根据官方文档,已经安装了如下软件
1 python(x64 版本>=2.7)
2 scons(版本>=3.0.0)
3 Visual Studio C++(版本>=2017)
进入win10 shell窗口输入命令 scons 编译报错 如下 、烦请各位大神看看啥情况,不胜感激 ![]()
目录: E:\AWTK Projects\awtk-v1.3-SDK
Mode LastWriteTime Length Name
d----- 2020/2/10 14:18 awtk
d----- 2020/2/10 14:14 awtk-examples
d----- 2020/2/10 14:34 awtk-linux-fb
d----- 2020/2/10 14:14 user_apps
-a---- 2020/1/16 17:07 179 version.txt
PS E:\AWTK Projects\awtk-v1.3-SDK> cd awtk
PS E:\AWTK Projects\awtk-v1.3-SDK\awtk> scons
scons: Reading SConscript files ...
MACH=AMD64 ARCH=('32bit', 'WindowsPE') TARGET_ARCH=arm
TK_ROOT: E:\AWTK Projects\awtk-v1.3-SDK\awtk
scons: done reading SConscript files.
scons: Building targets ...
g++ -o 3rd\agge\agge\math.o -c -DWIN32 -D_WIN32 -DWINDOWS /EHsc -D_CONSOLE /DEBUG /Od /FS /Z7 -DWITH_64BIT_CPU -DTK_ROOT=\"E:\\AWTK Projects\\awtk-v1.3-SDK\\awtk\" -DSTBTT_STATIC -DSTB_IMAGE_STATIC -DWITH_STB_IMAGE -DWITH_SOCKET -DWITH_VGCANVAS -DWITH_UNICODE_BREAK -DWITH_DESKTOP_STYLE -DSDL2 -DHAS_STD_MALLOC -DWITH_SDL -DWITH_FS_RES -DHAS_STDIO -DHAVE_STDIO_H -DWITH_STB_FONT -DWITH_BITMAP_BGRA -DWITH_NANOVG_SOFT -DWITH_FB_BGR565=1 -DWITH_NANOVG_AGGE -D_WIN64 -DSDL_REAL_API -DSDL_HAPTIC_DISABLED -DSDL_SENSOR_DISABLED -DSDL_JOYSTICK_DISABLED -D__STDC_LIMIT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_CONSTANT_MACROS -D_HAS_EXCEPTIONS=0 -D_HAS_ITERATOR_DEBUGGING=0 -D_ITERATOR_DEBUG_LEVEL=0 -D_SCL_SECURE=0-D_SECURE_SCL=0 -D_SCL_SECURE_NO_WARNINGS -D_CRT_SECURE_NO_WARNINGS -D_CRT_SECURE_NO_DEPRECATE -I. -Isrc -I3rd -Isrc\ext_widgets -I3rd\pixman -I3rd\cairo -I3rd\bgfx\bgfx\include -I3rd\bgfx\bx\include -I3rd\bgfx\bimg\include -I3rd\agge -I3rd\agg\include -I3rd\nanovg -I3rd\nanovg\gl -I3rd\nanovg\base -I3rd\nanovg\agge -I3rd\nanovg\bgfx -I3rd\SDL\src -I3rd\SDL\include -I3rd\agge\src -I3rd\agge\include -I3rd\gpinyin\include -I3rd\libunibreak -I3rd\gtest\googletest -I3rd\gtest\googletest\include -Itools 3rd\agge\agge\math.cpp
g++: error: /EHsc: No such file or directory
g++: error: /DEBUG: No such file or directory
g++: error: /Od: No such file or directory
g++: error: /FS: No such file or directory
g++: error: /Z7: No such file or directory
g++: error: Projects\\awtk-v1.3-SDK\\awtk": No such file or directory
scons: *** [3rd\agge\agge\math.o] Error 1
scons: building terminated because of errors.
PS E:\AWTK Projects\awtk-v1.3-SDK\awtk>请问各位大神这是啥情况呀?我电脑已经安装了gcc 和g++
命令行输入 g++ -v 可见如下 而且VS Studio2017也装的C++版本,编译LVGL都是正常的
PS E:\AWTK Projects\awtk-v1.3-SDK\awtk> g++ -v
Using built-in specs.
COLLECT_GCC=C:\MinGW\bin\g++.exe
COLLECT_LTO_WRAPPER=c:/mingw/bin/../libexec/gcc/mingw32/6.3.0/lto-wrapper.exe
Target: mingw32
Configured with: ../src/gcc-6.3.0/configure --build=x86_64-pc-linux-gnu --host=mingw32 --with-gmp=/mingw --with-mpfr=/mingw --with-mpc=/mingw --with-isl=/mingw --prefix=/mingw --disable-win32-registry --target=mingw32 --with-arch=i586 --enable-languages=c,c++,objc,obj-c++,fortran,ada --with-pkgversion='MinGW.org GCC-6.3.0-1' --enable-static --enable-shared --enable-threads --with-dwarf2 --disable-sjlj-exceptions --enable-version-specific-runtime-libs --with-libiconv-prefix=/mingw --with-libintl-prefix=/mingw --enable-libstdcxx-debug --with-tune=generic --enable-libgomp --disable-libvtv --enable-nls
Thread model: win32
gcc version 6.3.0 (MinGW.org GCC-6.3.0-1)
PS E:\AWTK Projects\awtk-v1.3-SDK\awtk>离线
要不看下这个有没有参考价值:
https://whycan.cn/t_2118.html
要不看下这个有没有参考价值:
好的谢谢,我试试看
