楼主 # 2025-05-09 08:49:29
yixiuge
已发帖子: 59
tplayerdemo播放一个mkv视频文件出错:
ERROR  : awplayer <ebml_read_num:403>: Invalid EBML number size tag 0x8 at pos(0x13ac0bb)
ERROR  : awplayer <ebml_peek_id:498>: Invalid id(0) at pos (0x13ac0bc)
ERROR  : awplayer <matroska_read_packet:4260>:  parse cluster error: -5
Segmentation fault
楼主 #1 2025-05-09 08:53:13
yixiuge
已发帖子: 59
Re: tplayerdemo播放一个mkv视频文件出错:
完整日志:
# tplayerdemo /mnt/exUDISK/播视频播放器闪退/播视频重启/飘花电影
piaohua.com爸爸的假期HD1280高清国语中英双字.mkv
WARNING: awplayer <cdx_log_set_level:30>: cdx Set log level to 4
[1970-01-02 23:48:06] INFO   : cedarc <CedarPluginVDInit:79>: register h264 decoder success!
[1970-01-02 23:48:06] INFO   : cedarc <CedarPluginVDInit:84>: register mjpeg decoder success!
[1970-01-02 23:48:06] INFO   : cedarc <CedarPluginVDInit:86>: register mpeg2 decoder success!
WARNING: awplayer <DlOpenPlugin:114>: Invalid plugin,function CedarPluginVDInit not found.
[1970-01-02 23:48:06] INFO   : cedarc <CedarPluginVDInit:92>: register mpeg4dx decoder success!
[1970-01-02 23:48:06] INFO   : cedarc <CedarPluginVDInit:79>: register mpeg4H263 decoder success!
[1970-01-02 23:48:06] INFO   : cedarc <CedarPluginVDInit:90>: register mpeg4Normal decoder success!
ERROR  : awplayer <DlOpenPlugin:105>: dlopen 'libawwmv3.so' fail: libawwmv3.so: cannot open shared object file: No such file or directory
[1970-01-02 23:48:06] INFO   : cedarc <CedarPluginVDInit:85>: register h265 decoder success!
INFO   : awplayer <AwParserInit:452>: aw parser init...
* This program implements a simple player, you can type commands to control the player.
* To show what commands supported, type 'help'.
dd: error writing '/dev/fb0': No space left on device
16001+0 records in
16000+0 records out
argc = 2
argv[0] = tplayerdemo
argv[1] = /mnt/exUDISK/播视频播放器闪退/播视频重启/飘花电影piaohua.com爸爸的假期HD1280高清国语中英双字.mkv
may be is one file:cut down suffix is:.mkv
find the matched type:.mkv
create player:0
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> tina_multimedia <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : tina3.5
branch: tina-dev
date  : Mon Jul 15 19:04:59 2019 +0800
Change-Id: I5f6c8a88d7b387a312b7744797a0d5f8ab07ee7a
xplayer:process message XPLAYER_COMMAND_SET_AUDIOSINK.
xplayer:process message XPLAYER_COMMAND_SET_SURFACE.
xplayer:process message XPLAYER_COMMAND_SET_SUBCTRL.
xplayer:process message XPLAYER_COMMAND_SET_DI.
create player[0]:0x80a6f0
screen width:800,screen height:1280
1:playVideo:0
before TPlayerSetDataSource,155680:/mnt/exUDISK/播视频播放器闪退/播视频重启/飘花电影piaohua.com爸爸的假期HD1280高清国语中英双字.mkv
INFO   : awplayer <XPlayerThread:1838>: process message XPLAYER_COMMAND_SET_SOURCE.
xplayer:process message XPLAYER_COMMAND_SET_SOURCE.
xplayer:process message XPLAYER_COMMAND_PREPARE.
INFO   : awplayer <ParserTypeGuess:690>: I think it's something about 'mkv', type id(1)
WARNING: awplayer <matroska_add_stream:1233>: cannot support this atom: 54b2
warning: unknown callback from Tinaplayer.
[1970-01-02 23:48:06] INFO   : cedarc <log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
[1970-01-02 23:48:06] ERROR  : cedarc <DebugCheckConfig:302>: now cedarc log level:5
setDataSource end
INFO   : awplayer <XPlayerThread:2137>: xxxxxxxxxx video size: width = 1280, height = 720
*****tplayer:video width = 1280,height = 720
TPLAYER_NOTIFY_PREPARED,has prepared.
