分享一个V3s bsp Linux 3.4 spi nor flash 修改分区参数的方法, 抛砖引玉,请问有没有更好的方法,
比如主线Linux那种 bootargs 后者 dts 传参自动生成分区?
这个帖子太长了: licheepi zero BSP 内核(linux3.4) 编译教程 https://whycan.cn/t_682.html
重起一个新的
/* Register the whole NorFlash as a partition. */
static int partition_register(struct mtd_info *mtd, struct mtd_part_parser_data *ppdata)
        struct mtd_partition partitions[] = {
                .name = "NorFlash part0",
                .offset = 0,
                .size = MTDPART_SIZ_FULL
        return mtd_device_parse_register(mtd, NULL, ppdata, partitions, 1);
}根据板子实际情况,改成如下即可 ===>
                        .name = "u-boot",
                        .offset = 0,
                        .size = SZ_512K
                        .name = "sys_config",
                        .offset = 0x80000,
                        .size = SZ_512K
                        .name = "kernel",
                        .offset = 0x100000,
                        .size = 3*SZ_1M
                        .name = "rootfs",
                        .offset = 0x400000,
                        .size = 12*SZ_1M
        return mtd_device_parse_register(mtd, NULL, ppdata, partitions, sizeof(partitions)/sizeof(struct mtd_partition));
}离线
选中:Device Drivers  ---><*> Memory Technology Device (MTD) support  ---> [*]   Command line partition table parsing
uboot中设置环境变量:setenv bootargs 'console=ttyS0,115200 root=/dev/mtdblock4 rootfstype=squashfs mtdparts=spi0.0:992K(uboot),32K(ubootenv),64K(dtb),4032K(kernel),11M(rootfs)'
启动时候内核打印以下信息就算是ok了。忽略我的size异常导致的打印吧。
[    0.833578] 5 cmdlinepart partitions found on MTD device spi0.0
[    0.840254] Creating 5 MTD partitions on "spi0.0":
[    0.845754] 0x000000000000-0x0000000f8000 : "uboot"
[    0.851279] mtd: partition "uboot" doesn't end on an erase block -- force read-only
[    0.860979] 0x0000000f8000-0x000000100000 : "ubootenv"
[    0.866815] mtd: partition "ubootenv" doesn't start on an erase block boundary -- force read-only
[    0.877720] 0x000000100000-0x000000110000 : "dtb"
[    0.884033] 0x000000110000-0x000000500000 : "kernel"
[    0.890646] 0x000000500000-0x000001000000 : "rootfs"离线
