楼主 #1 2021-01-05 09:20:32
流氓兔
已发帖子: 121
Visual C++ 编译一个OpenGL Demo
来自: https://learnopengl.com/Getting-started/Hello-Window
https://learnopengl.com/code_viewer_gh.php?code=src/1.getting_started/1.2.hello_window_clear/hello_window_clear.cpp
hello_window_clear.cpp:
#include <glad/glad.h>
#include <GLFW/glfw3.h>
#include <iostream>
void framebuffer_size_callback(GLFWwindow* window, int width, int height);
void processInput(GLFWwindow *window);
// settings
const unsigned int SCR_WIDTH = 800;
const unsigned int SCR_HEIGHT = 600;
int main()
    // glfw: initialize and configure
    glfwInit();
    glfwWindowHint(GLFW_CONTEXT_VERSION_MAJOR, 3);
    glfwWindowHint(GLFW_CONTEXT_VERSION_MINOR, 3);
    glfwWindowHint(GLFW_OPENGL_PROFILE, GLFW_OPENGL_CORE_PROFILE);
#ifdef __APPLE__
    glfwWindowHint(GLFW_OPENGL_FORWARD_COMPAT, GL_TRUE);
    // glfw window creation
    GLFWwindow* window = glfwCreateWindow(SCR_WIDTH, SCR_HEIGHT, "LearnOpenGL", NULL, NULL);
    if (window == NULL)
        std::cout << "Failed to create GLFW window" << std::endl;
        glfwTerminate();
        return -1;
    glfwMakeContextCurrent(window);
    glfwSetFramebufferSizeCallback(window, framebuffer_size_callback);
    // glad: load all OpenGL function pointers
    if (!gladLoadGLLoader((GLADloadproc)glfwGetProcAddress))
        std::cout << "Failed to initialize GLAD" << std::endl;
        return -1;
    // render loop
    while (!glfwWindowShouldClose(window))
        // input
        processInput(window);
        // render
        glClearColor(0.2f, 0.3f, 0.3f, 1.0f);
        glClear(GL_COLOR_BUFFER_BIT);
        // glfw: swap buffers and poll IO events (keys pressed/released, mouse moved etc.)
        glfwSwapBuffers(window);
        glfwPollEvents();
    // glfw: terminate, clearing all previously allocated GLFW resources.
    glfwTerminate();
// process all input: query GLFW whether relevant keys are pressed/released this frame and react accordingly
    if(glfwGetKey(window, GLFW_KEY_ESCAPE) == GLFW_PRESS)
        glfwSetWindowShouldClose(window, true);
// glfw: whenever the window size changed (by OS or user resize) this callback function executes
    // make sure the viewport matches the new window dimensions; note that width and
    // height will be significantly larger than specified on retina displays.
    glViewport(0, 0, width, height);
nuget 安装 nupengl 软件包:
添加 include\glad\glad.h   include\KHR\khrplatform.h   src\glad.c 文件:
glad.c 添加到工程:
运行结果:
楼主 #2 2021-01-05 09:23:48
流氓兔
已发帖子: 121
Re: Visual C++ 编译一个OpenGL Demo
Visual C++ 2017工程打包: Project7_opengl_glfw_clear.7z
#3 2021-01-05 11:39:20
拉轰的脚踏车
已发帖子: 288
OpenGL 画虚线代码:
//画 虚线 ,点线,通过glLineStipple设置虚线模型,然后enable GL_LINE_STIPPLE开关
glLineStipple(2, 0x5555);
glEnable(GL_LINE_STIPPLE);
glBegin(GL_LINES);
glVertex3f(0.25,0.85,0.6);
glVertex3f(0.75,0.85,0.6);
glEnd();
//结束画虚线
glDisable(GL_LINE_STIPPLE);
