楼主 # 2025-10-29 16:07:31
xsx_kair
已发帖子: 34
T113移植ST7789T3,能不能指点一下,没输出
&spi1 {
	clock-frequency = <100000000>;
	pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
	pinctrl-1 = <&spi1_pins_c>;
	spi_slave_mode = <0>;
	spi1_cs_number = <1>;
        spi1_cs_bitmap = <1>;
    	spi_dbi_enable = <0>;
	spi_board1@0 {
		device_type = "spi_board1";
		compatible = "rohm,dh2228fv";
		spi-max-frequency = <0x5f5e100>;
		reg = <0x0>;
		spi-rx-bus-width = <0x4>;
		spi-tx-bus-width = <0x4>;
		status = "disabled";
	st7789v@0 {
        	compatible = "sitronix,st7789v";
        	reg = <0>;
       		spi-max-frequency = <60000000>;
        	rotate = <0>;
        	bgr;
        	fps = <60>;
        	buswidth = <8>;
        	reset = <&pio PD 15 GPIO_ACTIVE_LOW>;
        	dc = <&pio PD 14 GPIO_ACTIVE_LOW>;
			latch = <&pio PD 16 GPIO_ACTIVE_HIGH>;
        	debug = <1>;
#1 2026-01-04 19:17:25
number007cool
Re: T113移植ST7789T3,能不能指点一下,没输出
我是这样写的,没毛病:
&spi1 {
    clock-frequency = <15000000>;
    pinctrl-0 = <&spi1_pins_a>;
    cs-gpios = <&pio 3 10 GPIO_ACTIVE_LOW>; // 可选:指定 CS 脚,如 PD10
    bias-pull-up;
     display@0{
        reg = <0>;
        spi-max-frequency = <15000000>;//96000000
        spi-cpol;
        spi-cpha;
        rotate = <180>;
       // width = <320>;
        // height = <240>;
        fps = <10>;
        buswidth = <8>;
        dc-gpios = <&pio 3 14 GPIO_ACTIVE_HIGH>;  // Pd14  dc
        reset-gpios = <&pio 3 15 GPIO_ACTIVE_HIGH>; // Pd15
        //led-gpios = <&pio 0 0 GPIO_ACTIVE_LOW>;  // PA0
        debug = <0x0>;
};  将SPI频率和帧率调低点
#2 2026-01-04 19:18:02
number007cool
然后staging driver 开启7789的驱动。
