楼主 #1 2019-11-07 14:07:37
AppTurtle
华嵌HQEmbed S3 开发板,板载的SD NAND,官方BSP linux3.4 不能读数据,是什么坑?
通过外接TF卡启动,已经检测到卡,但是不能读0扇区??
[    1.549119] mmc1: new high speed SD card at address 00c3
[    1.555534] mmcblk1: mmc1:00c3 E1601 120 MiB
[    1.561853] EXT4-fs (mmcblk0p2): recovery complete
[    1.567394] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.576619] mmcblk1: timed out sending r/w cmd command, card status 0x900
[    1.584394] end_request: I/O error, dev mmcblk1, sector 0
[    1.590513] Buffer I/O error on device mmcblk1, logical block 0
[    1.604367] mmcblk1: timed out sending r/w cmd command, card status 0x900
[    1.612138] end_request: I/O error, dev mmcblk1, sector 0
[    1.618341] Buffer I/O error on device mmcblk1, logical block 0
[    1.625085] ldm_validate_partition_table(): Disk read failed.
[    1.631948] mmcblk1: timed out sending r/w cmd command, card status 0x900
[    1.639633] end_request: I/O error, dev mmcblk1, sector 0
[    1.641868] Buffer I/O error on device mmcblk1, logical block 0
[    1.652668]  mmcblk1: unable to read partition table
最近编辑记录 AppTurtle (2019-11-07 14:09:23)
#2 2019-11-07 14:14:11
Re: 华嵌HQEmbed S3 开发板,板载的SD NAND,官方BSP linux3.4 不能读数据,是什么坑?
什么品牌的 SD NAND ?
楼主 #3 2019-11-07 14:28:09
AppTurtle
应该就是在本论证上有宣传的,雷龙发展的
#4 2019-11-07 14:34:52
先按@mango 说的 sdio 引脚都加上 10k 上拉看下结果。
