楼主 # 2025-09-17 09:57:12
qsy_qsy
&usbphy { status = "okay"; }; 这个一打开 内核就无线重启 为什么啊 我想打开USB虚拟网口的
U-Boot 2024.04-rc5-dirty (Sep 14 2025 - 21:10:55 +0800) Allwinner Technology
CPU:   Allwinner F Series (SUNIV)
Model: F1C200s LCOS
DRAM:  64 MiB
Core:  29 devices, 17 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
395 bytes read in 3 ms (127.9 KiB/s)
## Executing script at 81900000
5216296 bytes read in 220 ms (22.6 MiB/s)
6611 bytes read in 3 ms (2.1 MiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x4f9828 ]
## Flattened Device Tree blob at 81800000
   Booting using the fdt blob at 0x81800000
Working FDT set to 81800000
   Loading Device Tree to 82dfb000, end 82dff9d2 ... OK
Working FDT set to 82dfb000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.10.0-dirty (qsy@qsy-virtual-machine) (arm-none-eabi-gcc (GNU Arm Embedded Toolchain 10.3-2021.10) 10.3.1 20210824 (release), GNU ld (GNU Arm Embedded Toolchain 10.3-2021.10) 2.36.1.20210621) #6 Wed Sep 17 09:27:54 CST 2025
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] OF: fdt: Machine model: F1C200s LCOS
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x83000000 on node -1
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x0000000083ffffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x0000000083ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000083ffffff]
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[    0.000000] Unknown kernel command line parameters "earlyprintk", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16384
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 37332K/65536K available (7484K kernel code, 713K rwdata, 2216K rodata, 260K init, 248K bss, 11820K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000010] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000133] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000866] Console: colour dummy device 80x30
[    0.001008] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070273] CPU: Testing write buffer coherency: ok
[    0.070517] pid_max: default: 32768 minimum: 301
[    0.071081] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.071158] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.077838] Setting up static identity map for 0x80008400 - 0x80008458
[    0.080333] devtmpfs: initialized
[    0.085431] VFP support v0.3: not present
[    0.086083] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.086170] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.090096] pinctrl core: initialized pinctrl subsystem
[    0.095174] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.098151] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.100705] thermal_sys: Registered thermal governor 'step_wise'
[    0.117587] SCSI subsystem initialized
[    0.120627] usbcore: registered new interface driver usbfs
[    0.120772] usbcore: registered new interface driver hub
[    0.120968] usbcore: registered new device driver usb
[    0.121520] mc: Linux media interface: v0.10
[    0.121710] videodev: Linux video capture interface: v2.00
[    0.122005] pps_core: LinuxPPS API ver. 1 registered
[    0.122035] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.122101] PTP clock support registered
[    0.123918] Advanced Linux Sound Architecture Driver Initialized.
[    0.127320] clocksource: Switched to clocksource timer
[    0.175031] NET: Registered PF_INET protocol family
[    0.175698] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.177691] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.177807] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.177860] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.177922] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.177992] TCP: Hash tables configured (established 1024 bind 1024)
[    0.178268] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.178351] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.178919] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.180905] RPC: Registered named UNIX socket transport module.
[    0.180957] RPC: Registered udp transport module.
[    0.180975] RPC: Registered tcp transport module.
[    0.180988] RPC: Registered tcp-with-tls transport module.
[    0.181002] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.184590] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.187148] NFS: Registering the id_resolver key type
[    0.187416] Key type id_resolver registered
[    0.187453] Key type id_legacy registered
[    0.187880] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.187928] io scheduler mq-deadline registered
[    0.187952] io scheduler kyber registered
[    0.188084] io scheduler bfq registered
[    0.485389] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.512803] CAN device driver interface
[    0.515314] UDC core: g_ether: couldn't find an available UDC
[    0.515383] gadgetfs: USB Gadget filesystem, version 24 Aug 2004
[    0.515508] UDC core: g_cdc: couldn't find an available UDC
[    0.516539] i2c_dev: i2c /dev entries driver
[    0.521319] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.525564] usbcore: registered new interface driver usbhid
[    0.525607] usbhid: USB HID core driver
[    0.531139] NET: Registered PF_PACKET protocol family
[    0.531191] can: controller area network core
[    0.531371] NET: Registered PF_CAN protocol family
[    0.531404] can: raw protocol
[    0.531431] can: broadcast manager protocol
[    0.531463] can: netlink gateway - max_hops=1
[    0.531884] Key type dns_resolver registered
[    0.582312] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.595963] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.597598] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
[    0.600113] printk: legacy console [ttyS0] disabled
[    0.621688] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 116, base_baud = 6250000) is a 16550A
[    0.621863] printk: legacy console [ttyS0] enabled
[    1.205086] suniv-f1c100s-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
[    1.215053] sun6i-spi 1c05000.spi: Failed to request TX DMA channel
[    1.221516] sun6i-spi 1c05000.spi: Failed to request RX DMA channel
[    1.232107] usb_phy_generic usb_phy_generic.0.auto: dummy supplies not allowed for exclusive requests (id=vbus)
[    1.246270] g_ether gadget.0: HOST MAC 76:91:e2:fd:7b:5b
[    1.251780] g_ether gadget.0: MAC c2:b5:d0:26:14:6▒
U-Boot SPL 2024.04-rc5-dirty (Sep 14 2025 - 21:10:55 +0800)
DRAM: 64 MiB
Trying to boot from MMC1
Model: F1C200s LCOS
DRAM:  64 MiB
MMC:   mmc@1c0f000: 0
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Scanning mmc 0:1...
