git clone https://github.com/u-boot/u-boot.git -b v2020.04
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make Sinlinx_SinA33_defconfig
修改 .config 的
CONFIG_MMC0_CD_PIN="PB4"
CONFIG_MMC0_CD_PIN="PL9"
然后编译:
开启ums命令:
CONFIG_CMD_USB_MASS_STORAGE=y
#0延时
CONFIG_BOOTDELAY=0
#开启启动eMMC模拟U盘
CONFIG_BOOTCOMMAND="ums 0 mmc 1"
Win32diskImager 烧录这个固件到TF卡启动就能用USB把eMMC模拟成U盘了: smallwit_x3_usb_burn_emmc_2020_01.img
# U-Boot 2020.01 Configuration
CONFIG_CREATE_ARCH_SYMLINK=y
# CONFIG_ARC is not set
CONFIG_ARM=y
# CONFIG_M68K is not set
# CONFIG_MICROBLAZE is not set
# CONFIG_MIPS is not set
# CONFIG_NDS32 is not set
# CONFIG_NIOS2 is not set
# CONFIG_PPC is not set
# CONFIG_RISCV is not set
# CONFIG_SANDBOX is not set
# CONFIG_SH is not set
# CONFIG_X86 is not set
# CONFIG_XTENSA is not set
CONFIG_SYS_ARCH="arm"
CONFIG_SYS_CPU="armv7"
CONFIG_SYS_SOC="sunxi"
CONFIG_SYS_BOARD="sunxi"
CONFIG_SYS_CONFIG_NAME="sun8i"
# CONFIG_SYS_ICACHE_OFF is not set
# CONFIG_SPL_SYS_ICACHE_OFF is not set
# CONFIG_SYS_DCACHE_OFF is not set
# CONFIG_SPL_SYS_DCACHE_OFF is not set
# ARM architecture
CONFIG_HAS_VBAR=y
CONFIG_HAS_THUMB2=y
CONFIG_ARM_ASM_UNIFIED=y
CONFIG_SYS_ARM_CACHE_CP15=y
CONFIG_SYS_ARM_MMU=y
# CONFIG_SYS_ARM_MPU is not set
CONFIG_CPU_V7A=y
CONFIG_SYS_ARM_ARCH=7
CONFIG_SYS_CACHE_SHIFT_6=y
CONFIG_SYS_CACHELINE_SIZE=64
# CONFIG_ARCH_CPU_INIT is not set
# CONFIG_SYS_ARCH_TIMER is not set
# CONFIG_ARM_SMCCC is not set
# CONFIG_SEMIHOSTING is not set
CONFIG_SYS_THUMB_BUILD=y
CONFIG_SPL_SYS_THUMB_BUILD=y
# CONFIG_SYS_L2CACHE_OFF is not set
# CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set
CONFIG_USE_ARCH_MEMCPY=y
CONFIG_SPL_USE_ARCH_MEMCPY=y
CONFIG_USE_ARCH_MEMSET=y
CONFIG_SPL_USE_ARCH_MEMSET=y
# CONFIG_SET_STACK_SIZE is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_TARGET_EDB93XX is not set
# CONFIG_TARGET_ASPENITE is not set
# CONFIG_TARGET_GPLUGD is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_KIRKWOOD is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_TARGET_APF27 is not set
# CONFIG_ORION5X is not set
# CONFIG_TARGET_SPEAR300 is not set
# CONFIG_TARGET_SPEAR310 is not set
# CONFIG_TARGET_SPEAR320 is not set
# CONFIG_TARGET_SPEAR600 is not set
# CONFIG_TARGET_STV0991 is not set
# CONFIG_TARGET_X600 is not set
# CONFIG_TARGET_WOODBURN is not set
# CONFIG_TARGET_WOODBURN_SD is not set
# CONFIG_TARGET_FLEA3 is not set
# CONFIG_TARGET_MX35PDK is not set
# CONFIG_ARCH_BCM283X is not set
# CONFIG_ARCH_BCM63158 is not set
# CONFIG_ARCH_BCM6858 is not set
# CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set
# CONFIG_ARCH_BCMSTB is not set
# CONFIG_TARGET_VEXPRESS_CA5X2 is not set
# CONFIG_TARGET_VEXPRESS_CA9X4 is not set
# CONFIG_TARGET_BCM23550_W1D is not set
# CONFIG_TARGET_BCM28155_AP is not set
# CONFIG_TARGET_BCMCYGNUS is not set
# CONFIG_TARGET_BCMNSP is not set
# CONFIG_TARGET_BCMNS2 is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_S5PC1XX is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_K3 is not set
# CONFIG_ARCH_OMAP2PLUS is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_IMX8 is not set
# CONFIG_ARCH_IMX8M is not set
# CONFIG_ARCH_MX23 is not set
# CONFIG_ARCH_MX25 is not set
# CONFIG_ARCH_MX28 is not set
# CONFIG_ARCH_MX31 is not set
# CONFIG_ARCH_MX7ULP is not set
# CONFIG_ARCH_MX7 is not set
# CONFIG_ARCH_MX6 is not set
CONFIG_SPL_LDSCRIPT="arch/arm/cpu/armv7/sunxi/u-boot-spl.lds"
# CONFIG_ARCH_MX5 is not set
# CONFIG_ARCH_OWL is not set
# CONFIG_ARCH_QEMU is not set
# CONFIG_ARCH_RMOBILE is not set
# CONFIG_TARGET_S32V234EVB is not set
# CONFIG_ARCH_SNAPDRAGON is not set
# CONFIG_ARCH_SOCFPGA is not set
CONFIG_ARCH_SUNXI=y
# CONFIG_ARCH_VERSAL is not set
# CONFIG_ARCH_VF610 is not set
# CONFIG_ARCH_ZYNQ is not set
# CONFIG_ARCH_ZYNQMP_R5 is not set
# CONFIG_ARCH_ZYNQMP is not set
# CONFIG_TEGRA is not set
# CONFIG_TARGET_VEXPRESS64_AEMV8A is not set
# CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set
# CONFIG_TARGET_VEXPRESS64_JUNO is not set
# CONFIG_TARGET_LS2080A_EMU is not set
# CONFIG_TARGET_LS2080A_SIMU is not set
# CONFIG_TARGET_LS1088AQDS is not set
# CONFIG_TARGET_LS2080AQDS is not set
# CONFIG_TARGET_LS2080ARDB is not set
# CONFIG_TARGET_LS2081ARDB is not set
# CONFIG_TARGET_LX2160ARDB is not set
# CONFIG_TARGET_LX2160AQDS is not set
# CONFIG_TARGET_HIKEY is not set
# CONFIG_TARGET_HIKEY960 is not set
# CONFIG_TARGET_POPLAR is not set
# CONFIG_TARGET_LS1012AQDS is not set
# CONFIG_TARGET_LS1012ARDB is not set
# CONFIG_TARGET_LS1012A2G5RDB is not set
# CONFIG_TARGET_LS1012AFRWY is not set
# CONFIG_TARGET_LS1012AFRDM is not set
# CONFIG_TARGET_LS1028AQDS is not set
# CONFIG_TARGET_LS1028ARDB is not set
# CONFIG_TARGET_LS1088ARDB is not set
# CONFIG_TARGET_LS1021AQDS is not set
# CONFIG_TARGET_LS1021ATWR is not set
# CONFIG_TARGET_LS1021ATSN is not set
# CONFIG_TARGET_LS1021AIOT is not set
# CONFIG_TARGET_LS1043AQDS is not set
# CONFIG_TARGET_LS1043ARDB is not set
# CONFIG_TARGET_LS1046AQDS is not set
# CONFIG_TARGET_LS1046ARDB is not set
# CONFIG_TARGET_LS1046AFRWY is not set
# CONFIG_TARGET_COLIBRI_PXA270 is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_STM32 is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32MP is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_TARGET_THUNDERX_88XX is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_TARGET_DURIAN is not set
CONFIG_SYS_TEXT_BASE=0x4a000000
CONFIG_SPL_GPIO_SUPPORT=y
CONFIG_SPL_LIBCOMMON_SUPPORT=y
CONFIG_SPL_LIBGENERIC_SUPPORT=y
CONFIG_SYS_MALLOC_F_LEN=0x400
CONFIG_SPL_MMC_SUPPORT=y
CONFIG_SPL_SERIAL_SUPPORT=y
# CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set
CONFIG_ENV_SIZE=0x20000
CONFIG_SPL_STACK_R_ADDR=0x4fe00000
CONFIG_SPL_SYS_MALLOC_F_LEN=0x400
CONFIG_ERR_PTR_OFFSET=0x0
CONFIG_NR_DRAM_BANKS=1
CONFIG_SPL_SIZE_LIMIT=0
CONFIG_SPL=y
CONFIG_PRE_CON_BUF_ADDR=0x4f000000
CONFIG_PRE_CON_BUF_SZ=4096
CONFIG_BOOTSTAGE_STASH_ADDR=0
CONFIG_IDENT_STRING=" Allwinner Technology"
CONFIG_DRAM_SUN8I_A33=y
# CONFIG_SUN6I_P2WI is not set
CONFIG_SUN6I_PRCM=y
CONFIG_AXP_PMIC_BUS=y
CONFIG_SUN8I_RSB=y
CONFIG_SUNXI_SRAM_ADDRESS=0x0
CONFIG_SUNXI_GEN_SUN6I=y
CONFIG_SUNXI_DRAM_MAX_SIZE=0x80000000
# CONFIG_MACH_SUN4I is not set
# CONFIG_MACH_SUN5I is not set
# CONFIG_MACH_SUN6I is not set
# CONFIG_MACH_SUN7I is not set
# CONFIG_MACH_SUN8I_A23 is not set
CONFIG_MACH_SUN8I_A33=y
# CONFIG_MACH_SUN8I_A83T is not set
# CONFIG_MACH_SUN8I_H3 is not set
# CONFIG_MACH_SUN8I_R40 is not set
# CONFIG_MACH_SUN8I_V3S is not set
# CONFIG_MACH_SUN9I is not set
# CONFIG_MACH_SUN50I is not set
# CONFIG_MACH_SUN50I_H5 is not set
# CONFIG_MACH_SUN50I_H6 is not set
CONFIG_MACH_SUN8I=y
# CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER is not set
CONFIG_DRAM_CLK=552
CONFIG_DRAM_ZQ=15291
# CONFIG_DRAM_ODT_EN is not set
CONFIG_SYS_CLK_FREQ=1008000000
# CONFIG_UART0_PORT_F is not set
# CONFIG_OLD_SUNXI_KERNEL_COMPAT is not set
CONFIG_MACPWR=""
CONFIG_MMC1_CD_PIN=""
CONFIG_MMC2_CD_PIN=""
CONFIG_MMC3_CD_PIN=""
CONFIG_MMC1_PINS=""
CONFIG_MMC2_PINS=""
CONFIG_MMC3_PINS=""
CONFIG_MMC_SUNXI_SLOT_EXTRA=2
CONFIG_INITIAL_USB_SCAN_DELAY=0
CONFIG_USB0_VBUS_PIN=""
CONFIG_USB0_VBUS_DET=""
CONFIG_USB0_ID_DET="PH8"
CONFIG_USB1_VBUS_PIN=""
CONFIG_USB2_VBUS_PIN=""
CONFIG_USB3_VBUS_PIN=""
# CONFIG_I2C0_ENABLE is not set
# CONFIG_I2C1_ENABLE is not set
# CONFIG_I2C2_ENABLE is not set
# CONFIG_R_I2C_ENABLE is not set
# CONFIG_AXP_GPIO is not set
CONFIG_VIDEO_SUNXI=y
# CONFIG_VIDEO_VGA_VIA_LCD is not set
CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:66000,le:90,ri:160,up:3,lo:127,hs:70,vs:20,sync:3,vmode:0"
CONFIG_VIDEO_LCD_DCLK_PHASE=0
CONFIG_VIDEO_LCD_POWER=""
CONFIG_VIDEO_LCD_RESET=""
CONFIG_VIDEO_LCD_BL_EN="PH6"
CONFIG_VIDEO_LCD_BL_PWM="PH0"
CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW=y
# CONFIG_VIDEO_LCD_PANEL_I2C is not set
CONFIG_VIDEO_LCD_IF_PARALLEL=y
CONFIG_VIDEO_LCD_PANEL_PARALLEL=y
# CONFIG_VIDEO_LCD_PANEL_LVDS is not set
# CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828 is not set
# CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804 is not set
# CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM is not set
# CONFIG_VIDEO_LCD_TL059WV5C0 is not set
CONFIG_SATAPWR=""
CONFIG_GMAC_TX_DELAY=0
# CONFIG_SPL_FS_FAT is not set
# CONFIG_SPL_LIBDISK_SUPPORT is not set
CONFIG_SPL_SPI_FLASH_SUPPORT=y
CONFIG_SPL_SPI_SUPPORT=y
CONFIG_CPU_V7_HAS_NONSEC=y
CONFIG_CPU_V7_HAS_VIRT=y
CONFIG_ARCH_SUPPORT_PSCI=y
CONFIG_ARMV7_NONSEC=y
# CONFIG_ARMV7_BOOT_SEC_DEFAULT is not set
CONFIG_ARMV7_VIRT=y
CONFIG_ARMV7_PSCI=y
CONFIG_ARMV7_PSCI_NR_CPUS=4
CONFIG_ARMV7_LPAE=y
CONFIG_CSF_SIZE=0x2060
# CONFIG_CMD_DEKBLOB is not set
# CONFIG_CMD_HDMIDETECT is not set
CONFIG_IMX_DCD_ADDR=0x00910000
# ARM debug
# CONFIG_DEBUG_LL is not set
CONFIG_SMBIOS_PRODUCT_NAME="sunxi"
# CONFIG_DEBUG_UART is not set
# CONFIG_AHCI is not set
CONFIG_SPL_TEXT_BASE=0x00060
# General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_DISTRO_DEFAULTS=y
CONFIG_ENV_VARS_UBOOT_CONFIG=y
# CONFIG_SYS_BOOT_GET_CMDLINE is not set
# CONFIG_SYS_BOOT_GET_KBD is not set
CONFIG_SYS_MALLOC_F=y
CONFIG_EXPERT=y
# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
# CONFIG_TOOLS_DEBUG is not set
# CONFIG_PHYS_64BIT is not set
CONFIG_SPL_IMAGE="spl/u-boot-spl.bin"
CONFIG_BUILD_TARGET=""
# CONFIG_SYS_CUSTOM_LDSCRIPT is not set
# Boot images
CONFIG_ANDROID_BOOT_IMAGE=y
