https://blog.csdn.net/HOLYLANCES/article/details/82018065
存储是以.txt的方式存储token值的 先上代码
<?php
require_once("file_cache.php");
class WeixinUtil{
    private $appId = 'appId ';
    private $appSecret = 'appSecret ';
    //获取AccessToken
    public function getAccessToken(){
        $wx_access_token_cache_key = 'wx_access_token';
        $cache = new FileCache('./access_token.txt');//存储的本地位置
        $token = $cache->get($wx_access_token_cache_key);//去文件中获取token
        if (!$token){//没有的话就创建新的
            $url = "https://api.weixin.qq.com/cgi-bin/token?grant_type=client_credential&appid=".$this->appId."&secret=".$this->appSecret;
            $token = $this->https_curl_json($url,null);
            $cache->set($wx_access_token_cache_key, $token, time()+7000);
        $token = json_decode($token);
        $token = $token->access_token;
        return $token;
    /* 发送json格式的数据,到api接口*/
    public function https_curl_json($url,$data){
        $headers = array("Content-type: application/json;charset=UTF-8","Accept: application/json","Cache-Control: no-cache", "Pragma: no-cache");
        $curl = curl_init();
        curl_setopt($curl, CURLOPT_URL, $url);
        curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, FALSE);
        curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, FALSE);
        if (!empty($data)){
            curl_setopt($curl, CURLOPT_POST, 1);
            curl_setopt($curl, CURLOPT_POSTFIELDS,$data);
        curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
        curl_setopt($curl, CURLOPT_HTTPHEADER, $headers );
        $output = curl_exec($curl);
        if (curl_errno($curl)) {
            echo 'Errno'.curl_error($curl);//捕抓异常
        curl_close($curl);
        return $output;
?>另一个类 用来进行文件操作
<?php
//该类用来配合WeixinUtil.php类 进行token的文件操作
class FileCache{
    private $cache_file;
    private function load(){
        if(file_exists($this->cache_file)){
            $content = file_get_contents($this->cache_file);
            if (strlen($content) > 0){
                $data = json_decode($content);
                return $data;
        return array();
    private function save($data){
        $content = json_encode($data);
        return file_put_contents($this->cache_file, $content);
    public function __construct($filename) {
        $this->cache_file = $filename;
    public function get($key){
        $data = $this->load();
        foreach($data as $item){
            if ($item->key == $key){
                if ($item->expire_time > time()){
                    return $item->value;
                break;
        return NULL;
    public function set($key, $value, $expire_time=NULL){
        $obj = NULL;
                $obj = $item;
                $obj->value = $value;
                if ($expire_time != NULL){
                    $obj->expire_time = $expire_time;
                break;
        if ($obj == NULL){
            $obj = new CacheItem($key, $value, $expire_time);
            array_push($data, $obj);
        return $this->save($data);
class CacheItem{
    public $key;
    public $value;
    public $expire_time;
    public function __construct($key, $value, $expire_time) {
        $this->key = $key;
        $this->value = $value;
        $this->expire_time = $expire_time;
?>最后 测试类
<?php
include "WeixinUtil.php";
$wx = new WeixinUtil();
echo $wx->getAccessToken();第二个类来自https://www.cnblogs.com/hydonlee/p/5419063.html
18/9/11
access_token存储在DB里,参考文章↓
用session保存不是更好么?
用session保存不是更好么?
session 不能分布式布局的。token可以方便改为分布式。