#4 2021-01-05 11:58:59
拉轰的脚踏车
已发帖子: 288
glOrtho 设置原点
glGenRenderbuffers OpenGL离屏渲染
https://stackoverflow.com/questions/12157646/how-to-render-offscreen-on-opengl
#5 2021-01-06 11:35:14
拉轰的脚踏车
已发帖子: 288
https://www.cnblogs.com/1024Planet/p/5650131.html
#include <stdio.h>
#include <Windows.h>
#include <gl/glut.h>
 功能描述:使用OpenGL简单画一个虚心水壶
 缩放变换函数glScalef
//输出模式,0-单缓存模式;非0双缓存模式
#define OUTPUT_MODE 1
float scale = 0.0;
bool add = true;
unsigned char axle = 'x';
void init(void)
    //glClearColor函数设置好清除颜色,glClear利用glClearColor函数设置好的当前清除颜色设置窗口颜色
    glClearColor(1.0, 1.0, 0.8, 1.0);
void display(void)
    printf("scale=%f, axle=%c\n", scale, axle);
    //配置缩放比例大小scale
    scale = (add ? scale + 0.1 : scale - 0.1);
    if (scale >= 2.0)
        add = false;
    } else if (scale <= 0.0) {
        add = true;
    //开始绘画
    glPushMatrix();
        if (axle == 'x') {
            glScalef(scale, 1, 1);
        } else if (axle == 'y') {
            glScalef(1, scale, 1);
        } else if (axle == 'z') {
            glScalef(1, 1, scale);
        } else {
            glScalef(scale, scale, scale);
        glColor3f (1.0, 0.0, 1.0); //画笔梅红色
        glBegin(GL_POLYGON);
        glVertex2f(-0.2, -0.2);
        glVertex2f(-0.2, 0.2);
        glVertex2f(0.2, 0.2);
        glVertex2f(0.2, -0.2);
        glEnd();
    glPopMatrix();
    glLoadIdentity();  //加载单位矩阵
    glColor3f (0.0, 0.0, 1.0); //画笔蓝色
    //--------画直线START--------
    //画直线
    glBegin(GL_LINES);
    glVertex2f(-0.5, 0);
    glVertex2f(0.5, 0);
    glVertex2f(0, 0.5);
    glVertex2f(0, -0.5);
    glEnd();
    //--------画直线E N D--------
    if (OUTPUT_MODE == 0) {
        glFlush();//单缓存GLUT_SINGLE时使用
    } else {
        glutSwapBuffers();//因为使用的是双缓存GLUT_DOUBLE,所以这里必须要交换缓存才会显示
    Sleep(50);
void reshape(int w, int h)
    int offset = 50;
    int dis = (w > h ? h : w) - offset * 2;
    //配置显示物体屏幕的大小
    glViewport(offset, offset, (GLsizei)dis, (GLsizei)dis);
    printf("reshape: w=%d, h=%d, dis=%d\n", w, h, dis);
    glMatrixMode(GL_PROJECTION);
    glLoadIdentity();
    glOrtho(-1.5, 1.5, -1.5, 1.5, 0, 10);
    //gluOrtho2D(-1.5, 1.5, -1.5, 1.5);
    glMatrixMode(GL_MODELVIEW);
    glLoadIdentity();
void keyboard(unsigned char key, int x, int y)
    switch (key) {
        case 'x':
        case 'X':
            axle = 'x';
            glutPostRedisplay();
            break;
        case 'y':
        case 'Y':
            axle = 'y';
            break;
        case 'z':
        case 'Z':
            axle = 'z';
            break;
        case 'a':
        case 'A':
            axle = 'a';
            break;
        default:
            break;
    printf("按键%c\n", key);
    printf("可通过按键xyza控制图形按哪一轴缩放\n");
    glutInit(&argc, argv);
    glutInitDisplayMode(GLUT_RGB | (OUTPUT_MODE == 0 ? GLUT_SINGLE : GLUT_DOUBLE));
    glutInitWindowPosition(100, 100);
