楼主 #1 2020-04-01 14:04:05
已发帖子: 9,492
分享全志主线u-boot/linux 打包 TF/SD/SDNAND 镜像脚本
以下由 @哇酷小管家 2021-12-16 添加:
用 buildroot 更方便,参考这两个链接
buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 已支持DVP摄像头
https://whycan.com/t_5221.html
(V3s/V3x/S3/S3L/R11通吃)小智V3x开发板smallwitpi lite u-boot/linux/buildroot测试
https://whycan.com/t_7248.html#p69178
完毕
pack.sh
#!/bin/bash
_UBOOT_SIZE=1
###第一个分区(FAT)大小,单位MiB##
_P1_SIZE=16
###TF卡镜像文件名称###
_IMG_FILE='f1c100s_tfcard_img.bin'
###TF卡镜像文件大小, 单位MiB###
_IMG_SIZE=120
temp_root_dir=$PWD
_UBOOT_FILE="${temp_root_dir}/data/u-boot-sunxi-with-spl.bin"
_SPLASH_BMP_FILE="${temp_root_dir}/data/splash.bmp"
_BOOT_SCR_FILE="${temp_root_dir}/data/boot.scr"
_KERNEL_IMAGE_FILE="${temp_root_dir}/data/zImage"
_DTB_FILE="${temp_root_dir}/data/dtb.bin"
_ROOTFS_TGZ_FILE="${temp_root_dir}/data/rootfs.tgz"
        ###初始化镜像文件###
        dd if=/dev/zero of=$_IMG_FILE bs=1M count=$_IMG_SIZE
        ###判断镜像文件是否初始化成功###
        if [ $? -ne 0 ]
        then
                echo  "getting error in creating dd img!"
                exit
        fi
        ###获取一个循环设备###
        _LOOP_DEV=$(sudo losetup -f)
        #echo ${_LOOP_DEV}
        ##再次判断此设备是否存在###
        if [ -z $_LOOP_DEV ]
        then
                echo  "can not find a loop device!"
                exit
        fi
        ###把镜像文件和循环设备关联###
        sudo losetup $_LOOP_DEV $_IMG_FILE
        if [ $? -ne 0 ]
        then
                echo  "dd img --> $_LOOP_DEV error!"
                sudo losetup -d $_LOOP_DEV >/dev/null 2>&1 && exit
        fi
        echo  "--->creating partitions for tf image ..."
        #blockdev --rereadpt $_LOOP_DEV >/dev/null 2>&1
        # size only can be integer
###分区###
cat <<EOT |sudo  sfdisk ${_IMG_FILE}
${_UBOOT_SIZE}M,${_P1_SIZE}M,c
,,L
EOT
###格式化###
        sleep 2
        sudo partx -u $_LOOP_DEV
        sudo mkfs.vfat ${_LOOP_DEV}p1 ||exit
        sudo mkfs.ext4 ${_LOOP_DEV}p2 ||exit
        if [ $? -ne 0 ]
        then
                echo  "error in creating partitions"
                #sudo partprobe $_LOOP_DEV >/dev/null 2>&1 && exit
        fi
        ###u-boot写到TF卡8K偏移处###
        #pack uboot
        echo  "--->writing u-boot-sunxi-with-spl to $_LOOP_DEV"
        # sudo dd if=/dev/zero of=$_LOOP_DEV bs=1K seek=1 count=1023  # clear except mbr
        sudo dd if=$_UBOOT_FILE of=$_LOOP_DEV bs=1024 seek=8
        if [ $? -ne 0 ]
        then
                echo  "writing u-boot error!"
        fi
        ###新建 p1,p2 目录,并挂载TF卡两个分区###
        sudo sync
        mkdir -p ${temp_root_dir}/output/p1 >/dev/null 2>&1
        mkdir -p ${temp_root_dir}/output/p2 > /dev/null 2>&1
        sudo mount ${_LOOP_DEV}p1 ${temp_root_dir}/output/p1
        sudo mount ${_LOOP_DEV}p2 ${temp_root_dir}/output/p2
        echo  "--->copy boot and rootfs files..."
