U-Boot 2017.01-rc2 (Jan 06 2021 - 14:51:53 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
No controllers found
## Loading init Ramdisk from Legacy Image at 41a00000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 5909439 Bytes = 5.6 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Loading Ramdisk to 4285d000, end 42dffbbf ... OK
Loading Device Tree to 42857000, end 4285cc6f ... OK
[ 0.000000] Linux version 4.14.14-licheepi-zero (root@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #4 SMP Thu Jan 7 15:36:33 CST 2021
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] random: fast init done
[ 0.000000] percpu: Embedded 16 pages/cpu @c3f5f000 s33740 r8192 d23604 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/ram0 rdinit=/linuxrc earlyprintk rw
[ 0.000000] Memory: 49256K/65536K available (6144K kernel code, 280K rwdata, 1308K rodata, 1024K init, 255K bss, 16280K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a46380 ( 281 kB)
[ 0.000000] .bss : 0xc0a4d5b0 - 0xc0a8d2e4 ( 256 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000182] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000417] Console: colour dummy device 80x30
[ 0.000455] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000470] pid_max: default: 32768 minimum: 301
[ 0.000600] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001260] CPU: Testing write buffer coherency: ok
[ 0.001644] /cpus/cpu@0 missing clock-frequency property
[ 0.001669] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002126] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002301] Hierarchical SRCU implementation.
[ 0.002827] smp: Bringing up secondary CPUs ...
[ 0.002841] smp: Brought up 1 node, 1 CPU
[ 0.002850] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002857] CPU: All CPU(s) started in SVC mode.
[ 0.003627] devtmpfs: initialized
[ 0.006607] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006911] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006940] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007119] pinctrl core: initialized pinctrl subsystem
[ 0.008104] NET: Registered protocol family 16
[ 0.008539] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009540] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009558] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.020886] SCSI subsystem initialized
[ 0.021138] usbcore: registered new interface driver usbfs
[ 0.021205] usbcore: registered new interface driver hub
[ 0.021298] usbcore: registered new device driver usb
[ 0.021533] pps_core: LinuxPPS API ver. 1 registered
[ 0.021544] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.021565] PTP clock support registered
[ 0.021741] Advanced Linux Sound Architecture Driver Initialized.
[ 0.023400] clocksource: Switched to clocksource arch_sys_counter
[ 0.032737] NET: Registered protocol family 2
[ 0.033307] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.033341] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.033431] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.033574] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.033620] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.033843] NET: Registered protocol family 1
[ 0.034546] RPC: Registered named UNIX socket transport module.
[ 0.034568] RPC: Registered udp transport module.
[ 0.034574] RPC: Registered tcp transport module.
[ 0.034580] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.034854] Unpacking initramfs...
[ 0.426805] Freeing initrd memory: 5772K
[ 0.428442] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.434359] NFS: Registering the id_resolver key type
[ 0.434410] Key type id_resolver registered
[ 0.434417] Key type id_legacy registered
[ 0.438169] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.438194] io scheduler noop registered
[ 0.438201] io scheduler deadline registered
[ 0.438505] io scheduler cfq registered (default)
[ 0.438520] io scheduler mq-deadline registered
[ 0.438527] io scheduler kyber registered
[ 0.439101] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.442365] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.503780] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.506660] console [ttyS0] disabled
[ 0.526930] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 1.107582] console [ttyS0] enabled
[ 1.112769] libphy: Fixed MDIO Bus: probed
[ 1.117417] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 1.123210] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 1.129011] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 1.135238] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 1.140902] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 1.148155] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 1.153825] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 1.161037] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 1.166008] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 1.172983] libphy: stmmac: probed
[ 1.181745] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.188411] ehci-platform: EHCI generic platform driver
[ 1.193953] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.199563] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.207552] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 1.243428] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.250527] hub 1-0:1.0: USB hub found
[ 1.254503] hub 1-0:1.0: 1 port detected
[ 1.259002] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.265307] ohci-platform: OHCI generic platform driver
[ 1.270837] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.277583] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.285532] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 1.358382] hub 2-0:1.0: USB hub found
[ 1.362207] hub 2-0:1.0: 1 port detected
[ 1.367665] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.377206] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.386087] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.392882] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.397540] i2c /dev entries driver
[ 1.401248] IR NEC protocol handler initialized
[ 1.405839] IR RC5(x/sz) protocol handler initialized
[ 1.410885] IR RC6 protocol handler initialized
[ 1.415427] IR JVC protocol handler initialized
[ 1.419950] IR Sony protocol handler initialized
[ 1.424572] IR SANYO protocol handler initialized
[ 1.429269] IR Sharp protocol handler initialized
[ 1.433976] IR MCE Keyboard/mouse protocol handler initialized
[ 1.439799] IR XMP protocol handler initialized
[ 1.445001] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.513445] sunxi-mmc 1c0f000.mmc: base:0xc487d000 irq:23
[ 1.573435] sunxi-mmc 1c10000.mmc: base:0xc4983000 irq:24
[ 1.579745] usbcore: registered new interface driver usbhid
[ 1.585399] usbhid: USB HID core driver
[ 1.590732] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.598786] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.607512] NET: Registered protocol family 17
[ 1.612081] Key type dns_resolver registered
[ 1.616614] Registering SWP/SWPB emulation handler
[ 1.628918] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.640358] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.646198] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.655169] hub 3-0:1.0: USB hub found
[ 1.659010] hub 3-0:1.0: 1 port detected
[ 1.664114] using random self ethernet address
[ 1.668569] using random host ethernet address
[ 1.673972] usb0: HOST MAC 8a:e8:3a:16:99:33
[ 1.678288] usb0: MAC 42:ef:bb:d4:c4:6e
[ 1.682180] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.689744] g_cdc gadget: g_cdc ready
[ 1.695870] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.704525] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 04:50:13 UTC (17413)
[ 1.713051] vcc5v0: disabling
[ 1.716101] ALSA device list:
[ 1.719069] #0: V3s Audio Codec
[ 1.724388] Freeing unused kernel memory: 1024K
[ 1.732419] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.748665] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.759817] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.772285] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.783795] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.793683] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.801542] mmc1: new high speed SDIO card at address 0001
Starting logging: OK
Starting network: OK
/ # ls /dev/s*
/dev/shm:
