楼主 # 2025-05-05 11:53:16
无情一刀
已发帖子: 723
T113 在boot阶段关闭PWM7 在内核启动打开PWM7 配置如下 但是在uboot 和linux启动都没有开启背光
现在在uboot和linux测量PD22管脚电压都是0  各位大佬 帮我看下哦
我的配置如下uboot-board.dts
&pwm7_pin_a {
        pins = "PD22";
        function = "pwm7";
        muxsel = <5>;
        drive-strength = <10>;
        bias-pull-up;
&pwm7_pin_b {
        pins = "PD22";
        muxsel = <5>;
        function = "gpio_out";
        bias-pull-up;
&pwm7 {
        pinctrl-names = "active", "sleep";
        pinctrl-0 = <&pwm7_pin_a>;
        pinctrl-1 = <&pwm7_pin_b>;
内核配置如下
pwm7_pin_a: pwm7@0 {
                pins = "PD22";
                function = "pwm7";
                muxsel = <5>;
                bias-pull-up;
        pwm7_pin_b: pwm7@1 {
                pins = "PD22";
                bias-pull-up;
&pwm7 {
