先说明一下,决对不是Python问题
1.通过运行以下命令来安重新装
python -m pip install --user -r $IDF_PATH/requirements.txt
这个办法是不对的,别提这个办法了
我用我备份文件也还原不回来,有点怀凝是某些组件到期不认用,太多这样的事了,就像Genymotion虚拟机一样,就是不给正常的提醒
laotongxiao@DESKTOP-B0VE8KN MINGW32 ~/esp/nono
1 [main] make 1871 child_info_fork::abort: \??\C:\msys32new\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE20000) != child(0xE30000)
make: /home/laotongxiao/esp/esp-idf/make/project_config.mk:13: fork: Resource temporarily unavailable
1 [main] make 1872 child_info_fork::abort: \??\C:\msys32new\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE20000) != child(0x6C0000)
make: /home/laotongxiao/esp/esp-idf/make/project_config.mk:14: fork: Resource temporarily unavailable
2 [main] make 1873 child_info_fork::abort: \??\C:\msys32new\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE20000) != child(0xE00000)
make: /home/laotongxiao/esp/esp-idf/make/project_config.mk:15: fork: Resource temporarily unavailable
1 [main] make 1874 child_info_fork::abort: \??\C:\msys32new\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE20000) != child(0xE30000)
make: /home/laotongxiao/esp/esp-idf/make/project_config.mk:16: fork: Resource temporarily unavailable
1 [main] make 1875 child_info_fork::abort: \??\C:\msys32new\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE20000) != child(0xDE0000)
make: /home/laotongxiao/esp/esp-idf/make/project_config.mk:17: fork: Resource temporarily unavailable
2 [main] make 1876 child_info_fork::abort: \??\C:\msys32new\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE20000) != child(0xDC0000)
make: /home/laotongxiao/esp/esp-idf/make/project_config.mk:70: fork: Resource temporarily unavailable
1 [main] make 1877 child_info_fork::abort: \??\C:\msys32new\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE20000) != child(0xE00000)
make: fork: Resource temporarily unavailable
make: *** 没有规则可制作目标“check_python_dependencies”,由“menuconfig” 需求。 停止。
