楼主 #1 2018-06-30 19:47:41
zhuacai
已发帖子: 234
关于编译连接出现undefined reference to `xxx' 到底是没找到xxx涵数,还是找不到库呢,像这种问题如何解决?
arm-linux-g++ -lts -Wl,-O1 -Wl,-rpath,/usr/local/qt/lib -o demo_qzxing CameraImageWrapper.o qzxing.o imagehandler.o ResultPointCallback.o ResultPoint.o Result.o ReaderException.o Reader.o NotFoundException.o MultiFormatReader.o LuminanceSource.o FormatException.o Exception.o DecodeHints.o BinaryBitmap.o Binarizer.o BarcodeFormat.o AztecReader.o AztecDetectorResult.o StringUtils.o Str.o PerspectiveTransform.o IllegalArgumentException.o HybridBinarizer.o GridSampler.o GreyscaleRotatedLuminanceSource.o GreyscaleLuminanceSource.o GlobalHistogramBinarizer.o EdgeDetector.o DetectorResult.o DecoderResult.o Counted.o CharacterSetECI.o BitSource.o BitMatrix.o BitArray.o Array.o WhiteRectangleDetector.o MonochromeRectangleDetector.o ReedSolomonException.o ReedSolomonDecoder.o GenericGFPoly.o GenericGF.o DataMatrixReader.o UPCEReader.o UPCEANReader.o UPCAReader.o OneDResultPoint.o OneDReader.o MultiFormatUPCEANReader.o MultiFormatOneDReader.o ITFReader.o EAN13Reader.o EAN8Reader.o Code128Reader.o Code39Reader.o QRCodeReader.o QREdgeDetector.o MultipleBarcodeReader.o GenericMultipleBarcodeReader.o ByQuadrantReader.o QRCodeMultiReader.o MultiFinderPatternFinder.o MultiDetector.o AztecDecoder.o AztecDetector.o DataMatrixVersion.o DataMatrixDecoder.o DataMatrixBitMatrixParser.o DataMatrixDataBlock.o DataMatrixDecodedBitStreamParser.o DataMatrixCornerPoint.o DataMatrixDetector.o DataMatrixDetectorException.o DataMatrixMonochromeRectangleDetector.o QRBitMatrixParser.o QRDataBlock.o QRDataMask.o QRDecodedBitStreamParser.o QRDecoder.o QRMode.o QRAlignmentPattern.o QRAlignmentPatternFinder.o QRDetector.o QRFinderPattern.o QRFinderPatternFinder.o QRFinderPatternInfo.o QRVersion.o QRFormatInformation.o QRErrorCorrectionLevel.o main.o mainwindow.o moc_imagehandler.o moc_qzxing.o moc_mainwindow.o -L/usr/local/tslib/lib -L/usr/local/qt/lib -lQtDeclarative -L/usr/local/qt/lib -L/usr/local/tslib/lib -lQtScript -lQtSql -lQtGui -lQtNetwork -lQtCore -lpthread
AztecDecoder.o: In function `(anonymous namespace)::add(std::string&, unsigned char)':
AztecDecoder.cpp:(.text+0x38): undefined reference to `libiconv_open'
AztecDecoder.cpp:(.text+0x54): undefined reference to `libiconv'
AztecDecoder.cpp:(.text+0x5c): undefined reference to `libiconv_close'
QRDecodedBitStreamParser.o: In function `zxing::qrcode::DecodedBitStreamParser::append(std::string&, unsigned char const, unsigned int, char const)':
QRDecodedBitStreamParser.cpp:(.text+0x54): undefined reference to `libiconv_open'
QRDecodedBitStreamParser.cpp:(.text+0xc0): undefined reference to `libiconv'
QRDecodedBitStreamParser.cpp:(.text+0xd0): undefined reference to `libiconv_close'
QRDecodedBitStreamParser.cpp:(.text+0x10c): undefined reference to `libiconv_close'
make: *** [demo_qzxing] Error 1
#2 2018-06-30 20:09:39
Re: 关于编译连接出现undefined reference to `xxx' 到底是没找到xxx涵数,还是找不到库呢,像这种问题如何解决?
缺libiconv字符转码库。
楼主 #3 2018-06-30 20:40:50
zhuacai
已发帖子: 234
缺libiconv字符转码库。
晕哥,你是怎么断判缺少库的
#4 2018-06-30 21:29:09
根据经验,QRDecodedBitStreamParser.cpp:(.text+0x10c): undefined reference to `libiconv_close'
这种链接错误一看就是找不到链接对象。