CONFIG_FIT=y
CONFIG_FIT_EXTERNAL_OFFSET=0x0
CONFIG_FIT_ENABLE_SHA256_SUPPORT=y
# CONFIG_FIT_SIGNATURE is not set
# CONFIG_FIT_VERBOSE is not set
# CONFIG_FIT_BEST_MATCH is not set
# CONFIG_SPL_FIT is not set
# CONFIG_SPL_LOAD_FIT is not set
# CONFIG_SPL_LOAD_FIT_FULL is not set
CONFIG_LEGACY_IMAGE_FORMAT=y
CONFIG_OF_BOARD_SETUP=y
# CONFIG_OF_SYSTEM_SETUP is not set
# CONFIG_OF_STDOUT_VIA_ALIAS is not set
CONFIG_SYS_EXTRA_OPTIONS=""
CONFIG_ARCH_FIXUP_FDT_MEMORY=y
# API
# CONFIG_API is not set
# Boot timing
# CONFIG_BOOTSTAGE is not set
CONFIG_BOOTSTAGE_RECORD_COUNT=30
CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5
CONFIG_TPL_BOOTSTAGE_RECORD_COUNT=5
CONFIG_BOOTSTAGE_STASH_SIZE=0x1000
# CONFIG_SHOW_BOOT_PROGRESS is not set
# Boot media
# CONFIG_NAND_BOOT is not set
# CONFIG_ONENAND_BOOT is not set
# CONFIG_QSPI_BOOT is not set
# CONFIG_SATA_BOOT is not set
# CONFIG_SD_BOOT is not set
# CONFIG_SPI_BOOT is not set
CONFIG_BOOTDELAY=0
# CONFIG_USE_BOOTARGS is not set
CONFIG_USE_BOOTCOMMAND=y
CONFIG_USE_PREBOOT=y
CONFIG_PREBOOT=""
# Console
CONFIG_MENU=y
# CONFIG_CONSOLE_RECORD is not set
# CONFIG_DISABLE_CONSOLE is not set
CONFIG_LOGLEVEL=4
CONFIG_SPL_LOGLEVEL=4
CONFIG_TPL_LOGLEVEL=4
# CONFIG_SILENT_CONSOLE is not set
CONFIG_PRE_CONSOLE_BUFFER=y
CONFIG_CONSOLE_MUX=y
CONFIG_SYS_CONSOLE_IS_IN_ENV=y
# CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set
# CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set
# CONFIG_SYS_CONSOLE_INFO_QUIET is not set
CONFIG_SYS_STDIO_DEREGISTER=y
# Logging
# CONFIG_LOG is not set
CONFIG_LOG_DEFAULT_LEVEL=6
CONFIG_SUPPORT_RAW_INITRD=y
CONFIG_DEFAULT_FDT_FILE=""
CONFIG_MISC_INIT_R=y
# CONFIG_VERSION_VARIABLE is not set
# CONFIG_BOARD_LATE_INIT is not set
CONFIG_DISPLAY_CPUINFO=y
CONFIG_DISPLAY_BOARDINFO=y
# CONFIG_DISPLAY_BOARDINFO_LATE is not set
# CONFIG_BOUNCE_BUFFER is not set
# CONFIG_BOARD_TYPES is not set
# Start-up hooks
# CONFIG_ARCH_EARLY_INIT_R is not set
# CONFIG_ARCH_MISC_INIT is not set
# CONFIG_BOARD_EARLY_INIT_F is not set
# CONFIG_BOARD_EARLY_INIT_R is not set
# CONFIG_LAST_STAGE_INIT is not set
# Security support
CONFIG_HASH=y
# Update support
# CONFIG_UPDATE_TFTP is not set
# CONFIG_ANDROID_AB is not set
# Blob list
# CONFIG_BLOBLIST is not set
# SPL / TPL
CONFIG_SUPPORT_SPL=y
CONFIG_SPL_FRAMEWORK=y
# CONFIG_SPL_FRAMEWORK_BOARD_INIT_F is not set
CONFIG_SPL_SYS_STACK_F_CHECK_BYTE=0xaa
# CONFIG_SPL_SYS_REPORT_STACK_F_USAGE is not set
# CONFIG_SPL_BOARD_INIT is not set
# CONFIG_SPL_BOOTROM_SUPPORT is not set
CONFIG_SPL_RAW_IMAGE_SUPPORT=y
CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y
# CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK is not set
CONFIG_SPL_SYS_MALLOC_SIMPLE=y
CONFIG_SPL_STACK_R=y
CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000
# CONFIG_SPL_SEPARATE_BSS is not set
CONFIG_SPL_BANNER_PRINT=y
# CONFIG_SPL_EARLY_BSS is not set
# CONFIG_SPL_DISPLAY_PRINT is not set
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x50
# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is not set
CONFIG_SPL_CRC32_SUPPORT=y
# CONFIG_SPL_CACHE_SUPPORT is not set
# CONFIG_SPL_CPU_SUPPORT is not set
# CONFIG_SPL_CRYPTO_SUPPORT is not set
# CONFIG_SPL_HASH_SUPPORT is not set
# CONFIG_SPL_DMA_SUPPORT is not set
# CONFIG_SPL_DM_GPIO is not set
# CONFIG_SPL_ENV_SUPPORT is not set
# CONFIG_SPL_FS_EXT4 is not set
# CONFIG_SPL_FAT_WRITE is not set
# CONFIG_SPL_FPGA_SUPPORT is not set
# CONFIG_SPL_I2C_SUPPORT is not set
# CONFIG_SPL_DM_MAILBOX is not set
# CONFIG_SPL_FORCE_MMC_BOOT is not set
# CONFIG_SPL_MMC_TINY is not set
# CONFIG_SPL_MMC_WRITE is not set
# CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set
# CONFIG_SPL_MTD_SUPPORT is not set
# CONFIG_SPL_MUSB_NEW_SUPPORT is not set
# CONFIG_SPL_NAND_SUPPORT is not set
# CONFIG_SPL_UBI is not set
# CONFIG_SPL_NET_SUPPORT is not set
# CONFIG_SPL_NO_CPU_SUPPORT is not set
# CONFIG_SPL_NOR_SUPPORT is not set
# CONFIG_SPL_XIP_SUPPORT is not set
# CONFIG_SPL_ONENAND_SUPPORT is not set
# CONFIG_SPL_OS_BOOT is not set
CONFIG_SPL_PAYLOAD="u-boot.bin"
# CONFIG_SPL_PCI is not set
# CONFIG_SPL_PCH_SUPPORT is not set
# CONFIG_SPL_POST_MEM_SUPPORT is not set
# CONFIG_SPL_DM_RESET is not set
CONFIG_SPL_POWER_SUPPORT=y
# CONFIG_SPL_POWER_DOMAIN is not set
# CONFIG_SPL_RAM_SUPPORT is not set
# CONFIG_SPL_REMOTEPROC is not set
# CONFIG_SPL_RTC_SUPPORT is not set
# CONFIG_SPL_SATA_SUPPORT is not set
# CONFIG_SPL_SPI_LOAD is not set
# CONFIG_SPL_THERMAL is not set
# CONFIG_SPL_USB_HOST_SUPPORT is not set
# CONFIG_SPL_USB_GADGET is not set
# CONFIG_SPL_WATCHDOG_SUPPORT is not set
# CONFIG_SPL_YMODEM_SUPPORT is not set
# CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set
# CONFIG_SPL_OPTEE is not set
# Command line interface
CONFIG_CMDLINE=y
CONFIG_HUSH_PARSER=y
CONFIG_CMDLINE_EDITING=y
CONFIG_AUTO_COMPLETE=y
CONFIG_SYS_LONGHELP=y
CONFIG_SYS_PROMPT="=> "
CONFIG_SYS_XTRACE="y"
# Autoboot options
CONFIG_AUTOBOOT=y
# CONFIG_AUTOBOOT_KEYED is not set
# CONFIG_AUTOBOOT_USE_MENUKEY is not set
# Commands
# Info commands
CONFIG_CMD_BDI=y
# CONFIG_CMD_CONFIG is not set
CONFIG_CMD_CONSOLE=y
# CONFIG_CMD_CPU is not set
# CONFIG_CMD_LICENSE is not set
# Boot commands
CONFIG_CMD_BOOTD=y
CONFIG_CMD_BOOTM=y
CONFIG_CMD_BOOTZ=y
CONFIG_BOOTM_LINUX=y
CONFIG_BOOTM_NETBSD=y
# CONFIG_BOOTM_OPENRTOS is not set
# CONFIG_BOOTM_OSE is not set
CONFIG_BOOTM_PLAN9=y
CONFIG_BOOTM_RTEMS=y
CONFIG_BOOTM_VXWORKS=y
CONFIG_CMD_BOOTEFI=y
CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y
# CONFIG_CMD_BOOTEFI_HELLO is not set
# CONFIG_CMD_BOOTEFI_SELFTEST is not set
# CONFIG_CMD_BOOTMENU is not set
# CONFIG_CMD_DTIMG is not set
CONFIG_CMD_ELF=y
CONFIG_CMD_FDT=y
CONFIG_CMD_GO=y
CONFIG_CMD_RUN=y
CONFIG_CMD_IMI=y
# CONFIG_CMD_IMLS is not set
CONFIG_CMD_XIMG=y
# CONFIG_CMD_SPL is not set
# CONFIG_CMD_FITUPD is not set
# CONFIG_CMD_THOR_DOWNLOAD is not set
# CONFIG_CMD_ZBOOT is not set
# Environment commands
# CONFIG_CMD_ASKENV is not set
CONFIG_CMD_EXPORTENV=y
CONFIG_CMD_IMPORTENV=y
CONFIG_CMD_EDITENV=y
# CONFIG_CMD_GREPENV is not set
CONFIG_CMD_SAVEENV=y
# CONFIG_CMD_ERASEENV is not set
CONFIG_CMD_ENV_EXISTS=y
# CONFIG_CMD_ENV_CALLBACK is not set
# CONFIG_CMD_ENV_FLAGS is not set
# CONFIG_CMD_NVEDIT_EFI is not set
# CONFIG_CMD_NVEDIT_INFO is not set
# Memory commands
# CONFIG_CMD_BINOP is not set
CONFIG_CMD_CRC32=y
# CONFIG_CRC32_VERIFY is not set
# CONFIG_CMD_EEPROM is not set
# CONFIG_LOOPW is not set
# CONFIG_CMD_MD5SUM is not set
# CONFIG_CMD_MEMINFO is not set
CONFIG_CMD_MEMORY=y
# CONFIG_MX_CYCLIC is not set
CONFIG_CMD_RANDOM=y
# CONFIG_CMD_MEMTEST is not set
# CONFIG_CMD_MX_CYCLIC is not set
# CONFIG_CMD_SHA1SUM is not set
# CONFIG_CMD_STRINGS is not set
# Compression commands
# CONFIG_CMD_LZMADEC is not set
# CONFIG_CMD_UNZIP is not set
# CONFIG_CMD_ZIP is not set
# Device access commands
# CONFIG_CMD_ARMFLASH is not set
# CONFIG_CMD_ADC is not set
# CONFIG_CMD_BCB is not set
# CONFIG_CMD_BIND is not set
# CONFIG_CMD_CLK is not set
# CONFIG_CMD_DEMO is not set
CONFIG_CMD_DFU=y
CONFIG_CMD_DM=y
CONFIG_CMD_FASTBOOT=y
# CONFIG_CMD_FDC is not set
# CONFIG_CMD_FPGAD is not set
# CONFIG_CMD_FUSE is not set
CONFIG_CMD_GPIO=y
CONFIG_CMD_GPT=y
CONFIG_RANDOM_UUID=y
# CONFIG_CMD_GPT_RENAME is not set
# CONFIG_CMD_IDE is not set
# CONFIG_CMD_IO is not set
# CONFIG_CMD_IOTRACE is not set
# CONFIG_CMD_I2C is not set
CONFIG_CMD_LOADB=y
CONFIG_CMD_LOADS=y
CONFIG_CMD_MMC=y
# CONFIG_CMD_MMC_RPMB is not set
# CONFIG_CMD_MMC_SWRITE is not set
# CONFIG_CMD_OSD is not set
CONFIG_CMD_PART=y
# CONFIG_CMD_PCI is not set
# CONFIG_CMD_PINMUX is not set
CONFIG_CMD_POWEROFF=y
# CONFIG_CMD_READ is not set
# CONFIG_CMD_SATA is not set
# CONFIG_CMD_SAVES is not set
# CONFIG_CMD_SCSI is not set
# CONFIG_CMD_SDRAM is not set
# CONFIG_CMD_SF is not set
# CONFIG_CMD_SPI is not set
# CONFIG_CMD_TSI148 is not set
# CONFIG_CMD_UNIVERSE is not set
CONFIG_CMD_USB=y
# CONFIG_CMD_USB_SDP is not set
# Shell scripting commands
CONFIG_CMD_ECHO=y
CONFIG_CMD_ITEST=y
CONFIG_CMD_SOURCE=y
CONFIG_CMD_SETEXPR=y
# Android support commands
CONFIG_CMD_NET=y
CONFIG_CMD_BOOTP=y
CONFIG_CMD_DHCP=y
CONFIG_BOOTP_BOOTPATH=y
CONFIG_BOOTP_DNS=y
# CONFIG_BOOTP_DNS2 is not set
CONFIG_BOOTP_GATEWAY=y
CONFIG_BOOTP_HOSTNAME=y
# CONFIG_BOOTP_PREFER_SERVERIP is not set
CONFIG_BOOTP_SUBNETMASK=y
# CONFIG_BOOTP_NTPSERVER is not set
# CONFIG_CMD_PCAP is not set
CONFIG_BOOTP_PXE=y
CONFIG_BOOTP_PXE_CLIENTARCH=0x15
CONFIG_BOOTP_VCI_STRING="U-Boot.armv7"
CONFIG_CMD_TFTPBOOT=y
# CONFIG_CMD_TFTPPUT is not set
# CONFIG_CMD_TFTPSRV is not set
CONFIG_NET_TFTP_VARS=y
# CONFIG_CMD_RARP is not set
CONFIG_CMD_NFS=y
CONFIG_CMD_MII=y
CONFIG_CMD_PING=y
# CONFIG_CMD_CDP is not set
# CONFIG_CMD_SNTP is not set
# CONFIG_CMD_DNS is not set
# CONFIG_CMD_LINK_LOCAL is not set
# CONFIG_CMD_ETHSW is not set
CONFIG_CMD_PXE=y
# CONFIG_CMD_WOL is not set
# Misc commands
# CONFIG_CMD_BMP is not set
# CONFIG_CMD_BSP is not set
# CONFIG_CMD_BKOPS_ENABLE is not set
CONFIG_CMD_BLOCK_CACHE=y
# CONFIG_CMD_CACHE is not set
# CONFIG_CMD_CONITRACE is not set
# CONFIG_CMD_CLS is not set
# CONFIG_CMD_EFIDEBUG is not set
# CONFIG_CMD_EXCEPTION is not set
# CONFIG_CMD_DATE is not set
# CONFIG_CMD_TIME is not set
# CONFIG_CMD_GETTIME is not set
CONFIG_CMD_MISC=y
# CONFIG_MP is not set
# CONFIG_CMD_TIMER is not set
CONFIG_CMD_SYSBOOT=y
