscript files.
scons: Building targets ...
scons: building associated VariantDir targets: output\d13x_JLC_baremetal_bootloader
LINK output\d13x_JLC_baremetal_bootloader\images\d13x.elf
scons: *** [output\d13x_JLC_baremetal_bootloader\images\d13x.elf] TypeError : cannot concatenate 'str' and 'exceptions.WindowsError' objects
File "e:\luban-lite-master\tools\env\tools\python27\lib\site-packages\scons\SCons\Taskmaster.py", line 255, in execute self.targets[0].build()
File "e:\luban-lite-master\tools\env\tools\python27\lib\site-packages\scons\SCons\Node\__init__.py", line 766, in build
self.get_executor()(self, **kw)
File "e:\luban-lite-master\tools\env\tools\python27\lib\site-packages\scons\SCons\Executor.py", line 397, in __call__
return _do_execute_mapself._do_execute
File "e:\luban-lite-master\tools\env\tools\python27\lib\site-packages\scons\SCons\Executor.py", line 128, in execute_action_list
status = act(*args, **kw)
File "e:\luban-lite-master\tools\env\tools\python27\lib\site-packages\scons\SCons\Action.py", line 1120, in __call__
return c.__call__(self, target, source, env, *args, **kw)
File "e:\luban-lite-master\tools\env\tools\python27\lib\site-packages\scons\SCons\Action.py", line 708, in __call__
stat = self.execute(target, source, env, executor=executor)
File "e:\luban-lite-master\tools\env\tools\python27\lib\site-packages\scons\SCons\Action.py", line 952, in execute
result = spawn(shell, escape, cmd_line[0], cmd_line, ENV)
File "E:\luban-lite-master\kernel/rt-thread/tools\building.py", line 96, in spawn
print('Error removing file: ' + e)
TypeError: cannot concatenate 'str' and 'exceptions.WindowsError' objects
scons: building terminated because of errors.
楼主 #1 2025-04-23 15:17:00
gugou
Re: 编译问题 gitee下载下来的编译报 python错误
到这里请教一下,这种问题怎么解决
试了下载下来的各个项目 带 rtos不带的都是这个错误
楼主 #2 2025-04-27 12:06:51
gugou
下载安装了 python2.7.13 3. 多版本还是编译这样
不知道咋解决了
楼主 #3 2025-04-27 13:44:05
gugou
在虚拟机环境 linux 环境下安装各种软件,可以生成 img文件
曲线编译通过了
楼主 #4 2025-04-27 16:34:05
gugou
准备放弃了。。。虚拟机里可以编译 不能 menuconfig.....
#5 2025-04-27 19:52:06
海石生风
已发帖子: 790
先编译内置的工程,再来整自定义电路板吧。
现在的新手提问,普遍都是给出的信息少得可怜,一般人都懒得鸟
楼主 #6 2025-04-29 18:16:21
gugou
就是官方下载下来的sdk编译
看信息就是python有关的,环境有关
win下有问题,不知道怎么改
linux下,按步骤重新下载软件,在线
下载,可以编译,但是不同版本sdk有些可以编译过去
有些不能,都是和工具环境有关
目前在linux下,有一个版本可以编译了
先用用
个人觉得对新手不友好,层层封装,工具和源码都是太饶了,不利于推广
