楼主 #1 2019-08-29 11:36:53
cdxs
【求助】phoenixSuit烧写固件报错
给全志R328烧写固件,进度条一直没动,查看log如下,最后一行提示DRAM初始化失败,请问是什么原因?该怎么解决呢
sunxi flash init ok
Loading Environment from SUNXI_FLASH... OK
no secure os for keybox operation
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
(weak)update dtb dram start
update dtb dram  end
[00.950]update dts
root_partition is rootfs
set root to /dev/nand0p3
[00.956]update part info
NAND_UbootExit
[00.960]NB1: NAND_LogicExit
nand release dma:47fb5160
nand release dma:0
[38]HELLO! BOOT0 is starting Mar 19 2019 21:03:11!
[43]BOOT0 commit : 435c4ed154fd0d0a20e4625ca854c487ab332a03
[80]set pll start
[83]set pll end
[84]board init ok
[86]rtc[2] value = 0x5aa5a55a
[89]eraly jump fel
[2473]fes begin
[2475]set pll start
[2478]set pll end
[2480]board init ok
[2482]beign to init dram
[2484]the chip id is 0x3
[2486]ic cant match axp, please check...
[2490]init dram fail
最近编辑记录 cdxs (2019-08-29 11:37:33)
#2 2019-08-29 11:47:51
Re: 【求助】phoenixSuit烧写固件报错
init dram fail, dram 初始化错误, 看下是不是硬件布线,dram 电压, 波纹等硬件问题导致的。
也可以通过降低 DRAM 频率, 但是这个 boot0 貌似没有源码吧, 只能反编译改了 ;(
beign to init dram 强迫症看到这个单词真是受不了.
楼主 #3 2019-08-29 16:57:50
cdxs
谢谢晕哥回复,经过检查发现是芯片型号选择错误,R328的dram有 128/64 两个版本