# CONFIG_CMD_QFW is not set
# CONFIG_CMD_TERMINAL is not set
# CONFIG_CMD_UUID is not set
# TI specific command line interface
# CONFIG_CMD_DDR3 is not set
# Power commands
# Security commands
# CONFIG_CMD_AES is not set
# CONFIG_CMD_BLOB is not set
# CONFIG_CMD_HASH is not set
# Firmware commands
# Filesystem commands
# CONFIG_CMD_BTRFS is not set
CONFIG_CMD_EXT2=y
CONFIG_CMD_EXT4=y
# CONFIG_CMD_EXT4_WRITE is not set
CONFIG_CMD_FAT=y
CONFIG_CMD_FS_GENERIC=y
# CONFIG_CMD_FS_UUID is not set
# CONFIG_CMD_JFFS2 is not set
CONFIG_MTDIDS_DEFAULT=""
CONFIG_MTDPARTS_DEFAULT=""
# CONFIG_CMD_REISER is not set
# CONFIG_CMD_ZFS is not set
# Debug commands
# CONFIG_CMD_BEDBUG is not set
# CONFIG_CMD_DIAG is not set
# CONFIG_CMD_LOG is not set
# CONFIG_CMD_TRACE is not set
# CONFIG_CMD_UBI is not set
# Partition Types
CONFIG_PARTITIONS=y
# CONFIG_MAC_PARTITION is not set
# CONFIG_SPL_MAC_PARTITION is not set
CONFIG_DOS_PARTITION=y
# CONFIG_SPL_DOS_PARTITION is not set
CONFIG_ISO_PARTITION=y
# CONFIG_SPL_ISO_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_SPL_AMIGA_PARTITION is not set
CONFIG_EFI_PARTITION=y
CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=56
CONFIG_EFI_PARTITION_ENTRIES_OFF=0
CONFIG_SPL_EFI_PARTITION=y
CONFIG_PARTITION_UUIDS=y
# CONFIG_SPL_PARTITION_UUIDS is not set
# CONFIG_PARTITION_TYPE_GUID is not set
CONFIG_SUPPORT_OF_CONTROL=y
CONFIG_DTC=y
CONFIG_PYLIBFDT=y
CONFIG_DTOC=y
CONFIG_BINMAN=y
# Device Tree Control
CONFIG_OF_CONTROL=y
# CONFIG_OF_BOARD_FIXUP is not set
# CONFIG_SPL_OF_CONTROL is not set
# CONFIG_OF_LIVE is not set
CONFIG_OF_SEPARATE=y
# CONFIG_OF_EMBED is not set
# CONFIG_OF_BOARD is not set
# CONFIG_OF_PRIOR_STAGE is not set
CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33"
# CONFIG_MULTI_DTB_FIT is not set
CONFIG_MKIMAGE_DTC_PATH="dtc"
# Environment
# CONFIG_ENV_IS_NOWHERE is not set
# CONFIG_ENV_IS_IN_EEPROM is not set
CONFIG_ENV_IS_IN_FAT=y
# CONFIG_ENV_IS_IN_EXT4 is not set
# CONFIG_ENV_IS_IN_FLASH is not set
# CONFIG_ENV_IS_IN_MMC is not set
# CONFIG_ENV_IS_IN_NAND is not set
# CONFIG_ENV_IS_IN_NVRAM is not set
# CONFIG_ENV_IS_IN_ONENAND is not set
# CONFIG_ENV_IS_IN_REMOTE is not set
# CONFIG_ENV_IS_IN_SPI_FLASH is not set
CONFIG_ENV_FAT_INTERFACE="mmc"
CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto"
CONFIG_ENV_FAT_FILE="uboot.env"
CONFIG_SYS_RELOC_GD_ENV_ADDR=y
# CONFIG_USE_DEFAULT_ENV_FILE is not set
# CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set
CONFIG_NET=y
# CONFIG_NET_RANDOM_ETHADDR is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_IP_DEFRAG is not set
CONFIG_TFTP_BLOCKSIZE=1468
# Device Drivers
# Generic Driver Options
CONFIG_DM=y
# CONFIG_SPL_DM is not set
CONFIG_DM_WARN=y
# CONFIG_DM_DEBUG is not set
CONFIG_DM_DEVICE_REMOVE=y
CONFIG_DM_STDIO=y
CONFIG_DM_SEQ_ALIAS=y
# CONFIG_REGMAP is not set
# CONFIG_DEVRES is not set
CONFIG_SIMPLE_BUS=y
CONFIG_OF_TRANSLATE=y
# CONFIG_TRANSLATION_OFFSET is not set
CONFIG_DM_DEV_READ_INLINE=y
# CONFIG_ADC is not set
# CONFIG_ADC_EXYNOS is not set
# CONFIG_ADC_SANDBOX is not set
# CONFIG_SARADC_MESON is not set
# CONFIG_SARADC_ROCKCHIP is not set
# CONFIG_SATA is not set
# CONFIG_SCSI_AHCI is not set
# SATA/SCSI device support
# CONFIG_DWC_AHSATA is not set
# CONFIG_FSL_SATA is not set
# CONFIG_MVSATA_IDE is not set
# CONFIG_SATA_MV is not set
# CONFIG_SATA_SIL is not set
# CONFIG_SATA_SIL3114 is not set
# CONFIG_AXI is not set
CONFIG_BLK=y
CONFIG_HAVE_BLOCK_DEVICE=y
CONFIG_BLOCK_CACHE=y
# CONFIG_IDE is not set
# CONFIG_BOOTCOUNT_LIMIT is not set
# Cache Controller drivers
# CONFIG_CACHE is not set
# CONFIG_L2X0_CACHE is not set
# Clock
CONFIG_CLK=y
# CONFIG_SPL_CLK_CCF is not set
# CONFIG_CLK_CCF is not set
# CONFIG_CLK_HSDK is not set
# CONFIG_CLK_CDCE9XX is not set
# CONFIG_CLK_AT91 is not set
CONFIG_CLK_SUNXI=y
# CONFIG_CLK_SUN4I_A10 is not set
# CONFIG_CLK_SUN5I_A10S is not set
# CONFIG_CLK_SUN6I_A31 is not set
CONFIG_CLK_SUN8I_A23=y
# CONFIG_CLK_SUN8I_A83T is not set
# CONFIG_CLK_SUN8I_R40 is not set
# CONFIG_CLK_SUN8I_V3S is not set
# CONFIG_CLK_SUN9I_A80 is not set
# CONFIG_CLK_SUN8I_H3 is not set
# CONFIG_CLK_SUN50I_H6 is not set
# CONFIG_CLK_SUN50I_A64 is not set
# CONFIG_CLK_SIFIVE is not set
# CONFIG_ICS8N3QV01 is not set
# CONFIG_CLK_MPC83XX is not set
# CONFIG_CPU is not set
# Hardware crypto devices
# CONFIG_FSL_CAAM is not set
# CONFIG_SYS_FSL_SEC_BE is not set
# CONFIG_SYS_FSL_SEC_LE is not set
# Demo for driver model
# CONFIG_DM_DEMO is not set
# CONFIG_BOARD is not set
# DFU support
CONFIG_DFU=y
CONFIG_DFU_OVER_USB=y
# CONFIG_DFU_TFTP is not set
# CONFIG_DFU_MMC is not set
CONFIG_DFU_RAM=y
# CONFIG_DFU_SF is not set
# CONFIG_DFU_VIRT is not set
# DMA Support
# CONFIG_DMA is not set
# CONFIG_TI_EDMA3 is not set
# Fastboot support
CONFIG_FASTBOOT=y
CONFIG_USB_FUNCTION_FASTBOOT=y
# CONFIG_UDP_FUNCTION_FASTBOOT is not set
CONFIG_FASTBOOT_BUF_ADDR=0x42000000
CONFIG_FASTBOOT_BUF_SIZE=0x2000000
CONFIG_FASTBOOT_USB_DEV=0
CONFIG_FASTBOOT_FLASH=y
CONFIG_FASTBOOT_FLASH_MMC=y
CONFIG_FASTBOOT_FLASH_MMC_DEV=1
CONFIG_FASTBOOT_GPT_NAME="gpt"
CONFIG_FASTBOOT_MBR_NAME="mbr"
CONFIG_FASTBOOT_CMD_OEM_FORMAT=y
# CONFIG_FIRMWARE is not set
# CONFIG_ZYNQMP_FIRMWARE is not set
# FPGA support
# CONFIG_FPGA_ALTERA is not set
# CONFIG_FPGA_SOCFPGA is not set
# CONFIG_FPGA_XILINX is not set
# GPIO Support
CONFIG_DM_GPIO=y
# CONFIG_GPIO_HOG is not set
# CONFIG_ALTERA_PIO is not set
# CONFIG_DWAPB_GPIO is not set
# CONFIG_AT91_GPIO is not set
# CONFIG_ATMEL_PIO4 is not set
# CONFIG_DA8XX_GPIO is not set
# CONFIG_INTEL_BROADWELL_GPIO is not set
# CONFIG_INTEL_ICH6_GPIO is not set
# CONFIG_IMX_RGPIO2P is not set
# CONFIG_HSDK_CREG_GPIO is not set
# CONFIG_LPC32XX_GPIO is not set
# CONFIG_MSM_GPIO is not set
# CONFIG_MXC_GPIO is not set
# CONFIG_MXS_GPIO is not set
# CONFIG_CMD_PCA953X is not set
# CONFIG_ROCKCHIP_GPIO is not set
CONFIG_SUNXI_GPIO=y
# CONFIG_XILINX_GPIO is not set
# CONFIG_CMD_TCA642X is not set
# CONFIG_TEGRA_GPIO is not set
# CONFIG_TEGRA186_GPIO is not set
# CONFIG_VYBRID_GPIO is not set
# CONFIG_SIFIVE_GPIO is not set
# CONFIG_DM_74X164 is not set
# CONFIG_DM_PCA953X is not set
# CONFIG_SPL_DM_PCA953X is not set
# CONFIG_MPC8XXX_GPIO is not set
# Hardware Spinlock Support
# CONFIG_DM_HWSPINLOCK is not set
# I2C support
# CONFIG_DM_I2C is not set
# CONFIG_SYS_I2C_DW is not set
# CONFIG_SYS_I2C_IMX_LPI2C is not set
# CONFIG_SYS_I2C_MXC is not set
CONFIG_INPUT=y
CONFIG_DM_KEYBOARD=y
# CONFIG_CROS_EC_KEYB is not set
# CONFIG_I8042_KEYB is not set
# CONFIG_TEGRA_KEYBOARD is not set
# CONFIG_TWL4030_INPUT is not set
# LED Support
# CONFIG_LED is not set
# CONFIG_LED_STATUS is not set
# Mailbox Controller Support
# CONFIG_DM_MAILBOX is not set
# Memory Controller drivers
# Multifunction device drivers
# CONFIG_MISC is not set
# CONFIG_CROS_EC is not set
# CONFIG_SPL_CROS_EC is not set
# CONFIG_DS4510 is not set
# CONFIG_FSL_SEC_MON is not set
# CONFIG_NUVOTON_NCT6102D is not set
# CONFIG_PWRSEQ is not set
# CONFIG_PCA9551_LED is not set
# CONFIG_TWL4030_LED is not set
# CONFIG_WINBOND_W83627 is not set
# CONFIG_FS_LOADER is not set
# MMC Host controller Support
CONFIG_MMC=y
CONFIG_MMC_WRITE=y
# CONFIG_MMC_BROKEN_CD is not set
CONFIG_DM_MMC=y
# CONFIG_ARM_PL180_MMCI is not set
CONFIG_MMC_QUIRKS=y
CONFIG_MMC_HW_PARTITIONING=y
# CONFIG_SUPPORT_EMMC_RPMB is not set
# CONFIG_SUPPORT_EMMC_BOOT is not set
# CONFIG_MMC_IO_VOLTAGE is not set
# CONFIG_SPL_MMC_IO_VOLTAGE is not set
# CONFIG_MMC_HS400_ES_SUPPORT is not set
# CONFIG_SPL_MMC_HS400_ES_SUPPORT is not set
# CONFIG_MMC_HS400_SUPPORT is not set
# CONFIG_SPL_MMC_HS400_SUPPORT is not set
# CONFIG_MMC_HS200_SUPPORT is not set
# CONFIG_SPL_MMC_HS200_SUPPORT is not set
CONFIG_MMC_VERBOSE=y
# CONFIG_MMC_TRACE is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_MXC is not set
# CONFIG_MMC_PCI is not set
# CONFIG_MMC_OMAP_HS is not set
# CONFIG_MMC_SDHCI is not set
CONFIG_MMC_SUNXI=y
# CONFIG_STM32_SDMMC2 is not set
# CONFIG_FTSDC010 is not set
# CONFIG_FSL_ESDHC is not set
# CONFIG_FSL_ESDHC_IMX is not set
# MTD Support
# CONFIG_MTD is not set
# CONFIG_DM_MTD is not set
# CONFIG_MTD_NOR_FLASH is not set
# CONFIG_FLASH_CFI_DRIVER is not set
# CONFIG_MTD_RAW_NAND is not set
# SPI Flash Support
CONFIG_SPI_FLASH=y
CONFIG_SF_DEFAULT_BUS=0
CONFIG_SF_DEFAULT_CS=0
CONFIG_SF_DEFAULT_MODE=3
CONFIG_SF_DEFAULT_SPEED=1000000
CONFIG_SPI_FLASH_BAR=y
# CONFIG_SF_DUAL_FLASH is not set
# CONFIG_SPI_FLASH_ATMEL is not set
# CONFIG_SPI_FLASH_EON is not set
CONFIG_SPI_FLASH_GIGADEVICE=y
# CONFIG_SPI_FLASH_ISSI is not set
CONFIG_SPI_FLASH_MACRONIX=y
CONFIG_SPI_FLASH_SPANSION=y
# CONFIG_SPI_FLASH_STMICRO is not set
# CONFIG_SPI_FLASH_SST is not set
CONFIG_SPI_FLASH_WINBOND=y
# CONFIG_SPI_FLASH_XMC is not set
CONFIG_SPI_FLASH_USE_4K_SECTORS=y
# CONFIG_SPL_SPI_FLASH_MTD is not set
# UBI support
# CONFIG_UBI_SILENCE_MSG is not set
# CONFIG_MTD_UBI is not set
# CONFIG_BITBANGMII is not set
# CONFIG_MV88E6352_SWITCH is not set
# CONFIG_PHYLIB is not set
# CONFIG_FSL_PFE is not set
CONFIG_DM_ETH=y
CONFIG_NETDEVICES=y
