楼主 #1 2020-05-09 18:45:37
缥缈九哥
已发帖子: 93
基于QT 5.8.0 for Android 的 Windows 10 开发环境搭建--缥缈九哥
一、下载软件
1.jdk: jdk-8u121-windows-i586.exe
http://www.oracle.com/technetwork/java/javase/downloads/jdk8-downloads-2133151.html
http://download.oracle.com/otn-pub/java/jdk/8u121-b13/e9e7ea248e2c4826b92b3f075a80e441/jdk-8u121-windows-i586.exe
2.sdk: android-studio-bundle-145.3537739-windows.exe
https://developer.android.com/studio/index.html
https://dl.google.com/dl/android/studio/install/2.2.3.0/android-studio-bundle-145.3537739-windows.exe
3.qte:  qt-opensource-windows-x86-android-5.8.0-rc_699.exe
http://download.qt.io/development_releases/qt/5.8/5.8.0-rc/
http://download.qt.io/development_releases/qt/5.8/5.8.0-rc/qt-opensource-windows-x86-android-5.8.0-rc_699.exe
4.ndk: android-ndk-r13b-windows-x86.zip
https://developer.android.com/ndk/downloads/index.html
https://dl.google.com/android/repository/android-ndk-r13b-windows-x86.zip
5.ant: apache-ant-1.10.0-bin.zip
http://ant.apache.org/bindownload.cgi
http://mirror.bit.edu.cn/apache//ant/binaries/apache-ant-1.10.0-bin.zip
二、安装软件
1,把 jdk-8u121-windows-i586.exe 安装到 C:\Program Files (x86)\Java\jdk1.8.0_121\ 和 C:\Program Files (x86)\Java\jre1.8.0_121 下面;
2,把 android-studio-bundle-145.3537739-windows.exe 安装到 C:\Program Files\Android\Android Studio 和 C:\Users\yuanxihua\AppData\Local\Android\sdk 下面;
3,把 qt-opensource-windows-x86-android-5.8.0-rc_699  的全部组件安装到 C:\Qt\Qt5.8.0 下面;
4,把 android-ndk-r13b-windows-x86.zip 解压到 C:\Qt\android-ndk-r13b 下面;
5,把 apache-ant-1.10.0-bin.zip 解压到 C:\Qt\apache-ant-1.10.0 下面;
三、开发项目
1,配置环境
    打开 C:\Qt\Qt5.8.0\Tools\QtCreator\bin 下面的 qtcreator.exe,在 “工具”->“选项”->“设备”里面选择“andorid”的配置填入上面的软件
JDK、SDK、NDK、ANT的路径:C:\Program Files (x86)\Java\jdk1.8.0_121  和 C:\Users\yuanxihua\AppData\Local\Android\sdk1  和 C:\Qt\android-ndk-r13b
及 C:\Qt\apache-ant-1.10.0\bin\ant.bat
2,建立工程
   A,打开 qtcreator.exe,在“文件”->“新建文件或项目”选择“所有模板”->Application->Qt Widgets Application
然后点击“Choose…”,选择项目路径“D:\works\TEST\qttest”和项目名称“test”,勾选“Android for armeabi-v7a(GCC 4.9 ,Qt 5.8.0)”
和“Desktop Qt 5.8.0 MinGW 32bit”两个模板;
   B,一路直接按下去就建立好测试项目,选择项目里面的“Android for armeabi-v7a(GCC 4.9 ,Qt 5.8.0)”下的构建,然在“构建”菜单下选择
   “选择重新构建项目‘TEST’”进行编译,就会在
“D:\works\TEST\qttest\build-test-Android_for_armeabi_v7a_GCC_4_9_Qt_5_8_0-Release\android-build\bin”下生成“QtApp-debug.apk”
和“QtApp-debug-unaligned.apk”文件;
   C,把生成的APK文件通过数据线下载到安卓手机就能安装测试使用。
最近编辑记录 缥缈九哥 (2020-05-09 20:22:19)
