尝试用go语言操作gpio驱动oled,驱动方式是spi,io操作方式是文件方式。由于这种方式需要不断写文件,oled刷新有点慢。后期会改成mmap方式。
https://github.com/kekemuyu/f1c100s/tree/master/oled_spi
oled 部分代码:
package oled
import (
"oled_spi/gpio"
"time"
const (
OLED_CLK = "gpio131"
OLED_DI = "gpio132"
OLED_RST = "gpio133"
OLED_DC = "gpio138"
OLED_CS = "gpio139"
OLED_CMD = 0 //写命令
OLED_DATA = 1 //写数据
SIZE = 16
Max_Column = 128
Max_Row = 64
func Init() {
gpio.OpenGpioFile(OLED_CLK)
gpio.OpenGpioFile(OLED_DI)
gpio.OpenGpioFile(OLED_RST)
gpio.OpenGpioFile(OLED_DC)
gpio.OpenGpioFile(OLED_CS)
SetRst()
time.Sleep(time.Millisecond * 100)
ClrRst()
SetRst()
WriteByte(0xAE, OLED_CMD) //--turn off oled panel
WriteByte(0x00, OLED_CMD) //---set low column address
WriteByte(0x10, OLED_CMD) //---set high column address
WriteByte(0x40, OLED_CMD) //--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
WriteByte(0x81, OLED_CMD) //--set contrast control register
WriteByte(0x66, OLED_CMD) // Set SEG Output Current Brightness
WriteByte(0xA1, OLED_CMD) //--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
WriteByte(0xC8, OLED_CMD) //Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
WriteByte(0xA6, OLED_CMD) //--set normal display
WriteByte(0xA8, OLED_CMD) //--set multiplex ratio(1 to 64)
WriteByte(0x3f, OLED_CMD) //--1/64 duty
WriteByte(0xD3, OLED_CMD) //-set display offset Shift Mapping RAM Counter (0x00~0x3F)
WriteByte(0x00, OLED_CMD) //-not offset
WriteByte(0xd5, OLED_CMD) //--set display clock divide ratio/oscillator frequency
WriteByte(0x80, OLED_CMD) //--set divide ratio, Set Clock as 100 Frames/Sec
WriteByte(0xD9, OLED_CMD) //--set pre-charge period
WriteByte(0xF1, OLED_CMD) //Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
WriteByte(0xDA, OLED_CMD) //--set com pins hardware configuration
WriteByte(0x12, OLED_CMD)
WriteByte(0xDB, OLED_CMD) //--set vcomh
WriteByte(0x40, OLED_CMD) //Set VCOM Deselect Level
WriteByte(0x20, OLED_CMD) //-Set Page Addressing Mode (0x00/0x01/0x02)
WriteByte(0x02, OLED_CMD) //
WriteByte(0x8D, OLED_CMD) //--set Charge Pump enable/disable
WriteByte(0x14, OLED_CMD) //--set(0x10) disable
WriteByte(0xA4, OLED_CMD) // Disable Entire Display On (0xa4/0xa5)
WriteByte(0xA6, OLED_CMD) // Disable Inverse Display On (0xa6/a7)
WriteByte(0xAF, OLED_CMD) //--turn on oled panel
WriteByte(0xAF, OLED_CMD) /*display ON*/
Clear()
SetPos(0, 0)
func SetClk() {
gpio.GpioNSetValue(OLED_CLK, "1")
func ClrClk() {
gpio.GpioNSetValue(OLED_CLK, "0")
func SetDi() {
gpio.GpioNSetValue(OLED_DI, "1")
func ClrDi() {
gpio.GpioNSetValue(OLED_DI, "0")
func SetRst() {
gpio.GpioNSetValue(OLED_RST, "1")
func ClrRst() {
gpio.GpioNSetValue(OLED_RST, "0")
func SetDc() {
gpio.GpioNSetValue(OLED_DC, "1")
func ClrDc() {
gpio.GpioNSetValue(OLED_DC, "0")
func SetCs() {
gpio.GpioNSetValue(OLED_CS, "1")
func ClrCs() {
gpio.GpioNSetValue(OLED_CS, "0")
func WriteByte(dat, cmd byte) {
if cmd != 0 {
SetDc()
} else {
ClrDc()
ClrCs()
for i := 0; i < 8; i++ {
ClrClk()
if dat&0x80 != 0 {
SetDi()
} else {
ClrDi()
SetClk()
dat <<= 1
SetCs()
SetDc()
func SetPos(x, y byte) {
WriteByte(0xb0+y, OLED_CMD)
WriteByte(((x&0xf0)>>4)|0x10, OLED_CMD)
WriteByte((x&0x0f)|0x01, OLED_CMD)
func Clear() {
for i := byte(0); i < 8; i++ {
WriteByte(0xb0+i, OLED_CMD) //设置页地址(0~7)
WriteByte(0x00, OLED_CMD) //设置显示位置—列低地址
WriteByte(0x10, OLED_CMD) //设置显示位置—列高地址
for n := 0; n < 128; n++ {
WriteByte(0, OLED_DATA) //更新显示
func ShowChar(x, y, chr byte) {
c := chr - ' ' //得到偏移后的值
if x > Max_Column-1 {
x = 0
y = y + 2
if SIZE == 16 {
SetPos(x, y)
WriteByte(F8X16[int(c)*16+i], OLED_DATA)
SetPos(x, y+1)
WriteByte(F8X16[int(c)*16+i+8], OLED_DATA)
} else {
SetPos(x, y+1)
func ShowString(x, y byte, chrs string) {
for _, v := range []byte(chrs) {
ShowChar(x, y, v)
x += 8
if x > 120 {
x = 0
y += 2
}离线
看不懂,帮顶
脚本语言适合于DIY
脚本语言适合于DIY
go不是脚本语言,也是静态编译型语言,已经大量应用于web开发和云计算区块连
大赞,想一块去了,之前弄过,但是忙其他的了,没搞下去
效率如何?
效率如何?
开发效率类似于python,执行速度略低于c/c++。是平衡了开发效率和执行速度的绝佳选择
楼主高人啊,在哪个城市啊
楼主高人啊,在哪个城市啊
这是要面基?
牛人!
话说,golang真实一个强悍的语言。