# CONFIG_PHY_GIGE is not set
# CONFIG_ALTERA_TSE is not set
# CONFIG_BCM_SF2_ETH is not set
# CONFIG_DWC_ETH_QOS is not set
# CONFIG_E1000 is not set
# CONFIG_ETH_DESIGNWARE is not set
# CONFIG_ETHOC is not set
# CONFIG_FMAN_ENET is not set
# CONFIG_FTMAC100 is not set
# CONFIG_FTGMAC100 is not set
# CONFIG_MACB is not set
# CONFIG_RGMII is not set
# CONFIG_MII is not set
# CONFIG_RTL8139 is not set
# CONFIG_RTL8169 is not set
# CONFIG_SMC911X is not set
# CONFIG_SUN7I_GMAC is not set
# CONFIG_SUN4I_EMAC is not set
# CONFIG_SUN8I_EMAC is not set
# CONFIG_SH_ETHER is not set
# CONFIG_DRIVER_TI_CPSW is not set
# CONFIG_DRIVER_TI_EMAC is not set
# CONFIG_DRIVER_TI_KEYSTONE_NET is not set
# CONFIG_SYS_DPAA_QBMAN is not set
# CONFIG_TSEC_ENET is not set
# CONFIG_MEDIATEK_ETH is not set
# CONFIG_HIGMACV300_ETH is not set
# CONFIG_PCI is not set
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# PHY Subsystem
CONFIG_PHY=y
# CONFIG_SPL_PHY is not set
# CONFIG_NOP_PHY is not set
# CONFIG_MSM8916_USB_PHY is not set
CONFIG_PHY_SUN4I_USB=y
# CONFIG_MVEBU_COMPHY_SUPPORT is not set
# Pin controllers
# CONFIG_PINCTRL is not set
# Power
# Power Domain Support
# CONFIG_POWER_DOMAIN is not set
# CONFIG_DM_PMIC is not set
# CONFIG_PMIC_AS3722 is not set
# CONFIG_POWER_MC34VR500 is not set
# CONFIG_DM_REGULATOR is not set
# CONFIG_SUNXI_NO_PMIC is not set
CONFIG_AXP221_POWER=y
CONFIG_AXP_DCDC1_VOLT=3000
CONFIG_AXP_DCDC2_VOLT=1100
CONFIG_AXP_DCDC3_VOLT=1200
CONFIG_AXP_DCDC4_VOLT=0
CONFIG_AXP_DCDC5_VOLT=1500
CONFIG_AXP_ALDO1_VOLT=3000
CONFIG_AXP_ALDO2_VOLT=2500
CONFIG_AXP_ALDO3_VOLT=3000
CONFIG_AXP_DLDO1_VOLT=0
CONFIG_AXP_DLDO2_VOLT=0
CONFIG_AXP_DLDO3_VOLT=0
CONFIG_AXP_DLDO4_VOLT=0
CONFIG_AXP_ELDO1_VOLT=0
CONFIG_AXP_ELDO2_VOLT=0
CONFIG_AXP_ELDO3_VOLT=0
# CONFIG_DM_PWM is not set
# CONFIG_PWM_IMX is not set
# CONFIG_PWM_SANDBOX is not set
# CONFIG_U_QE is not set
# CONFIG_RAM is not set
CONFIG_RAM_ROCKCHIP_DEBUG=y
# Remote Processor drivers
# Reset Controller Support
CONFIG_DM_RESET=y
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_HISILICON is not set
# Real Time Clock
# CONFIG_DM_RTC is not set
# CONFIG_RTC_ENABLE_32KHZ_OUTPUT is not set
# CONFIG_RTC_RX8025 is not set
# CONFIG_RTC_PL031 is not set
# CONFIG_RTC_S35392A is not set
# CONFIG_RTC_MC146818 is not set
# CONFIG_RTC_M41T62 is not set
# CONFIG_SCSI is not set
# CONFIG_DM_SCSI is not set
# Serial drivers
CONFIG_BAUDRATE=115200
CONFIG_REQUIRE_SERIAL_CONSOLE=y
CONFIG_SPECIFY_CONSOLE_INDEX=y
CONFIG_SERIAL_PRESENT=y
CONFIG_SPL_SERIAL_PRESENT=y
CONFIG_CONS_INDEX=1
CONFIG_DM_SERIAL=y
# CONFIG_SERIAL_RX_BUFFER is not set
# CONFIG_SERIAL_SEARCH_ALL is not set
# CONFIG_ALTERA_JTAG_UART is not set
# CONFIG_ALTERA_UART is not set
# CONFIG_ARC_SERIAL is not set
# CONFIG_ATMEL_USART is not set
# CONFIG_BCM6345_SERIAL is not set
# CONFIG_FSL_LINFLEXUART is not set
# CONFIG_FSL_LPUART is not set
# CONFIG_MVEBU_A3700_UART is not set
# CONFIG_MCFUART is not set
# CONFIG_NULLDEV_SERIAL is not set
CONFIG_SYS_NS16550=y
# CONFIG_PL01X_SERIAL is not set
# CONFIG_MSM_SERIAL is not set
# CONFIG_OMAP_SERIAL is not set
# CONFIG_PXA_SERIAL is not set
# CONFIG_SIFIVE_SERIAL is not set
# CONFIG_MTK_SERIAL is not set
# CONFIG_SMEM is not set
# Sound support
# CONFIG_SOUND is not set
# SOC (System On Chip) specific Drivers
# CONFIG_SOC_TI is not set
CONFIG_SPI=y
# CONFIG_DM_SPI is not set
CONFIG_SPI_MEM=y
# CONFIG_CF_SPI is not set
# CONFIG_FSL_ESPI is not set
# CONFIG_FSL_QSPI is not set
# CONFIG_SH_QSPI is not set
# CONFIG_KIRKWOOD_SPI is not set
# CONFIG_MXC_SPI is not set
# CONFIG_MXS_SPI is not set
# CONFIG_OMAP3_SPI is not set
# SPMI support
# CONFIG_SPMI is not set
# System reset device drivers
# CONFIG_SYSRESET is not set
# CONFIG_SYSRESET_SYSCON is not set
# CONFIG_SYSRESET_WATCHDOG is not set
# CONFIG_SYSRESET_MPC83XX is not set
# CONFIG_TEE is not set
# CONFIG_OPTEE is not set
# CONFIG_DM_THERMAL is not set
# Timer Support
# CONFIG_TIMER is not set
# TPM support
CONFIG_USB=y
CONFIG_DM_USB=y
# CONFIG_DM_USB_GADGET is not set
# USB Host Controller Drivers
CONFIG_USB_HOST=y
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_MSM is not set
# CONFIG_USB_EHCI_PCI is not set
CONFIG_USB_EHCI_GENERIC=y
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_OHCI_HCD=y
# CONFIG_USB_OHCI_PCI is not set
CONFIG_USB_OHCI_GENERIC=y
# CONFIG_USB_OHCI_DA8XX is not set
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_CDNS3 is not set
# CONFIG_USB_DWC3 is not set
# Legacy MUSB Support
# CONFIG_USB_MUSB_HCD is not set
# CONFIG_USB_MUSB_UDC is not set
# MUSB Controller Driver
# CONFIG_USB_MUSB_HOST is not set
CONFIG_USB_MUSB_GADGET=y
# CONFIG_USB_MUSB_DA8XX is not set
# CONFIG_USB_MUSB_TI is not set
# CONFIG_USB_MUSB_AM35X is not set
# CONFIG_USB_MUSB_DSPS is not set
CONFIG_USB_MUSB_SUNXI=y
CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT=y
CONFIG_USB_MUSB_PIO_ONLY=y
# USB Phy
# CONFIG_TWL4030_USB is not set
# CONFIG_OMAP_USB_PHY is not set
# CONFIG_ROCKCHIP_USB2_PHY is not set
# ULPI drivers
# USB peripherals
CONFIG_USB_STORAGE=y
CONFIG_USB_KEYBOARD=y
# CONFIG_USB_KEYBOARD_FN_KEYS is not set
# CONFIG_SYS_USB_EVENT_POLL is not set
CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
# CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP is not set
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology"
CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a
CONFIG_USB_GADGET_PRODUCT_NUM=0x1010
# CONFIG_USB_GADGET_ATMEL_USBA is not set
# CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set
# CONFIG_USB_GADGET_DWC2_OTG is not set
# CONFIG_CI_UDC is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_DUALSPEED=y
CONFIG_USB_GADGET_DOWNLOAD=y
CONFIG_USB_FUNCTION_MASS_STORAGE=y
# CONFIG_USB_FUNCTION_ROCKUSB is not set
# CONFIG_USB_FUNCTION_SDP is not set
# CONFIG_USB_FUNCTION_THOR is not set
CONFIG_USB_ETHER=y
# CONFIG_USB_ETH_CDC is not set
CONFIG_USB_ETH_RNDIS=y
CONFIG_USBNET_DEVADDR="de:ad:be:ef:00:01"
CONFIG_USBNET_HOST_ADDR="de:ad:be:ef:00:00"
# CONFIG_USB_HOST_ETHER is not set
# UFS Host Controller Support
# CONFIG_TI_J721E_UFS is not set
# Graphics support
# CONFIG_DM_VIDEO is not set
CONFIG_SYS_WHITE_ON_BLACK=y
# CONFIG_NO_FB_CLEAR is not set
# TrueType Fonts
# CONFIG_VIDEO_VESA is not set
# CONFIG_VIDEO_LCD_ANX9804 is not set
# CONFIG_VIDEO_LCD_SSD2828 is not set
# CONFIG_VIDEO_LCD_HITACHI_TX18D42VM is not set
# CONFIG_VIDEO_MVEBU is not set
# CONFIG_I2C_EDID is not set
# CONFIG_DISPLAY is not set
# CONFIG_VIDEO_FSL_DCU_FB is not set
# CONFIG_VIDEO_TEGRA20 is not set
# CONFIG_VIDEO_BRIDGE is not set
CONFIG_VIDEO=y
CONFIG_CFB_CONSOLE=y
CONFIG_CFB_CONSOLE_ANSI=y
CONFIG_VGA_AS_SINGLE_DEVICE=y
CONFIG_VIDEO_SW_CURSOR=y
# CONFIG_CONSOLE_EXTRA_INFO is not set
CONFIG_CONSOLE_SCROLL_LINES=1
CONFIG_SYS_CONSOLE_BG_COL=0x00
CONFIG_SYS_CONSOLE_FG_COL=0xa0
# CONFIG_LCD is not set
# CONFIG_VIDEO_SIMPLE is not set
CONFIG_VIDEO_DT_SIMPLEFB=y
# CONFIG_OSD is not set
# VirtIO Drivers
# CONFIG_VIRTIO_MMIO is not set
# 1-Wire support
# CONFIG_W1 is not set
# 1-wire EEPROM support
# CONFIG_W1_EEPROM is not set
# Watchdog Timer Support
# CONFIG_WATCHDOG is not set
CONFIG_WATCHDOG_TIMEOUT_MSECS=60000
# CONFIG_WATCHDOG_RESET_DISABLE is not set
# CONFIG_IMX_WATCHDOG is not set
# CONFIG_ULP_WATCHDOG is not set
# CONFIG_WDT is not set
# CONFIG_PHYS_TO_BUS is not set
# File systems
# CONFIG_FS_BTRFS is not set
# CONFIG_FS_CBFS is not set
# CONFIG_SPL_FS_CBFS is not set
CONFIG_FS_EXT4=y
# CONFIG_EXT4_WRITE is not set
CONFIG_FS_FAT=y
CONFIG_FAT_WRITE=y
CONFIG_FS_FAT_MAX_CLUSTSIZE=65536
# CONFIG_FS_JFFS2 is not set
# CONFIG_UBIFS_SILENCE_MSG is not set
# CONFIG_FS_CRAMFS is not set
# CONFIG_YAFFS2 is not set
# Library routines
# CONFIG_BCH is not set
# CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set
# CONFIG_DYNAMIC_CRC_TABLE is not set
CONFIG_HAVE_PRIVATE_LIBGCC=y
CONFIG_LIB_UUID=y
CONFIG_PRINTF=y
CONFIG_SPL_PRINTF=y
CONFIG_SPRINTF=y
CONFIG_SPL_SPRINTF=y
CONFIG_STRTO=y
CONFIG_SPL_STRTO=y
CONFIG_IMAGE_SPARSE=y
CONFIG_IMAGE_SPARSE_FILLBUF_SIZE=0x80000
CONFIG_USE_PRIVATE_LIBGCC=y
CONFIG_SYS_HZ=1000
CONFIG_SPL_USE_TINY_PRINTF=y
# CONFIG_PANIC_HANG is not set
CONFIG_REGEX=y
CONFIG_LIB_RAND=y
# CONFIG_LIB_HW_RAND is not set
# CONFIG_SPL_TINY_MEMSET is not set
# CONFIG_TPL_TINY_MEMSET is not set
# CONFIG_BITREVERSE is not set
# CONFIG_TRACE is not set
# CONFIG_CMD_DHRYSTONE is not set
# Security support
# CONFIG_AES is not set
# CONFIG_RSA is not set
# CONFIG_ASYMMETRIC_KEY_TYPE is not set
# CONFIG_TPM is not set
# Android Verified Boot
# CONFIG_LIBAVB is not set
# Hashing Support
CONFIG_SHA1=y
CONFIG_SHA256=y
# CONFIG_SHA_HW_ACCEL is not set
CONFIG_MD5=y
# Compression Support
# CONFIG_LZ4 is not set
# CONFIG_LZMA is not set
# CONFIG_LZO is not set
CONFIG_GZIP=y
CONFIG_ZLIB=y
# CONFIG_ZSTD is not set
# CONFIG_SPL_LZ4 is not set
# CONFIG_SPL_LZO is not set
# CONFIG_SPL_GZIP is not set
# CONFIG_SPL_ZSTD is not set
# CONFIG_ERRNO_STR is not set
# CONFIG_HEXDUMP is not set
CONFIG_OF_LIBFDT=y
CONFIG_OF_LIBFDT_ASSUME_MASK=0
CONFIG_OF_LIBFDT_OVERLAY=y
# CONFIG_SPL_OF_LIBFDT is not set
CONFIG_SPL_OF_LIBFDT_ASSUME_MASK=0xff
# CONFIG_TPL_OF_LIBFDT is not set
CONFIG_TPL_OF_LIBFDT_ASSUME_MASK=0xff
# System tables
CONFIG_GENERATE_SMBIOS_TABLE=y
CONFIG_SMBIOS_MANUFACTURER=""
CONFIG_EFI_LOADER=y
CONFIG_EFI_DEVICE_PATH_TO_TEXT=y
CONFIG_EFI_LOADER_HII=y
CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2=y
CONFIG_EFI_UNICODE_CAPITALIZATION=y
# CONFIG_EFI_UNICODE_COLLATION_PROTOCOL is not set
CONFIG_EFI_PLATFORM_LANG_CODES="en-US"
