楼主 #1 2017-11-01 11:51:00
陆闻天
已发帖子: 34
luci web网页起不来,有没有办法用串口升级固件呢?
#2 2017-11-01 11:52:38
已发帖子: 9,401
Re: luci web网页起不来,有没有办法用串口升级固件呢?
陆闻天 说:
编译出新固件,然后想办法拷贝到widora上,
可以通过http, ssh, tf卡,
然后执行: sysupgrade openwrt-ramips-mt7688-Widora-squashfs-sysupgrade.bin
重启, 看版本日期是否升级成功
#3 2017-11-01 11:56:45
已发帖子: 9,401
root@Widora:~# sysupgrade
Usage: /sbin/sysupgrade [<upgrade-option>...] <image file or URL>
       /sbin/sysupgrade [-q] [-i] <backup-command> <file>
upgrade-option:
        -d <delay>   add a delay before rebooting
        -f <config>  restore configuration from .tar.gz (file or url)
        -i           interactive mode
        -c           attempt to preserve all changed files in /etc/
        -n           do not save configuration over reflash
        -T | --test
                     Verify image and config .tar.gz but do not actually flash.
        -F | --force
                     Flash image even if image checks fail, this is dangerous!
        -q           less verbose
        -v           more verbose
        -h | --help  display this help
backup-command:
        -b | --create-backup <file>
                     create .tar.gz of files specified in sysupgrade.conf
                     then exit. Does not flash an image. If file is '-',
                     i.e. stdout, verbosity is set to 0 (i.e. quiet).
        -r | --restore-backup <file>
                     restore a .tar.gz created with sysupgrade -b
                     the archive is read from stdin.
        -l | --list-backup
                     list the files that would be backed up when calling
                     sysupgrade -b. Does not create a backup file.
这个选项是不保留旧配置
如果没有重要的配置文件,建议不保留配置升级
楼主 #4 2017-11-01 11:57:04
陆闻天
已发帖子: 34
搞定,非常感谢!
楼主 #5 2017-11-01 15:29:30
陆闻天
已发帖子: 34
运行
现在网页跑起来了, 但是原来那些设置的菜单、页面都不见了.
要怎么才能找回来呢?
#6 2017-11-01 15:31:09
已发帖子: 9,401
make menuconfig
[ ] Image configuration  --->   Separate feed repositories  ---> [ * ]   Enable feed luci
LuCI  --->
看看这里有没有你想要的?
#7 2017-11-01 21:51:35
落雁
已发帖子: 62
make menuconfig
LuCI  --->
看看这里有没有你想要的?
https://github.com/openwrt/luci
要这样才行哦:
./scripts/feeds update luci
./scripts/feeds install -a -p luci
楼主 #8 2017-11-01 21:53:18
陆闻天
已发帖子: 34
落雁 说:
make menuconfig
LuCI  --->
看看这里有没有你想要的?
要这样才行哦:
非常感谢,
这样可以了,终于看到了网页界面.
楼主 #9 2017-11-01 22:02:28
陆闻天
已发帖子: 34
终于可以安心睡觉了, 明天开始搞Linux内核声卡配置
#10 2017-11-02 09:35:59
已发帖子: 9,401
陆闻天 说:
参考这个:
http://antkillerfarm.github.io/linux/2015/02/01/Openwrt.html
如果要配置linux内核的话,可以执行make kernel_menuconfig命令
#11 2017-11-02 09:37:47
已发帖子: 9,401
我试过是可以的!
你可以参考一下
#12 2017-11-02 10:06:24
已发帖子: 9,401
https://github.com/hnhkj/CC15.05/commit/d74fcf753b37a2e6e8945ce56de30e341d06377d
+--- a/sound/soc/mtk/Makefile
++++ b/sound/soc/mtk/Makefile
+@@ -17,6 +17,7 @@ KBUILD_CFLAGS += -DCONFIG_SND_MT76XX_SOC
+ KBUILD_CFLAGS += -DCONFIG_I2S_WM8960
+ #KBUILD_CFLAGS += -DCONFIG_I2S_MCLK_12P288MHZ
+ KBUILD_CFLAGS += -DCONFIG_I2S_MCLK_12MHZ
++KBUILD_CFLAGS += -DCONFIG_I2S_IN_MCLK
+ KBUILD_CFLAGS += -DCONFIG_GDMA_EVERYBODY
+ KBUILD_CFLAGS += -DSURFBOARDINT_DMA=15
+ KBUILD_CFLAGS += -DRALINK_INTCTL_DMA=128
Linkit的默认的声卡是WM8960,该声卡为I2S接口。Linkit默认WM8960使用的为外部晶振提供时钟频率。所以如果我们希望采用MT7688的REF_CLK0信号作为WM8960的时钟信号的话,我们就需要对MTK的配置文件进行一些修改。
关于I2S和WM8960声卡的代码都在这个附近:
openwrt_widora/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_mt7688/linux-3.18.29/sound/soc/mtk
板子上面初始化脚本:
/etc/modules.d/90-sound-mtk
ralink_gdma
snd-soc-wm8960
i2c_wm8960
snd-soc-mt76xx-i2s-ctl
snd-soc-mt76xx-i2s
snd-soc-mt76xx-pcm
snd-soc-mt76xx-machine
