参照文档进行操作,结果再也无法烧录了,也无法运行。
Pre-boot 也看不到输出了 SPL也无法执行。密钥肯定正确,不知道哪个环节出了问题,请玩过的大佬指点一下,谢谢!
keys文件夹下的文件已经正确生成,镜像也打包成功,但是无法运行。
镜像配置文件
"spi-nor": { // Device, The name should be the same with string in image:info:media:type
"size": "8m", // Size of SPI NOR
"partitions": {
"spl": { "size": "256k" },
"os": { "size": "5m" },
"rootfs": { "size": "2m" }
"image": {
"info": { // Header information about image
"platform": "d13x",
"product": "wif_clock",
"version": "1.0.0",
"media": {
"type": "spi-nor",
"device_id": 0,
"updater": { // Image writer which is downloaded to RAM by USB
"psram": {
"file": "usbupg-psram-init.aic",
"attr": ["required", "run"],
"ram": "0x30044000"
"spl": {
"file": "bootloader.aic",
"ram": "0x30100000"
"target": { // Image components which will be burn to device's partitions
"spl": {
"file": "bootloader.aic.enc",
"attr": ["mtd", "required"],
"part": ["spl"]
"os": {
"file": "d13x_os.itb.enc",
"part": ["os"]
"rootfs": {
"file": "data.fatfs.enc",
"attr": ["mtd", "optional"],
"part": ["rootfs"]
"pre-process": { // Pre-proccess to generate image components from raw data
"aicimage": { // Create aic boot image
"usbupg-psram-init.aic": { // No loader, only PreBootProgram to initialize PSRAM
"head_ver": "0x00010001",
"resource": {
"private": "pbp_cfg.bin",
"pubkey": "keys/rsa_public_key.der",
"pbp": "d13x.pbp",
"encryption": {
"algo": "aes-128-cbc",
"key": "keys/aes-128-cbc-key.bin",
"iv": "keys/aes-128-cbc-iv.bin",
"ssk_derived_key": "true",
"signature": {
"algo": "rsa,2048",
"privkey": "keys/rsa_private_key.der",
"pbp_ext.aic": {
"resource": {
"pbp": "d13x.pbp",
"encryption": {
"signature": {
"algo": "rsa,2048",
// combine to use with loader.aic
"with_ext": "true",
"loader.aic": {
"loader": {
"file": "bootloader.bin",
"load address": "CONFIG_AIC_BOOTLOADER_LOAD_BASE",
"entry point": "CONFIG_AIC_BOOTLOADER_TEXT_BASE", // 256 byte aic header
"resource": {
"encryption": {
"signature": {
"algo": "rsa,2048",
"concatenate": { // cat files in order
"bootloader.aic": ["pbp_ext.aic", "loader.aic"],
"itb": { // Create itb image from its
"d13x_os.itb": {
"its": "d13x_os.its"
"data_crypt": {
"bootloader.aic.enc": {
"algo": "spienc-aes-128-ecb",
"file": "bootloader.aic", // File to be encrypted
"key": "keys/spi_aes.key", // Keys the same in eFuse
"nonce": "keys/spi_nonce.key", // Nonce the same in eFuse
"tweak": "0",
"env.bin.enc": {
"file": "env.bin", // File to be encrypted
"tweak": "0",
"d13x_os.itb.enc": {
"file": "d13x_os.itb", // File to be encrypted
"tweak": "0",
"data.fatfs.enc": {
"file": "data.fatfs", // File to be encrypted
"tweak": "0",
}离线
没人测试过官方提供的加密方案吗?
@xfdr0805
spienc 的量产安全方案中,是不需要加下面这段代码的
"encryption": {
@gemrisk
一开始我是没加,但是烧录后不能运行,参照demo就加上了,结果还是不能运行。
我只要固件加密还不需要硬件授权认证,SPI ENC [KEY NONCE ROTPK] 已经烧录好了。
