楼主 #1 2020-09-05 11:16:52
xel
Tina 生成的img使用PhoenixSuit烧录报错
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
[05.535]Loading Environment from SUNXI_FLASH... OK
[05.540]Net:   [05.541]Net Initialization Skipped
[05.544]No ethernet found.
sunxi work mode=0x10
run usb efex
delay time 2500
weak:otg_phy_config
usb init ok
set address 0x2f
set address 0x2f ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
*************MBR DUMP***************
total mbr part 7
part[0] name      :boot
part[0] classname :DISK
part[0] addrlo    :0x20
part[0] lenlo     :0x1800
part[0] user_type :32768
part[0] keydata   :0
part[0] ro        :0
part[1] name      :rootfs
part[1] classname :DISK
part[1] addrlo    :0x1820
part[1] lenlo     :0x2f00
part[1] user_type :32768
part[1] keydata   :0
part[1] ro        :0
part[2] name      :extend
part[2] classname :DISK
part[2] addrlo    :0x4720
part[2] lenlo     :0x2900
part[2] user_type :32768
part[2] keydata   :0
part[2] ro        :0
part[3] name      :rootfs_data
part[3] classname :DISK
part[3] addrlo    :0x7020
part[3] lenlo     :0x400
part[3] user_type :32768
part[3] keydata   :0
part[3] ro        :0
part[4] name      :env
part[4] classname :DISK
part[4] addrlo    :0x7420
part[4] lenlo     :0x200
part[4] user_type :32768
part[4] keydata   :0
part[4] ro        :0
part[5] name      :misc
part[5] classname :DISK
part[5] addrlo    :0x7620
part[5] lenlo     :0x80
part[5] user_type :32768
part[5] keydata   :0
part[5] ro        :0
part[6] name      :UDISK
part[6] classname :DISK
part[6] addrlo    :0x76a0
part[6] lenlo     :0x0
part[6] user_type :0
part[6] keydata   :0
part[6] ro        :0
need erase flash: 1
no part need to protect user data
erase size: 4096 ,sector size: 4096
total 4096 sectors, erase index 0
total 4096 sectors, erase index 256
total 4096 sectors, erase index 512
total 4096 sectors, erase index 768
total 4096 sectors, erase index 1024
total 4096 sectors, erase index 1280
total 4096 sectors, erase index 1536
total 4096 sectors, erase index 1792
total 4096 sectors, erase index 2048
total 4096 sectors, erase index 2304
total 4096 sectors, erase index 2560
total 4096 sectors, erase index 2816
total 4096 sectors, erase index 3072
total 4096 sectors, erase index 3328
total 4096 sectors, erase index 3584
total 4096 sectors, erase index 3840
SUNXI_EFEX_MBR_TAG
mbr size = 0x4000
write primary GPT success
SF: write offset not multiple of erase size
write Backup GPT success
FEX_CMD_fes_verify_value, start 0x20, size high 0x0:low 0x25e448
FEX_CMD_fes_verify_value 0x670b5304
串口打印之后上位机就报错停止了烧录,有盆友遇到过吗.
#2 2020-09-05 11:27:53
流氓兔
已发帖子: 121
Re: Tina 生成的img使用PhoenixSuit烧录报错
换 MX 的flash试一试, 或者跟踪一下u-boot代码
话说全志的SDK太恶心了。。。
楼主 #3 2020-09-05 13:47:23
xel
流氓兔 说:
话说全志的SDK太恶心了。。。
uboot 是预编译的..