        sudo rm -rf  ${temp_root_dir}/output/p1/* && sudo rm -rf ${temp_root_dir}/output/p2/*
        ###复制zImage, dtb, boot.scr, splash.bmp 等文件到第一分区 ###
        sudo cp ${_KERNEL_IMAGE_FILE} ${temp_root_dir}/output/p1/zImage &&\
        sudo cp ${_DTB_FILE} ${temp_root_dir}/output/p1/ &&\
        sudo cp ${_BOOT_SCR_FILE} ${temp_root_dir}/output/p1/ &&\
        sudo cp ${_SPLASH_BMP_FILE} ${temp_root_dir}/output/p1/ &&\
        echo "--->p1 done~"
        ###解压 rootfs.tgz 到第二分区###
        sudo tar xvf ${_ROOTFS_TGZ_FILE} -C ${temp_root_dir}/output/p2/ &&\
        echo "--->p2 done~"
        ###同步, 等待, 卸载, 退出###
        sudo sync
        sleep 2
        sudo umount ${temp_root_dir}/output/p1 ${temp_root_dir}/output/p2  && sudo losetup -d $_LOOP_DEV
        if [ $? -ne 0 ]
        then
                echo  "umount or losetup -d error!!"
                exit
        fi
目录结构:
pack.sh
data/
    boot.scr
    dtb.bin
    rootfs.tgz
    zImage
以上脚本参考本站 @xiaohui 的打包脚本, 我加了部分注释, 把其他非打包脚本剥离开了。
楼主 #2 2020-04-01 14:07:11
已发帖子: 9,492
Re: 分享全志主线u-boot/linux 打包 TF/SD/SDNAND 镜像脚本
如果以前你按这个帖子: 【视频分享】制作荔枝派Zero开发板(全志V3s) TF/SD卡启动盘,
那么现在就可以把这个 GParted 扔掉了。
楼主 #3 2020-04-01 14:09:17
已发帖子: 9,492
今天偶然翻到以前许诺@达克罗德 大神做一个TF打包脚本的,
后来事多忘记,今天突然看到,把这个坑给填了。
#4 2020-04-08 16:26:30
光头程序员
这个脚本真是 666666
#5 2020-04-17 11:07:14
renhuge
这个脚本可以打包F1C200S么
楼主 #6 2020-04-17 11:12:49
已发帖子: 9,492
renhuge wrote:
这个脚本可以打包F1C200S么
当然可以,而且本来就是。
#7 2020-04-17 16:44:55
Jmhh247
已发帖子: 262
向大神学习, 学习
#8 2020-04-17 19:55:56
LinjieGuo
已发帖子: 597
只能mark支持一下了
#9 2020-04-20 23:30:55
XZHDJH
已发帖子: 37
入坑了,当初荔枝派的脚本找了很久.....
#10 2020-05-07 09:20:23
tianjjff
已发帖子: 129
这个脚本好!
#11 2020-05-08 18:46:01
wonrowl
已发帖子: 103
自己画一个板子,需要做什么才能让它从spiflash引导启动呢?
#12 2020-05-09 13:36:11
苍狼青雯
已发帖子: 0
感谢楼主分享,新买的Tiny200,正好下载下来测试一下
#13 2020-05-13 09:42:21
weiyongwill
已发帖子: 65
新的BuildRoot里面有个support/scripts/genimage.sh,不过完全看不懂
#!/usr/bin/env bash
die() {
  cat <<EOF >&2
Error: $@
Usage: ${0} -c GENIMAGE_CONFIG_FILE
EOF
  exit 1
# Parse arguments and put into argument list of the script
opts="$(getopt -n "${0##*/}" -o c: -- "$@")" || exit $?
