https://www.cairographics.org/Xlib/
https://www.cypherpunk.at/files/2014/11/cairo_xlib_simple.c
#include <X11/Xlib.h>
#include <X11/Xatom.h>
#include <X11/Xutil.h>
#include <cairo.h>
#include <cairo-xlib.h>
#include <stdio.h>
#include <stdlib.h>
/*! Simple Cairo/Xlib example.
* @author Bernhard R. Fischer, 2048R/5C5FFD47 <bf@abenteuerland.at>.
* @version 2014110801
* Compile with
* gcc -Wall $(pkg-config --libs --cflags cairo x11) -o cairo_xlib_simple cairo_xlib_simple.c
/*! Check for Xlib Mouse/Keypress events. All other events are discarded.
* @param sfc Pointer to Xlib surface.
* @param block If block is set to 0, this function always returns immediately
* and does not block. if set to a non-zero value, the function will block
* until the next event is received.
* @return The function returns 0 if no event occured (and block is set). A
* positive value indicates that a key was pressed and the X11 key symbol as
* defined in <X11/keysymdef.h> is returned. A negative value indicates a mouse
* button event. -1 is button 1 (left button), -2 is the middle button, and -3
* the right button.
int cairo_check_event(cairo_surface_t *sfc, int block)
char keybuf[8];
KeySym key;
XEvent e;
for (;;)
if (block || XPending(cairo_xlib_surface_get_display(sfc)))
XNextEvent(cairo_xlib_surface_get_display(sfc), &e);
switch (e.type)
case ButtonPress:
return -e.xbutton.button;
case KeyPress:
XLookupString(&e.xkey, keybuf, sizeof(keybuf), &key, NULL);
return key;
default:
fprintf(stderr, "Dropping unhandled XEevent.type = %d.\n", e.type);
/*! Open an X11 window and create a cairo surface base on that window.
* @param x Width of window.
* @param y Height of window.
* @return Returns a pointer to a valid Xlib cairo surface. The function does
* not return on error (exit(3)).
cairo_surface_t *cairo_create_x11_surface0(int x, int y)
Display *dsp;
Drawable da;
int screen;
cairo_surface_t *sfc;
if ((dsp = XOpenDisplay(NULL)) == NULL)
exit(1);
screen = DefaultScreen(dsp);
da = XCreateSimpleWindow(dsp, DefaultRootWindow(dsp), 0, 0, x, y, 0, 0, 0);
XSelectInput(dsp, da, ButtonPressMask | KeyPressMask);
XMapWindow(dsp, da);
sfc = cairo_xlib_surface_create(dsp, da, DefaultVisual(dsp, screen), x, y);
cairo_xlib_surface_set_size(sfc, x, y);
return sfc;
/*! Destroy cairo Xlib surface and close X connection.
void cairo_close_x11_surface(cairo_surface_t *sfc)
Display *dsp = cairo_xlib_surface_get_display(sfc);
cairo_surface_destroy(sfc);
XCloseDisplay(dsp);
int main(int argc, char **argv)
cairo_t *ctx;
sfc = cairo_create_x11_surface0(500, 500);
ctx = cairo_create(sfc);
cairo_set_source_rgb(ctx, 1, 1, 1);
cairo_paint(ctx);
cairo_move_to(ctx, 20, 20);
cairo_line_to(ctx, 200, 400);
cairo_line_to(ctx, 450, 100);
cairo_line_to(ctx, 20, 20);
cairo_set_source_rgb(ctx, 0, 0, 1);
cairo_fill_preserve(ctx);
cairo_set_line_width(ctx, 5);
cairo_set_source_rgb(ctx, 1, 1, 0);
cairo_stroke(ctx);
cairo_destroy(ctx);
cairo_check_event(sfc, 1);
cairo_close_x11_surface(sfc);
包含代码可能需要修改一点点:
#include <cairo/cairo.h>
#include <cairo/cairo-xlib.h>安装cairo库:
sudo apt-get install libcairo2-dev
编译指令:
gcc -o cairo_xlib_simple cairo_xlib_simple.c -lcairo -lX11
