楼主 #1 2020-08-20 15:49:28
明月照我沟渠
已发帖子: 121
全志 X3 跑 u-boot 2020.07, 出现Reading file would overwrite reserved memory
U-Boot SPL 2020.07-dirty (Aug 20 2020 - 00:42:14 -0700)
DRAM: 128 MiB
Failed to set core voltage! Can't set CPU frequency
Trying to boot from MMC1
U-Boot 2020.07-dirty (Aug 20 2020 - 00:42:14 -0700) Allwinner Technology
CPU:   Allwinner A33 (SUN8I 1667)
Model: Sinlinx SinA33
DRAM:  128 MiB
MMC:   mmc@1c0f000: 0, mmc@1c11000: 1
Loading Environment from FAT... Card did not respond to voltage select!
In:    serial
Out:   vga
Err:   vga
Net:
Warning: usb_ether using MAC address from ROM
eth0: usb_ether
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
355 bytes read in 3 ms (115.2 KiB/s)
** Reading file would overwrite reserved memory **
There is no valid bmp file at the given address
SCRIPT FAILED: continuing...
Device 0: unknown device
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
The remote end did not respond in time.missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-de-ad-be-ef-00-01
RNDIS ready
The remote end did not respond in time.missing environment variable: bootfile
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
The remote end did not respond in time.Config file not found
RNDIS ready
The remote end did not respond in time.using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
RNDIS ready
The remote end did not respond in time.=>
楼主 #2 2020-08-20 15:53:07
明月照我沟渠
已发帖子: 121
Re: 全志 X3 跑 u-boot 2020.07, 出现Reading file would overwrite reserved memory
找到了: https://github.com/u-boot/u-boot/blob/master/fs/fs.c
#ifdef CONFIG_LMB
/* Check if a file may be read to the given address */
static int fs_read_lmb_check(const char *filename, ulong addr, loff_t offset,
                             loff_t len, struct fstype_info *info)
        struct lmb lmb;
        int ret;
        loff_t size;
        loff_t read_len;
        /* get the actual size of the file */
        ret = info->size(filename, &size);
        if (ret)
                return ret;
        if (offset >= size) {
                /* offset >= EOF, no bytes will be written */
        read_len = size - offset;
        /* limit to 'len' if it is smaller */
        if (len && len < read_len)
                read_len = len;
        lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob);
        lmb_dump_all(&lmb);
        if (lmb_alloc_addr(&lmb, addr, read_len) == addr)
        printf("** Reading file would overwrite reserved memory **\n");
        return -ENOSPC;