CONFIG_EFI_GRUB_ARM32_WORKAROUND=y
# CONFIG_TEST_FDTDEC is not set
# CONFIG_UNIT_TEST is not setSPI FLASH 编译通过, 不知道能不能用呢.
这个应该是 SPL 检测TF卡的引脚
这个是u-boot的tf卡检测脚 (arch/arm/dts/sun8i-a33-sinlinx-sina33.dts):
&pio {
mmc0_cd_pin_sina33: mmc0_cd_pin@0 {
pins = "PL4";
function = "gpio_in";
bias-pull-up;
&mmc0 {
pinctrl-names = "default";
pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_sina33>;
vmmc-supply = <®_dcdc1>;
bus-width = <4>;
cd-gpios = <&r_pio 0 9 GPIO_ACTIVE_LOW>; /* PL9 */
u-boot读TF卡gpio状态:
gpio status pl9
gpio clear pl11
gpio set pl11
控制PL11 高/低电平正常.
这个可以把程序放在spi flash启动吗?
SPI NOR /SPI NAND/ TF卡 都可以的.
cloudxxcloud 说:这个可以把程序放在spi flash启动吗?
有具体的方法吗?用什么工具? PhoneixUSB好像不行
# # Automatically generated file; DO NOT EDIT. # U-Boot 2020.01 Configuration # CONFIG_CREATE_ARCH_SYMLINK=y # CONFIG_ARC is not set CONFIG_ARM=y # CONFIG_M68K is not set # CONFIG_MICROBLAZE is not set # CONFIG_MIPS is not set # CONFIG_NDS32 is not set # CONFIG_NIOS2 is not set # CONFIG_PPC is not set # CONFIG_RISCV is not set # CONFIG_SANDBOX is not set # CONFIG_SH is not set # CONFIG_X86 is not set # CONFIG_XTENSA is not set CONFIG_SYS_ARCH="arm" CONFIG_SYS_CPU="armv7" CONFIG_SYS_SOC="sunxi" CONFIG_SYS_BOARD="sunxi" CONFIG_SYS_CONFIG_NAME="sun8i" # CONFIG_SYS_ICACHE_OFF is not set # CONFIG_SPL_SYS_ICACHE_OFF is not set # CONFIG_SYS_DCACHE_OFF is not set # CONFIG_SPL_SYS_DCACHE_OFF is not set # # ARM architecture # CONFIG_HAS_VBAR=y CONFIG_HAS_THUMB2=y CONFIG_ARM_ASM_UNIFIED=y CONFIG_SYS_ARM_CACHE_CP15=y CONFIG_SYS_ARM_MMU=y # CONFIG_SYS_ARM_MPU is not set CONFIG_CPU_V7A=y CONFIG_SYS_ARM_ARCH=7 CONFIG_SYS_CACHE_SHIFT_6=y CONFIG_SYS_CACHELINE_SIZE=64 # CONFIG_ARCH_CPU_INIT is not set # CONFIG_SYS_ARCH_TIMER is not set # CONFIG_ARM_SMCCC is not set # CONFIG_SEMIHOSTING is not set CONFIG_SYS_THUMB_BUILD=y CONFIG_SPL_SYS_THUMB_BUILD=y # CONFIG_SYS_L2CACHE_OFF is not set # CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set CONFIG_USE_ARCH_MEMCPY=y CONFIG_SPL_USE_ARCH_MEMCPY=y CONFIG_USE_ARCH_MEMSET=y CONFIG_SPL_USE_ARCH_MEMSET=y # CONFIG_SET_STACK_SIZE is not set # CONFIG_ARCH_AT91 is not set # CONFIG_TARGET_EDB93XX is not set # CONFIG_TARGET_ASPENITE is not set # CONFIG_TARGET_GPLUGD is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_KIRKWOOD is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_TARGET_APF27 is not set # CONFIG_ORION5X is not set # CONFIG_TARGET_SPEAR300 is not set # CONFIG_TARGET_SPEAR310 is not set # CONFIG_TARGET_SPEAR320 is not set # CONFIG_TARGET_SPEAR600 is not set # CONFIG_TARGET_STV0991 is not set # CONFIG_TARGET_X600 is not set # CONFIG_TARGET_WOODBURN is not set # CONFIG_TARGET_WOODBURN_SD is not set # CONFIG_TARGET_FLEA3 is not set # CONFIG_TARGET_MX35PDK is not set # CONFIG_ARCH_BCM283X is not set # CONFIG_ARCH_BCM63158 is not set # CONFIG_ARCH_BCM6858 is not set # CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set # CONFIG_ARCH_BCMSTB is not set # CONFIG_TARGET_VEXPRESS_CA5X2 is not set # CONFIG_TARGET_VEXPRESS_CA9X4 is not set # CONFIG_TARGET_BCM23550_W1D is not set # CONFIG_TARGET_BCM28155_AP is not set # CONFIG_TARGET_BCMCYGNUS is not set # CONFIG_TARGET_BCMNSP is not set # CONFIG_TARGET_BCMNS2 is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_S5PC1XX is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_K3 is not set # CONFIG_ARCH_OMAP2PLUS is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_IMX8 is not set # CONFIG_ARCH_IMX8M is not set # CONFIG_ARCH_MX23 is not set # CONFIG_ARCH_MX25 is not set # CONFIG_ARCH_MX28 is not set # CONFIG_ARCH_MX31 is not set # CONFIG_ARCH_MX7ULP is not set # CONFIG_ARCH_MX7 is not set # CONFIG_ARCH_MX6 is not set CONFIG_SPL_LDSCRIPT="arch/arm/cpu/armv7/sunxi/u-boot-spl.lds" # CONFIG_ARCH_MX5 is not set # CONFIG_ARCH_OWL is not set # CONFIG_ARCH_QEMU is not set # CONFIG_ARCH_RMOBILE is not set # CONFIG_TARGET_S32V234EVB is not set # CONFIG_ARCH_SNAPDRAGON is not set # CONFIG_ARCH_SOCFPGA is not set CONFIG_ARCH_SUNXI=y # CONFIG_ARCH_VERSAL is not set # CONFIG_ARCH_VF610 is not set # CONFIG_ARCH_ZYNQ is not set # CONFIG_ARCH_ZYNQMP_R5 is not set # CONFIG_ARCH_ZYNQMP is not set # CONFIG_TEGRA is not set # CONFIG_TARGET_VEXPRESS64_AEMV8A is not set # CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set # CONFIG_TARGET_VEXPRESS64_JUNO is not set # CONFIG_TARGET_LS2080A_EMU is not set # CONFIG_TARGET_LS2080A_SIMU is not set # CONFIG_TARGET_LS1088AQDS is not set # CONFIG_TARGET_LS2080AQDS is not set # CONFIG_TARGET_LS2080ARDB is not set # CONFIG_TARGET_LS2081ARDB is not set # CONFIG_TARGET_LX2160ARDB is not set # CONFIG_TARGET_LX2160AQDS is not set # CONFIG_TARGET_HIKEY is not set # CONFIG_TARGET_HIKEY960 is not set # CONFIG_TARGET_POPLAR is not set # CONFIG_TARGET_LS1012AQDS is not set # CONFIG_TARGET_LS1012ARDB is not set # CONFIG_TARGET_LS1012A2G5RDB is not set # CONFIG_TARGET_LS1012AFRWY is not set # CONFIG_TARGET_LS1012AFRDM is not set # CONFIG_TARGET_LS1028AQDS is not set # CONFIG_TARGET_LS1028ARDB is not set # CONFIG_TARGET_LS1088ARDB is not set # CONFIG_TARGET_LS1021AQDS is not set # CONFIG_TARGET_LS1021ATWR is not set # CONFIG_TARGET_LS1021ATSN is not set # CONFIG_TARGET_LS1021AIOT is not set # CONFIG_TARGET_LS1043AQDS is not set # CONFIG_TARGET_LS1043ARDB is not set # CONFIG_TARGET_LS1046AQDS is not set # CONFIG_TARGET_LS1046ARDB is not set # CONFIG_TARGET_LS1046AFRWY is not set # CONFIG_TARGET_COLIBRI_PXA270 is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_STM32 is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_STM32MP is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_TARGET_THUNDERX_88XX is not set # CONFIG_ARCH_ASPEED is not set # CONFIG_TARGET_DURIAN is not set CONFIG_SYS_TEXT_BASE=0x4a000000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y # CONFIG_SPL_DRIVERS_MISC_SUPPORT is not set CONFIG_ENV_SIZE=0x20000 CONFIG_SPL_STACK_R_ADDR=0x4fe00000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_ERR_PTR_OFFSET=0x0 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL_SIZE_LIMIT=0 CONFIG_SPL=y CONFIG_PRE_CON_BUF_ADDR=0x4f000000 CONFIG_PRE_CON_BUF_SZ=4096 CONFIG_BOOTSTAGE_STASH_ADDR=0 CONFIG_IDENT_STRING=" Allwinner Technology" CONFIG_DRAM_SUN8I_A33=y # CONFIG_SUN6I_P2WI is not set CONFIG_SUN6I_PRCM=y CONFIG_AXP_PMIC_BUS=y CONFIG_SUN8I_RSB=y CONFIG_SUNXI_SRAM_ADDRESS=0x0 CONFIG_SUNXI_GEN_SUN6I=y CONFIG_SUNXI_DRAM_MAX_SIZE=0x80000000 # CONFIG_MACH_SUN4I is not set # CONFIG_MACH_SUN5I is not set # CONFIG_MACH_SUN6I is not set # CONFIG_MACH_SUN7I is not set # CONFIG_MACH_SUN8I_A23 is not set CONFIG_MACH_SUN8I_A33=y # CONFIG_MACH_SUN8I_A83T is not set # CONFIG_MACH_SUN8I_H3 is not set # CONFIG_MACH_SUN8I_R40 is not set # CONFIG_MACH_SUN8I_V3S is not set # CONFIG_MACH_SUN9I is not set # CONFIG_MACH_SUN50I is not set # CONFIG_MACH_SUN50I_H5 is not set # CONFIG_MACH_SUN50I_H6 is not set CONFIG_MACH_SUN8I=y # CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER is not set CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=15291 # CONFIG_DRAM_ODT_EN is not set CONFIG_SYS_CLK_FREQ=1008000000 # CONFIG_UART0_PORT_F is not set # CONFIG_OLD_SUNXI_KERNEL_COMPAT is not set CONFIG_MACPWR="" CONFIG_MMC0_CD_PIN="PL9" CONFIG_MMC1_CD_PIN="" CONFIG_MMC2_CD_PIN="" CONFIG_MMC3_CD_PIN="" CONFIG_MMC1_PINS="" CONFIG_MMC2_PINS="" CONFIG_MMC3_PINS="" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_INITIAL_USB_SCAN_DELAY=0 CONFIG_USB0_VBUS_PIN="" CONFIG_USB0_VBUS_DET="" CONFIG_USB0_ID_DET="PH8" CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_USB3_VBUS_PIN="" # CONFIG_I2C0_ENABLE is not set # CONFIG_I2C1_ENABLE is not set # CONFIG_I2C2_ENABLE is not set # CONFIG_R_I2C_ENABLE is not set # CONFIG_AXP_GPIO is not set CONFIG_VIDEO_SUNXI=y # CONFIG_VIDEO_VGA_VIA_LCD is not set CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:66000,le:90,ri:160,up:3,lo:127,hs:70,vs:20,sync:3,vmode:0" CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="" CONFIG_VIDEO_LCD_RESET="" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW=y # CONFIG_VIDEO_LCD_PANEL_I2C is not set CONFIG_VIDEO_LCD_IF_PARALLEL=y CONFIG_VIDEO_LCD_PANEL_PARALLEL=y # CONFIG_VIDEO_LCD_PANEL_LVDS is not set # CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828 is not set # CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804 is not set # CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM is not set # CONFIG_VIDEO_LCD_TL059WV5C0 is not set CONFIG_SATAPWR="" CONFIG_GMAC_TX_DELAY=0 # CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_CPU_V7_HAS_NONSEC=y CONFIG_CPU_V7_HAS_VIRT=y CONFIG_ARCH_SUPPORT_PSCI=y CONFIG_ARMV7_NONSEC=y # CONFIG_ARMV7_BOOT_SEC_DEFAULT is not set CONFIG_ARMV7_VIRT=y CONFIG_ARMV7_PSCI=y CONFIG_ARMV7_PSCI_NR_CPUS=4 CONFIG_ARMV7_LPAE=y CONFIG_CSF_SIZE=0x2060 # CONFIG_CMD_DEKBLOB is not set # CONFIG_CMD_HDMIDETECT is not set CONFIG_IMX_DCD_ADDR=0x00910000 # # ARM debug # # CONFIG_DEBUG_LL is not set CONFIG_SMBIOS_PRODUCT_NAME="sunxi" # CONFIG_DEBUG_UART is not set # CONFIG_AHCI is not set CONFIG_SPL_TEXT_BASE=0x00060 # # General setup # CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_SYS_BOOT_GET_CMDLINE is not set # CONFIG_SYS_BOOT_GET_KBD is not set CONFIG_SYS_MALLOC_F=y CONFIG_EXPERT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_TOOLS_DEBUG is not set # CONFIG_PHYS_64BIT is not set CONFIG_SPL_IMAGE="spl/u-boot-spl.bin" CONFIG_BUILD_TARGET="" # CONFIG_SYS_CUSTOM_LDSCRIPT is not set # # Boot images # CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x0 