楼主 #1 2019-10-08 09:14:00
我思故我在
已发帖子: 244
ubuntu18.04 nvidia显卡GPU编程
  1. 安装nvidia开发工具
    https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&target_distro=Ubuntu&target_version=1804&target_type=deblocal
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-ubuntu1804.pin
sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
wget http://developer.download.nvidia.com/compute/cuda/10.1/Prod/local_installers/cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00_1.0-1_amd64.deb
sudo dpkg -i cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00_1.0-1_amd64.deb
sudo apt-key add /var/cuda-repo-10-1-local-10.1.243-418.87.00/7fa2af80.pub
sudo apt-get update
sudo apt-get -y install cuda
  1. 测试代码:
    https://linuxhint.com/gpu-programming-cpp/
    https://eslinux.com/programacion-gpu-cuda/
gpu-example.cu:
#include "cuda_runtime.h"
#include <stdio.h>
#include <stdlib.h>
#include <iostream>
#include <cstdio>
#include <chrono>
typedef std::chrono::high_resolution_clock Clock;
#define ITER 65535
// CPU version of the vector add function
void vector_add_cpu(int *a, int *b, int *c, int n) {
    int i;
    // Add the vector elements a and b to the vector c
    for (i = 0; i < n; ++i) {
    c[i] = a[i] + b[i];
// GPU version of the vector add function
__global__ void vector_add_gpu(int *gpu_a, int *gpu_b, int *gpu_c, int n) {
    int i = threadIdx.x;
    // No for loop needed because the CUDA runtime
    // will thread this ITER times
    gpu_c[i] = gpu_a[i] + gpu_b[i];
int main() {
    int *a, *b, *c;
    int *gpu_a, *gpu_b, *gpu_c;
    a = (int *)malloc(ITER * sizeof(int));
    b = (int *)malloc(ITER * sizeof(int));
    c = (int *)malloc(ITER * sizeof(int));
    // We need variables accessible to the GPU,
    // so cudaMallocManaged provides these
    cudaMallocManaged(&gpu_a, ITER * sizeof(int));
    cudaMallocManaged(&gpu_b, ITER * sizeof(int));
    cudaMallocManaged(&gpu_c, ITER * sizeof(int));
    for (int i = 0; i < ITER; ++i) {
        a[i] = i;
        b[i] = i;
        c[i] = i;
    // Call the CPU function and time it
    auto cpu_start = Clock::now();
    vector_add_cpu(a, b, c, ITER);
    auto cpu_end = Clock::now();
    std::cout << "vector_add_cpu: "
    << std::chrono::duration_cast<std::chrono::nanoseconds>(cpu_end - cpu_start).count()
    << " nanoseconds.\n";
    // Call the GPU function and time it
    // The triple angle brakets is a CUDA runtime extension that allows
    // parameters of a CUDA kernel call to be passed.
    // In this example, we are passing one thread block with ITER threads.
    auto gpu_start = Clock::now();
    vector_add_gpu <<<1, ITER>>> (gpu_a, gpu_b, gpu_c, ITER);
    cudaDeviceSynchronize();
    auto gpu_end = Clock::now();
    std::cout << "vector_add_gpu: "
    << std::chrono::duration_cast<std::chrono::nanoseconds>(gpu_end - gpu_start).count()
    // Free the GPU-function based memory allocations
    cudaFree(a);
    cudaFree(b);
    cudaFree(c);
    // Free the CPU-function based memory allocations
    free(a);
    free(b);
    free(c);
Makefile:
INC=-I/usr/local/cuda/include
NVCC=/usr/local/cuda/bin/nvcc
NVCC_OPT=-std=c++11
all:
    $(NVCC) $(NVCC_OPT) gpu-example.cu-o gpu-example
clean:
    -rm -f gpu-example
  1. 运行:
gpu-test$ ./gpu-example
vector_add_cpu: 1370132 nanoseconds.
vector_add_gpu: 6445 nanoseconds.
