楼主 # 2025-12-08 10:32:45
TivonLiu
已发帖子: 53
T113s3 gpio-keys 驱动,上拉配置无效
根节点下添加
key-1 {
        compatible = "gpio-keys";
        autorepeat;
      //pinctrl-names = "default";
      //pinctrl-0 = <&user_pin_a>;   //开启这个上拉有效,但是不会出现event节点
        key1{
            label = "KEY 1";
            linux,code = <355>;
           gpios = <&pio PD 16 (GPIO_ACTIVE_LOW)>;
&pio结点下添加
    user_pin_a: user_pin_a{
        pins = "PD16";
        function = "gpio_in";
        bias-pull-up;
开启上拉,event结点就消失了,但是上拉有效,屏蔽掉pinctrl-0 = <&user_pin_a>上拉就失效了,但是能出event结点,但是我想开启上拉同时又有结点出来就不知道咋办了。
楼主 #1 2025-12-09 20:51:36
TivonLiu
已发帖子: 53
Re: T113s3 gpio-keys 驱动,上拉配置无效
这样改驱动也不行
       if (flags & OF_GPIO_PULL_UP) {
        dev_info(dev,"gpio_keys.c pullup gpio is %d\n",gpionum);
            config_set = pinconf_to_config_packed(SUNXI_PINCFG_TYPE_PUD, 1);
            pinctrl_gpio_set_config(gpionum, config_set);
楼主 #2 2025-12-09 21:14:32
TivonLiu
已发帖子: 53
SUNXI_PINCFG_TYPE_PUD 要换成 PIN_CONFIG_BIAS_PULL_UP