CONFIG_FIT_ENABLE_SHA256_SUPPORT=y # CONFIG_FIT_SIGNATURE is not set # CONFIG_FIT_VERBOSE is not set # CONFIG_FIT_BEST_MATCH is not set # CONFIG_SPL_FIT is not set # CONFIG_SPL_LOAD_FIT is not set # CONFIG_SPL_LOAD_FIT_FULL is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_BOARD_SETUP=y # CONFIG_OF_SYSTEM_SETUP is not set # CONFIG_OF_STDOUT_VIA_ALIAS is not set CONFIG_SYS_EXTRA_OPTIONS="" CONFIG_ARCH_FIXUP_FDT_MEMORY=y # # API # # CONFIG_API is not set # # Boot timing # # CONFIG_BOOTSTAGE is not set CONFIG_BOOTSTAGE_RECORD_COUNT=30 CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5 CONFIG_TPL_BOOTSTAGE_RECORD_COUNT=5 CONFIG_BOOTSTAGE_STASH_SIZE=0x1000 # CONFIG_SHOW_BOOT_PROGRESS is not set # # Boot media # # CONFIG_NAND_BOOT is not set # CONFIG_ONENAND_BOOT is not set # CONFIG_QSPI_BOOT is not set # CONFIG_SATA_BOOT is not set # CONFIG_SD_BOOT is not set # CONFIG_SPI_BOOT is not set CONFIG_BOOTDELAY=0 # CONFIG_USE_BOOTARGS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="ums 0 mmc 1" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="" # # Console # CONFIG_MENU=y # CONFIG_CONSOLE_RECORD is not set # CONFIG_DISABLE_CONSOLE is not set CONFIG_LOGLEVEL=4 CONFIG_SPL_LOGLEVEL=4 CONFIG_TPL_LOGLEVEL=4 # CONFIG_SILENT_CONSOLE is not set CONFIG_PRE_CONSOLE_BUFFER=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set # CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set # CONFIG_SYS_CONSOLE_INFO_QUIET is not set CONFIG_SYS_STDIO_DEREGISTER=y # # Logging # # CONFIG_LOG is not set CONFIG_LOG_DEFAULT_LEVEL=6 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="" CONFIG_MISC_INIT_R=y # CONFIG_VERSION_VARIABLE is not set # CONFIG_BOARD_LATE_INIT is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_DISPLAY_BOARDINFO_LATE is not set # CONFIG_BOUNCE_BUFFER is not set # CONFIG_BOARD_TYPES is not set # # Start-up hooks # # CONFIG_ARCH_EARLY_INIT_R is not set # CONFIG_ARCH_MISC_INIT is not set # CONFIG_BOARD_EARLY_INIT_F is not set # CONFIG_BOARD_EARLY_INIT_R is not set # CONFIG_LAST_STAGE_INIT is not set # # Security support # CONFIG_HASH=y # # Update support # # CONFIG_UPDATE_TFTP is not set # CONFIG_ANDROID_AB is not set # # Blob list # # CONFIG_BLOBLIST is not set # # SPL / TPL # CONFIG_SUPPORT_SPL=y CONFIG_SPL_FRAMEWORK=y # CONFIG_SPL_FRAMEWORK_BOARD_INIT_F is not set CONFIG_SPL_SYS_STACK_F_CHECK_BYTE=0xaa # CONFIG_SPL_SYS_REPORT_STACK_F_USAGE is not set # CONFIG_SPL_BOARD_INIT is not set # CONFIG_SPL_BOOTROM_SUPPORT is not set CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_LEGACY_IMAGE_SUPPORT=y # CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x100000 # CONFIG_SPL_SEPARATE_BSS is not set CONFIG_SPL_BANNER_PRINT=y # CONFIG_SPL_EARLY_BSS is not set # CONFIG_SPL_DISPLAY_PRINT is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x50 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is not set CONFIG_SPL_CRC32_SUPPORT=y # CONFIG_SPL_CACHE_SUPPORT is not set # CONFIG_SPL_CPU_SUPPORT is not set # CONFIG_SPL_CRYPTO_SUPPORT is not set # CONFIG_SPL_HASH_SUPPORT is not set # CONFIG_SPL_DMA_SUPPORT is not set # CONFIG_SPL_DM_GPIO is not set # CONFIG_SPL_ENV_SUPPORT is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_FAT_WRITE is not set # CONFIG_SPL_FPGA_SUPPORT is not set # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_DM_MAILBOX is not set # CONFIG_SPL_FORCE_MMC_BOOT is not set # CONFIG_SPL_MMC_TINY is not set # CONFIG_SPL_MMC_WRITE is not set # CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT is not set # CONFIG_SPL_MTD_SUPPORT is not set # CONFIG_SPL_MUSB_NEW_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set # CONFIG_SPL_UBI is not set # CONFIG_SPL_NET_SUPPORT is not set # CONFIG_SPL_NO_CPU_SUPPORT is not set # CONFIG_SPL_NOR_SUPPORT is not set # CONFIG_SPL_XIP_SUPPORT is not set # CONFIG_SPL_ONENAND_SUPPORT is not set # CONFIG_SPL_OS_BOOT is not set CONFIG_SPL_PAYLOAD="u-boot.bin" # CONFIG_SPL_PCI is not set # CONFIG_SPL_PCH_SUPPORT is not set # CONFIG_SPL_POST_MEM_SUPPORT is not set # CONFIG_SPL_DM_RESET is not set CONFIG_SPL_POWER_SUPPORT=y # CONFIG_SPL_POWER_DOMAIN is not set # CONFIG_SPL_RAM_SUPPORT is not set # CONFIG_SPL_REMOTEPROC is not set # CONFIG_SPL_RTC_SUPPORT is not set # CONFIG_SPL_SATA_SUPPORT is not set # CONFIG_SPL_SPI_LOAD is not set # CONFIG_SPL_THERMAL is not set # CONFIG_SPL_USB_HOST_SUPPORT is not set # CONFIG_SPL_USB_GADGET is not set # CONFIG_SPL_WATCHDOG_SUPPORT is not set # CONFIG_SPL_YMODEM_SUPPORT is not set # CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is not set # CONFIG_SPL_OPTEE is not set # # Command line interface # CONFIG_CMDLINE=y CONFIG_HUSH_PARSER=y CONFIG_CMDLINE_EDITING=y CONFIG_AUTO_COMPLETE=y CONFIG_SYS_LONGHELP=y CONFIG_SYS_PROMPT="=> " CONFIG_SYS_XTRACE="y" # # Autoboot options # CONFIG_AUTOBOOT=y # CONFIG_AUTOBOOT_KEYED is not set # CONFIG_AUTOBOOT_USE_MENUKEY is not set # # Commands # # # Info commands # CONFIG_CMD_BDI=y # CONFIG_CMD_CONFIG is not set CONFIG_CMD_CONSOLE=y # CONFIG_CMD_CPU is not set # CONFIG_CMD_LICENSE is not set # # Boot commands # CONFIG_CMD_BOOTD=y CONFIG_CMD_BOOTM=y CONFIG_CMD_BOOTZ=y CONFIG_BOOTM_LINUX=y CONFIG_BOOTM_NETBSD=y # CONFIG_BOOTM_OPENRTOS is not set # CONFIG_BOOTM_OSE is not set CONFIG_BOOTM_PLAN9=y CONFIG_BOOTM_RTEMS=y CONFIG_BOOTM_VXWORKS=y CONFIG_CMD_BOOTEFI=y CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y # CONFIG_CMD_BOOTEFI_HELLO is not set # CONFIG_CMD_BOOTEFI_SELFTEST is not set # CONFIG_CMD_BOOTMENU is not set # CONFIG_CMD_DTIMG is not set CONFIG_CMD_ELF=y CONFIG_CMD_FDT=y CONFIG_CMD_GO=y CONFIG_CMD_RUN=y CONFIG_CMD_IMI=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_XIMG=y # CONFIG_CMD_SPL is not set # CONFIG_CMD_FITUPD is not set # CONFIG_CMD_THOR_DOWNLOAD is not set # CONFIG_CMD_ZBOOT is not set # # Environment commands # # CONFIG_CMD_ASKENV is not set CONFIG_CMD_EXPORTENV=y CONFIG_CMD_IMPORTENV=y CONFIG_CMD_EDITENV=y # CONFIG_CMD_GREPENV is not set CONFIG_CMD_SAVEENV=y # CONFIG_CMD_ERASEENV is not set CONFIG_CMD_ENV_EXISTS=y # CONFIG_CMD_ENV_CALLBACK is not set # CONFIG_CMD_ENV_FLAGS is not set # CONFIG_CMD_NVEDIT_EFI is not set # CONFIG_CMD_NVEDIT_INFO is not set # # Memory commands # # CONFIG_CMD_BINOP is not set CONFIG_CMD_CRC32=y # CONFIG_CRC32_VERIFY is not set # CONFIG_CMD_EEPROM is not set # CONFIG_LOOPW is not set # CONFIG_CMD_MD5SUM is not set # CONFIG_CMD_MEMINFO is not set CONFIG_CMD_MEMORY=y # CONFIG_MX_CYCLIC is not set CONFIG_CMD_RANDOM=y # CONFIG_CMD_MEMTEST is not set # CONFIG_CMD_MX_CYCLIC is not set # CONFIG_CMD_SHA1SUM is not set # CONFIG_CMD_STRINGS is not set # # Compression commands # # CONFIG_CMD_LZMADEC is not set # CONFIG_CMD_UNZIP is not set # CONFIG_CMD_ZIP is not set # # Device access commands # # CONFIG_CMD_ARMFLASH is not set # CONFIG_CMD_ADC is not set # CONFIG_CMD_BCB is not set # CONFIG_CMD_BIND is not set # CONFIG_CMD_CLK is not set # CONFIG_CMD_DEMO is not set CONFIG_CMD_DFU=y CONFIG_CMD_DM=y CONFIG_CMD_FASTBOOT=y # CONFIG_CMD_FDC is not set # CONFIG_CMD_FPGAD is not set # CONFIG_CMD_FUSE is not set CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_RANDOM_UUID=y # CONFIG_CMD_GPT_RENAME is not set # CONFIG_CMD_IDE is not set # CONFIG_CMD_IO is not set # CONFIG_CMD_IOTRACE is not set # CONFIG_CMD_I2C is not set CONFIG_CMD_LOADB=y CONFIG_CMD_LOADS=y CONFIG_CMD_MMC=y # CONFIG_CMD_MMC_RPMB is not set # CONFIG_CMD_MMC_SWRITE is not set # CONFIG_CMD_OSD is not set CONFIG_CMD_PART=y # CONFIG_CMD_PCI is not set # CONFIG_CMD_PINMUX is not set CONFIG_CMD_POWEROFF=y # CONFIG_CMD_READ is not set # CONFIG_CMD_SATA is not set # CONFIG_CMD_SAVES is not set # CONFIG_CMD_SCSI is not set # CONFIG_CMD_SDRAM is not set # CONFIG_CMD_SF is not set # CONFIG_CMD_SPI is not set # CONFIG_CMD_TSI148 is not set # CONFIG_CMD_UNIVERSE is not set CONFIG_CMD_USB=y # CONFIG_CMD_USB_SDP is not set CONFIG_CMD_USB_MASS_STORAGE=y # # Shell scripting commands # CONFIG_CMD_ECHO=y CONFIG_CMD_ITEST=y CONFIG_CMD_SOURCE=y CONFIG_CMD_SETEXPR=y # # Android support commands # CONFIG_CMD_NET=y CONFIG_CMD_BOOTP=y CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTPATH=y CONFIG_BOOTP_DNS=y # CONFIG_BOOTP_DNS2 is not set CONFIG_BOOTP_GATEWAY=y CONFIG_BOOTP_HOSTNAME=y # CONFIG_BOOTP_PREFER_SERVERIP is not set CONFIG_BOOTP_SUBNETMASK=y # CONFIG_BOOTP_NTPSERVER is not set # CONFIG_CMD_PCAP is not set CONFIG_BOOTP_PXE=y CONFIG_BOOTP_PXE_CLIENTARCH=0x15 CONFIG_BOOTP_VCI_STRING="U-Boot.armv7" CONFIG_CMD_TFTPBOOT=y # CONFIG_CMD_TFTPPUT is not set # CONFIG_CMD_TFTPSRV is not set CONFIG_NET_TFTP_VARS=y # CONFIG_CMD_RARP is not set CONFIG_CMD_NFS=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_CDP is not set # CONFIG_CMD_SNTP is not set # CONFIG_CMD_DNS is not set # CONFIG_CMD_LINK_LOCAL is not set # CONFIG_CMD_ETHSW is not set CONFIG_CMD_PXE=y # CONFIG_CMD_WOL is not set # # Misc commands # # CONFIG_CMD_BMP is not set # CONFIG_CMD_BSP is not set # CONFIG_CMD_BKOPS_ENABLE is not set CONFIG_CMD_BLOCK_CACHE=y # CONFIG_CMD_CACHE is not set # CONFIG_CMD_CONITRACE is not set # CONFIG_CMD_CLS is not set # CONFIG_CMD_EFIDEBUG is not set # CONFIG_CMD_EXCEPTION is not set # CONFIG_CMD_DATE is not set # CONFIG_CMD_TIME is not set # CONFIG_CMD_GETTIME is not set CONFIG_CMD_MISC=y # CONFIG_MP is not set # CONFIG_CMD_TIMER is not set CONFIG_CMD_SYSBOOT=y # CONFIG_CMD_QFW is not set # CONFIG_CMD_TERMINAL is not set # CONFIG_CMD_UUID is not set # # TI specific command line interface # # CONFIG_CMD_DDR3 is not set # # Power commands # # # Security commands # # CONFIG_CMD_AES is not set # CONFIG_CMD_BLOB is not set # CONFIG_CMD_HASH is not set # # Firmware commands # # # Filesystem commands # # CONFIG_CMD_BTRFS is not set CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y # CONFIG_CMD_EXT4_WRITE is not set CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y # CONFIG_CMD_FS_UUID is not set # CONFIG_CMD_JFFS2 is not set CONFIG_MTDIDS_DEFAULT="" CONFIG_MTDPARTS_DEFAULT="" # CONFIG_CMD_REISER is not set # CONFIG_CMD_ZFS is not set # # Debug commands # # CONFIG_CMD_BEDBUG is not set # CONFIG_CMD_DIAG is not set # CONFIG_CMD_LOG is not set # CONFIG_CMD_TRACE is not set # CONFIG_CMD_UBI is not set # # Partition Types # CONFIG_PARTITIONS=y # CONFIG_MAC_PARTITION is not set # CONFIG_SPL_MAC_PARTITION is not set CONFIG_DOS_PARTITION=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_SPL_AMIGA_PARTITION is not set CONFIG_EFI_PARTITION=y CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=56 CONFIG_EFI_PARTITION_ENTRIES_OFF=0 CONFIG_SPL_EFI_PARTITION=y CONFIG_PARTITION_UUIDS=y # CONFIG_SPL_PARTITION_UUIDS is not set # CONFIG_PARTITION_TYPE_GUID is not set CONFIG_SUPPORT_OF_CONTROL=y CONFIG_DTC=y CONFIG_PYLIBFDT=y CONFIG_DTOC=y CONFIG_BINMAN=y # # Device Tree Control # CONFIG_OF_CONTROL=y # CONFIG_OF_BOARD_FIXUP is not set # CONFIG_SPL_OF_CONTROL is not set # CONFIG_OF_LIVE is not set CONFIG_OF_SEPARATE=y # CONFIG_OF_EMBED is not set # CONFIG_OF_BOARD is not set # CONFIG_OF_PRIOR_STAGE is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33" # CONFIG_MULTI_DTB_FIT is not set CONFIG_MKIMAGE_DTC_PATH="dtc" # # Environment # # CONFIG_ENV_IS_NOWHERE is not set # CONFIG_ENV_IS_IN_EEPROM is not set CONFIG_ENV_IS_IN_FAT=y # CONFIG_ENV_IS_IN_EXT4 is not set # CONFIG_ENV_IS_IN_FLASH is not set # CONFIG_ENV_IS_IN_MMC is not set # CONFIG_ENV_IS_IN_NAND is not set # CONFIG_ENV_IS_IN_NVRAM is not set # CONFIG_ENV_IS_IN_ONENAND is not set # CONFIG_ENV_IS_IN_REMOTE is not set # CONFIG_ENV_IS_IN_SPI_FLASH is not set CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="1:auto" CONFIG_ENV_FAT_FILE="uboot.env" CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_USE_DEFAULT_ENV_FILE is not set # CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set CONFIG_NET=y # CONFIG_NET_RANDOM_ETHADDR is not set # CONFIG_NETCONSOLE is not set # CONFIG_IP_DEFRAG is not set CONFIG_TFTP_BLOCKSIZE=1468 # # Device Drivers # # # Generic Driver Options # CONFIG_DM=y # CONFIG_SPL_DM is not set CONFIG_DM_WARN=y # CONFIG_DM_DEBUG is not set CONFIG_DM_DEVICE_REMOVE=y CONFIG_DM_STDIO=y CONFIG_DM_SEQ_ALIAS=y # CONFIG_REGMAP is not set # CONFIG_DEVRES is not set CONFIG_SIMPLE_BUS=y CONFIG_OF_TRANSLATE=y # CONFIG_TRANSLATION_OFFSET is not set CONFIG_DM_DEV_READ_INLINE=y # CONFIG_ADC is not set # CONFIG_ADC_EXYNOS is not set # CONFIG_ADC_SANDBOX is not set # CONFIG_SARADC_MESON is not set # CONFIG_SARADC_ROCKCHIP is not set # CONFIG_SATA is not set # CONFIG_SCSI_AHCI is not set # # SATA/SCSI device support # # CONFIG_DWC_AHSATA is not set # CONFIG_FSL_SATA is not set # CONFIG_MVSATA_IDE is not set # CONFIG_SATA_MV is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIL3114 is not set # CONFIG_AXI is not set CONFIG_BLK=y CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_BLOCK_CACHE=y # CONFIG_IDE is not set # CONFIG_BOOTCOUNT_LIMIT is not set # # Cache Controller drivers # # CONFIG_CACHE is not set # CONFIG_L2X0_CACHE is not set # # Clock # CONFIG_CLK=y # CONFIG_SPL_CLK_CCF is not set # CONFIG_CLK_CCF is not set # CONFIG_CLK_HSDK is not set # CONFIG_CLK_CDCE9XX is not set # CONFIG_CLK_AT91 is not set CONFIG_CLK_SUNXI=y # CONFIG_CLK_SUN4I_A10 is not set # CONFIG_CLK_SUN5I_A10S is not set # CONFIG_CLK_SUN6I_A31 is not set CONFIG_CLK_SUN8I_A23=y # CONFIG_CLK_SUN8I_A83T is not set # CONFIG_CLK_SUN8I_R40 is not set # CONFIG_CLK_SUN8I_V3S is not set # CONFIG_CLK_SUN9I_A80 is not set # CONFIG_CLK_SUN8I_H3 is not set # CONFIG_CLK_SUN50I_H6 is not set # CONFIG_CLK_SUN50I_A64 is not set # CONFIG_CLK_SIFIVE is not set # CONFIG_ICS8N3QV01 is not set # CONFIG_CLK_MPC83XX is not set # CONFIG_CPU is not set # # Hardware crypto devices # # CONFIG_FSL_CAAM is not set # CONFIG_SYS_FSL_SEC_BE is not set # CONFIG_SYS_FSL_SEC_LE is not set # # Demo for driver model # # CONFIG_DM_DEMO is not set # CONFIG_BOARD is not set # # DFU support # CONFIG_DFU=y CONFIG_DFU_OVER_USB=y # CONFIG_DFU_TFTP is not set # CONFIG_DFU_MMC is not set CONFIG_DFU_RAM=y # CONFIG_DFU_SF is not set # CONFIG_DFU_VIRT is not set # # DMA Support # # CONFIG_DMA is not set # CONFIG_TI_EDMA3 is not set # # Fastboot support # CONFIG_FASTBOOT=y CONFIG_USB_FUNCTION_FASTBOOT=y # CONFIG_UDP_FUNCTION_FASTBOOT is not set CONFIG_FASTBOOT_BUF_ADDR=0x42000000 CONFIG_FASTBOOT_BUF_SIZE=0x2000000 CONFIG_FASTBOOT_USB_DEV=0 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC=y CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_FASTBOOT_GPT_NAME="gpt" CONFIG_FASTBOOT_MBR_NAME="mbr" CONFIG_FASTBOOT_CMD_OEM_FORMAT=y # CONFIG_FIRMWARE is not set # CONFIG_ZYNQMP_FIRMWARE is not set # # FPGA support # # CONFIG_FPGA_ALTERA is not set # CONFIG_FPGA_SOCFPGA is not set # CONFIG_FPGA_XILINX is not set # # GPIO Support # CONFIG_DM_GPIO=y # CONFIG_GPIO_HOG is not set # CONFIG_ALTERA_PIO is not set # CONFIG_DWAPB_GPIO is not set # CONFIG_AT91_GPIO is not set # CONFIG_ATMEL_PIO4 is not set # CONFIG_DA8XX_GPIO is not set # CONFIG_INTEL_BROADWELL_GPIO is not set # CONFIG_INTEL_ICH6_GPIO is not set # CONFIG_IMX_RGPIO2P is not set # CONFIG_HSDK_CREG_GPIO is not set # CONFIG_LPC32XX_GPIO is not set # CONFIG_MSM_GPIO is not set # CONFIG_MXC_GPIO is not set # CONFIG_MXS_GPIO is not set # CONFIG_CMD_PCA953X is not set # CONFIG_ROCKCHIP_GPIO is not set CONFIG_SUNXI_GPIO=y # CONFIG_XILINX_GPIO is not set # CONFIG_CMD_TCA642X is not set # CONFIG_TEGRA_GPIO is not set # CONFIG_TEGRA186_GPIO is not set # CONFIG_VYBRID_GPIO is not set # CONFIG_SIFIVE_GPIO is not set # CONFIG_DM_74X164 is not set # CONFIG_DM_PCA953X is not set # CONFIG_SPL_DM_PCA953X is not set # CONFIG_MPC8XXX_GPIO is not set # # Hardware Spinlock Support # # CONFIG_DM_HWSPINLOCK is not set # # I2C support # # CONFIG_DM_I2C is not set # CONFIG_SYS_I2C_DW is not set # CONFIG_SYS_I2C_IMX_LPI2C is not set # CONFIG_SYS_I2C_MXC is not set CONFIG_INPUT=y CONFIG_DM_KEYBOARD=y # CONFIG_CROS_EC_KEYB is not set # CONFIG_I8042_KEYB is not set # CONFIG_TEGRA_KEYBOARD is not set # CONFIG_TWL4030_INPUT is not set # # LED Support # # CONFIG_LED is not set # CONFIG_LED_STATUS is not set # # Mailbox Controller Support # # CONFIG_DM_MAILBOX is not set # # Memory Controller drivers # # # Multifunction device drivers # # CONFIG_MISC is not set # CONFIG_CROS_EC is not set # CONFIG_SPL_CROS_EC is not set # CONFIG_DS4510 is not set # CONFIG_FSL_SEC_MON is not set # CONFIG_NUVOTON_NCT6102D is not set # CONFIG_PWRSEQ is not set # CONFIG_PCA9551_LED is not set # CONFIG_TWL4030_LED is not set # CONFIG_WINBOND_W83627 is not set # CONFIG_FS_LOADER is not set # # MMC Host controller Support # CONFIG_MMC=y CONFIG_MMC_WRITE=y # CONFIG_MMC_BROKEN_CD is not set CONFIG_DM_MMC=y # CONFIG_ARM_PL180_MMCI is not set CONFIG_MMC_QUIRKS=y CONFIG_MMC_HW_PARTITIONING=y # CONFIG_SUPPORT_EMMC_RPMB is not set # CONFIG_SUPPORT_EMMC_BOOT is not set # CONFIG_MMC_IO_VOLTAGE is not set # CONFIG_SPL_MMC_IO_VOLTAGE is not set # CONFIG_MMC_HS400_ES_SUPPORT is not set # CONFIG_SPL_MMC_HS400_ES_SUPPORT is not set # CONFIG_MMC_HS400_SUPPORT is not set # CONFIG_SPL_MMC_HS400_SUPPORT is not set # CONFIG_MMC_HS200_SUPPORT is not set # CONFIG_SPL_MMC_HS200_SUPPORT is not set CONFIG_MMC_VERBOSE=y # CONFIG_MMC_TRACE is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_MXC is not set # CONFIG_MMC_PCI is not set # CONFIG_MMC_OMAP_HS is not set # CONFIG_MMC_SDHCI is not set CONFIG_MMC_SUNXI=y # CONFIG_STM32_SDMMC2 is not set # CONFIG_FTSDC010 is not set # CONFIG_FSL_ESDHC is not set # CONFIG_FSL_ESDHC_IMX is not set # # MTD Support # # CONFIG_MTD is not set # CONFIG_DM_MTD is not set # CONFIG_MTD_NOR_FLASH is not set # CONFIG_FLASH_CFI_DRIVER is not set # CONFIG_MTD_RAW_NAND is not set # # SPI Flash Support # CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=0 CONFIG_SF_DEFAULT_CS=0 CONFIG_SF_DEFAULT_MODE=3 CONFIG_SF_DEFAULT_SPEED=1000000 CONFIG_SPI_FLASH_BAR=y # CONFIG_SF_DUAL_FLASH is not set # CONFIG_SPI_FLASH_ATMEL is not set # CONFIG_SPI_FLASH_EON is not set CONFIG_SPI_FLASH_GIGADEVICE=y # CONFIG_SPI_FLASH_ISSI is not set CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_STMICRO is not set # CONFIG_SPI_FLASH_SST is not set CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_XMC is not set CONFIG_SPI_FLASH_USE_4K_SECTORS=y # CONFIG_SPL_SPI_FLASH_MTD is not set # # UBI support # # CONFIG_UBI_SILENCE_MSG is not set # CONFIG_MTD_UBI is not set # CONFIG_BITBANGMII is not set # CONFIG_MV88E6352_SWITCH is not set # CONFIG_PHYLIB is not set # CONFIG_FSL_PFE is not set CONFIG_DM_ETH=y CONFIG_NETDEVICES=y # CONFIG_PHY_GIGE is not set # CONFIG_ALTERA_TSE is not set # CONFIG_BCM_SF2_ETH is not set # CONFIG_DWC_ETH_QOS is not set # CONFIG_E1000 is not set # CONFIG_ETH_DESIGNWARE is not set # CONFIG_ETHOC is not set # CONFIG_FMAN_ENET is not set # CONFIG_FTMAC100 is not set # CONFIG_FTGMAC100 is not set # CONFIG_MACB is not set # CONFIG_RGMII is not set # CONFIG_MII is not set # CONFIG_RTL8139 is not set # CONFIG_RTL8169 is not set # CONFIG_SMC911X is not set # CONFIG_SUN7I_GMAC is not set # CONFIG_SUN4I_EMAC is