# lsmod
u_ether 20480 0 - Live 0xbf02d000
usb_f_fs 36864 0 - Live 0xbf023000
libcomposite 53248 1 usb_f_fs, Live 0xbf005000
ns2009 16384 0 - Live 0xbf000000
# ls
g_ffs.ko modules.dep usb_f_mass_storage.ko
g_mass_storage.ko modules.dep.bb usb_f_rndis.ko
g_zero.ko u_ether.ko usb_f_ss_lb.ko
libcomposite.ko usb_f_fs.ko
# insmod usb_f_rndis.ko
# modprobe g_ffs idVendor=0x18d1 idProduct=0x4e42 iSerialNumber="buildroot"
[ 3361.753684] file system registered
# mkdir -p /dev/usb-ffs/adb
# mount -t functionfs adb /dev/usb-ffs/adb -o uid=2000,gid=2000
# adbd &
# install_listener('tcp:5037','*smartsocket*')
cannot bind 'tcp:5037'
[1]+ Done(1) adbd# adb
adb adbd
# adbd
# netstat
netstat netstat-nat
# netstat
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
netstat: /proc/net/tcp: No such file or directory
netstat: /proc/net/tcp6: No such file or directory
netstat: /proc/net/udp: No such file or directory
netstat: /proc/net/udp6: No such file or directory
netstat: /proc/net/raw: No such file or directory
netstat: /proc/net/raw6: No such file or directory
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 3 [ ] DGRAM 1590 /dev/log
unix 2 [ ] DGRAM 1594
# netstat -a
Active Internet connections (servers and established)
Active UNIX domain sockets (servers and established)
# lsmod
g_ffs 16384 1 - Live 0xbf013000
usb_f_rndis 24576 1 g_ffs, Live 0xbf06d000
u_ether 20480 2 g_ffs,usb_f_rndis, Live 0xbf02d000
usb_f_fs 36864 3 g_ffs, Live 0xbf023000
libcomposite 53248 3 g_ffs,usb_f_rndis,usb_f_fs, Live 0xbf005000
ns2009 16384 0 - Live 0xbf000000参考
这个帖子和论坛里一些其他帖子
使用的kernerl -5.2-tf
## 执行adbd 报错,端口监听失败,以为是端口占用了,但是查看没有被占用,初步怀疑是kernel 里的 NET 相关的没有被打开,后来去内核里Networking options 里配置了一番后,发现加载内核的的时候,就卡在了 Starting kernel ... 。。。
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
Setting up a 480x600 lcd console (overscan 0x0)
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
278 bytes read in 15 ms (17.6 KiB/s)
## Executing script at 80c50000
reading zImage
4711848 bytes read in 427 ms (10.5 MiB/s)
10155 bytes read in 31 ms (319.3 KiB/s)
Loading Device Tree to 80e2b000, end 80e307aa ... OK
Starting kernel ... 卡在这里。。。。。。。。。。。。。。。。。。。。。。。。。。。最近编辑记录 小熊猫 (2020-08-26 18:46:23)
结帖 ifconfig 没有回环lo设备,5.2-tf 默认把network options 里的TCP 相关的去掉了,配置上即可,adbd 端口监听就不会失败,
Starting kernel ... 卡在这里。。。。。。。。。。。。。。。。。。。。。。。。。。。### 主要是应该是.config 文件里有手动修改导致编译出来的zimag 有些问题, 基本上按照 https://whycan.cn/t_2794.html 就可以了。。
不知道为啥虚拟机ubuntu 里可以,win10 下确实虚拟出来的是usb串口设备。。。
