来自: https://learnopengl.com/Getting-started/Hello-Window
hello_window_clear.cpp:
#include <glad/glad.h>
#include <GLFW/glfw3.h>
#include <iostream>
void framebuffer_size_callback(GLFWwindow* window, int width, int height);
void processInput(GLFWwindow *window);
// settings
const unsigned int SCR_WIDTH = 800;
const unsigned int SCR_HEIGHT = 600;
int main()
// glfw: initialize and configure
glfwInit();
glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
#ifdef __APPLE__
glfwWindowHint(GLFW_OPENGL_FORWARD_COMPAT, GL_TRUE);
// glfw window creation
GLFWwindow* window = glfwCreateWindow(SCR_WIDTH, SCR_HEIGHT, "LearnOpenGL", NULL, NULL);
if (window == NULL)
std::cout << "Failed to create GLFW window" << std::endl;
glfwTerminate();
return -1;
glfwMakeContextCurrent(window);
glfwSetFramebufferSizeCallback(window, framebuffer_size_callback);
// glad: load all OpenGL function pointers
if (!gladLoadGLLoader((GLADloadproc)glfwGetProcAddress))
std::cout << "Failed to initialize GLAD" << std::endl;
return -1;
// render loop
while (!glfwWindowShouldClose(window))
// input
processInput(window);
// render
glClearColor(0.2f, 0.3f, 0.3f, 1.0f);
glClear(GL_COLOR_BUFFER_BIT);
// glfw: swap buffers and poll IO events (keys pressed/released, mouse moved etc.)
glfwSwapBuffers(window);
glfwPollEvents();
// glfw: terminate, clearing all previously allocated GLFW resources.
glfwTerminate();
// process all input: query GLFW whether relevant keys are pressed/released this frame and react accordingly
if(glfwGetKey(window, GLFW_KEY_ESCAPE) == GLFW_PRESS)
glfwSetWindowShouldClose(window, true);
// glfw: whenever the window size changed (by OS or user resize) this callback function executes
// make sure the viewport matches the new window dimensions; note that width and
// height will be significantly larger than specified on retina displays.
glViewport(0, 0, width, height);
}nuget 安装 nupengl 软件包:
添加 include\glad\glad.h include\KHR\khrplatform.h src\glad.c 文件:
glad.c 添加到工程:
运行结果:
Visual C++ 2017工程打包: Project7_opengl_glfw_clear.7z
OpenGL 画虚线代码:
//画 虚线 ,点线,通过glLineStipple设置虚线模型,然后enable GL_LINE_STIPPLE开关
glLineStipple(2, 0x5555);
glEnable(GL_LINE_STIPPLE);
glBegin(GL_LINES);
glVertex3f(0.25,0.85,0.6);
glVertex3f(0.75,0.85,0.6);
glEnd();
//结束画虚线
glDisable(GL_LINE_STIPPLE);离线
glOrtho 设置原点
glGenRenderbuffers OpenGL离屏渲染
https://stackoverflow.com/questions/12157646/how-to-render-offscreen-on-opengl
https://www.cnblogs.com/1024Planet/p/5650131.html
#include <stdio.h>
#include <Windows.h>
#include <gl/glut.h>
功能描述:使用OpenGL简单画一个虚心水壶
缩放变换函数glScalef
//输出模式,0-单缓存模式;非0双缓存模式
#define OUTPUT_MODE 1
float scale = 0.0;
bool add = true;
unsigned char axle = 'x';
void init(void)
//glClearColor函数设置好清除颜色,glClear利用glClearColor函数设置好的当前清除颜色设置窗口颜色
glClearColor(1.0, 1.0, 0.8, 1.0);
void display(void)
printf("scale=%f, axle=%c\n", scale, axle);
//配置缩放比例大小scale
scale = (add ? scale + 0.1 : scale - 0.1);
if (scale >= 2.0)
add = false;
} else if (scale <= 0.0) {
add = true;
//开始绘画
glPushMatrix();
if (axle == 'x') {
glScalef(scale, 1, 1);
} else if (axle == 'y') {
glScalef(1, scale, 1);
} else if (axle == 'z') {
glScalef(1, 1, scale);
} else {
glScalef(scale, scale, scale);
glColor3f (1.0, 0.0, 1.0); //画笔梅红色
glBegin(GL_POLYGON);
glVertex2f(-0.2, -0.2);
glVertex2f(-0.2, 0.2);
glVertex2f(0.2, 0.2);
glVertex2f(0.2, -0.2);
glEnd();
glPopMatrix();
glLoadIdentity(); //加载单位矩阵
glColor3f (0.0, 0.0, 1.0); //画笔蓝色
//--------画直线START--------
//画直线
glBegin(GL_LINES);
glVertex2f(-0.5, 0);
glVertex2f(0.5, 0);
glVertex2f(0, 0.5);
glVertex2f(0, -0.5);
glEnd();
//--------画直线E N D--------