not set # CONFIG_SUN8I_EMAC is not set # CONFIG_SH_ETHER is not set # CONFIG_DRIVER_TI_CPSW is not set # CONFIG_DRIVER_TI_EMAC is not set # CONFIG_DRIVER_TI_KEYSTONE_NET is not set # CONFIG_SYS_DPAA_QBMAN is not set # CONFIG_TSEC_ENET is not set # CONFIG_MEDIATEK_ETH is not set # CONFIG_HIGMACV300_ETH is not set # CONFIG_PCI is not set # # PCI Endpoint # # CONFIG_PCI_ENDPOINT is not set # # PHY Subsystem # CONFIG_PHY=y # CONFIG_SPL_PHY is not set # CONFIG_NOP_PHY is not set # CONFIG_MSM8916_USB_PHY is not set CONFIG_PHY_SUN4I_USB=y # CONFIG_MVEBU_COMPHY_SUPPORT is not set # # Pin controllers # # CONFIG_PINCTRL is not set # # Power # # # Power Domain Support # # CONFIG_POWER_DOMAIN is not set # CONFIG_DM_PMIC is not set # CONFIG_PMIC_AS3722 is not set # CONFIG_POWER_MC34VR500 is not set # CONFIG_DM_REGULATOR is not set # CONFIG_SUNXI_NO_PMIC is not set CONFIG_AXP221_POWER=y CONFIG_AXP_DCDC1_VOLT=3000 CONFIG_AXP_DCDC2_VOLT=1100 CONFIG_AXP_DCDC3_VOLT=1200 CONFIG_AXP_DCDC4_VOLT=0 CONFIG_AXP_DCDC5_VOLT=1500 CONFIG_AXP_ALDO1_VOLT=3000 CONFIG_AXP_ALDO2_VOLT=2500 CONFIG_AXP_ALDO3_VOLT=3000 CONFIG_AXP_DLDO1_VOLT=0 CONFIG_AXP_DLDO2_VOLT=0 CONFIG_AXP_DLDO3_VOLT=0 CONFIG_AXP_DLDO4_VOLT=0 CONFIG_AXP_ELDO1_VOLT=0 CONFIG_AXP_ELDO2_VOLT=0 CONFIG_AXP_ELDO3_VOLT=0 # CONFIG_DM_PWM is not set # CONFIG_PWM_IMX is not set # CONFIG_PWM_SANDBOX is not set # CONFIG_U_QE is not set # CONFIG_RAM is not set CONFIG_RAM_ROCKCHIP_DEBUG=y # # Remote Processor drivers # # # Reset Controller Support # CONFIG_DM_RESET=y CONFIG_RESET_SUNXI=y # CONFIG_RESET_HISILICON is not set # # Real Time Clock # # CONFIG_DM_RTC is not set # CONFIG_RTC_ENABLE_32KHZ_OUTPUT is not set # CONFIG_RTC_RX8025 is not set # CONFIG_RTC_PL031 is not set # CONFIG_RTC_S35392A is not set # CONFIG_RTC_MC146818 is not set # CONFIG_RTC_M41T62 is not set # CONFIG_SCSI is not set # CONFIG_DM_SCSI is not set # # Serial drivers # CONFIG_BAUDRATE=115200 CONFIG_REQUIRE_SERIAL_CONSOLE=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_SERIAL_PRESENT=y CONFIG_SPL_SERIAL_PRESENT=y CONFIG_CONS_INDEX=1 CONFIG_DM_SERIAL=y # CONFIG_SERIAL_RX_BUFFER is not set # CONFIG_SERIAL_SEARCH_ALL is not set # CONFIG_ALTERA_JTAG_UART is not set # CONFIG_ALTERA_UART is not set # CONFIG_ARC_SERIAL is not set # CONFIG_ATMEL_USART is not set # CONFIG_BCM6345_SERIAL is not set # CONFIG_FSL_LINFLEXUART is not set # CONFIG_FSL_LPUART is not set # CONFIG_MVEBU_A3700_UART is not set # CONFIG_MCFUART is not set # CONFIG_NULLDEV_SERIAL is not set CONFIG_SYS_NS16550=y # CONFIG_PL01X_SERIAL is not set # CONFIG_MSM_SERIAL is not set # CONFIG_OMAP_SERIAL is not set # CONFIG_PXA_SERIAL is not set # CONFIG_SIFIVE_SERIAL is not set # CONFIG_MTK_SERIAL is not set # CONFIG_SMEM is not set # # Sound support # # CONFIG_SOUND is not set # # SOC (System On Chip) specific Drivers # # CONFIG_SOC_TI is not set CONFIG_SPI=y # CONFIG_DM_SPI is not set CONFIG_SPI_MEM=y # CONFIG_CF_SPI is not set # CONFIG_FSL_ESPI is not set # CONFIG_FSL_QSPI is not set # CONFIG_SH_QSPI is not set # CONFIG_KIRKWOOD_SPI is not set # CONFIG_MXC_SPI is not set # CONFIG_MXS_SPI is not set # CONFIG_OMAP3_SPI is not set # # SPMI support # # CONFIG_SPMI is not set # # System reset device drivers # # CONFIG_SYSRESET is not set # CONFIG_SYSRESET_SYSCON is not set # CONFIG_SYSRESET_WATCHDOG is not set # CONFIG_SYSRESET_MPC83XX is not set # CONFIG_TEE is not set # CONFIG_OPTEE is not set # CONFIG_DM_THERMAL is not set # # Timer Support # # CONFIG_TIMER is not set # # TPM support # CONFIG_USB=y CONFIG_DM_USB=y # CONFIG_DM_USB_GADGET is not set # # USB Host Controller Drivers # CONFIG_USB_HOST=y # CONFIG_USB_XHCI_HCD is not set CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_MSM is not set # CONFIG_USB_EHCI_PCI is not set CONFIG_USB_EHCI_GENERIC=y # CONFIG_USB_EHCI_FSL is not set CONFIG_USB_OHCI_HCD=y # CONFIG_USB_OHCI_PCI is not set CONFIG_USB_OHCI_GENERIC=y # CONFIG_USB_OHCI_DA8XX is not set # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_DWC2 is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_CDNS3 is not set # CONFIG_USB_DWC3 is not set # # Legacy MUSB Support # # CONFIG_USB_MUSB_HCD is not set # CONFIG_USB_MUSB_UDC is not set # # MUSB Controller Driver # # CONFIG_USB_MUSB_HOST is not set CONFIG_USB_MUSB_GADGET=y # CONFIG_USB_MUSB_DA8XX is not set # CONFIG_USB_MUSB_TI is not set # CONFIG_USB_MUSB_AM35X is not set # CONFIG_USB_MUSB_DSPS is not set CONFIG_USB_MUSB_SUNXI=y CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT=y CONFIG_USB_MUSB_PIO_ONLY=y # # USB Phy # # CONFIG_TWL4030_USB is not set # CONFIG_OMAP_USB_PHY is not set # CONFIG_ROCKCHIP_USB2_PHY is not set # # ULPI drivers # # # USB peripherals # CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y # CONFIG_USB_KEYBOARD_FN_KEYS is not set # CONFIG_SYS_USB_EVENT_POLL is not set CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y # CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP is not set CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Allwinner Technology" CONFIG_USB_GADGET_VENDOR_NUM=0x1f3a CONFIG_USB_GADGET_PRODUCT_NUM=0x1010 # CONFIG_USB_GADGET_ATMEL_USBA is not set # CONFIG_USB_GADGET_BCM_UDC_OTG_PHY is not set # CONFIG_USB_GADGET_DWC2_OTG is not set # CONFIG_CI_UDC is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_DUALSPEED=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_MASS_STORAGE=y # CONFIG_USB_FUNCTION_ROCKUSB is not set # CONFIG_USB_FUNCTION_SDP is not set # CONFIG_USB_FUNCTION_THOR is not set CONFIG_USB_ETHER=y # CONFIG_USB_ETH_CDC is not set CONFIG_USB_ETH_RNDIS=y CONFIG_USBNET_DEVADDR="de:ad:be:ef:00:01" CONFIG_USBNET_HOST_ADDR="de:ad:be:ef:00:00" # CONFIG_USB_HOST_ETHER is not set # # UFS Host Controller Support # # CONFIG_TI_J721E_UFS is not set # # Graphics support # # CONFIG_DM_VIDEO is not set CONFIG_SYS_WHITE_ON_BLACK=y # CONFIG_NO_FB_CLEAR is not set # # TrueType Fonts # # CONFIG_VIDEO_VESA is not set # CONFIG_VIDEO_LCD_ANX9804 is not set # CONFIG_VIDEO_LCD_SSD2828 is not set # CONFIG_VIDEO_LCD_HITACHI_TX18D42VM is not set # CONFIG_VIDEO_MVEBU is not set # CONFIG_I2C_EDID is not set # CONFIG_DISPLAY is not set # CONFIG_VIDEO_FSL_DCU_FB is not set # CONFIG_VIDEO_TEGRA20 is not set # CONFIG_VIDEO_BRIDGE is not set CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_CFB_CONSOLE_ANSI=y CONFIG_VGA_AS_SINGLE_DEVICE=y CONFIG_VIDEO_SW_CURSOR=y # CONFIG_CONSOLE_EXTRA_INFO is not set CONFIG_CONSOLE_SCROLL_LINES=1 CONFIG_SYS_CONSOLE_BG_COL=0x00 CONFIG_SYS_CONSOLE_FG_COL=0xa0 # CONFIG_LCD is not set # CONFIG_VIDEO_SIMPLE is not set CONFIG_VIDEO_DT_SIMPLEFB=y # CONFIG_OSD is not set # # VirtIO Drivers # # CONFIG_VIRTIO_MMIO is not set # # 1-Wire support # # CONFIG_W1 is not set # # 1-wire EEPROM support # # CONFIG_W1_EEPROM is not set # # Watchdog Timer Support # # CONFIG_WATCHDOG is not set CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 # CONFIG_WATCHDOG_RESET_DISABLE is not set # CONFIG_IMX_WATCHDOG is not set # CONFIG_ULP_WATCHDOG is not set # CONFIG_WDT is not set # CONFIG_PHYS_TO_BUS is not set # # File systems # # CONFIG_FS_BTRFS is not set # CONFIG_FS_CBFS is not set # CONFIG_SPL_FS_CBFS is not set CONFIG_FS_EXT4=y # CONFIG_EXT4_WRITE is not set CONFIG_FS_FAT=y CONFIG_FAT_WRITE=y CONFIG_FS_FAT_MAX_CLUSTSIZE=65536 # CONFIG_FS_JFFS2 is not set # CONFIG_UBIFS_SILENCE_MSG is not set # CONFIG_FS_CRAMFS is not set # CONFIG_YAFFS2 is not set # # Library routines # # CONFIG_BCH is not set # CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set # CONFIG_DYNAMIC_CRC_TABLE is not set CONFIG_HAVE_PRIVATE_LIBGCC=y CONFIG_LIB_UUID=y CONFIG_PRINTF=y CONFIG_SPL_PRINTF=y CONFIG_SPRINTF=y CONFIG_SPL_SPRINTF=y CONFIG_STRTO=y CONFIG_SPL_STRTO=y CONFIG_IMAGE_SPARSE=y CONFIG_IMAGE_SPARSE_FILLBUF_SIZE=0x80000 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_SYS_HZ=1000 CONFIG_SPL_USE_TINY_PRINTF=y # CONFIG_PANIC_HANG is not set CONFIG_REGEX=y CONFIG_LIB_RAND=y # CONFIG_LIB_HW_RAND is not set # CONFIG_SPL_TINY_MEMSET is not set # CONFIG_TPL_TINY_MEMSET is not set # CONFIG_BITREVERSE is not set # CONFIG_TRACE is not set # CONFIG_CMD_DHRYSTONE is not set # # Security support # # CONFIG_AES is not set # CONFIG_RSA is not set # CONFIG_ASYMMETRIC_KEY_TYPE is not set # CONFIG_TPM is not set # # Android Verified Boot # # CONFIG_LIBAVB is not set # # Hashing Support # CONFIG_SHA1=y CONFIG_SHA256=y # CONFIG_SHA_HW_ACCEL is not set CONFIG_MD5=y # # Compression Support # # CONFIG_LZ4 is not set # CONFIG_LZMA is not set # CONFIG_LZO is not set CONFIG_GZIP=y CONFIG_ZLIB=y # CONFIG_ZSTD is not set # CONFIG_SPL_LZ4 is not set # CONFIG_SPL_LZO is not set # CONFIG_SPL_GZIP is not set # CONFIG_SPL_ZSTD is not set # CONFIG_ERRNO_STR is not set # CONFIG_HEXDUMP is not set CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_ASSUME_MASK=0 CONFIG_OF_LIBFDT_OVERLAY=y # CONFIG_SPL_OF_LIBFDT is not set CONFIG_SPL_OF_LIBFDT_ASSUME_MASK=0xff # CONFIG_TPL_OF_LIBFDT is not set CONFIG_TPL_OF_LIBFDT_ASSUME_MASK=0xff # # System tables # CONFIG_GENERATE_SMBIOS_TABLE=y CONFIG_SMBIOS_MANUFACTURER="" CONFIG_EFI_LOADER=y CONFIG_EFI_DEVICE_PATH_TO_TEXT=y CONFIG_EFI_LOADER_HII=y CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2=y CONFIG_EFI_UNICODE_CAPITALIZATION=y # CONFIG_EFI_UNICODE_COLLATION_PROTOCOL is not set CONFIG_EFI_PLATFORM_LANG_CODES="en-US" CONFIG_EFI_GRUB_ARM32_WORKAROUND=y # CONFIG_TEST_FDTDEC is not set # CONFIG_UNIT_TEST is not setSPI FLASH 编译通过, 不知道能不能用呢.
SPI FLASH可以启动吗?
您好,这个可以用sunxi_fei加载到内存直接运行吗?