TPlayerPrepare end
xplayer:process message XPLAYER_COMMAND_START.
(Allwinner Audio Middle Layer),line(971) : Create Decoder!!=====
(Allwinner Audio Middle Layer),line(603) : AudioDec_Installaudiolib ok
(Allwinner Audio Middle Layer),line(606) : audio decoder init start ...
(AllwinnerAlibs),line(50) :
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Audio <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
tag   : audiocodec-v1.2
branch: new
commit: 3ba65962c01cbf1280ddda19d843009b6ef8ce85
date  : Tue Jan 8 16:25:27 2019 +0800
(AllwinnerAlibs),line(700) : ----Loading so success!
(AllwinnerAlibs),line(902) : *************pAudioStreamInfo start******************
(AllwinnerAlibs),line(903) : eCodecFormat         :id(3), name(mpeg layer-III)
(AllwinnerAlibs),line(904) : eSubCodecFormat      :0
(AllwinnerAlibs),line(905) : nChannelNum          :2
(AllwinnerAlibs),line(906) : nBitsPerSample       :16
(AllwinnerAlibs),line(907) : nSampleRate          :48000
(AllwinnerAlibs),line(908) : nAvgBitrate          :0
(AllwinnerAlibs),line(909) : nMaxBitRate          :0
(AllwinnerAlibs),line(910) : nFileSize            :0
(AllwinnerAlibs),line(911) : eAudioBitstreamSource:0
(AllwinnerAlibs),line(912) : eDataEncodeType      :1
(AllwinnerAlibs),line(913) : nCodecSpecificDataLen:0
(AllwinnerAlibs),line(914) : pCodecSpecificData   :(nil)
(AllwinnerAlibs),line(915) : nFlags               :0
(AllwinnerAlibs),line(916) : nBlockAlign          :0
(AllwinnerAlibs),line(917) : *************pAudioStreamInfo end  ******************
(AllwinnerAlibs),line(27) : init successs...
(Allwinner Audio Middle Layer),line(614) : AUDIO DECODE INIT OK...0
INFO   : audioRender <handleStart:295>: audio render process start message.
started.
WARNING: awplayer <callbackProcess:3733>: message 0x40b not handled.
****player(0x80b9d8): first audio pts = 24000*****
ERROR  : awplayer <__LayerQueueBuffer:934>: *** picNode is full when queue buffer
*****tplayer:video decoded width = 1280,height = 720
*****tplayerdemo:video decoded width = 1280,height = 720real set to display rect:w = 1280,h = 720
INFO   : awplayer <callbackProcess:3578>: xxxxxxxxxx video size : width = 2560, height = 1440
*****tplayer:video width = 2560,height = 1440
****player(0x80b9d8): first video pts = 0*****
WARNING: audioRender <checkSampleRate:647>: sample rate change from 48000 to 48000.
WARNING: audioRender <checkSampleRate:649>: channel num change from 2 to 2.
WARNING: audioRender <checkSampleRate:651>: bitPerSample num change from 16 to 16.
WARNING: audioRender <checkSampleRate:653>: if need direct out put flag change from 0 to 1.
WARNING: audioRender <checkSampleRate:655>: data type change from 1 to 1.
WARNING: audioRender <checkSampleRate:674>: start sound devide again because samplaRate or channelNum change
[1970-01-02 23:48:06] ERROR  : fbm.c <FbmReturnPicture:1043>: invalid frame status, a picture being returned,                 but bUsedByRender=0, bInValidPictureQueue=0, bAlreadyDisplayed=0.
[1970-01-02 23:48:06] ERROR  : fbm.c <FbmReturnPicture:1044>: **picture[0xb22018d8],id[9]
[1970-01-02 23:48:06] WARNING: cedarc <ReturnPicture:1700>: FbmReturnPicture return fail,            it means the picture being returned it not one of this FBM.
Got signal 11, exiting ...
WARNING: awplayer <XPlayerDestroy:350>: XPlayerDestroy
WARNING: awplayer <XPlayerReset:1005>: reset...
xplayer:process message XPLAYER_COMMAND_RESET.
