楼主 #1 2020-11-26 21:43:14
歌以咏志
已发帖子: 219
请问Linux kernel空间和User空间的两个复合 usb gadget 功能怎么玩呢?
https://elinux.org/images/e/ef/USB_Gadget_Configfs_API_0.pdf
FunctionFS added in 2010
○ compositable version of gadgetfs
○ now userspace gadget functions can be combined
with kernel gadget functions in a composite gadget
○ e.g. mass storage (kernel) + MTP (via FunctionFS)
aodzip大佬这个只实现了MTP, 没有mass storage实现
buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 已支持DVP摄像头
http://whycan.com/t_5221.html
#2 2020-11-26 21:56:27
孤星泪
已发帖子: 235
Re: 请问Linux kernel空间和User空间的两个复合 usb gadget 功能怎么玩呢?
好奇搜了一下, 还真有这玩意: http://www.trivialfeat.com/home/2016/11/17/media-transfer-protocol-in-a-usb-composite-gadget
/etc/init.d/S99-gadget
#!/bin/sh
CONFIGFS="/sys/kernel/config"
GADGET="$CONFIGFS/usb_gadget"
VID="0x0000"
PID="0x0000"
SERIAL="0123456789"
MANUF="Me"
PRODUCT="Radget"
case "$1" in
    start)
        echo "Creating the USB gadget"
        echo "Loading composite module"
        modprobe libcomposite
        echo "Mounting ConfigFS"
        mount -t configfs none $CONFIGFS
        cd $GADGET
        if [ $? -ne 0 ]; then
            echo "Error setting up configfs"
            exit 1;
        fi
        echo "Creating gadget directory"
        mkdir gadget
        cd gadget
            echo "Error creating usb gadget in configfs"
            exit 1;
        fi
        echo "Setting Vendor and Product ID's"
        echo $VID > idVendor
        echo $PID > idProduct
        echo "Setting English strings"
        mkdir strings/0x409
        echo $SERIAL > strings/0x409/serialnumber
        echo $MANUF > strings/0x409/manufacturer
        echo $PRODUCT > strings/0x409/product
        echo "Setting configuration"
        mkdir configs/c.1
        mkdir configs/c.1/strings/0x409
        echo "CDC ACM + MTP + Mass Storage" > configs/c.1/strings/0x409/configuration
        echo 120 > configs/c.1/MaxPower
        echo "Creating ACM interface"
        mkdir functions/acm.GS0
        ln -s functions/acm.GS0 configs/c.1
        echo "Creating MTP interface"
        mkdir functions/mtp.mtp
        ln -s functions/mtp.mtp configs/c.1
        mkdir /dev/mtp
        mount -t functionfs mtp /dev/mtp
        echo "Creating Mass Storage interface"
        mkdir functions/mass_storage.ms0
        echo "/dev/mmcblk0" > functions/mass_storage.ms0/lun.0/file
        echo "1" > functions/mass_storage.ms0/lun.0/removable
        ln -s functions/mass_storage.ms0 configs/c.1/mass_storage.ms0
        echo "Binding USB Device Controller"
        echo `ls /sys/class/udc` > UDC
        echo "Starting the MTP responder daemon"
        mtp-server &
    stop)
        echo "Stopping the USB gadget"
        echo "Killing MTP responder daemon"
        killall mtp-server
        cd $GADGET/gadget
            echo "Error: no configfs gadget found"
            exit 1;
        fi
        echo "Unbinding USB Device Controller"
        echo "" > UDC
        echo "Removing Mass Storage interface"
        rm configs/c.1/mass_storage.ms0
        rmdir functions/mass_storage.ms0
        echo "Removing MTP interface"
        umount /dev/mtp
        rmdir /dev/mtp
        rm configs/c.1/mtp.mtp
        rmdir functions/mtp.mtp
        echo "Removing ACM interface"
        rm configs/c.1/acm.GS0
        rmdir functions/acm.GS0
        echo "Clearing English strings"
        rmdir strings/0x409
        echo "Cleaning up configuration"
        rmdir configs/c.1/strings/0x409
        rmdir configs/c.1
        echo "Removing gadget directory"
        cd $GADGET
        rmdir gadget
        cd /
        echo "Unmounting ConfigFS"
        umount $CONFIGFS
esac
楼主 #3 2020-11-26 22:05:12
歌以咏志
已发帖子: 219
太棒了, 我要的就是这玩意, 看来还能整一个adbd进去.