    glutInitWindowSize(400, 400);
    glutCreateWindow("第一个 OpenGL 程序");
    init();
    glutDisplayFunc(&display);
    glutIdleFunc(display);  //设置不断调用显示函数
    glutReshapeFunc(reshape);
    glutKeyboardFunc(keyboard);
    glutMainLoop();
#6 2021-01-06 11:56:49
拉轰的脚踏车
已发帖子: 288
#include <GL/glut.h>
//窗口长宽
int width = 400, height = 400;
//鼠标点击位置
int hit_pos_x, hit_pos_y;
//鼠标拖动位置
int move_pos_x, move_pos_y;
//鼠标操作种类
int button_kind = -1;
void display()
	// 清除屏幕
	glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
	//重新设置OpenGL窗口:原点位置为左上角,x轴从左到右,y轴从上到下,坐标值与像素坐标值相同
	glViewport(0, 0, (GLsizei)width, (GLsizei)height);
	glLoadIdentity();
	gluOrtho2D(0, width, height, 0);
	if (button_kind == 0)	//左键点击
		//画一个蓝色的点
		glPointSize(20);
		glBegin(GL_POINTS);
		glColor3f(0.0f, 0.0f, 1.0f);
		glVertex2f(hit_pos_x, hit_pos_y);
		glEnd();
	else if (button_kind == 2)	//右键点击
		//画一个绿色的点
		glPointSize(20);
		glBegin(GL_POINTS);
		glColor3f(0.0f, 1.0f, 0.0f);
		glEnd();
	else if (button_kind == 3)	//鼠标拖动
		//沿拖动轨迹画一条红色的线
		glLineWidth(5);
		glColor3f(1.0f, 0.0f, 0.0f);
		glBegin(GL_LINES);
		glVertex2f(move_pos_x, move_pos_y);
		glEnd();
	//双缓存交换缓存以显示图像
	glutSwapBuffers();
	//每次更新显示
void mouse_hit(int button, int state, int x, int y)
	//鼠标操作种类赋值
	button_kind = button;
	//鼠标操作基本结构
	switch (button)
	case GLUT_LEFT_BUTTON:	//左键操作,也可为数字0
		if (state == GLUT_DOWN)	//左键按下时
			//记录按键位置
			hit_pos_x = x;
			hit_pos_y = y;
		break;
	case GLUT_RIGHT_BUTTON:	//右键操作,也可为数字1
		if (state == GLUT_DOWN)	//右键按下时
			//记录按键位置
			hit_pos_x = x;
			hit_pos_y = y;
		break;
	default:
		break;
void mouse_move(int x, int y)
	//鼠标移动时操作种类设为3(0 1 2分别为左键、中键、右键)
	button_kind = 3;
	//记录拖动位置
	move_pos_x = x;
	move_pos_y = y;
void main(int argc, char** argv)
	//初始化GL
	//设置显示参数(双缓存,RGB格式)
	glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB);
	//设置窗口尺寸:width*height
	glutInitWindowSize(width, height);
	//设置窗口位置:在屏幕左上角像素值(100,100)处
	//设置窗口名称
	glutCreateWindow("OpenGL");
	//显示函数,display事件需要自行编写
	glutDisplayFunc(display);
	//鼠标点击函数,mouse_hit事件需要自行编写
	glutMouseFunc(mouse_hit);
	//鼠标拖动函数,mouse_move事件需要自行编写
	glutMotionFunc(mouse_move);
	//重复循环GLUT事件
	glutMainLoop();
https://zhuanlan.zhihu.com/p/24735850
OpenGL鼠标操作
#7 2021-01-06 15:13:09
拉轰的脚踏车
已发帖子: 288
glEnable(GL_POINT_SMOOTH); //打圆形点
glDisable(GL_POINT_SMOOTH); //打方形点
打点过程:
		//画一个蓝色的点
		glPointSize(20);
		glBegin(GL_POINTS);
		glEnd();
#8 2021-01-06 15:43:57
拉轰的脚踏车
已发帖子: 288
glut 的设计有问题, 单核CPU占用率100%, 双核占用率50%, 这里有讨论:
https://community.khronos.org/t/100-cpu-usage/63231/6
glutIdleFunc()在单核上占用100%的CPU,在双核上占用50%的CPU。
如何在不使用Shrieks Win32“ Sleep()”函数的情况下解决CPU使用率过高的问题?
我可以经常使用glutTimerFunc()来glutPostRedisplay(),但我想知道是否有更清洁的方法吗?
https://gamedev.net/forums/topic/388780-glut-100-cpu-issue/3571642/
嘿,希望有人能希望能帮助我解决我遇到的问题。基本上,我创建了一个GLUT应用程序,每次我编译并运行它时都会达到100%的CPU使用率。奇怪而令人困惑的是,它在任何其他PC上都能正常工作,如果我在PC上运行任何其他GLUT应用程序,它只会使我的CPU耗尽。有任何想法吗?
