楼主 # 2025-07-16 07:31:17
david
已发帖子: 398
RV1106移植DVP摄像头,好像还差一点
摄像头识别没问题,好像也能抓数据,数据怎么样还没看。
目前问题是 v4l2-ctl --list-devices 时报错
[ 136.480547] rkcif-dvp: get_remote_sensor: remote pad is null
[ 136.480585] rkcif-dvp: rkcif_update_sensor_info: stream[1] get remote sensor_sd failed!
[ 136.480605] rkcif_scale_ch1: update sensor info failed -19
应该会是哪方面的问题?
PS. 查看拓扑结构 media-ctl -d /dev/media0 -p
Media controller API version 5.10.160
Media device information
driver rkcif
model rkcif-dvp
serial
bus info
hw revision 0x0
driver version 5.10.160
Device topology
  • entity 1: stream_cif_dvp_id0 (1 pad, 1 link)
    type Node subtype V4L flags 0
    device node name /dev/video0
    pad0: Sink
    <- "m00_f_ov5647 1-0036":0 [ENABLED]
  • entity 5: stream_cif_dvp_id1 (1 pad, 0 link)
    device node name /dev/video1
    pad0: Sink
  • entity 9: stream_cif_dvp_id2 (1 pad, 0 link)
    device node name /dev/video2
    pad0: Sink
  • entity 13: stream_cif_dvp_id3 (1 pad, 0 link)
    device node name /dev/video3
    pad0: Sink
  • entity 17: rkcif_scale_ch0 (1 pad, 0 link)
    device node name /dev/video4
    pad0: Sink
  • entity 21: rkcif_scale_ch1 (1 pad, 0 link)
    device node name /dev/video5
    pad0: Sink
  • entity 25: rkcif_scale_ch2 (1 pad, 0 link)
    device node name /dev/video6
    pad0: Sink
  • entity 29: rkcif_scale_ch3 (1 pad, 0 link)
    device node name /dev/video7
    pad0: Sink
  • entity 33: rkcif_tools_id0 (1 pad, 0 link)
    device node name /dev/video8
    pad0: Sink
  • entity 37: rkcif_tools_id1 (1 pad, 0 link)
    device node name /dev/video9
    pad0: Sink
  • entity 41: rkcif_tools_id2 (1 pad, 0 link)
    device node name /dev/video10
    pad0: Sink
  • entity 45: m00_f_ov5647 1-0036 (1 pad, 1 link)
    type V4L2 subdev subtype Sensor flags 0
    device node name /dev/v4l-subdev0
    pad0: Source
    [fmt:SBGGR10_1X10/2592x1944@10000/150000 field:none colorspace:raw]
    -> "stream_cif_dvp_id0":0 [ENABLED]
  • entity 47: rkcif-dvp-sof (0 pad, 0 link)
    type V4L2 subdev subtype Unknown flags 0
    device node name /dev/v4l-subdev1
最近编辑记录 david (2025-07-16 07:32:12)
#1 2025-07-21 09:45:17
已发帖子: 649
Re: RV1106移植DVP摄像头,好像还差一点
这个是设备数没有配好。摄像头接口的remote endpoint要链接 I2C sensor的节点 。I2C sensor的节点也要链接到这个摄像头接口的一个port