if (OUTPUT_MODE == 0) {
glFlush();//单缓存GLUT_SINGLE时使用
} else {
glutSwapBuffers();//因为使用的是双缓存GLUT_DOUBLE,所以这里必须要交换缓存才会显示
Sleep(50);
void reshape(int w, int h)
int offset = 50;
int dis = (w > h ? h : w) - offset * 2;
//配置显示物体屏幕的大小
glViewport(offset, offset, (GLsizei)dis, (GLsizei)dis);
printf("reshape: w=%d, h=%d, dis=%d\n", w, h, dis);
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
glOrtho(-1.5, 1.5, -1.5, 1.5, 0, 10);
//gluOrtho2D(-1.5, 1.5, -1.5, 1.5);
glMatrixMode(GL_MODELVIEW);
glLoadIdentity();
void keyboard(unsigned char key, int x, int y)
switch (key) {
case 'x':
case 'X':
axle = 'x';
glutPostRedisplay();
break;
case 'y':
case 'Y':
axle = 'y';
break;
case 'z':
case 'Z':
axle = 'z';
break;
case 'a':
case 'A':
axle = 'a';
break;
default:
break;
printf("按键%c\n", key);
printf("可通过按键xyza控制图形按哪一轴缩放\n");
glutInit(&argc, argv);
glutInitDisplayMode(GLUT_RGB | (OUTPUT_MODE == 0 ? GLUT_SINGLE : GLUT_DOUBLE));
glutInitWindowPosition(100, 100);
glutInitWindowSize(400, 400);
glutCreateWindow("第一个 OpenGL 程序");
init();
glutDisplayFunc(&display);
glutIdleFunc(display); //设置不断调用显示函数
glutReshapeFunc(reshape);
glutKeyboardFunc(keyboard);
glutMainLoop();
}离线
#include <GL/glut.h>
//窗口长宽
int width = 400, height = 400;
//鼠标点击位置
int hit_pos_x, hit_pos_y;
//鼠标拖动位置
int move_pos_x, move_pos_y;
//鼠标操作种类
int button_kind = -1;
void display()
// 清除屏幕
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
//重新设置OpenGL窗口:原点位置为左上角,x轴从左到右,y轴从上到下,坐标值与像素坐标值相同
glViewport(0, 0, (GLsizei)width, (GLsizei)height);
glLoadIdentity();
gluOrtho2D(0, width, height, 0);
if (button_kind == 0) //左键点击
//画一个蓝色的点
glPointSize(20);
glBegin(GL_POINTS);
glColor3f(0.0f, 0.0f, 1.0f);
glVertex2f(hit_pos_x, hit_pos_y);
glEnd();
else if (button_kind == 2) //右键点击
//画一个绿色的点
glPointSize(20);
glBegin(GL_POINTS);
glColor3f(0.0f, 1.0f, 0.0f);
glEnd();
else if (button_kind == 3) //鼠标拖动
//沿拖动轨迹画一条红色的线
glLineWidth(5);
glColor3f(1.0f, 0.0f, 0.0f);
glBegin(GL_LINES);
glVertex2f(move_pos_x, move_pos_y);
glEnd();
//双缓存交换缓存以显示图像
glutSwapBuffers();
//每次更新显示
void mouse_hit(int button, int state, int x, int y)
//鼠标操作种类赋值
button_kind = button;
//鼠标操作基本结构
switch (button)
case GLUT_LEFT_BUTTON: //左键操作,也可为数字0
if (state == GLUT_DOWN) //左键按下时
//记录按键位置
hit_pos_x = x;
hit_pos_y = y;
break;
case GLUT_RIGHT_BUTTON: //右键操作,也可为数字1
if (state == GLUT_DOWN) //右键按下时
//记录按键位置
hit_pos_x = x;
hit_pos_y = y;
break;
default:
break;
void mouse_move(int x, int y)
//鼠标移动时操作种类设为3(0 1 2分别为左键、中键、右键)
button_kind = 3;
//记录拖动位置
move_pos_x = x;
move_pos_y = y;
void main(int argc, char** argv)
//初始化GL
//设置显示参数(双缓存,RGB格式)
glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB);
//设置窗口尺寸:width*height
glutInitWindowSize(width, height);
//设置窗口位置:在屏幕左上角像素值(100,100)处
//设置窗口名称
glutCreateWindow("OpenGL");
//显示函数,display事件需要自行编写
glutDisplayFunc(display);
//鼠标点击函数,mouse_hit事件需要自行编写
glutMouseFunc(mouse_hit);
//鼠标拖动函数,mouse_move事件需要自行编写
glutMotionFunc(mouse_move);
//重复循环GLUT事件
glutMainLoop();
}https://zhuanlan.zhihu.com/p/24735850
OpenGL鼠标操作
glEnable(GL_POINT_SMOOTH); //打圆形点
glDisable(GL_POINT_SMOOTH); //打方形点
打点过程:
//画一个蓝色的点
glPointSize(20);
glBegin(GL_POINTS);
glEnd();离线
glut 的设计有问题, 单核CPU占用率100%, 双核占用率50%, 这里有讨论:
https://community.khronos.org/t/100-cpu-usage/63231/6
glutIdleFunc()在单核上占用100%的CPU,在双核上占用50%的CPU。
如何在不使用Shrieks Win32“ Sleep()”函数的情况下解决CPU使用率过高的问题?
我可以经常使用glutTimerFunc()来glutPostRedisplay(),但我想知道是否有更清洁的方法吗?
https://gamedev.net/forums/topic/388780-glut-100-cpu-issue/3571642/
嘿,希望有人能希望能帮助我解决我遇到的问题。基本上,我创建了一个GLUT应用程序,每次我编译并运行它时都会达到100%的CPU使用率。奇怪而令人困惑的是,它在任何其他PC上都能正常工作,如果我在PC上运行任何其他GLUT应用程序,它只会使我的CPU耗尽。有任何想法吗?
