页次: 1
设备端是esp32+sht30,程序源码:
import bluetooth
from ble_advertising import advertising_payload
from micropython import const
from sht30 import SHT30
import json
sensor = SHT30()
_IRQ_CENTRAL_CONNECT = const(1)
_IRQ_CENTRAL_DISCONNECT = const(2)
_IRQ_GATTS_WRITE = const(3)
_UART_UUID = bluetooth.UUID("6E400001-B5A3-F393-E0A9-E50E24DCCA9E")
_UART_TX = (
bluetooth.UUID("6E400003-B5A3-F393-E0A9-E50E24DCCA9E"),
bluetooth.FLAG_NOTIFY,
_UART_RX = (
bluetooth.UUID("6E400002-B5A3-F393-E0A9-E50E24DCCA9E"),
bluetooth.FLAG_WRITE,
_UART_SERVICE = (
_UART_UUID,
(_UART_TX, _UART_RX,),
# org.bluetooth.characteristic.gap.appearance.xml
_ADV_APPEARANCE_GENERIC_COMPUTER = const(128)
class BLEUART:
def __init__(self, ble, name="mpy-uart", rxbuf=100):
self._ble = ble
self._ble.active(True)
self._ble.irq(handler=self._irq)
((self._tx_handle, self._rx_handle,),) = self._ble.gatts_register_services(
(_UART_SERVICE,)
# Increase the size of the rx buffer and enable append mode.
self._ble.gatts_set_buffer(self._rx_handle, rxbuf, True)
self._connections = set()
self._rx_buffer = bytearray()
self._handler = None
# Optionally add services=[_UART_UUID], but this is likely to make the payload too large.
self._payload = advertising_payload(name=name, appearance=_ADV_APPEARANCE_GENERIC_COMPUTER)
self._advertise()
def irq(self, handler):
self._handler = handler
def _irq(self, event, data):
# Track connections so we can send notifications.
if event == _IRQ_CENTRAL_CONNECT:
conn_handle, _, _, = data
self._connections.add(conn_handle)
elif event == _IRQ_CENTRAL_DISCONNECT:
if conn_handle in self._connections:
self._connections.remove(conn_handle)
# Start advertising again to allow a new connection.
self._advertise()
elif event == _IRQ_GATTS_WRITE:
conn_handle, value_handle, = data
if conn_handle in self._connections and value_handle == self._rx_handle:
self._rx_buffer += self._ble.gatts_read(self._rx_handle)
if self._handler:
self._handler()
def any(self):
return len(self._rx_buffer)
def read(self, sz=None):
if not sz:
sz = len(self._rx_buffer)
result = self._rx_buffer[0:sz]
self._rx_buffer = self._rx_buffer[sz:]
return result
def write(self, data):
for conn_handle in self._connections:
self._ble.gatts_notify(conn_handle, self._tx_handle, data)
def close(self):
self._ble.gap_disconnect(conn_handle)
self._connections.clear()
def _advertise(self, interval_us=500000):
self._ble.gap_advertise(interval_us, adv_data=self._payload)
def demo():
import time
ble = bluetooth.BLE()
uart = BLEUART(ble)
def on_rx():
print("rx: ", uart.read().decode().strip())
uart.irq(handler=on_rx)
#nums = [4, 8, 15, 16, 23, 42]
#i = 0
try:
while True:
temperature, humidity = sensor.measure()
print('Temperature:', temperature, '℃, RH:', humidity, '%')
#uart.write(str(nums[i]) + "\n")
uart.write(json.dumps({"temp":'%.2f' % temperature})) #ble max len 20 bytes
uart.write(json.dumps({"humi":'%.2f' % humidity}))
time.sleep_ms(1000)
except KeyboardInterrupt:
pass
uart.close()
if __name__ == "__main__":
demo()
ble_advertising.py
# Helpers for generating BLE advertising payloads.
import struct
import bluetooth
# Advertising payloads are repeated packets of the following form:
# 1 byte data length (N + 1)
# 1 byte type (see constants below)
# N bytes type-specific data
_ADV_TYPE_FLAGS = const(0x01)
_ADV_TYPE_NAME = const(0x09)
_ADV_TYPE_UUID16_COMPLETE = const(0x3)
_ADV_TYPE_UUID32_COMPLETE = const(0x5)
_ADV_TYPE_UUID128_COMPLETE = const(0x7)
_ADV_TYPE_UUID16_MORE = const(0x2)
_ADV_TYPE_UUID32_MORE = const(0x4)
_ADV_TYPE_UUID128_MORE = const(0x6)
_ADV_TYPE_APPEARANCE = const(0x19)
# Generate a payload to be passed to gap_advertise(adv_data=...).
def advertising_payload(limited_disc=False, br_edr=False, name=None, services=None, appearance=0):
payload = bytearray()
def _append(adv_type, value):
nonlocal payload
payload += struct.pack("BB", len(value) + 1, adv_type) + value
_append(
_ADV_TYPE_FLAGS,
struct.pack("B", (0x01 if limited_disc else 0x02) + (0x18 if br_edr else 0x04)),
if name:
_append(_ADV_TYPE_NAME, name)
if services:
for uuid in services:
b = bytes(uuid)
if len(b) == 2:
_append(_ADV_TYPE_UUID16_COMPLETE, b)
elif len(b) == 4:
_append(_ADV_TYPE_UUID32_COMPLETE, b)
elif len(b) == 16:
_append(_ADV_TYPE_UUID128_COMPLETE, b)
# See org.bluetooth.characteristic.gap.appearance.xml
_append(_ADV_TYPE_APPEARANCE, struct.pack("<h", appearance))
return payload
def decode_field(payload, adv_type):
i = 0
result = []
while i + 1 < len(payload):
if payload[i + 1] == adv_type:
result.append(payload[i + 2 : i + payload[i] + 1])
i += 1 + payload[i]
return result
def decode_name(payload):
n = decode_field(payload, _ADV_TYPE_NAME)
return str(n[0], "utf-8") if n else ""
def decode_services(payload):
services = []
for u in decode_field(payload, _ADV_TYPE_UUID16_COMPLETE):
services.append(bluetooth.UUID(struct.unpack("<h", u)[0]))
for u in decode_field(payload, _ADV_TYPE_UUID32_COMPLETE):
services.append(bluetooth.UUID(struct.unpack("<d", u)[0]))
for u in decode_field(payload, _ADV_TYPE_UUID128_COMPLETE):
services.append(bluetooth.UUID(u))
return services
def demo():
name="micropython",
services=[bluetooth.UUID(0x181A), bluetooth.UUID("6E400001-B5A3-F393-E0A9-E50E24DCCA9E")],
print(payload)
print(decode_name(payload))
print(decode_services(payload))
demo()
蓝牙数据格式是json的字符串:
{"temp":25.5}
{"humi":27.5}
最近编辑记录 kekemuyu (2020-12-28 11:35:38)
哪里买的?
uuid那些好像是要以公司名义申请之后才可以从微信端扫描到ble吧?自己重新写的是不是就不行?
页次: 1