eval set -- "$opts"
GENIMAGE_TMP="${BUILD_DIR}/genimage.tmp"
while true ; do
	case "$1" in
	-c)
	  GENIMAGE_CFG="${2}";
	  shift 2 ;;
	--) # Discard all non-option parameters
	  shift 1;
	  break ;;
	  die "unknown option '${1}'" ;;
	esac
done
[ -n "${GENIMAGE_CFG}" ] || die "Missing argument"
# Pass an empty rootpath. genimage makes a full copy of the given rootpath to
# ${GENIMAGE_TMP}/root so passing TARGET_DIR would be a waste of time and disk
# space. We don't rely on genimage to build the rootfs image, just to insert a
# pre-built one in the disk image.
trap 'rm -rf "${ROOTPATH_TMP}"' EXIT
ROOTPATH_TMP="$(mktemp -d)"
rm -rf "${GENIMAGE_TMP}"
genimage \
	--rootpath "${ROOTPATH_TMP}"     \
	--tmppath "${GENIMAGE_TMP}"    \
	--inputpath "${BINARIES_DIR}"  \
	--outputpath "${BINARIES_DIR}" \
	--config "${GENIMAGE_CFG}"
#14 2020-05-28 17:33:00
zhang235hai
已发帖子: 212
我平时用的只有下面四个文件
sun8i-v3s-licheepi-zero-dock.dtb
zImage
rootfs.tar
也能打包成为TF卡的烧写程序吗?
怎么做呢?
#15 2020-05-28 17:59:10
已发帖子: 3,409
zhang235hai wrote:
我平时用的只有下面四个文件
zImage
rootfs.tar
也能打包成为TF卡的烧写程序吗?
怎么做呢?
可以的,按一楼那个脚本就行,只要写一个 boot.cmd的文本文件,编译成 boot.scr 就可以了。
#16 2020-08-08 18:05:46
angelsan
已发帖子: 139
怎么编译成 boot.scr啊?不用这个就行了吧?
#17 2020-08-08 19:21:14
jkl
已发帖子: 271
mkimage -C none -A arm -T script -d boot.cmd boot.scr
#18 2020-08-10 11:37:51
angelsan
已发帖子: 139
非常感谢!boot.cmd是怎么来的,新建一个空的文本文件吗?
#19 2020-08-10 11:56:07
angelsan
已发帖子: 139
请教一下,boot.cmd该怎么写,V3s没有用到啊
#20 2020-08-10 13:49:21
jkl
已发帖子: 271
是的,将你的一些加载、启动命令写入进去就行了,再按照上面的命令生成boot.src!
#21 2020-08-10 14:43:35
angelsan
已发帖子: 139
实在是看不明白啊,请问是哪些加载、启动命令呢?能介绍清楚一些么?
#22 2020-08-10 14:45:07
angelsan
已发帖子: 139
麻烦老大,能不能写一个V3s能用的。boot.cmd不知道怎么写,boot.scr 没有文档啊
当然可以,而且本来就是。
#23 2020-08-10 15:12:24
jkl
已发帖子: 271
fatload mmc 1:1 0x46000000 zImage
fatload mmc 1:1 0x49000000 sun8i-x3-smallwit-card-taurus.dtb
setenv bootargs console=ttyS0,115200 earlyprintk root=/dev/mmcblk2p2 rootwait panic=10
bootz 0x46000000 - 0x49000000,类似于这些。
#24 2020-09-17 09:06:05
shawn.d
已发帖子: 164
感谢晕哥,这个方便很多了
#25 2020-09-17 09:14:16
touchey
已发帖子: 143
这个实用
#26 2021-12-13 21:26:50
jack123321
  • 不通过:其他
#27 2021-12-16 10:17:22
pinkgun
这脚本实在是太方便了啊,感谢
#29 2024-01-16 13:18:03
a06041114
已发帖子: 24
V3S生成的设备树文件是dtb,脚本用到的dtb.bin,这2者怎么转化
#30 2024-02-18 10:55:46
ahui450331
zhang235hai wrote:
我平时用的只有下面四个文件
zImage
rootfs.tar
也能打包成为TF卡的烧写程序吗?
怎么做呢?
同问,怎么打包 spinand 128MB 用全志的 PhoenixSuit 烧录?打包成bin文件烧录太慢了
#31 2026-03-15 07:41:06
mararmyjj
有没有全志v3s的uboot,sd卡启动的
#32 2026-03-21 00:16:42
tooldown
同求全志v3s的uboot,sd卡启动的