最近编辑记录 我思故我在 (2019-10-08 09:21:32)
楼主 #2 2019-10-08 09:20:41
我思故我在
已发帖子: 244
Re: ubuntu18.04 nvidia显卡GPU编程
链接: C ++中的CUDA GPU编程教程
引言
在本指南中,我们将探讨使用C ++编程的GPU的强大功能。
开发人员可以期望使用C ++具有令人难以置信的性能,
并且使用低级语言访问GPU的强大功能可以生成一些当前可用的最快的计算。
要求条件
虽然任何能够运行现代版本Linux的计算机都可以支持C ++编译器,
但您将需要基于NVIDIA的显卡。如果没有GPU,
则可以使用Amazon Web Services或您喜欢的任何其他云服务提供商来激活实例。
如果决定使用物理机,请确保已安装专有的NVDIA驱动程序。您可以在以下位置找到有关此信息:
https://linuxhint.com/install-nvidia-drivers-linux/
除了驱动程序,您还需要CUDA工具包。在此示例中,我们将使用Ubuntu 16.04 LTS,
但是大多数主要Linux发行版都有可供下载的版本,可以在以下链接中找到:
对于Ubuntu,您应该选择下载.deb文件。下载的文件没有扩展名.deb,但是您可以轻松地重命名它。
然后,您可以使用以下命令进行安装:
sudo dpkg -i package-name.deb
可能会询问您是否要安装GPG密钥,如果要安装,请按照提供的说明进行安装。
完成后,更新您的存储库:
sudo apt-get update
sudo apt-get install cuda -y
完成后,建议您重新启动系统以确保所有内容均已正确加载。
GPU开发的好处
CPU处理许多不同的输入和输出,并且包含各种功能,
不仅可以处理各种必需的程序,而且还可以管理各种硬件配置。
它们还处理内存,缓存,系统总线,分段和I / O功能,使它们成为所有任务的服务器。
GPU相反,它们包含许多单独的处理器,它们专注于非常简单的数学函数。
因此,它们处理任务的速度比CPU快许多倍。通过专门研究标量函数(接受一个或多个输入并返回单个输出的函数),
它们以牺牲极度专业化为代价来实现极高的性能。
样例代码
在此示例中,我们将添加两个向量。添加一个带有CPU的版本和一个带有GPU的版本以进行速度比较。
gpu-example.cu 文件包含以下代码:
#include <stdio.h>
#include <stdlib.h>
#include <iostream>
#include <cstdio>
#include <chrono>
#define ITER 65535
// Version CPU de la función suma de vectores
    int i;
    c[i] = a[i] + b[i];
// Versión GPU de la función suma de vectores
    // No es necesario el loop for por que el runtime de CUDA
    // maneja estos hilos ITER veces
int main() {
    int *a, *b, *c;
    // Necesitamos variables accesibles en CUDA,
    // para eso cudaMallocManaged nos las provee
        a[i] = i;
        b[i] = i;
        c[i] = i;
    // Llama a la versión CPU y la temporiza
    // Llama a la versión GPU y la temporiza
    // Los triples <> es una extensión del runtime CUDA que permite
    // que los parametros de una llamada al kernel CUDA sean pasados
    // En este ejemplo estamos pasando un thread block con ITER threads
    // Libere la memoria basada en la función GPU allocations
    cudaFree(a);
    cudaFree(b);
    cudaFree(c);
    // Libere la memoria basada en la función CPU allocations
    free(a);
    free(b);
    free(c);
Makefile包含:
NVCC_OPT=-std=c++11
all:
clean:
    -rm -f gpu-example
要运行该示例,请首先编译:
make
然后运行程序:
./gpu-example
如您所见,CPU版本的运行速度明显慢于GPU版本。
如果不是,则必须将gpu-example.cu 中定义的ITER设置为更高的数字。
这是因为GPU的配置时间比一些占用大量CPU的较小循环更长。
我发现65535在我的机器上可以正常工作,但是其里程可能会有所不同。
但是,一旦清除此阈值,GPU就会比CPU快得多。
结论
希望您从我们的C ++ GPU编程入门中学到很多。前面的示例并没有太大的成就,
但是演示的概念提供了一个框架,您可以使用该框架合并您的想法以释放GPU的功能。
最近编辑记录 我思故我在 (2019-10-08 09:21:19)
楼主 #3 2019-10-08 09:22:09
我思故我在
已发帖子: 244
楼主 #4 2019-10-08 22:00:31
我思故我在
已发帖子: 244
一楼那个toolkit安装或许可以用这个命令代替: sudo apt install nvidia-cuda-toolkit
