楼主 #1 2020-07-10 21:11:15
hljswl
荔枝派V3S移植rtthread,外设中断不进入irq中断,进入swi中断
向大佬们求助,尝试在荔枝派zero上移植rtthread,rtt启动后外设中断会进入swi中断函数里面去。
rtt启动信息:
  • RT - Thread Operating System
    / | \ 3.1.4 build Jul 10 2020
    2006 - 2019 Copyright by rt-thread team
    periph_get_pll_clk: 600000000
    cpu_get_clk: 1008000000
    ahb1_get_clk: 300000000
    ahb2_get_clk: 300000000
    apb1_get_clk: 150000000
    apb2_get_clk: 24000000
    software interrupt:
    Execption:
    r00:0x00000017 r01:0x0000000a r02:0x01c2807c r03:0x40038828
    r04:0xdeadbeef r05:0xdeadbeef r06:0xdeadbeef r07:0xdeadbeef
    r08:0xdeadbeef r09:0xdeadbeef r10:0xdeadbeef
    fp :0xdeadbeef ip :0x0000014b
    sp :0x40052ff8 lr :0x40032ad0 pc :0x40032ad4
    cpsr:0x60000013
    thread pri status sp stack size max used left tick error
    tshell 20 ready 0x00000040 0x00001000 01% 0x0000000a 000
    tidle 31 ready 0x00000040 0x00000100 25% 0x00000020 000
    timer 4 suspend 0x0000006c 0x00000200 21% 0x0000000a 000
    main 10 ready 0x00000040 0x00000800 50% 0x00000014 000
    --- high pending priority: 32(00000020)
    --- hw mask ---
    0x0000ffff, 0x00028001, 0x00000000, 0x00000000,
    --- hw pending ---
    0x00000000, 0x00000001, 0x00000000, 0x00000000,
    --- hw active ---
    0x00000000, 0x00000000, 0x00000000, 0x00000000,
    shutdown...
    (0) assertion failed at function:rt_hw_cpu_shutdown, line number:85
楼主 #2 2020-07-11 00:14:14
hljswl
Re: 荔枝派V3S移植rtthread,外设中断不进入irq中断,进入swi中断
问题解决了,就是中断向量表位置的问题。
VBAR描述
VBAR寄存器会忽略末尾5位,原来的system_vectors在0x40000010,实际变成0x40000000,漂移0x10,正好对应_vector_swi。将system_vectors改为0x40000020就解决了。
#3 2020-07-11 00:19:11
虽然看不懂,但是仍然感谢楼主热心分享。
#4 2020-07-11 13:46:50
john78
已发帖子: 223
踩一脚,关注下
#5 2020-07-11 17:55:15
aozima
已发帖子: 488
学习一下
